  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
  • mickymM mickym
    @tiger sagte in Update System iobroker failed:
    @mickym
    I'm Trying to understand :)
    1 I've to test with your command
    cd /opt/iobroker/iobroker-data
    mv node-red node-red.new
    once made, (depending of the result)
    • change the name of the directory to have backup I supposed
    • Copy all the directory from the old SD Card (lots of files... more than 60.000....) to the new SD Card at same place
    and after?
    after you copied the old directory under /opt/iobroker/iobroker-data make sure that the rights are adapted.
    go to the /opt/iobroker/iobroker-data directory and execute:
    sudo chown -R iobroker:iobroker node-red
    this will ensure that user iobroker has access to all files and you can try to start the adapter. If this will not work - you have to use again the backup (node-red.new) and delete the reference of the old alexa node in the package.json file. However I guess all other nodes should have been installed.
    I have to go off now and can only support you on my mobile. But this is very limited. But these are standard procedures all others should be familiar with. ;)
    Tiger
    #131
    @mickym said in Update System iobroker failed:
    What do you mean by that?
    • T Tiger
      mickymM Offline
      mickymM Offline
      mickym
      #132
      @tiger If you copy with user pi - all files are owned by this user. As iobroker runs under user iobroker you need to change the owner of the files and directories.
      • mickymM mickym
        Tiger
        #133
        @mickym
        ok I've same user name as before
        • T Tiger
          @mickym
          mickymM Offline
          mickymM Offline
          mickym
          #134
          @tiger So but I am not sure if the old node will work at all with the new node version. You should better think about a replacement.
          • mickymM mickym
            Tiger
            #135
            @mickym
            So... if I'm understanding well...
            I've to let like that without copy the directory...
            install the new node of Alexa...
            and made a new programmation?
            as i wanted to have an installation up to date... if it's your recommandation... i'll do like that...
              is it possible to place the SDcard on my windows desktop pc and save it
              I'm pretty sure windows won't see it :-(
              Tiger
              #136
              No problem Now that I'd understood Filezilla :)
              I'm going to have all working, and after we'll see to the update.
              After Node-red.. that if I understand well I've to reprogram... for alexa
              I've to check VIS
              RFXCOM it seems that I've to pair everything as I've the devices but seems not connected
              Zigbee, probably same, I've to pair everything
              • T Tiger
                @crunchip
                don't remember if socketio is used but it was installed.
                Web.0 is not configured, And I didn't reached to change the Ip adress.
                Configuration of VIS, nothing, lincence key is show and when checking licence it's OK
                Configuration of Web.0
                No ip Adress, supposed is the reason
                crunchipC Abwesend
                crunchipC Abwesend
                #137
                Not currently, you can switch and test it or use pure web sockets
                • T Tiger
                  @mickym
                  mickymM Offline
                  mickymM Offline
                  mickym
                  #138
                  @mickym
                  Yes my recommendation is to do not copy the old stuff. Edit your package.json and delete the line in the dependencies section which refers to the old- alexa node. Run npm install hopefully without errors. Activate in the node red adapter configuration that you use the pallet manager and install a different node. Then you need to rework all alexa flows
                  • T Tiger
                    I've to check VIS
                    #139
                    i don't use zigbee and therefore I'm very sorry if there is a pitfall too.
                    But @Thomas-Braun may know wether there will be a solution.
                    • mickymM mickym
                      @mickym
                      Tiger
                      #140
                      package.json
                      ok I'll do it...
                      but, how do you edit the package.json?
                        Tiger
                        #141
                        No it seems everything is working well...
                        Zigbee and Rfxcom... good news...
                          Tiger
                          #142
                          @crunchip
                          it seems it's due to my version of iobroker.admin...
                          I thing we'll be able to solve it after upgrading system...
                          2022-08-16 18:10:28.357	error	startInstance system.adapter.web.0 Adapter dependency not fulfilled on any host: required adapter "admin" has wrong version. Installed "4.0.10", required ">=5.1.0"!
                          • T Tiger
                            @crunchip
                            crunchipC Abwesend
                            crunchipC Abwesend
                            #143
                            @tiger I do not understand all the problems, that was a backup with the backitup adapter? Why admin 4
                              #144
                              @crunchip sagte in Update System iobroker failed:
                              no manually by iobroker backup
                              the admin had been downgraded by the restore
                                crunchipC Abwesend
                                crunchipC Abwesend
                                #145
                                Vis installed
                                Backup with --force done...
                                ADmin version has beenn downgrade to 4.0 as before...
                                Why
                                itself or through backup
                                then do the upgrade
                                • T Tiger
                                  package.json
                                  ok I'll do it...
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  #146
                                  package.json
                                  ok I'll do it...
                                  Goto directory
                                  cd /opt/iobroker/iobroker-data/node-red
                                  nano package.json
                                  If a message occurs that file is write protected then use
                                  sudo nano package.json
                                  Search for the reference of the alexa node. CTRL + k should delete line. I’m typing on my mobile so you need to look at the bottom describing the short-cuts. CTRL + x to
                                  exit and confirm to write.
                                  Ensure that you run npm install in the directory /opt/iobroker/iobroker-data/node-red. After you started the Node Red Adapter using the pallet manager, remove all alexa nodes from your flows and update your nodes within the pallet manager, if updates are available. This should be done on a regular base. Keep your system up to date to avoid surprises like this.
                                  T 3 Antworten Letzte Antwort
                                    Vis installed
                                    Why
                                    then do the upgrade
                                    #147
                                    through backup
                                    as I understood
                                    • mickymM mickym
                                      package.json
                                      ok I'll do it...
                                      Goto directory
                                      nano package.json
                                      Tiger
                                      #148
                                      @mickym
                                      I made by another way as i've not a lot of node to install and needed.
                                      I installed node manually,
                                      Now I'm trying to find the correct alexa node...
                                      moreover The boolean-logic that was installed don't work now... I had a AND node, that works good... now don't work...
                                      So I'm truing to find these two solution.
                                      node-red is correctly connect to My LOGO !8 from siemens
                                      Regards
                                      • mickymM mickym
                                        package.json
                                        ok I'll do it...
                                        Goto directory
                                        nano package.json
                                        Tiger
                                        schrieb am zuletzt editiert von Tiger
                                        #149
                                        @mickym
                                        Alexa works... and boolean now too...
                                        So I'm going to made all as before with the new node...
                                        See you all after that to upgrade my system !
                                        • mickymM mickym
                                          package.json
                                          ok I'll do it...
                                          Goto directory
                                          nano package.json
                                          Tiger
                                          #150
                                          @mickym
                                          Don't know why,
                                          Was trying to add other functionnality that doesn't work with node amazon
                                          and connexion lost
                                          message in the log file are like that
                                          node-red.0	2022-08-16 21:00:26.108	info	(8145) node-red exited with 1
                                          node-red.0	2022-08-16 21:00:25.642	warn	(8145) 16 Aug 21:00:25 - [warn] Projects disabled : editorTheme.projects.enabled=false
                                          node-red.0	2022-08-16 21:00:21.074	warn	(8145) (node:8183) [DEP0128] DeprecationWarning: Invalid 'main' field in '/opt/iobroker/node_modules/@node-red/editor-client/package.json' of './lib/index.js'. Please either fix that or report it to t
                                          node-red.0	2022-08-16 21:00:21.067	warn	(8145) 16 Aug 21:00:21 - [warn] server.httpadminauth-deprecated
                                          node-red.0	2022-08-16 21:00:19.544	info	(8145) Starting node-red: --max-old-space-size=2048 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
