  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
    @tiger sagte in Update System iobroker failed:
    No you're a specialist
    no I'm just a regular user! Maybe a little advanced by nearly 10 years with iobroker.
    have juste to copy the file from my USB key to the folder you mentionned...
    but don't change the rights
    If it's correct, I will search how to copy it
    Searching is easy for me... finding... it's different
    let's ask @Thomas-Braun , he really is the specialist for linux commands
    Tiger
    schrieb am zuletzt editiert von Tiger
    #98
    @homoran said in Update System iobroker failed:
    You instist, but how can I change the rights?
    I've just coopy the backup file from the old Sdcard...
    Used same user in the Raspberry.
    Or you mean the username and password of iobroker? if it's that... I've to restart and you've to tell me how to find it frome the old system... and hoping I can change this... if not I will have to restart from beginning :)
    or there is something I'd miss... we'll see...
    Maybe? for sure :)
    • T Tiger
      Maybe? for sure :)
      #99
      @tiger
      The backup file is on the usb stick now?
      And it is sticking in the USB port of your raspberry?
        @tiger
        Tiger
        #100
        yes it is
        and USB key is inserted
        file name is
        • T Tiger
          yes it is
          file name is
          #101
          file name is
          Which path?
          Is that FileZilla that you are using as a filemanager?
          T 2 Antworten Letzte Antwort
            file name is
            Which path?
            Tiger
            #102
            file is directly on the usb key, not in a folder
              file name is
              Which path?
              Tiger
              #103
              I've nothing installed on the raspberry
              only iobroker and the OS lite
              • T Tiger
                #104
                @tiger
                But in Linux all files are in a path.
                Usually usb sticks are mounted in /media/
                  @tiger
                  Tiger
                  #105
                  I understand, but As I said... as I don't know Linux... difficult to know the path :)
                  • T Tiger
                    #106
                    @tiger
                    But where is the stick now plugged? In your Desktop computer? In your Raspberry?
                      @tiger
                      Tiger
                      #107
                      plug on the raspberry, and i've install without desktop... as recommended
                      • T Tiger
                        #108
                        @tiger
                        I don't get it...
                        ls -la /media
                          @tiger
                          I don't get it...
                          ls -la /media
                          Tiger
                          #109
                          Sorry, I didn't found up to know how to copy text from PuTTY
                          • T Tiger
                            #110
                            @tiger
                            Copy the backupfile from your Desktop computer over to the Raspberry with FileZilla. Target directroy /opt/iobroker/backups
                            T 3 Antworten Letzte Antwort
                              @tiger
                              Tiger
                              #111
                              ok, I've to search how to achieve it... Filezila should be installed on raspberry? or only on y desktop computer?
                              If you've a website with some tuto or explanation... it should good :)
                              I'm going to work now... will try later.
                              Thanks a lot.
                                @tiger
                                Tiger
                                #112
                                ok found an explanation...
                                will try later.
                                  @tiger
                                  Tiger
                                  #113
                                  everything done..
                                  try to restore...
                                  but
                                  pi@raspberrypi:~ $ iobroker restore 2022_08_15-10_41_07_backupiobroker.tar.gz
                                  iobroker controller daemon is not running
                                  host.raspberrypi OK.
                                  The current version of js-controller differs from the version in the backup.
                                  The js-controller version of the backup can not be restored automatically.
                                  To restore the js-controller version of the backup, execute "npm i iobroker.js-controller@3.1.6 --production" inside your ioBroker directory
                                  If you really want to restore the backup with the current installed js-controller, execute the restore command with the --force flag
                                  • T Tiger
                                    everything done..
                                    try to restore...
                                    but
                                    #114
                                    but
                                    what a luck!
                                    as @crunchip mentioned you should install vis before restore
                                    so please do it now.
                                    the fialog asks you what controller you wsnt to have.
                                    The actual install also has the actual controller.
                                    Your backup has an ancient one
                                    so please install vis iobroker install vis after that make another try ant choose the
                                    i.e.
                                    iobroker restore 2022_08_15-10_41_07_backupiobroker.tar.gz --force
                                    (i hope)
                                      but
                                      what a luck!
                                      i.e.
                                      (i hope)
                                      Tiger
                                      #115
                                      Vis installed
                                      Backup with --force done...
                                      ADmin version has beenn downgrade to 4.0 as before...
                                      In the journal log it seems that iobroker is reinstalling all the adapters needed...
                                      as there is all line like that
                                      host.raspberrypi 2022-08-16 15:16:43.415 info iobroker npm-install: 28 packages are looking for funding run npm fund for details
                                      host.raspberrypi 2022-08-16 15:16:43.413 info iobroker npm-install: added 1 package in 5s
                                      host.raspberrypi 2022-08-16 15:16:43.412 info iobroker npm-install:
                                      host.raspberrypi 2022-08-16 15:16:37.347 info iobroker npm-install: Installing iobroker.history@1.9.10... (System call)
                                      host.raspberrypi 2022-08-16 15:16:37.342 info iobroker npm-install: NPM version: 8.11.0
                                      host.raspberrypi 2022-08-16 15:16:34.656 info iobroker install history@1.9.10 using installedFrom
                                      host.raspberrypi 2022-08-16 15:16:34.656 warn startInstance cannot find adapter "history@1.9.10". Try to install it... 1 attempt
                                      • T Tiger
                                        Vis installed
                                        #116
                                        @tiger at this moment the restore itself is finished and all adapters were built.
                                        this will last a time
                                          Tiger
                                          #117
                                          It can take is time:)
                                          after that, supposed that all adapters will be installed with the last versions...
                                          and the last thing will be to update the iobroker.admin... and perhaps js-controller depending of the version.
