  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
    @tiger sagte in Update System iobroker failed:
    As I don't know the navigation by console
    not now! but you will do!
    there is just a little you have to do by cmd.
    (concerning iob!)
    I don't know what the other applications need
    Tiger
    #90
    Hello,
    so, I bought the Sdcard, installed OS Lite...
    Connect to my wifi and installed iobroker.
    Now I have access to iobroker from my web browser on my PC.
    One question, If I understood well, it is possible to connect to the Raspberry pi with computer and made all modification and command from the PC and not directly on the Raspberry Pi correct?
    As finally the Raspberry will not be connected to a Screen and keyboard...
    But I didn't yet search to do it, one step...
    So now, what is the next step to restore the backup ?
    Actually the backup is saved on my computer.
    And in the webpage of iobroker it's written "WELCOME" and wanted to start the assistant.
    Thanks in advance
    • T Tiger
      Hello,
      Thanks in advance
      #91
      wonderful! ...but...
      Connect to my wifi
      why wifi? wired is more stable. No one recommends wifi for a server.
      correct!
      get yourself a ssh client. i prefer puTTY, but you also can use powershell.
      therefore you'll need a filetransfer program as filezilla.
      If you login to your raspi you should use the credentials of your user you installed iobroker with
      caution.
      if you know what to do don't use the discovery. just follow the initisl steps and if you choose using credentials, write them down!
      T 2 Antworten Letzte Antwort
        Connect to my wifi
        correct!
        caution.
        Tiger
        #92
        Juste because The place where it will be has no wired connexion
        i'm going to saerch with the SSH as I saw it directly on raspberry
        This is the biggest point... where You lost me...
        instead of filezilla, can I put on USB key? more easy for me I think.
        caution.
        Are you speaking chinese? 😊
        follow the intialization steps... Supposed you are speaking about the assistant shown in the web browser with iobroker.
        what I didn't understood (perhaps you didn't mentionned presently) is once initialization step will be done, how I will use the restore...
        in my idea, is from USB key, and I supposed that qitch the command we will restore and used the file on the usb key
        don't forget I was a newbee on System installation and upgrade, but already a very big newbee to work only with command :)
          Connect to my wifi
          correct!
          caution.
          Tiger
          #93
          Juste one more point...
          Can I change the password of my Raspberry? I let the "pi" username, but if I activate the SSH... It should be better to have another password.
          Thanks
          • T Tiger
            Thanks
            #94
            @tiger
            Change your password in
            sudo raspi-config
            • T Tiger
              caution.
              #95
              but not for me :-)
              surely you can do. But I don't know about mount and so.
              no! it's suaheli!
              Yes!
              but after the initial settings, there you will be asked to start an automated device search. (this is the discovery adapter)
              I think you don't need it. Maybe it will bring more confusion than benefits.
              using the cli with iobroker restore filenameOfBackup you first have to copy the backup into /opt/iobroker/backups. after a clean install you have to create this folder
              then you can call the restore command with the appropriate filename
              you should!
              at bootup the pi will tell you that not changing it is a security issue!
                but not for me :-)
                no! it's suaheli!
                Yes!
                you should!
                Tiger
                #96
                ok, SSD : Done
                Connexion from distant PC : Done
                Password change : Done
                but not for me 🙂
                No you're a specialist :) If I understood weel, I have juste to copy the file from my USB key to the folder you mentionned...
                If it's correct, I will search how to copy it :)
                Searching is easy for me... finding... it's different 😊
                • T Tiger
                  ok, SSD : Done
                  but not for me 🙂
                  #97
                  no I'm just a regular user! Maybe a little advanced by nearly 10 years with iobroker.
                  but don't change the rights
                  let's ask @Thomas-Braun , he really is the specialist for linux commands
                    Tiger
                    schrieb am zuletzt editiert von Tiger
                    #98
                    @homoran said in Update System iobroker failed:
                    You instist, but how can I change the rights?
                    I've just coopy the backup file from the old Sdcard...
                    Used same user in the Raspberry.
                    Or you mean the username and password of iobroker? if it's that... I've to restart and you've to tell me how to find it frome the old system... and hoping I can change this... if not I will have to restart from beginning :)
                    or there is something I'd miss... we'll see...
                    Maybe? for sure :)
                    • T Tiger
                      Maybe? for sure :)
                      #99
                      @tiger
                      The backup file is on the usb stick now?
                      And it is sticking in the USB port of your raspberry?
                        @tiger
                        Tiger
                        #100
                        yes it is
                        and USB key is inserted
                        file name is
                        • T Tiger
                          yes it is
                          file name is
                          #101
                          file name is
                          Which path?
                          Is that FileZilla that you are using as a filemanager?
                            file name is
                            Which path?
                            Tiger
                            #102
                            file is directly on the usb key, not in a folder
                              file name is
                              Which path?
                              Tiger
                              #103
                              I've nothing installed on the raspberry
                              only iobroker and the OS lite
                              • T Tiger
                                #104
                                @tiger
                                But in Linux all files are in a path.
                                Usually usb sticks are mounted in /media/
                                  @tiger
                                  Tiger
                                  #105
                                  I understand, but As I said... as I don't know Linux... difficult to know the path :)
                                  • T Tiger
                                    #106
                                    @tiger
                                    But where is the stick now plugged? In your Desktop computer? In your Raspberry?
                                      @tiger
                                      Tiger
                                      #107
                                      plug on the raspberry, and i've install without desktop... as recommended
                                      • T Tiger
                                        #108
                                        @tiger
                                        I don't get it...
                                        ls -la /media
                                          @tiger
                                          I don't get it...
                                          ls -la /media
                                          Tiger
                                          #109
                                          Sorry, I didn't found up to know how to copy text from PuTTY
