  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
  • T Tiger
    yes it is
    and USB key is inserted
    file name is
    #101
    @tiger sagte in Update System iobroker failed:
    file name is
    Which path?
    Is that FileZilla that you are using as a filemanager?
    T 2 Antworten Letzte Antwort
      file name is
      Which path?
      Tiger
      #102
      file is directly on the usb key, not in a folder
        file name is
        Which path?
        Tiger
        schrieb am zuletzt editiert von Tiger
        #103
        I've nothing installed on the raspberry
        only iobroker and the OS lite
        • T Tiger
          #104
          @tiger
          But in Linux all files are in a path.
          Usually usb sticks are mounted in /media/
            @tiger
            Tiger
            #105
            I understand, but As I said... as I don't know Linux... difficult to know the path :)
            • T Tiger
              #106
              @tiger
              But where is the stick now plugged? In your Desktop computer? In your Raspberry?
                @tiger
                Tiger
                #107
                plug on the raspberry, and i've install without desktop... as recommended
                • T Tiger
                  #108
                  @tiger
                  I don't get it...
                  ls -la /media
                    @tiger
                    I don't get it...
                    ls -la /media
                    Tiger
                    #109
                    Sorry, I didn't found up to know how to copy text from PuTTY
                    • T Tiger
                      #110
                      @tiger
                      Copy the backupfile from your Desktop computer over to the Raspberry with FileZilla. Target directroy /opt/iobroker/backups
                      T 3 Antworten Letzte Antwort
                        @tiger
                        Tiger
                        #111
                        ok, I've to search how to achieve it... Filezila should be installed on raspberry? or only on y desktop computer?
                        If you've a website with some tuto or explanation... it should good :)
                        I'm going to work now... will try later.
                        Thanks a lot.
                          @tiger
                          Tiger
                          #112
                          ok found an explanation...
                          will try later.
                            @tiger
                            Tiger
                            #113
                            everything done..
                            try to restore...
                            but
                            pi@raspberrypi:~ $ iobroker restore 2022_08_15-10_41_07_backupiobroker.tar.gz
                            iobroker controller daemon is not running
                            host.raspberrypi OK.
                            The current version of js-controller differs from the version in the backup.
                            The js-controller version of the backup can not be restored automatically.
                            To restore the js-controller version of the backup, execute "npm i iobroker.js-controller@3.1.6 --production" inside your ioBroker directory
                            If you really want to restore the backup with the current installed js-controller, execute the restore command with the --force flag
                            • T Tiger
                              everything done..
                              try to restore...
                              but
                              #114
                              but
                              what a luck!
                              as @crunchip mentioned you should install vis before restore
                              so please do it now.
                              the fialog asks you what controller you wsnt to have.
                              The actual install also has the actual controller.
                              Your backup has an ancient one
                              so please install vis iobroker install vis after that make another try ant choose the
                              i.e.
                              iobroker restore 2022_08_15-10_41_07_backupiobroker.tar.gz --force
                              (i hope)
                                but
                                what a luck!
                                i.e.
                                (i hope)
                                Tiger
                                #115
                                Vis installed
                                Backup with --force done...
                                ADmin version has beenn downgrade to 4.0 as before...
                                In the journal log it seems that iobroker is reinstalling all the adapters needed...
                                as there is all line like that
                                host.raspberrypi 2022-08-16 15:16:43.415 info iobroker npm-install: 28 packages are looking for funding run npm fund for details
                                host.raspberrypi 2022-08-16 15:16:43.413 info iobroker npm-install: added 1 package in 5s
                                host.raspberrypi 2022-08-16 15:16:43.412 info iobroker npm-install:
                                host.raspberrypi 2022-08-16 15:16:37.347 info iobroker npm-install: Installing iobroker.history@1.9.10... (System call)
                                host.raspberrypi 2022-08-16 15:16:37.342 info iobroker npm-install: NPM version: 8.11.0
                                host.raspberrypi 2022-08-16 15:16:34.656 info iobroker install history@1.9.10 using installedFrom
                                host.raspberrypi 2022-08-16 15:16:34.656 warn startInstance cannot find adapter "history@1.9.10". Try to install it... 1 attempt
                                • T Tiger
                                  Vis installed
                                  #116
                                  @tiger at this moment the restore itself is finished and all adapters were built.
                                  this will last a time
                                    Tiger
                                    #117
                                    @homoran said in Update System iobroker failed:
                                    It can take is time:)
                                    after that, supposed that all adapters will be installed with the last versions...
                                    and the last thing will be to update the iobroker.admin... and perhaps js-controller depending of the version.
                                    • T Tiger
                                      #118
                                      no!
                                      they will stay in their versions of the backup.
                                      but now your controller is in a living version and all updates should work
                                      it has to be the next thing, and then the others
                                        no!
                                        Tiger
                                        #119
                                        everything came back as before.
                                        But, Things I forgot to do...
                                        Node-red doens't work as all node has to be reinstall ...
                                        So, what is your recommandation? trying to have all working as before and after made the update?
                                        Or I search before how to have the backup of Node-red and other things... before continue?
                                        same for VIS, not possible to connect to vis from browser
                                        HomoranH mickymM crunchipC 3 Antworten Letzte Antwort
                                        • T Tiger
                                          #120
                                          ohhhh, I didn't work with node red for years now.
                                          let's try to call @mickym , i guess he can help. I've read there are different possibilities to install the nodes not supplied with the adapter.
