  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
  • mickymM mickym
    @tiger sagte in Update System iobroker failed:
    @mickym
    So... if I'm understanding well...
    I've to let like that without copy the directory...
    install the new node of Alexa...
    and made a new programmation?
    as i wanted to have an installation up to date... if it's your recommandation... i'll do like that...
    Yes my recommendation is to do not copy the old stuff. Edit your package.json and delete the line in the dependencies section which refers to the old- alexa node. Run npm install hopefully without errors. Activate in the node red adapter configuration that you use the pallet manager and install a different node. Then you need to rework all alexa flows
    Tiger
    #140
    @mickym said in Update System iobroker failed:
    package.json
    ok I'll do it...
    but, how do you edit the package.json?
      Zigbee, probably same, I've to pair everything
      i don't use zigbee and therefore I'm very sorry if there is a pitfall too.
      But @Thomas-Braun may know wether there will be a solution.
      Tiger
      #141
      No it seems everything is working well...
      Zigbee and Rfxcom... good news...
        don't remember if socketio is used but it was installed.
        Not currently, you can switch and test it or use pure web sockets
        Tiger
        #142
        @crunchip
        it seems it's due to my version of iobroker.admin...
        I thing we'll be able to solve it after upgrading system...
        2022-08-16 18:10:28.357	error	startInstance system.adapter.web.0 Adapter dependency not fulfilled on any host: required adapter "admin" has wrong version. Installed "4.0.10", required ">=5.1.0"!
        • T Tiger
          @crunchip
          crunchipC Abwesend
          crunchipC Abwesend
          #143
          @tiger I do not understand all the problems, that was a backup with the backitup adapter? Why admin 4
            #144
            @crunchip sagte in Update System iobroker failed:
            no manually by iobroker backup
            the admin had been downgraded by the restore
              crunchipC Abwesend
              crunchipC Abwesend
              #145
              Vis installed
              Backup with --force done...
              ADmin version has beenn downgrade to 4.0 as before...
              Why
              itself or through backup
              then do the upgrade
              • T Tiger
                package.json
                ok I'll do it...
                mickymM Offline
                mickymM Offline
                mickym
                #146
                package.json
                ok I'll do it...
                Goto directory
                cd /opt/iobroker/iobroker-data/node-red
                nano package.json
                If a message occurs that file is write protected then use
                sudo nano package.json
                Search for the reference of the alexa node. CTRL + k should delete line. I’m typing on my mobile so you need to look at the bottom describing the short-cuts. CTRL + x to
                exit and confirm to write.
                Ensure that you run npm install in the directory /opt/iobroker/iobroker-data/node-red. After you started the Node Red Adapter using the pallet manager, remove all alexa nodes from your flows and update your nodes within the pallet manager, if updates are available. This should be done on a regular base. Keep your system up to date to avoid surprises like this.
                T 3 Antworten Letzte Antwort
                  Vis installed
                  Why
                  then do the upgrade
                  #147
                  through backup
                  as I understood
                  • mickymM mickym
                    package.json
                    ok I'll do it...
                    Goto directory
                    nano package.json
                    Tiger
                    #148
                    @mickym
                    I made by another way as i've not a lot of node to install and needed.
                    I installed node manually,
                    Now I'm trying to find the correct alexa node...
                    moreover The boolean-logic that was installed don't work now... I had a AND node, that works good... now don't work...
                    So I'm truing to find these two solution.
                    node-red is correctly connect to My LOGO !8 from siemens
                    Regards
                    • mickymM mickym
                      package.json
                      ok I'll do it...
                      Goto directory
                      nano package.json
                      Tiger
                      schrieb am zuletzt editiert von Tiger
                      #149
                      @mickym
                      Alexa works... and boolean now too...
                      So I'm going to made all as before with the new node...
                      See you all after that to upgrade my system !
                      • mickymM mickym
                        package.json
                        ok I'll do it...
                        Goto directory
                        nano package.json
                        Tiger
                        #150
                        @mickym
                        Don't know why,
                        Was trying to add other functionnality that doesn't work with node amazon
                        and connexion lost
                        message in the log file are like that
                        node-red.0	2022-08-16 21:00:26.108	info	(8145) node-red exited with 1
                        node-red.0	2022-08-16 21:00:25.642	warn	(8145) 16 Aug 21:00:25 - [warn] Projects disabled : editorTheme.projects.enabled=false
                        node-red.0	2022-08-16 21:00:21.074	warn	(8145) (node:8183) [DEP0128] DeprecationWarning: Invalid 'main' field in '/opt/iobroker/node_modules/@node-red/editor-client/package.json' of './lib/index.js'. Please either fix that or report it to t
                        node-red.0	2022-08-16 21:00:21.067	warn	(8145) 16 Aug 21:00:21 - [warn] server.httpadminauth-deprecated
                        node-red.0	2022-08-16 21:00:19.544	info	(8145) Starting node-red: --max-old-space-size=2048 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                        • T Tiger
                          @mickym
                          Don't know why,
                          and connexion lost
                          mickymM Offline
                          mickymM Offline
                          mickym
                          #151
                          @tiger I cant help you with alexa - as I personally do not use it. The only node - which I help for support was this node:
                          node-red-contrib-virtual-smart-home. The message which you log are specific to nodes that you have installed.
                          • mickymM mickym
                            Tiger
                            #152
                            @mickym
                            how can i solved it?
                            as i can't access to node-red now...
                            when trying to open node-red message appear
                            This site is not accessible
                            192.168.1.16 don't allow the connexion
                            • T Tiger
                              @mickym
                              mickymM Offline
                              mickymM Offline
                              mickym
                              #153
                              @tiger Try to start node-red in secure mode - then the flows do not start and you can delete all alexa stuff.
                              • mickymM mickym
                                Tiger
                                #154
                                @mickym
                                ok now.
                                With your node-red-contrib-virtual-smart-home, it works with alexa?
                                • T Tiger
                                  @mickym
                                  ok now.
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  #155
                                  @tiger As I said - I have no alexa - however when users used it they had good experience .
                                  https://flows.nodered.org/node/node-red-contrib-virtual-smart-home
                                  You need to register it.
                                  But to be honest - if there are only problems with alexa and the other flows work - you may should ask for help from users who work with alexa. So if all your other nodes work - then you should open a separate thread to solve your alexa issues.
                                  • mickymM mickym
                                    Tiger
                                    #156
                                    @mickym
                                    node-red is only for alexa...
                                    all other node are for the programmation of alexa.
                                    I had register, connect...
                                    but you are right, I think we can continue to upgrade and i will solve the problem of node-red after
                                    • mickymM mickym
                                      Tiger
                                      #157
                                      @mickym
                                      Your node is extremely good and easy...
                                      everything is working now
                                      @Homoran
                                      Everything is good now, not VIS, SOCKETIO and WEB but we've to upgrade :)
                                      can you help me to do it in a correct way?
                                      • mickymM mickym
                                        Tiger
                                        #158
                                        @mickym
                                        Hy,
                                        everything is update...
                                        The only problem is node-red, on the left, when I click On Node-Red icon, I have to login,
                                        But it failed and I don't know why..
                                        Is there another user or password? I out the usernam and password written in the configuration of Node-red
                                        Thanks
                                        • T Tiger
                                          @mickym
                                          Hy,
                                          Thanks
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          #159
                                          @tiger I do not work with authentication. May be you should disable it in the adapter config.
