  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
  • T Tiger
    @mickym
    ok I've same user name as before
    mickymM Offline
    mickymM Offline
    mickym
    #134
    @tiger So but I am not sure if the old node will work at all with the new node version. You should better think about a replacement.
    • mickymM mickym
      Tiger
      #135
      @mickym
      So... if I'm understanding well...
      I've to let like that without copy the directory...
      install the new node of Alexa...
      and made a new programmation?
      as i wanted to have an installation up to date... if it's your recommandation... i'll do like that...
        @tiger sagte in Update System iobroker failed:
        is it possible to place the SDcard on my windows desktop pc and save it
        I'm pretty sure windows won't see it :-(
        Tiger
        #136
        No problem Now that I'd understood Filezilla :)
        I'm going to have all working, and after we'll see to the update.
        After Node-red.. that if I understand well I've to reprogram... for alexa
        I've to check VIS
        RFXCOM it seems that I've to pair everything as I've the devices but seems not connected
        Zigbee, probably same, I've to pair everything
        • T Tiger
          @crunchip
          don't remember if socketio is used but it was installed.
          Web.0 is not configured, And I didn't reached to change the Ip adress.
          Configuration of VIS, nothing, lincence key is show and when checking licence it's OK
          Configuration of Web.0
          No ip Adress, supposed is the reason
          crunchipC Abwesend
          crunchipC Abwesend
          #137
          Not currently, you can switch and test it or use pure web sockets
          • T Tiger
            @mickym
            mickymM Offline
            mickymM Offline
            mickym
            #138
            @mickym
            Yes my recommendation is to do not copy the old stuff. Edit your package.json and delete the line in the dependencies section which refers to the old- alexa node. Run npm install hopefully without errors. Activate in the node red adapter configuration that you use the pallet manager and install a different node. Then you need to rework all alexa flows
            • T Tiger
              I've to check VIS
              #139
              i don't use zigbee and therefore I'm very sorry if there is a pitfall too.
              But @Thomas-Braun may know wether there will be a solution.
              • mickymM mickym
                @mickym
                Tiger
                #140
                @mickym said in Update System iobroker failed:
                package.json
                ok I'll do it...
                but, how do you edit the package.json?
                  Tiger
                  #141
                  No it seems everything is working well...
                  Zigbee and Rfxcom... good news...
                    Tiger
                    #142
                    @crunchip
                    it seems it's due to my version of iobroker.admin...
                    I thing we'll be able to solve it after upgrading system...
                    2022-08-16 18:10:28.357	error	startInstance system.adapter.web.0 Adapter dependency not fulfilled on any host: required adapter "admin" has wrong version. Installed "4.0.10", required ">=5.1.0"!
                    • T Tiger
                      @crunchip
                      crunchipC Abwesend
                      crunchipC Abwesend
                      #143
                      @tiger I do not understand all the problems, that was a backup with the backitup adapter? Why admin 4
                        #144
                        @crunchip sagte in Update System iobroker failed:
                        no manually by iobroker backup
                        the admin had been downgraded by the restore
                          crunchipC Abwesend
                          crunchipC Abwesend
                          #145
                          Vis installed
                          Backup with --force done...
                          ADmin version has beenn downgrade to 4.0 as before...
                          Why
                          itself or through backup
                          then do the upgrade
                          • T Tiger
                            package.json
                            ok I'll do it...
                            mickymM Offline
                            mickymM Offline
                            mickym
                            #146
                            package.json
                            ok I'll do it...
                            Goto directory
                            cd /opt/iobroker/iobroker-data/node-red
                            nano package.json
                            If a message occurs that file is write protected then use
                            sudo nano package.json
                            Search for the reference of the alexa node. CTRL + k should delete line. I’m typing on my mobile so you need to look at the bottom describing the short-cuts. CTRL + x to
                            exit and confirm to write.
                            Ensure that you run npm install in the directory /opt/iobroker/iobroker-data/node-red. After you started the Node Red Adapter using the pallet manager, remove all alexa nodes from your flows and update your nodes within the pallet manager, if updates are available. This should be done on a regular base. Keep your system up to date to avoid surprises like this.
                            T 3 Antworten Letzte Antwort
                              Vis installed
                              Why
                              then do the upgrade
                              #147
                              through backup
                              as I understood
                              • mickymM mickym
                                package.json
                                ok I'll do it...
                                Goto directory
                                nano package.json
                                Tiger
                                #148
                                @mickym
                                I made by another way as i've not a lot of node to install and needed.
                                I installed node manually,
                                Now I'm trying to find the correct alexa node...
                                moreover The boolean-logic that was installed don't work now... I had a AND node, that works good... now don't work...
                                So I'm truing to find these two solution.
                                node-red is correctly connect to My LOGO !8 from siemens
                                Regards
                                • mickymM mickym
                                  package.json
                                  ok I'll do it...
                                  Goto directory
                                  nano package.json
                                  Tiger
                                  schrieb am zuletzt editiert von Tiger
                                  #149
                                  @mickym
                                  Alexa works... and boolean now too...
                                  So I'm going to made all as before with the new node...
                                  See you all after that to upgrade my system !
                                  • mickymM mickym
                                    package.json
                                    ok I'll do it...
                                    Goto directory
                                    nano package.json
                                    Tiger
                                    #150
                                    @mickym
                                    Don't know why,
                                    Was trying to add other functionnality that doesn't work with node amazon
                                    and connexion lost
                                    message in the log file are like that
                                    node-red.0	2022-08-16 21:00:26.108	info	(8145) node-red exited with 1
                                    node-red.0	2022-08-16 21:00:25.642	warn	(8145) 16 Aug 21:00:25 - [warn] Projects disabled : editorTheme.projects.enabled=false
                                    node-red.0	2022-08-16 21:00:21.074	warn	(8145) (node:8183) [DEP0128] DeprecationWarning: Invalid 'main' field in '/opt/iobroker/node_modules/@node-red/editor-client/package.json' of './lib/index.js'. Please either fix that or report it to t
                                    node-red.0	2022-08-16 21:00:21.067	warn	(8145) 16 Aug 21:00:21 - [warn] server.httpadminauth-deprecated
                                    node-red.0	2022-08-16 21:00:19.544	info	(8145) Starting node-red: --max-old-space-size=2048 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                                    • T Tiger
                                      @mickym
                                      Don't know why,
                                      and connexion lost
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      #151
                                      @tiger I cant help you with alexa - as I personally do not use it. The only node - which I help for support was this node:
                                      node-red-contrib-virtual-smart-home. The message which you log are specific to nodes that you have installed.
                                      • mickymM mickym
                                        Tiger
                                        #152
                                        @mickym
                                        how can i solved it?
                                        as i can't access to node-red now...
                                        when trying to open node-red message appear
                                        This site is not accessible
                                        192.168.1.16 don't allow the connexion
                                        • T Tiger
                                          @mickym
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          #153
                                          @tiger Try to start node-red in secure mode - then the flows do not start and you can delete all alexa stuff.
