  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
    @crunchip sagte in Update System iobroker failed:
    that was a backup with the backitup adapter?
    no manually by iobroker backup
    the admin had been downgraded by the restore
    crunchipC Abwesend
    crunchipC Abwesend
    #145
    @tiger sagte in Update System iobroker failed:
    Vis installed
    Backup with --force done...
    ADmin version has beenn downgrade to 4.0 as before...
    Why
    itself or through backup
    Installed "4.0.10", required ">=5.1.0"
    then do the upgrade
    • T Tiger
      @mickym said in Update System iobroker failed:
      package.json
      ok I'll do it...
      but, how do you edit the package.json?
      mickymM Offline
      mickymM Offline
      mickym
      #146
      package.json
      ok I'll do it...
      Goto directory
      cd /opt/iobroker/iobroker-data/node-red
      nano package.json
      If a message occurs that file is write protected then use
      sudo nano package.json
      Search for the reference of the alexa node. CTRL + k should delete line. I’m typing on my mobile so you need to look at the bottom describing the short-cuts. CTRL + x to
      exit and confirm to write.
      Ensure that you run npm install in the directory /opt/iobroker/iobroker-data/node-red. After you started the Node Red Adapter using the pallet manager, remove all alexa nodes from your flows and update your nodes within the pallet manager, if updates are available. This should be done on a regular base. Keep your system up to date to avoid surprises like this.
      T 3 Antworten Letzte Antwort
        Vis installed
        Why
        then do the upgrade
        #147
        through backup
        as I understood
        • mickymM mickym
          package.json
          ok I'll do it...
          Goto directory
          nano package.json
          Tiger
          #148
          @mickym
          I made by another way as i've not a lot of node to install and needed.
          I installed node manually,
          Now I'm trying to find the correct alexa node...
          moreover The boolean-logic that was installed don't work now... I had a AND node, that works good... now don't work...
          So I'm truing to find these two solution.
          node-red is correctly connect to My LOGO !8 from siemens
          Regards
          • mickymM mickym
            package.json
            ok I'll do it...
            Goto directory
            nano package.json
            Tiger
            schrieb am zuletzt editiert von Tiger
            #149
            @mickym
            Alexa works... and boolean now too...
            So I'm going to made all as before with the new node...
            See you all after that to upgrade my system !
            • mickymM mickym
              package.json
              ok I'll do it...
              Goto directory
              nano package.json
              Tiger
              #150
              @mickym
              Don't know why,
              Was trying to add other functionnality that doesn't work with node amazon
              and connexion lost
              message in the log file are like that
              node-red.0	2022-08-16 21:00:26.108	info	(8145) node-red exited with 1
              node-red.0	2022-08-16 21:00:25.642	warn	(8145) 16 Aug 21:00:25 - [warn] Projects disabled : editorTheme.projects.enabled=false
              node-red.0	2022-08-16 21:00:21.074	warn	(8145) (node:8183) [DEP0128] DeprecationWarning: Invalid 'main' field in '/opt/iobroker/node_modules/@node-red/editor-client/package.json' of './lib/index.js'. Please either fix that or report it to t
              node-red.0	2022-08-16 21:00:21.067	warn	(8145) 16 Aug 21:00:21 - [warn] server.httpadminauth-deprecated
              node-red.0	2022-08-16 21:00:19.544	info	(8145) Starting node-red: --max-old-space-size=2048 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
              • T Tiger
                @mickym
                Don't know why,
                and connexion lost
                mickymM Offline
                mickymM Offline
                mickym
                #151
                @tiger I cant help you with alexa - as I personally do not use it. The only node - which I help for support was this node:
                node-red-contrib-virtual-smart-home. The message which you log are specific to nodes that you have installed.
                • mickymM mickym
                  Tiger
                  #152
                  @mickym
                  how can i solved it?
                  as i can't access to node-red now...
                  when trying to open node-red message appear
                  This site is not accessible
                  192.168.1.16 don't allow the connexion
                  • T Tiger
                    @mickym
                    mickymM Offline
                    mickymM Offline
                    mickym
                    #153
                    @tiger Try to start node-red in secure mode - then the flows do not start and you can delete all alexa stuff.
                    • mickymM mickym
                      Tiger
                      #154
                      @mickym
                      ok now.
                      With your node-red-contrib-virtual-smart-home, it works with alexa?
                      • T Tiger
                        @mickym
                        ok now.
                        mickymM Offline
                        mickymM Offline
                        mickym
                        #155
                        @tiger As I said - I have no alexa - however when users used it they had good experience .
                        https://flows.nodered.org/node/node-red-contrib-virtual-smart-home
                        You need to register it.
                        But to be honest - if there are only problems with alexa and the other flows work - you may should ask for help from users who work with alexa. So if all your other nodes work - then you should open a separate thread to solve your alexa issues.
                        • mickymM mickym
                          Tiger
                          #156
                          @mickym
                          node-red is only for alexa...
                          all other node are for the programmation of alexa.
                          I had register, connect...
                          but you are right, I think we can continue to upgrade and i will solve the problem of node-red after
                          • mickymM mickym
                            Tiger
                            #157
                            @mickym
                            Your node is extremely good and easy...
                            everything is working now
                            @Homoran
                            Everything is good now, not VIS, SOCKETIO and WEB but we've to upgrade :)
                            can you help me to do it in a correct way?
                            • mickymM mickym
                              Tiger
                              #158
                              @mickym
                              Hy,
                              everything is update...
                              The only problem is node-red, on the left, when I click On Node-Red icon, I have to login,
                              But it failed and I don't know why..
                              Is there another user or password? I out the usernam and password written in the configuration of Node-red
                              Thanks
                              • T Tiger
                                @mickym
                                Hy,
                                Thanks
                                mickymM Offline
                                mickymM Offline
                                mickym
                                #159
                                @tiger I do not work with authentication. May be you should disable it in the adapter config.
                                  is it possible to place the SDcard on my windows desktop pc and save it
                                  I'm pretty sure windows won't see it :-(
                                  Tiger
                                  #160
                                  @Thomas-Braun
                                  @mickym
                                  @crunchip
                                  THanks a lot for your help !
                                  My system is completely as before but with all update !!! (just the problem of login in node red)
                                  Last question, to stay up to date, I've only to check if there is update on Iobroker?
                                  As I don't go very often in the page of iobroker, is it possible to send all the update available via notification on vis?
                                  Thanks a lot for all!
                                  HomoranH mickymM 2 Antworten Letzte Antwort
                                  • mickymM mickym
                                    Tiger
                                    #161
                                    @mickym
                                    ok works without password...strange
                                    Thanks a lot :)
                                    • T Tiger
                                      @Thomas-Braun
                                      @mickym
                                      @crunchip
                                      #162
                                      as you've learned the last days, you should keep your system up to date.
                                      so you surely will open puTTY at least all 2 weeks and upgrade the system with
                                      sudo apt update followed by a sudo apt upgrade
                                      after finishing upgrading the OS you can upgrade iobroker the same way with iobroker update followed by a iobroker upgrade
                                      I know, this isn't any new information for you :-)
                                      How to display existing upgrades in the vis, you should ask in another thread, as I don't know
                                        Tiger
                                        #163
                                        you're right... with PuTTY is more easy...
                                        Very big THANK YOU.
                                        • T Tiger
                                          @Thomas-Braun
                                          @mickym
                                          @crunchip
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          #164
                                          @tiger For the nodes within Node-Red you need to look to the palette manager. If you use the linux device adapter, you get automatically states where you can see if update packages are available.
                                          Check Hosts.mp4
