  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
  • T Tiger
    No problem Now that I'd understood Filezilla :)
    I'm going to have all working, and after we'll see to the update.
    After Node-red.. that if I understand well I've to reprogram... for alexa
    I've to check VIS
    RFXCOM it seems that I've to pair everything as I've the devices but seems not connected
    Zigbee, probably same, I've to pair everything
    #139
    @tiger sagte in Update System iobroker failed:
    i don't use zigbee and therefore I'm very sorry if there is a pitfall too.
    But @Thomas-Braun may know wether there will be a solution.
    • mickymM mickym
      @mickym
      So... if I'm understanding well...
      I've to let like that without copy the directory...
      install the new node of Alexa...
      and made a new programmation?
      as i wanted to have an installation up to date... if it's your recommandation... i'll do like that...
      Yes my recommendation is to do not copy the old stuff. Edit your package.json and delete the line in the dependencies section which refers to the old- alexa node. Run npm install hopefully without errors. Activate in the node red adapter configuration that you use the pallet manager and install a different node. Then you need to rework all alexa flows
      Tiger
      #140
      @mickym said in Update System iobroker failed:
      package.json
      ok I'll do it...
      but, how do you edit the package.json?
        Tiger
        #141
        No it seems everything is working well...
        Zigbee and Rfxcom... good news...
          don't remember if socketio is used but it was installed.
          Not currently, you can switch and test it or use pure web sockets
          Tiger
          #142
          @crunchip
          it seems it's due to my version of iobroker.admin...
          I thing we'll be able to solve it after upgrading system...
          2022-08-16 18:10:28.357	error	startInstance system.adapter.web.0 Adapter dependency not fulfilled on any host: required adapter "admin" has wrong version. Installed "4.0.10", required ">=5.1.0"!
          • T Tiger
            @crunchip
            crunchipC Abwesend
            crunchipC Abwesend
            #143
            @tiger I do not understand all the problems, that was a backup with the backitup adapter? Why admin 4
              #144
              @crunchip sagte in Update System iobroker failed:
              no manually by iobroker backup
              the admin had been downgraded by the restore
                crunchipC Abwesend
                crunchipC Abwesend
                #145
                Vis installed
                Backup with --force done...
                ADmin version has beenn downgrade to 4.0 as before...
                Why
                itself or through backup
                then do the upgrade
                • T Tiger
                  package.json
                  ok I'll do it...
                  mickymM Offline
                  mickymM Offline
                  mickym
                  #146
                  package.json
                  ok I'll do it...
                  Goto directory
                  cd /opt/iobroker/iobroker-data/node-red
                  nano package.json
                  If a message occurs that file is write protected then use
                  sudo nano package.json
                  Search for the reference of the alexa node. CTRL + k should delete line. I’m typing on my mobile so you need to look at the bottom describing the short-cuts. CTRL + x to
                  exit and confirm to write.
                  Ensure that you run npm install in the directory /opt/iobroker/iobroker-data/node-red. After you started the Node Red Adapter using the pallet manager, remove all alexa nodes from your flows and update your nodes within the pallet manager, if updates are available. This should be done on a regular base. Keep your system up to date to avoid surprises like this.
                  T 3 Antworten Letzte Antwort
                    Vis installed
                    Why
                    then do the upgrade
                    #147
                    through backup
                    as I understood
                    • mickymM mickym
                      package.json
                      ok I'll do it...
                      Goto directory
                      nano package.json
                      Tiger
                      #148
                      @mickym
                      I made by another way as i've not a lot of node to install and needed.
                      I installed node manually,
                      Now I'm trying to find the correct alexa node...
                      moreover The boolean-logic that was installed don't work now... I had a AND node, that works good... now don't work...
                      So I'm truing to find these two solution.
                      node-red is correctly connect to My LOGO !8 from siemens
                      Regards
                      • mickymM mickym
                        package.json
                        ok I'll do it...
                        Goto directory
                        nano package.json
                        Tiger
                        schrieb am zuletzt editiert von Tiger
                        #149
                        @mickym
                        Alexa works... and boolean now too...
                        So I'm going to made all as before with the new node...
                        See you all after that to upgrade my system !
                        • mickymM mickym
                          package.json
                          ok I'll do it...
                          Goto directory
                          nano package.json
                          Tiger
                          #150
                          @mickym
                          Don't know why,
                          Was trying to add other functionnality that doesn't work with node amazon
                          and connexion lost
                          message in the log file are like that
                          node-red.0	2022-08-16 21:00:26.108	info	(8145) node-red exited with 1
                          node-red.0	2022-08-16 21:00:25.642	warn	(8145) 16 Aug 21:00:25 - [warn] Projects disabled : editorTheme.projects.enabled=false
                          node-red.0	2022-08-16 21:00:21.074	warn	(8145) (node:8183) [DEP0128] DeprecationWarning: Invalid 'main' field in '/opt/iobroker/node_modules/@node-red/editor-client/package.json' of './lib/index.js'. Please either fix that or report it to t
                          node-red.0	2022-08-16 21:00:21.067	warn	(8145) 16 Aug 21:00:21 - [warn] server.httpadminauth-deprecated
                          node-red.0	2022-08-16 21:00:19.544	info	(8145) Starting node-red: --max-old-space-size=2048 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                          • T Tiger
                            @mickym
                            Don't know why,
                            and connexion lost
                            mickymM Offline
                            mickymM Offline
                            mickym
                            #151
                            @tiger I cant help you with alexa - as I personally do not use it. The only node - which I help for support was this node:
                            node-red-contrib-virtual-smart-home. The message which you log are specific to nodes that you have installed.
                            • mickymM mickym
                              Tiger
                              #152
                              @mickym
                              how can i solved it?
                              as i can't access to node-red now...
                              when trying to open node-red message appear
                              This site is not accessible
                              192.168.1.16 don't allow the connexion
                              • T Tiger
                                @mickym
                                mickymM Offline
                                mickymM Offline
                                mickym
                                #153
                                @tiger Try to start node-red in secure mode - then the flows do not start and you can delete all alexa stuff.
                                • mickymM mickym
                                  Tiger
                                  #154
                                  @mickym
                                  ok now.
                                  With your node-red-contrib-virtual-smart-home, it works with alexa?
                                  • T Tiger
                                    @mickym
                                    ok now.
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    #155
                                    @tiger As I said - I have no alexa - however when users used it they had good experience .
                                    https://flows.nodered.org/node/node-red-contrib-virtual-smart-home
                                    You need to register it.
                                    But to be honest - if there are only problems with alexa and the other flows work - you may should ask for help from users who work with alexa. So if all your other nodes work - then you should open a separate thread to solve your alexa issues.
                                    • mickymM mickym
                                      Tiger
                                      #156
                                      @mickym
                                      node-red is only for alexa...
                                      all other node are for the programmation of alexa.
                                      I had register, connect...
                                      but you are right, I think we can continue to upgrade and i will solve the problem of node-red after
                                      • mickymM mickym
                                        Tiger
                                        #157
                                        @mickym
                                        Your node is extremely good and easy...
                                        everything is working now
                                        @Homoran
                                        Everything is good now, not VIS, SOCKETIO and WEB but we've to upgrade :)
                                        can you help me to do it in a correct way?
                                        • mickymM mickym
                                          Tiger
                                          #158
                                          @mickym
                                          Hy,
                                          everything is update...
                                          The only problem is node-red, on the left, when I click On Node-Red icon, I have to login,
                                          But it failed and I don't know why..
                                          Is there another user or password? I out the usernam and password written in the configuration of Node-red
                                          Thanks
