  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
  • T Tiger
    @mickym
    how can i solved it?
    as i can't access to node-red now...
    when trying to open node-red message appear
    This site is not accessible
    192.168.1.16 don't allow the connexion
    mickymM Offline
    mickymM Offline
    mickym
    #153
    @tiger Try to start node-red in secure mode - then the flows do not start and you can delete all alexa stuff.
    • mickymM mickym
      Tiger
      #154
      @mickym
      ok now.
      With your node-red-contrib-virtual-smart-home, it works with alexa?
      • T Tiger
        @mickym
        ok now.
        mickymM Offline
        mickymM Offline
        mickym
        #155
        @tiger As I said - I have no alexa - however when users used it they had good experience .
        https://flows.nodered.org/node/node-red-contrib-virtual-smart-home
        You need to register it.
        But to be honest - if there are only problems with alexa and the other flows work - you may should ask for help from users who work with alexa. So if all your other nodes work - then you should open a separate thread to solve your alexa issues.
        T 3 Antworten Letzte Antwort
        • mickymM mickym
          Tiger
          #156
          @mickym
          node-red is only for alexa...
          all other node are for the programmation of alexa.
          I had register, connect...
          but you are right, I think we can continue to upgrade and i will solve the problem of node-red after
          • mickymM mickym
            Tiger
            #157
            @mickym
            Your node is extremely good and easy...
            everything is working now
            @Homoran
            Everything is good now, not VIS, SOCKETIO and WEB but we've to upgrade :)
            can you help me to do it in a correct way?
            • mickymM mickym
              Tiger
              #158
              @mickym
              Hy,
              everything is update...
              The only problem is node-red, on the left, when I click On Node-Red icon, I have to login,
              But it failed and I don't know why..
              Is there another user or password? I out the usernam and password written in the configuration of Node-red
              Thanks
              • T Tiger
                @mickym
                Hy,
                Thanks
                mickymM Offline
                mickymM Offline
                mickym
                #159
                @tiger I do not work with authentication. May be you should disable it in the adapter config.
                  @tiger sagte in Update System iobroker failed:
                  is it possible to place the SDcard on my windows desktop pc and save it
                  I'm pretty sure windows won't see it :-(
                  Tiger
                  #160
                  @Thomas-Braun
                  @mickym
                  @crunchip
                  THanks a lot for your help !
                  My system is completely as before but with all update !!! (just the problem of login in node red)
                  Last question, to stay up to date, I've only to check if there is update on Iobroker?
                  As I don't go very often in the page of iobroker, is it possible to send all the update available via notification on vis?
                  Thanks a lot for all!
                  HomoranH mickymM 2 Antworten Letzte Antwort
                  • mickymM mickym
                    Tiger
                    #161
                    @mickym
                    ok works without password...strange
                    Thanks a lot :)
                    • T Tiger
                      @Thomas-Braun
                      @mickym
                      @crunchip
                      #162
                      as you've learned the last days, you should keep your system up to date.
                      so you surely will open puTTY at least all 2 weeks and upgrade the system with
                      sudo apt update followed by a sudo apt upgrade
                      after finishing upgrading the OS you can upgrade iobroker the same way with iobroker update followed by a iobroker upgrade
                      I know, this isn't any new information for you :-)
                      How to display existing upgrades in the vis, you should ask in another thread, as I don't know
                        Tiger
                        #163
                        you're right... with PuTTY is more easy...
                        Very big THANK YOU.
                        • T Tiger
                          @Thomas-Braun
                          @mickym
                          @crunchip
                          mickymM Offline
                          mickymM Offline
                          mickym
                          #164
                          @tiger For the nodes within Node-Red you need to look to the palette manager. If you use the linux device adapter, you get automatically states where you can see if update packages are available.
                          Check Hosts.mp4
