  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
    @tiger
    The backup file is on the usb stick now?
    And it is sticking in the USB port of your raspberry?
    Tiger
    #100
    yes it is
    and USB key is inserted
    file name is
    • T Tiger
      yes it is
      file name is
      #101
      @tiger sagte in Update System iobroker failed:
      file name is
      Which path?
      Is that FileZilla that you are using as a filemanager?
      T 2 Antworten Letzte Antwort
        file name is
        Which path?
        Tiger
        #102
        file is directly on the usb key, not in a folder
          file name is
          Which path?
          Tiger
          schrieb am zuletzt editiert von Tiger
          #103
          I've nothing installed on the raspberry
          only iobroker and the OS lite
          • T Tiger
            #104
            @tiger
            But in Linux all files are in a path.
            Usually usb sticks are mounted in /media/
              @tiger
              Tiger
              #105
              I understand, but As I said... as I don't know Linux... difficult to know the path :)
              • T Tiger
                #106
                @tiger
                But where is the stick now plugged? In your Desktop computer? In your Raspberry?
                  @tiger
                  Tiger
                  #107
                  plug on the raspberry, and i've install without desktop... as recommended
                  • T Tiger
                    #108
                    @tiger
                    I don't get it...
                    ls -la /media
                      @tiger
                      I don't get it...
                      ls -la /media
                      Tiger
                      #109
                      Sorry, I didn't found up to know how to copy text from PuTTY
                      • T Tiger
                        #110
                        @tiger
                        Copy the backupfile from your Desktop computer over to the Raspberry with FileZilla. Target directroy /opt/iobroker/backups
                        T 3 Antworten Letzte Antwort
                          @tiger
                          Tiger
                          #111
                          ok, I've to search how to achieve it... Filezila should be installed on raspberry? or only on y desktop computer?
                          If you've a website with some tuto or explanation... it should good :)
                          I'm going to work now... will try later.
                          Thanks a lot.
                            @tiger
                            Tiger
                            #112
                            ok found an explanation...
                            will try later.
                              @tiger
                              Tiger
                              #113
                              everything done..
                              try to restore...
                              but
                              pi@raspberrypi:~ $ iobroker restore 2022_08_15-10_41_07_backupiobroker.tar.gz
                              iobroker controller daemon is not running
                              host.raspberrypi OK.
                              The current version of js-controller differs from the version in the backup.
                              The js-controller version of the backup can not be restored automatically.
                              To restore the js-controller version of the backup, execute "npm i iobroker.js-controller@3.1.6 --production" inside your ioBroker directory
                              If you really want to restore the backup with the current installed js-controller, execute the restore command with the --force flag
                              • T Tiger
                                everything done..
                                try to restore...
                                but
                                #114
                                but
                                what a luck!
                                as @crunchip mentioned you should install vis before restore
                                so please do it now.
                                the fialog asks you what controller you wsnt to have.
                                The actual install also has the actual controller.
                                Your backup has an ancient one
                                so please install vis iobroker install vis after that make another try ant choose the
                                i.e.
                                iobroker restore 2022_08_15-10_41_07_backupiobroker.tar.gz --force
                                (i hope)
                                  but
                                  what a luck!
                                  i.e.
                                  (i hope)
                                  Tiger
                                  #115
                                  Vis installed
                                  Backup with --force done...
                                  ADmin version has beenn downgrade to 4.0 as before...
                                  In the journal log it seems that iobroker is reinstalling all the adapters needed...
                                  as there is all line like that
                                  host.raspberrypi 2022-08-16 15:16:43.415 info iobroker npm-install: 28 packages are looking for funding run npm fund for details
                                  host.raspberrypi 2022-08-16 15:16:43.413 info iobroker npm-install: added 1 package in 5s
                                  host.raspberrypi 2022-08-16 15:16:43.412 info iobroker npm-install:
                                  host.raspberrypi 2022-08-16 15:16:37.347 info iobroker npm-install: Installing iobroker.history@1.9.10... (System call)
                                  host.raspberrypi 2022-08-16 15:16:37.342 info iobroker npm-install: NPM version: 8.11.0
                                  host.raspberrypi 2022-08-16 15:16:34.656 info iobroker install history@1.9.10 using installedFrom
                                  host.raspberrypi 2022-08-16 15:16:34.656 warn startInstance cannot find adapter "history@1.9.10". Try to install it... 1 attempt
                                  • T Tiger
                                    Vis installed
                                    #116
                                    @tiger at this moment the restore itself is finished and all adapters were built.
                                    this will last a time
                                      Tiger
                                      #117
                                      @homoran said in Update System iobroker failed:
                                      It can take is time:)
                                      after that, supposed that all adapters will be installed with the last versions...
                                      and the last thing will be to update the iobroker.admin... and perhaps js-controller depending of the version.
                                      • T Tiger
                                        #118
                                        no!
                                        they will stay in their versions of the backup.
                                        but now your controller is in a living version and all updates should work
                                        it has to be the next thing, and then the others
                                          no!
                                          Tiger
                                          #119
                                          everything came back as before.
                                          But, Things I forgot to do...
                                          Node-red doens't work as all node has to be reinstall ...
                                          So, what is your recommandation? trying to have all working as before and after made the update?
                                          Or I search before how to have the backup of Node-red and other things... before continue?
                                          same for VIS, not possible to connect to vis from browser
                                          HomoranH mickymM crunchipC 3 Antworten Letzte Antwort
