  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
    @tiger sagte in Update System iobroker failed:
    same for VIS, not possible to connect to vis from browser
    show the settings for vis and web. You use the socketio?
    Tiger
    #129
    @crunchip
    don't remember if socketio is used but it was installed.
    Web.0 is not configured, And I didn't reached to change the Ip adress.
    Configuration of VIS, nothing, lincence key is show and when checking licence it's OK
    Configuration of Web.0
    No ip Adress, supposed is the reason
    • T Tiger
      @mickym
      I'm Trying to understand :)
      1 I've to test with your command
      cd /opt/iobroker/iobroker-data
      mv node-red node-red.new
      once made, (depending of the result)
      • change the name of the directory to have backup I supposed
      • Copy all the directory from the old SD Card (lots of files... more than 60.000....) to the new SD Card at same place
      and after?
      mickymM Offline
      mickymM Offline
      mickym
      #130
      @mickym
      and after?
      after you copied the old directory under /opt/iobroker/iobroker-data make sure that the rights are adapted.
      go to the /opt/iobroker/iobroker-data directory and execute:
      sudo chown -R iobroker:iobroker node-red
      this will ensure that user iobroker has access to all files and you can try to start the adapter. If this will not work - you have to use again the backup (node-red.new) and delete the reference of the old alexa node in the package.json file. However I guess all other nodes should have been installed.
      I have to go off now and can only support you on my mobile. But this is very limited. But these are standard procedures all others should be familiar with. ;)
      • mickymM mickym
        @mickym
        and after?
        Tiger
        #131
        @mickym said in Update System iobroker failed:
        What do you mean by that?
        • T Tiger
          mickymM Offline
          mickymM Offline
          mickym
          #132
          @tiger If you copy with user pi - all files are owned by this user. As iobroker runs under user iobroker you need to change the owner of the files and directories.
          • mickymM mickym
            Tiger
            #133
            @mickym
            ok I've same user name as before
            • T Tiger
              @mickym
              mickymM Offline
              mickymM Offline
              mickym
              #134
              @tiger So but I am not sure if the old node will work at all with the new node version. You should better think about a replacement.
              • mickymM mickym
                Tiger
                #135
                @mickym
                So... if I'm understanding well...
                I've to let like that without copy the directory...
                install the new node of Alexa...
                and made a new programmation?
                as i wanted to have an installation up to date... if it's your recommandation... i'll do like that...
                  is it possible to place the SDcard on my windows desktop pc and save it
                  I'm pretty sure windows won't see it :-(
                  Tiger
                  #136
                  No problem Now that I'd understood Filezilla :)
                  I'm going to have all working, and after we'll see to the update.
                  After Node-red.. that if I understand well I've to reprogram... for alexa
                  I've to check VIS
                  RFXCOM it seems that I've to pair everything as I've the devices but seems not connected
                  Zigbee, probably same, I've to pair everything
                  • T Tiger
                    @crunchip
                    crunchipC Abwesend
                    crunchipC Abwesend
                    #137
                    Not currently, you can switch and test it or use pure web sockets
                    • T Tiger
                      @mickym
                      mickymM Offline
                      mickymM Offline
                      mickym
                      #138
                      @mickym
                      Yes my recommendation is to do not copy the old stuff. Edit your package.json and delete the line in the dependencies section which refers to the old- alexa node. Run npm install hopefully without errors. Activate in the node red adapter configuration that you use the pallet manager and install a different node. Then you need to rework all alexa flows
                      • T Tiger
                        I've to check VIS
                        #139
                        i don't use zigbee and therefore I'm very sorry if there is a pitfall too.
                        But @Thomas-Braun may know wether there will be a solution.
                        • mickymM mickym
                          @mickym
                          Tiger
                          #140
                          package.json
                          ok I'll do it...
                          but, how do you edit the package.json?
                            Tiger
                            #141
                            No it seems everything is working well...
                            Zigbee and Rfxcom... good news...
                              Tiger
                              #142
                              @crunchip
                              it seems it's due to my version of iobroker.admin...
                              I thing we'll be able to solve it after upgrading system...
                              2022-08-16 18:10:28.357	error	startInstance system.adapter.web.0 Adapter dependency not fulfilled on any host: required adapter "admin" has wrong version. Installed "4.0.10", required ">=5.1.0"!
                              • T Tiger
                                @crunchip
                                crunchipC Abwesend
                                crunchipC Abwesend
                                #143
                                @tiger I do not understand all the problems, that was a backup with the backitup adapter? Why admin 4
                                  #144
                                  @crunchip sagte in Update System iobroker failed:
                                  no manually by iobroker backup
                                  the admin had been downgraded by the restore
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    #145
                                    Vis installed
                                    Backup with --force done...
                                    ADmin version has beenn downgrade to 4.0 as before...
                                    Why
                                    itself or through backup
                                    then do the upgrade
                                    • T Tiger
                                      package.json
                                      ok I'll do it...
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      #146
                                      package.json
                                      ok I'll do it...
                                      Goto directory
                                      cd /opt/iobroker/iobroker-data/node-red
                                      nano package.json
                                      If a message occurs that file is write protected then use
                                      sudo nano package.json
                                      Search for the reference of the alexa node. CTRL + k should delete line. I’m typing on my mobile so you need to look at the bottom describing the short-cuts. CTRL + x to
                                      exit and confirm to write.
                                      Ensure that you run npm install in the directory /opt/iobroker/iobroker-data/node-red. After you started the Node Red Adapter using the pallet manager, remove all alexa nodes from your flows and update your nodes within the pallet manager, if updates are available. This should be done on a regular base. Keep your system up to date to avoid surprises like this.
                                      T 3 Antworten Letzte Antwort
                                        Vis installed
                                        Why
                                        then do the upgrade
                                        #147
                                        through backup
                                        as I understood
                                        • mickymM mickym
                                          package.json
                                          ok I'll do it...
                                          Goto directory
                                          nano package.json
                                          Tiger
                                          #148
                                          @mickym
                                          I made by another way as i've not a lot of node to install and needed.
                                          I installed node manually,
                                          Now I'm trying to find the correct alexa node...
                                          moreover The boolean-logic that was installed don't work now... I had a AND node, that works good... now don't work...
                                          So I'm truing to find these two solution.
                                          node-red is correctly connect to My LOGO !8 from siemens
                                          Regards
