  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
    @tiger sagte in Update System iobroker failed:
    Now I have access to iobroker from my web browser on my PC.
    wonderful! ...but...
    Connect to my wifi
    why wifi? wired is more stable. No one recommends wifi for a server.
    One question, If I understood well, it is possible to connect to the Raspberry pi with computer and made all modification and command from the PC and not directly on the Raspberry Pi correct?
    correct!
    But I didn't yet search to do it, one step...
    get yourself a ssh client. i prefer puTTY, but you also can use powershell.
    Actually the backup is saved on my computer.
    therefore you'll need a filetransfer program as filezilla.
    If you login to your raspi you should use the credentials of your user you installed iobroker with
    caution.
    if you know what to do don't use the discovery. just follow the initisl steps and if you choose using credentials, write them down!
    Tiger
    #93
    Juste one more point...
    Can I change the password of my Raspberry? I let the "pi" username, but if I activate the SSH... It should be better to have another password.
    Thanks
    • T Tiger
      Thanks
      #94
      @tiger
      Change your password in
      sudo raspi-config
      • T Tiger
        Juste because The place where it will be has no wired connexion
        i'm going to saerch with the SSH as I saw it directly on raspberry
        This is the biggest point... where You lost me...
        instead of filezilla, can I put on USB key? more easy for me I think.
        caution.
        Are you speaking chinese? 😊
        follow the intialization steps... Supposed you are speaking about the assistant shown in the web browser with iobroker.
        what I didn't understood (perhaps you didn't mentionned presently) is once initialization step will be done, how I will use the restore...
        in my idea, is from USB key, and I supposed that qitch the command we will restore and used the file on the usb key
        don't forget I was a newbee on System installation and upgrade, but already a very big newbee to work only with command :)
        #95
        but not for me :-)
        surely you can do. But I don't know about mount and so.
        no! it's suaheli!
        Yes!
        but after the initial settings, there you will be asked to start an automated device search. (this is the discovery adapter)
        I think you don't need it. Maybe it will bring more confusion than benefits.
        using the cli with iobroker restore filenameOfBackup you first have to copy the backup into /opt/iobroker/backups. after a clean install you have to create this folder
        then you can call the restore command with the appropriate filename
        you should!
        at bootup the pi will tell you that not changing it is a security issue!
          but not for me :-)
          no! it's suaheli!
          Yes!
          you should!
          Tiger
          #96
          ok, SSD : Done
          Connexion from distant PC : Done
          Password change : Done
          but not for me 🙂
          No you're a specialist :) If I understood weel, I have juste to copy the file from my USB key to the folder you mentionned...
          If it's correct, I will search how to copy it :)
          Searching is easy for me... finding... it's different 😊
          • T Tiger
            ok, SSD : Done
            but not for me 🙂
            #97
            no I'm just a regular user! Maybe a little advanced by nearly 10 years with iobroker.
            but don't change the rights
            let's ask @Thomas-Braun , he really is the specialist for linux commands
              Tiger
              schrieb am zuletzt editiert von Tiger
              #98
              @homoran said in Update System iobroker failed:
              You instist, but how can I change the rights?
              I've just coopy the backup file from the old Sdcard...
              Used same user in the Raspberry.
              Or you mean the username and password of iobroker? if it's that... I've to restart and you've to tell me how to find it frome the old system... and hoping I can change this... if not I will have to restart from beginning :)
              or there is something I'd miss... we'll see...
              Maybe? for sure :)
              • T Tiger
                Maybe? for sure :)
                #99
                @tiger
                The backup file is on the usb stick now?
                And it is sticking in the USB port of your raspberry?
                  @tiger
                  Tiger
                  #100
                  yes it is
                  and USB key is inserted
                  file name is
                  • T Tiger
                    yes it is
                    file name is
                    #101
                    file name is
                    Which path?
                    Is that FileZilla that you are using as a filemanager?
                    T 2 Antworten Letzte Antwort
                      file name is
                      Which path?
                      Tiger
                      #102
                      file is directly on the usb key, not in a folder
                        file name is
                        Which path?
                        Tiger
                        #103
                        I've nothing installed on the raspberry
                        only iobroker and the OS lite
                        • T Tiger
                          #104
                          @tiger
                          But in Linux all files are in a path.
                          Usually usb sticks are mounted in /media/
                            @tiger
                            Tiger
                            #105
                            I understand, but As I said... as I don't know Linux... difficult to know the path :)
                            • T Tiger
                              #106
                              @tiger
                              But where is the stick now plugged? In your Desktop computer? In your Raspberry?
                                @tiger
                                Tiger
                                #107
                                plug on the raspberry, and i've install without desktop... as recommended
                                • T Tiger
                                  #108
                                  @tiger
                                  I don't get it...
                                  ls -la /media
                                    @tiger
                                    I don't get it...
                                    ls -la /media
                                    Tiger
                                    #109
                                    Sorry, I didn't found up to know how to copy text from PuTTY
                                    • T Tiger
                                      #110
                                      @tiger
                                      Copy the backupfile from your Desktop computer over to the Raspberry with FileZilla. Target directroy /opt/iobroker/backups
                                      T 3 Antworten Letzte Antwort
                                        @tiger
                                        Tiger
                                        #111
                                        ok, I've to search how to achieve it... Filezila should be installed on raspberry? or only on y desktop computer?
                                        If you've a website with some tuto or explanation... it should good :)
                                        I'm going to work now... will try later.
                                        Thanks a lot.
                                          @tiger
                                          Tiger
                                          #112
                                          ok found an explanation...
                                          will try later.
