  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
  • T Tiger
    @mickym
    Sorry, didn't see your post before doing it...
    So I took the package.json and replace in the node-red and made npm install in the directory
    Error with alexa node, seems that the node used before doesn't exist now
    pi@raspberrypi:/opt/iobroker/iobroker-data/node-red $ npm install
    npm ERR! code ENOVERSIONS
    npm ERR! No versions available for node-red-node-alexa
    npm ERR!     /home/iobroker/.npm/_logs/2022-08-16T14_59_56_194Z-debug-0.log
    log file 2022-08-16T14_59_56_194Z-debug-0.log
    Do you want that I tryed with copy af all the directory? there is a lot of files... more than 60.000
    mickymM Offline
    mickymM Offline
    mickym
    #127
    @tiger sagte in Update System iobroker failed:
    node-red-node-alexa
    So this node is no longer supported. As said you can rename the existing directory and copy the whole directory to the original place - but I do not recommend this. So better is to look for an replacement.
    If you want to try if the old one is running copying the old directory in total - you should first rename the exiting one before you copy the old one. But better is to remove the alexa node. If this is the only error then you should have all except the alexa node.
    to test if the old one will run. you can do
    cd /opt/iobroker/iobroker-data
    mv node-red node-red.new
    and then copy the old directory into the iobroker-data directory. But I am not sure if this old alexa node will work at all.
    • mickymM mickym
      node-red-node-alexa
      Tiger
      schrieb am zuletzt editiert von Tiger
      #128
      @mickym
      I'm Trying to understand :)
      1 I've to test with your command
      once made, (depending of the result)
      • change the name of the directory to have backup I supposed
      • Copy all the directory from the old SD Card (lots of files... more than 60.000....) to the new SD Card at same place
      and after?
        same for VIS, not possible to connect to vis from browser
        show the settings for vis and web. You use the socketio?
        Tiger
        #129
        @crunchip
        don't remember if socketio is used but it was installed.
        Web.0 is not configured, And I didn't reached to change the Ip adress.
        Configuration of VIS, nothing, lincence key is show and when checking licence it's OK
        Configuration of Web.0
        No ip Adress, supposed is the reason
        • T Tiger
          @mickym
          and after?
          mickymM Offline
          mickymM Offline
          mickym
          #130
          @mickym
          and after?
          after you copied the old directory under /opt/iobroker/iobroker-data make sure that the rights are adapted.
          go to the /opt/iobroker/iobroker-data directory and execute:
          sudo chown -R iobroker:iobroker node-red
          this will ensure that user iobroker has access to all files and you can try to start the adapter. If this will not work - you have to use again the backup (node-red.new) and delete the reference of the old alexa node in the package.json file. However I guess all other nodes should have been installed.
          I have to go off now and can only support you on my mobile. But this is very limited. But these are standard procedures all others should be familiar with. ;)
          • mickymM mickym
            @mickym
            and after?
            Tiger
            #131
            @mickym said in Update System iobroker failed:
            What do you mean by that?
            • T Tiger
              mickymM Offline
              mickymM Offline
              mickym
              #132
              @tiger If you copy with user pi - all files are owned by this user. As iobroker runs under user iobroker you need to change the owner of the files and directories.
              • mickymM mickym
                Tiger
                #133
                @mickym
                ok I've same user name as before
                • T Tiger
                  @mickym
                  mickymM Offline
                  mickymM Offline
                  mickym
                  #134
                  @tiger So but I am not sure if the old node will work at all with the new node version. You should better think about a replacement.
                  • mickymM mickym
                    Tiger
                    #135
                    @mickym
                    So... if I'm understanding well...
                    I've to let like that without copy the directory...
                    install the new node of Alexa...
                    and made a new programmation?
                    as i wanted to have an installation up to date... if it's your recommandation... i'll do like that...
                      is it possible to place the SDcard on my windows desktop pc and save it
                      I'm pretty sure windows won't see it :-(
                      Tiger
                      #136
                      No problem Now that I'd understood Filezilla :)
                      I'm going to have all working, and after we'll see to the update.
                      After Node-red.. that if I understand well I've to reprogram... for alexa
                      I've to check VIS
                      RFXCOM it seems that I've to pair everything as I've the devices but seems not connected
                      Zigbee, probably same, I've to pair everything
                      • T Tiger
                        @crunchip
                        crunchipC Abwesend
                        crunchipC Abwesend
                        #137
                        Not currently, you can switch and test it or use pure web sockets
                        • T Tiger
                          @mickym
                          mickymM Offline
                          mickymM Offline
                          mickym
                          #138
                          @mickym
                          Yes my recommendation is to do not copy the old stuff. Edit your package.json and delete the line in the dependencies section which refers to the old- alexa node. Run npm install hopefully without errors. Activate in the node red adapter configuration that you use the pallet manager and install a different node. Then you need to rework all alexa flows
                          • T Tiger
                            I've to check VIS
                            #139
                            i don't use zigbee and therefore I'm very sorry if there is a pitfall too.
                            But @Thomas-Braun may know wether there will be a solution.
                            • mickymM mickym
                              @mickym
                              Tiger
                              #140
                              package.json
                              ok I'll do it...
                              but, how do you edit the package.json?
                                Tiger
                                #141
                                No it seems everything is working well...
                                Zigbee and Rfxcom... good news...
                                  Tiger
                                  #142
                                  @crunchip
                                  it seems it's due to my version of iobroker.admin...
                                  I thing we'll be able to solve it after upgrading system...
                                  2022-08-16 18:10:28.357	error	startInstance system.adapter.web.0 Adapter dependency not fulfilled on any host: required adapter "admin" has wrong version. Installed "4.0.10", required ">=5.1.0"!
                                  • T Tiger
                                    @crunchip
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    #143
                                    @tiger I do not understand all the problems, that was a backup with the backitup adapter? Why admin 4
                                      #144
                                      @crunchip sagte in Update System iobroker failed:
                                      no manually by iobroker backup
                                      the admin had been downgraded by the restore
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        #145
                                        Vis installed
                                        Backup with --force done...
                                        ADmin version has beenn downgrade to 4.0 as before...
                                        Why
                                        itself or through backup
                                        then do the upgrade
                                        • T Tiger
                                          package.json
                                          ok I'll do it...
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          #146
                                          package.json
                                          ok I'll do it...
                                          Goto directory
                                          cd /opt/iobroker/iobroker-data/node-red
                                          nano package.json
                                          If a message occurs that file is write protected then use
                                          sudo nano package.json
                                          Search for the reference of the alexa node. CTRL + k should delete line. I’m typing on my mobile so you need to look at the bottom describing the short-cuts. CTRL + x to
                                          exit and confirm to write.
                                          Ensure that you run npm install in the directory /opt/iobroker/iobroker-data/node-red. After you started the Node Red Adapter using the pallet manager, remove all alexa nodes from your flows and update your nodes within the pallet manager, if updates are available. This should be done on a regular base. Keep your system up to date to avoid surprises like this.
                                          T 3 Antworten Letzte Antwort
