  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
    @tiger
    Copy the backupfile from your Desktop computer over to the Raspberry with FileZilla. Target directroy /opt/iobroker/backups
    Tiger
    #111
    ok, I've to search how to achieve it... Filezila should be installed on raspberry? or only on y desktop computer?
    If you've a website with some tuto or explanation... it should good :)
    I'm going to work now... will try later.
    Thanks a lot.
      @tiger
      Tiger
      #112
      ok found an explanation...
      will try later.
        @tiger
        Tiger
        #113
        everything done..
        try to restore...
        but
        pi@raspberrypi:~ $ iobroker restore 2022_08_15-10_41_07_backupiobroker.tar.gz
        iobroker controller daemon is not running
        host.raspberrypi OK.
        The current version of js-controller differs from the version in the backup.
        The js-controller version of the backup can not be restored automatically.
        To restore the js-controller version of the backup, execute "npm i iobroker.js-controller@3.1.6 --production" inside your ioBroker directory
        If you really want to restore the backup with the current installed js-controller, execute the restore command with the --force flag
        • T Tiger
          everything done..
          try to restore...
          but
          #114
          @tiger sagte in Update System iobroker failed:
          but
          what a luck!
          as @crunchip mentioned you should install vis before restore
          so please do it now.
          the fialog asks you what controller you wsnt to have.
          The actual install also has the actual controller.
          Your backup has an ancient one
          so please install vis iobroker install vis after that make another try ant choose the
          i.e.
          iobroker restore 2022_08_15-10_41_07_backupiobroker.tar.gz --force
          (i hope)
            but
            what a luck!
            i.e.
            (i hope)
            Tiger
            schrieb am zuletzt editiert von Tiger
            #115
            Vis installed
            Backup with --force done...
            ADmin version has beenn downgrade to 4.0 as before...
            In the journal log it seems that iobroker is reinstalling all the adapters needed...
            as there is all line like that
            host.raspberrypi 2022-08-16 15:16:43.415 info iobroker npm-install: 28 packages are looking for funding run npm fund for details
            host.raspberrypi 2022-08-16 15:16:43.413 info iobroker npm-install: added 1 package in 5s
            host.raspberrypi 2022-08-16 15:16:43.412 info iobroker npm-install:
            host.raspberrypi 2022-08-16 15:16:37.347 info iobroker npm-install: Installing iobroker.history@1.9.10... (System call)
            host.raspberrypi 2022-08-16 15:16:37.342 info iobroker npm-install: NPM version: 8.11.0
            host.raspberrypi 2022-08-16 15:16:34.656 info iobroker install history@1.9.10 using installedFrom
            host.raspberrypi 2022-08-16 15:16:34.656 warn startInstance cannot find adapter "history@1.9.10". Try to install it... 1 attempt
            • T Tiger
              Vis installed
              #116
              @tiger at this moment the restore itself is finished and all adapters were built.
              this will last a time
                Tiger
                #117
                @homoran said in Update System iobroker failed:
                It can take is time:)
                after that, supposed that all adapters will be installed with the last versions...
                and the last thing will be to update the iobroker.admin... and perhaps js-controller depending of the version.
                • T Tiger
                  #118
                  no!
                  they will stay in their versions of the backup.
                  but now your controller is in a living version and all updates should work
                  it has to be the next thing, and then the others
                    no!
                    Tiger
                    #119
                    everything came back as before.
                    But, Things I forgot to do...
                    Node-red doens't work as all node has to be reinstall ...
                    So, what is your recommandation? trying to have all working as before and after made the update?
                    Or I search before how to have the backup of Node-red and other things... before continue?
                    same for VIS, not possible to connect to vis from browser
                    HomoranH mickymM crunchipC 3 Antworten Letzte Antwort
                    • T Tiger
                      #120
                      ohhhh, I didn't work with node red for years now.
                      let's try to call @mickym , i guess he can help. I've read there are different possibilities to install the nodes not supplied with the adapter.
                      • T Tiger
                        mickymM Offline
                        mickymM Offline
                        mickym
                        #121
                        @tiger You can try - the following.
                        Restore from your former image the package.json file into /opt/iobroker/iobroker-data/node-red directory. replace the existing one or rename it. Run npm install.
