  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
  • T Tiger
    @homoran said in Update System iobroker failed:
    @tiger sagte in Update System iobroker failed:
    have juste to copy the file from my USB key to the folder you mentionned...
    but don't change the rights
    You instist, but how can I change the rights?
    I've just coopy the backup file from the old Sdcard...
    Used same user in the Raspberry.
    Or you mean the username and password of iobroker? if it's that... I've to restart and you've to tell me how to find it frome the old system... and hoping I can change this... if not I will have to restart from beginning :)
    or there is something I'd miss... we'll see...
    no I'm just a regular user! Maybe a little advanced by nearly 10 years with iobroker.
    Maybe? for sure :)
    #99
    @tiger
    The backup file is on the usb stick now?
    And it is sticking in the USB port of your raspberry?
      @tiger
      Tiger
      #100
      yes it is
      and USB key is inserted
      file name is
      • T Tiger
        yes it is
        file name is
        #101
        file name is
        Which path?
        Is that FileZilla that you are using as a filemanager?
        T 2 Antworten Letzte Antwort
          file name is
          Which path?
          Tiger
          #102
          file is directly on the usb key, not in a folder
            file name is
            Which path?
            Tiger
            schrieb am zuletzt editiert von Tiger
            #103
            I've nothing installed on the raspberry
            only iobroker and the OS lite
            • T Tiger
              #104
              @tiger
              But in Linux all files are in a path.
              Usually usb sticks are mounted in /media/
                @tiger
                Tiger
                #105
                I understand, but As I said... as I don't know Linux... difficult to know the path :)
                • T Tiger
                  #106
                  @tiger
                  But where is the stick now plugged? In your Desktop computer? In your Raspberry?
                    @tiger
                    Tiger
                    #107
                    plug on the raspberry, and i've install without desktop... as recommended
                    • T Tiger
                      #108
                      @tiger
                      I don't get it...
                      ls -la /media
                        @tiger
                        I don't get it...
                        ls -la /media
                        Tiger
                        #109
                        Sorry, I didn't found up to know how to copy text from PuTTY
                        • T Tiger
                          #110
                          @tiger
                          Copy the backupfile from your Desktop computer over to the Raspberry with FileZilla. Target directroy /opt/iobroker/backups
                          T 3 Antworten Letzte Antwort
                            @tiger
                            Tiger
                            #111
                            ok, I've to search how to achieve it... Filezila should be installed on raspberry? or only on y desktop computer?
                            If you've a website with some tuto or explanation... it should good :)
                            I'm going to work now... will try later.
                            Thanks a lot.
                              @tiger
                              Tiger
                              #112
                              ok found an explanation...
                              will try later.
                                @tiger
                                Tiger
                                #113
                                everything done..
                                try to restore...
                                but
                                pi@raspberrypi:~ $ iobroker restore 2022_08_15-10_41_07_backupiobroker.tar.gz
                                iobroker controller daemon is not running
                                host.raspberrypi OK.
                                The current version of js-controller differs from the version in the backup.
                                The js-controller version of the backup can not be restored automatically.
                                To restore the js-controller version of the backup, execute "npm i iobroker.js-controller@3.1.6 --production" inside your ioBroker directory
                                If you really want to restore the backup with the current installed js-controller, execute the restore command with the --force flag
                                • T Tiger
                                  everything done..
                                  try to restore...
                                  but
                                  #114
                                  but
                                  what a luck!
                                  as @crunchip mentioned you should install vis before restore
                                  so please do it now.
                                  the fialog asks you what controller you wsnt to have.
                                  The actual install also has the actual controller.
                                  Your backup has an ancient one
                                  so please install vis iobroker install vis after that make another try ant choose the
                                  i.e.
                                  iobroker restore 2022_08_15-10_41_07_backupiobroker.tar.gz --force
                                  (i hope)
                                    but
                                    what a luck!
                                    i.e.
                                    (i hope)
                                    Tiger
                                    #115
                                    Vis installed
                                    Backup with --force done...
                                    ADmin version has beenn downgrade to 4.0 as before...
                                    In the journal log it seems that iobroker is reinstalling all the adapters needed...
                                    as there is all line like that
                                    host.raspberrypi 2022-08-16 15:16:43.415 info iobroker npm-install: 28 packages are looking for funding run npm fund for details
                                    host.raspberrypi 2022-08-16 15:16:43.413 info iobroker npm-install: added 1 package in 5s
                                    host.raspberrypi 2022-08-16 15:16:43.412 info iobroker npm-install:
                                    host.raspberrypi 2022-08-16 15:16:37.347 info iobroker npm-install: Installing iobroker.history@1.9.10... (System call)
                                    host.raspberrypi 2022-08-16 15:16:37.342 info iobroker npm-install: NPM version: 8.11.0
                                    host.raspberrypi 2022-08-16 15:16:34.656 info iobroker install history@1.9.10 using installedFrom
                                    host.raspberrypi 2022-08-16 15:16:34.656 warn startInstance cannot find adapter "history@1.9.10". Try to install it... 1 attempt
                                    • T Tiger
                                      Vis installed
                                      #116
                                      @tiger at this moment the restore itself is finished and all adapters were built.
                                      this will last a time
                                        Tiger
                                        #117
                                        It can take is time:)
                                        after that, supposed that all adapters will be installed with the last versions...
                                        and the last thing will be to update the iobroker.admin... and perhaps js-controller depending of the version.
                                        • T Tiger
                                          #118
                                          no!
                                          they will stay in their versions of the backup.
                                          but now your controller is in a living version and all updates should work
                                          it has to be the next thing, and then the others
