  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
    @tiger sagte in Update System iobroker failed:
    Zigbee, probably same, I've to pair everything
    i don't use zigbee and therefore I'm very sorry if there is a pitfall too.
    But @Thomas-Braun may know wether there will be a solution.
    Tiger
    #141
    No it seems everything is working well...
    Zigbee and Rfxcom... good news...
      don't remember if socketio is used but it was installed.
      Not currently, you can switch and test it or use pure web sockets
      Tiger
      #142
      @crunchip
      it seems it's due to my version of iobroker.admin...
      I thing we'll be able to solve it after upgrading system...
      2022-08-16 18:10:28.357	error	startInstance system.adapter.web.0 Adapter dependency not fulfilled on any host: required adapter "admin" has wrong version. Installed "4.0.10", required ">=5.1.0"!
      • T Tiger
        @crunchip
        crunchipC Abwesend
        crunchipC Abwesend
        #143
        @tiger I do not understand all the problems, that was a backup with the backitup adapter? Why admin 4
          #144
          @crunchip sagte in Update System iobroker failed:
          no manually by iobroker backup
          the admin had been downgraded by the restore
            crunchipC Abwesend
            crunchipC Abwesend
            #145
            Vis installed
            Backup with --force done...
            ADmin version has beenn downgrade to 4.0 as before...
            Why
            itself or through backup
            then do the upgrade
            • T Tiger
              @mickym said in Update System iobroker failed:
              package.json
              ok I'll do it...
              but, how do you edit the package.json?
              mickymM Offline
              mickymM Offline
              mickym
              #146
              package.json
              ok I'll do it...
              Goto directory
              cd /opt/iobroker/iobroker-data/node-red
              nano package.json
              If a message occurs that file is write protected then use
              sudo nano package.json
              Search for the reference of the alexa node. CTRL + k should delete line. I’m typing on my mobile so you need to look at the bottom describing the short-cuts. CTRL + x to
              exit and confirm to write.
              Ensure that you run npm install in the directory /opt/iobroker/iobroker-data/node-red. After you started the Node Red Adapter using the pallet manager, remove all alexa nodes from your flows and update your nodes within the pallet manager, if updates are available. This should be done on a regular base. Keep your system up to date to avoid surprises like this.
              T 3 Antworten Letzte Antwort
                Vis installed
                Why
                then do the upgrade
                #147
                through backup
                as I understood
                • mickymM mickym
                  package.json
                  ok I'll do it...
                  Goto directory
                  nano package.json
                  Tiger
                  #148
                  @mickym
                  I made by another way as i've not a lot of node to install and needed.
                  I installed node manually,
                  Now I'm trying to find the correct alexa node...
                  moreover The boolean-logic that was installed don't work now... I had a AND node, that works good... now don't work...
                  So I'm truing to find these two solution.
                  node-red is correctly connect to My LOGO !8 from siemens
                  Regards
                  • mickymM mickym
                    package.json
                    ok I'll do it...
                    Goto directory
                    nano package.json
                    Tiger
                    schrieb am zuletzt editiert von Tiger
                    #149
                    @mickym
                    Alexa works... and boolean now too...
                    So I'm going to made all as before with the new node...
                    See you all after that to upgrade my system !
                    • mickymM mickym
                      package.json
                      ok I'll do it...
                      Goto directory
                      nano package.json
                      Tiger
                      #150
                      @mickym
                      Don't know why,
                      Was trying to add other functionnality that doesn't work with node amazon
                      and connexion lost
                      message in the log file are like that
                      node-red.0	2022-08-16 21:00:26.108	info	(8145) node-red exited with 1
                      node-red.0	2022-08-16 21:00:25.642	warn	(8145) 16 Aug 21:00:25 - [warn] Projects disabled : editorTheme.projects.enabled=false
                      node-red.0	2022-08-16 21:00:21.074	warn	(8145) (node:8183) [DEP0128] DeprecationWarning: Invalid 'main' field in '/opt/iobroker/node_modules/@node-red/editor-client/package.json' of './lib/index.js'. Please either fix that or report it to t
                      node-red.0	2022-08-16 21:00:21.067	warn	(8145) 16 Aug 21:00:21 - [warn] server.httpadminauth-deprecated
                      node-red.0	2022-08-16 21:00:19.544	info	(8145) Starting node-red: --max-old-space-size=2048 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                      • T Tiger
                        @mickym
                        Don't know why,
                        and connexion lost
                        mickymM Offline
                        mickymM Offline
                        mickym
                        #151
                        @tiger I cant help you with alexa - as I personally do not use it. The only node - which I help for support was this node:
                        node-red-contrib-virtual-smart-home. The message which you log are specific to nodes that you have installed.
                        • mickymM mickym
                          Tiger
                          #152
                          @mickym
                          how can i solved it?
                          as i can't access to node-red now...
                          when trying to open node-red message appear
                          This site is not accessible
                          192.168.1.16 don't allow the connexion
                          • T Tiger
                            @mickym
                            mickymM Offline
                            mickymM Offline
                            mickym
                            #153
                            @tiger Try to start node-red in secure mode - then the flows do not start and you can delete all alexa stuff.
                            • mickymM mickym
                              Tiger
                              #154
                              @mickym
                              ok now.
                              With your node-red-contrib-virtual-smart-home, it works with alexa?
                              • T Tiger
                                @mickym
                                ok now.
                                mickymM Offline
                                mickymM Offline
                                mickym
                                #155
                                @tiger As I said - I have no alexa - however when users used it they had good experience .
                                https://flows.nodered.org/node/node-red-contrib-virtual-smart-home
                                You need to register it.
                                But to be honest - if there are only problems with alexa and the other flows work - you may should ask for help from users who work with alexa. So if all your other nodes work - then you should open a separate thread to solve your alexa issues.
                                • mickymM mickym
                                  Tiger
                                  #156
                                  @mickym
                                  node-red is only for alexa...
                                  all other node are for the programmation of alexa.
                                  I had register, connect...
                                  but you are right, I think we can continue to upgrade and i will solve the problem of node-red after
                                  • mickymM mickym
                                    Tiger
                                    #157
                                    @mickym
                                    Your node is extremely good and easy...
                                    everything is working now
                                    @Homoran
                                    Everything is good now, not VIS, SOCKETIO and WEB but we've to upgrade :)
                                    can you help me to do it in a correct way?
                                    • mickymM mickym
                                      Tiger
                                      #158
                                      @mickym
                                      Hy,
                                      everything is update...
                                      The only problem is node-red, on the left, when I click On Node-Red icon, I have to login,
                                      But it failed and I don't know why..
                                      Is there another user or password? I out the usernam and password written in the configuration of Node-red
                                      Thanks
                                      • T Tiger
                                        @mickym
                                        Hy,
                                        Thanks
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        #159
                                        @tiger I do not work with authentication. May be you should disable it in the adapter config.
                                          is it possible to place the SDcard on my windows desktop pc and save it
                                          I'm pretty sure windows won't see it :-(
                                          Tiger
                                          #160
                                          @Thomas-Braun
                                          @mickym
                                          @crunchip
                                          THanks a lot for your help !
                                          My system is completely as before but with all update !!! (just the problem of login in node red)
                                          Last question, to stay up to date, I've only to check if there is update on Iobroker?
                                          As I don't go very often in the page of iobroker, is it possible to send all the update available via notification on vis?
                                          Thanks a lot for all!
                                          HomoranH mickymM 2 Antworten Letzte Antwort