                        Change to that directory:
                        cd /opt/iobroker/iobroker-data/node-red
                        npm install
                        T 2 Antworten Letzte Antwort
                        • mickymM mickym
                          npm install
                          Tiger
                          #122
                          @mickym
                          thanks for your answer,
                          To be sure what I've to do... (to avoid problem... I'm newbee :) )
                          I've juste to replace the package.json file in the actual directory /opt/iobroker/iobroker-data/node-red by the old one my old sdcard?
                          and after that run npm install, correct?
                          stupid question, to have access to the file on my old SDcard, is it possible to place the SDcard on my windows desktop pc and save it? or I've to place the old SDcard in the raspberry Pi to pick up file with filezilla?
                          HomoranH mickymM 2 Antworten Letzte Antwort
                          • T Tiger
                            @mickym
                            #123
                            I'm pretty sure windows won't see it :-(
                            • T Tiger
                              crunchipC Abwesend
                              crunchipC Abwesend
                              #124
                              show the settings for vis and web. You use the socketio?
                              • T Tiger
                                @mickym
                                mickymM Offline
                                mickymM Offline
                                mickym
                                #125
                                @mickym
                                correct. I doubt that you can directly access the files on your SD card , because you have no drivers in windows. for the ext4 file system. In your case - I would boot with the old SD card and copy the whole directory /opt/iobroker/iobroker-data/node-red to your USB stick. When you boot with the new card - you should have access to all files wherever you mounted your USB stick. You should even be able to replace the complete new directory in the /opt/iobroker-dat with the old one. Rename the exiting one and replace it with the new one. If you want to know what the files in your /opt/iobroker/iobroker-data/node-red data mean you can have a look to my extensive description here: https://github.com/ioBroker/ioBroker.node-red/issues/320
                                • mickymM mickym
                                  npm install
                                  Tiger
                                  #126
                                  @mickym
                                  Sorry, didn't see your post before doing it...
                                  So I took the package.json and replace in the node-red and made npm install in the directory
                                  Error with alexa node, seems that the node used before doesn't exist now
                                  pi@raspberrypi:/opt/iobroker/iobroker-data/node-red $ npm install
                                  npm ERR! code ENOVERSIONS
                                  npm ERR! No versions available for node-red-node-alexa
                                  npm ERR!     /home/iobroker/.npm/_logs/2022-08-16T14_59_56_194Z-debug-0.log
                                  log file 2022-08-16T14_59_56_194Z-debug-0.log
                                  Do you want that I tryed with copy af all the directory? there is a lot of files... more than 60.000
                                  • T Tiger
                                    @mickym
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    #127
                                    node-red-node-alexa
                                    So this node is no longer supported. As said you can rename the existing directory and copy the whole directory to the original place - but I do not recommend this. So better is to look for an replacement.
                                    If you want to try if the old one is running copying the old directory in total - you should first rename the exiting one before you copy the old one. But better is to remove the alexa node. If this is the only error then you should have all except the alexa node.
                                    to test if the old one will run. you can do
                                    mv node-red node-red.new
                                    and then copy the old directory into the iobroker-data directory. But I am not sure if this old alexa node will work at all.
                                    • mickymM mickym
                                      node-red-node-alexa
                                      Tiger
                                      #128
                                      @mickym
                                      I'm Trying to understand :)
                                      1 I've to test with your command
                                      once made, (depending of the result)
                                      • change the name of the directory to have backup I supposed
                                      • Copy all the directory from the old SD Card (lots of files... more than 60.000....) to the new SD Card at same place
                                      and after?
                                        Tiger
                                        #129
                                        @crunchip
                                        don't remember if socketio is used but it was installed.
                                        Web.0 is not configured, And I didn't reached to change the Ip adress.
                                        Configuration of VIS, nothing, lincence key is show and when checking licence it's OK
                                        Configuration of Web.0
                                        No ip Adress, supposed is the reason
                                        • T Tiger
                                          @mickym
                                          and after?
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          #130
                                          @mickym
                                          and after?
                                          after you copied the old directory under /opt/iobroker/iobroker-data make sure that the rights are adapted.
                                          go to the /opt/iobroker/iobroker-data directory and execute:
                                          sudo chown -R iobroker:iobroker node-red
                                          this will ensure that user iobroker has access to all files and you can try to start the adapter. If this will not work - you have to use again the backup (node-red.new) and delete the reference of the old alexa node in the package.json file. However I guess all other nodes should have been installed.
                                          I have to go off now and can only support you on my mobile. But this is very limited. But these are standard procedures all others should be familiar with. ;)
