  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
  • T Tiger
    @mickym said in Update System iobroker failed:
    make sure that the rights are adapted.
    What do you mean by that?
    mickymM Offline
    mickymM Offline
    mickym
    #132
    @tiger If you copy with user pi - all files are owned by this user. As iobroker runs under user iobroker you need to change the owner of the files and directories.
    • mickymM mickym
      Tiger
      #133
      @mickym
      ok I've same user name as before
      • T Tiger
        @mickym
        mickymM Offline
        mickymM Offline
        mickym
        #134
        @tiger So but I am not sure if the old node will work at all with the new node version. You should better think about a replacement.
        • mickymM mickym
          Tiger
          #135
          @mickym
          So... if I'm understanding well...
          I've to let like that without copy the directory...
          install the new node of Alexa...
          and made a new programmation?
          as i wanted to have an installation up to date... if it's your recommandation... i'll do like that...
            @tiger sagte in Update System iobroker failed:
            is it possible to place the SDcard on my windows desktop pc and save it
            I'm pretty sure windows won't see it :-(
            Tiger
            #136
            No problem Now that I'd understood Filezilla :)
            I'm going to have all working, and after we'll see to the update.
            After Node-red.. that if I understand well I've to reprogram... for alexa
            I've to check VIS
            RFXCOM it seems that I've to pair everything as I've the devices but seems not connected
            Zigbee, probably same, I've to pair everything
            • T Tiger
              @crunchip
              don't remember if socketio is used but it was installed.
              Web.0 is not configured, And I didn't reached to change the Ip adress.
              Configuration of VIS, nothing, lincence key is show and when checking licence it's OK
              Configuration of Web.0
              No ip Adress, supposed is the reason
              crunchipC Abwesend
              crunchipC Abwesend
              #137
              Not currently, you can switch and test it or use pure web sockets
              • T Tiger
                @mickym
                mickymM Offline
                mickymM Offline
                mickym
                #138
                @mickym
                Yes my recommendation is to do not copy the old stuff. Edit your package.json and delete the line in the dependencies section which refers to the old- alexa node. Run npm install hopefully without errors. Activate in the node red adapter configuration that you use the pallet manager and install a different node. Then you need to rework all alexa flows
                • T Tiger
                  I've to check VIS
                  #139
                  i don't use zigbee and therefore I'm very sorry if there is a pitfall too.
                  But @Thomas-Braun may know wether there will be a solution.
                  • mickymM mickym
                    @mickym
                    Tiger
                    #140
                    package.json
                    ok I'll do it...
                    but, how do you edit the package.json?
                      Tiger
                      #141
                      No it seems everything is working well...
                      Zigbee and Rfxcom... good news...
                        Tiger
                        #142
                        @crunchip
                        it seems it's due to my version of iobroker.admin...
                        I thing we'll be able to solve it after upgrading system...
                        2022-08-16 18:10:28.357	error	startInstance system.adapter.web.0 Adapter dependency not fulfilled on any host: required adapter "admin" has wrong version. Installed "4.0.10", required ">=5.1.0"!
                        • T Tiger
                          @crunchip
                          crunchipC Abwesend
                          crunchipC Abwesend
                          #143
                          @tiger I do not understand all the problems, that was a backup with the backitup adapter? Why admin 4
                            #144
                            @crunchip sagte in Update System iobroker failed:
                            no manually by iobroker backup
                            the admin had been downgraded by the restore
                              crunchipC Abwesend
                              crunchipC Abwesend
                              #145
                              Vis installed
                              Backup with --force done...
                              ADmin version has beenn downgrade to 4.0 as before...
                              Why
                              itself or through backup
                              then do the upgrade
                              • T Tiger
                                package.json
                                ok I'll do it...
                                mickymM Offline
                                mickymM Offline
                                mickym
                                #146
                                package.json
                                ok I'll do it...
                                Goto directory
                                cd /opt/iobroker/iobroker-data/node-red
                                nano package.json
                                If a message occurs that file is write protected then use
                                sudo nano package.json
                                Search for the reference of the alexa node. CTRL + k should delete line. I’m typing on my mobile so you need to look at the bottom describing the short-cuts. CTRL + x to
                                exit and confirm to write.
                                Ensure that you run npm install in the directory /opt/iobroker/iobroker-data/node-red. After you started the Node Red Adapter using the pallet manager, remove all alexa nodes from your flows and update your nodes within the pallet manager, if updates are available. This should be done on a regular base. Keep your system up to date to avoid surprises like this.
                                T 3 Antworten Letzte Antwort
                                  Vis installed
                                  Why
                                  then do the upgrade
                                  #147
                                  through backup
                                  as I understood
                                  • mickymM mickym
                                    package.json
                                    ok I'll do it...
                                    Goto directory
                                    nano package.json
                                    Tiger
                                    #148
                                    @mickym
                                    I made by another way as i've not a lot of node to install and needed.
                                    I installed node manually,
                                    Now I'm trying to find the correct alexa node...
                                    moreover The boolean-logic that was installed don't work now... I had a AND node, that works good... now don't work...
                                    So I'm truing to find these two solution.
                                    node-red is correctly connect to My LOGO !8 from siemens
                                    Regards
                                    • mickymM mickym
                                      package.json
                                      ok I'll do it...
                                      Goto directory
                                      nano package.json
                                      Tiger
                                      schrieb am zuletzt editiert von Tiger
                                      #149
                                      @mickym
                                      Alexa works... and boolean now too...
                                      So I'm going to made all as before with the new node...
                                      See you all after that to upgrade my system !
                                      • mickymM mickym
                                        package.json
                                        ok I'll do it...
                                        Goto directory
                                        nano package.json
                                        Tiger
                                        #150
                                        @mickym
                                        Don't know why,
                                        Was trying to add other functionnality that doesn't work with node amazon
                                        and connexion lost
                                        message in the log file are like that
                                        node-red.0	2022-08-16 21:00:26.108	info	(8145) node-red exited with 1
                                        node-red.0	2022-08-16 21:00:25.642	warn	(8145) 16 Aug 21:00:25 - [warn] Projects disabled : editorTheme.projects.enabled=false
                                        node-red.0	2022-08-16 21:00:21.074	warn	(8145) (node:8183) [DEP0128] DeprecationWarning: Invalid 'main' field in '/opt/iobroker/node_modules/@node-red/editor-client/package.json' of './lib/index.js'. Please either fix that or report it to t
                                        node-red.0	2022-08-16 21:00:21.067	warn	(8145) 16 Aug 21:00:21 - [warn] server.httpadminauth-deprecated
                                        node-red.0	2022-08-16 21:00:19.544	info	(8145) Starting node-red: --max-old-space-size=2048 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                                        • T Tiger
                                          @mickym
                                          Don't know why,
                                          and connexion lost
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          #151
                                          @tiger I cant help you with alexa - as I personally do not use it. The only node - which I help for support was this node:
                                          node-red-contrib-virtual-smart-home. The message which you log are specific to nodes that you have installed.
