  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
    @tiger sagte in Update System iobroker failed:
    and USB key is inserted
    file name is
    Which path?
    Is that FileZilla that you are using as a filemanager?
    Tiger
    schrieb am zuletzt editiert von Tiger
    #103
    I've nothing installed on the raspberry
    only iobroker and the OS lite
    • T Tiger
      file is directly on the usb key, not in a folder
      #104
      @tiger
      But in Linux all files are in a path.
      Usually usb sticks are mounted in /media/
        @tiger
        Tiger
        #105
        I understand, but As I said... as I don't know Linux... difficult to know the path :)
        • T Tiger
          #106
          @tiger
          But where is the stick now plugged? In your Desktop computer? In your Raspberry?
            @tiger
            Tiger
            #107
            plug on the raspberry, and i've install without desktop... as recommended
            • T Tiger
              #108
              @tiger
              I don't get it...
              ls -la /media
                @tiger
                I don't get it...
                ls -la /media
                Tiger
                #109
                Sorry, I didn't found up to know how to copy text from PuTTY
                • T Tiger
                  #110
                  @tiger
                  Copy the backupfile from your Desktop computer over to the Raspberry with FileZilla. Target directroy /opt/iobroker/backups
                  T 3 Antworten Letzte Antwort
                    @tiger
                    Tiger
                    #111
                    ok, I've to search how to achieve it... Filezila should be installed on raspberry? or only on y desktop computer?
                    If you've a website with some tuto or explanation... it should good :)
                    I'm going to work now... will try later.
                    Thanks a lot.
                      @tiger
                      Tiger
                      #112
                      ok found an explanation...
                      will try later.
                        @tiger
                        Tiger
                        #113
                        everything done..
                        try to restore...
                        but
                        pi@raspberrypi:~ $ iobroker restore 2022_08_15-10_41_07_backupiobroker.tar.gz
                        iobroker controller daemon is not running
                        host.raspberrypi OK.
                        The current version of js-controller differs from the version in the backup.
                        The js-controller version of the backup can not be restored automatically.
                        To restore the js-controller version of the backup, execute "npm i iobroker.js-controller@3.1.6 --production" inside your ioBroker directory
                        If you really want to restore the backup with the current installed js-controller, execute the restore command with the --force flag
                        • T Tiger
                          everything done..
                          try to restore...
                          but
                          #114
                          but
                          what a luck!
                          as @crunchip mentioned you should install vis before restore
                          so please do it now.
                          the fialog asks you what controller you wsnt to have.
                          The actual install also has the actual controller.
                          Your backup has an ancient one
                          so please install vis iobroker install vis after that make another try ant choose the
                          i.e.
                          iobroker restore 2022_08_15-10_41_07_backupiobroker.tar.gz --force
                          (i hope)
                            but
                            what a luck!
                            i.e.
                            (i hope)
                            Tiger
                            #115
                            Vis installed
                            Backup with --force done...
                            ADmin version has beenn downgrade to 4.0 as before...
                            In the journal log it seems that iobroker is reinstalling all the adapters needed...
                            as there is all line like that
                            host.raspberrypi 2022-08-16 15:16:43.415 info iobroker npm-install: 28 packages are looking for funding run npm fund for details
                            host.raspberrypi 2022-08-16 15:16:43.413 info iobroker npm-install: added 1 package in 5s
                            host.raspberrypi 2022-08-16 15:16:43.412 info iobroker npm-install:
                            host.raspberrypi 2022-08-16 15:16:37.347 info iobroker npm-install: Installing iobroker.history@1.9.10... (System call)
                            host.raspberrypi 2022-08-16 15:16:37.342 info iobroker npm-install: NPM version: 8.11.0
                            host.raspberrypi 2022-08-16 15:16:34.656 info iobroker install history@1.9.10 using installedFrom
                            host.raspberrypi 2022-08-16 15:16:34.656 warn startInstance cannot find adapter "history@1.9.10". Try to install it... 1 attempt
                            • T Tiger
                              Vis installed
                              #116
                              @tiger at this moment the restore itself is finished and all adapters were built.
                              this will last a time
                                Tiger
                                #117
                                @homoran said in Update System iobroker failed:
                                It can take is time:)
                                after that, supposed that all adapters will be installed with the last versions...
                                and the last thing will be to update the iobroker.admin... and perhaps js-controller depending of the version.
                                • T Tiger
                                  #118
                                  no!
                                  they will stay in their versions of the backup.
                                  but now your controller is in a living version and all updates should work
                                  it has to be the next thing, and then the others
                                    no!
                                    Tiger
                                    #119
                                    everything came back as before.
                                    But, Things I forgot to do...
                                    Node-red doens't work as all node has to be reinstall ...
                                    So, what is your recommandation? trying to have all working as before and after made the update?
                                    Or I search before how to have the backup of Node-red and other things... before continue?
                                    same for VIS, not possible to connect to vis from browser
                                    HomoranH mickymM crunchipC 3 Antworten Letzte Antwort
                                    • T Tiger
                                      #120
                                      ohhhh, I didn't work with node red for years now.
                                      let's try to call @mickym , i guess he can help. I've read there are different possibilities to install the nodes not supplied with the adapter.
                                      • T Tiger
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        #121
                                        @tiger You can try - the following.
                                        Restore from your former image the package.json file into /opt/iobroker/iobroker-data/node-red directory. replace the existing one or rename it. Run npm install.
                                        Change to that directory:
                                        cd /opt/iobroker/iobroker-data/node-red
                                        npm install
                                        T 2 Antworten Letzte Antwort
                                        • mickymM mickym
                                          npm install
                                          Tiger
                                          #122
                                          @mickym
                                          thanks for your answer,
                                          To be sure what I've to do... (to avoid problem... I'm newbee :) )
                                          I've juste to replace the package.json file in the actual directory /opt/iobroker/iobroker-data/node-red by the old one my old sdcard?
                                          and after that run npm install, correct?
                                          stupid question, to have access to the file on my old SDcard, is it possible to place the SDcard on my windows desktop pc and save it? or I've to place the old SDcard in the raspberry Pi to pick up file with filezilla?
                                          HomoranH mickymM 2 Antworten Letzte Antwort
