  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
  • Thomas BraunT Online
    @tiger
    So what is the output to
    sudo apt update
    then?
    T 2 Antworten Letzte Antwort
      @tiger
      sudo apt update
      then?
      Tiger
      command : sudo apt full-upgrade took time
      progress is 13% since some minutes
      Unpacking wolfram-engine (12.2.0+2021041101) over (12.0.1+2019062401) ...
      Progress: [ 13%] [#######...................................................]
      • T Tiger
        @tiger
        Then you never did update your system before.
        And you are running the Desktop-Variant. Both is a no-go.
          @tiger
          Tiger
          Once everything was working.. i Didn't made any update...
          Now It's because I would like to add some functionnality as Smappee on my Vis...
          I need it.
          or I will continue like that with old version and will continue to work as before :)
          Whatever, thanks to all for your help.
          progress is 48%
          • T Tiger
            I need it.
            progress is 48%
            @tiger sagte in Update System iobroker failed:
            don't even think about this.
            the day will come and you have to update an adapter you need.
            due to the 'never change a running system' approach, now you are in trouble.
            And then you'll be in big trouble for sure.
            Please keep your system up to date always. for security and convenience
              @tiger
              sudo apt update
              then?
              Tiger
              so, here the result
              pi@raspberrypi:~ $ sudo apt update
              Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
              Hit:2 https://deb.nodesource.com/node_10.x buster InRelease
              Hit:3 http://archive.raspberrypi.org/debian buster InRelease
              Reading package lists... Done
              Building dependency tree
              All packages are up to date.
              • T Tiger
                I need it.
                progress is 48%
                I'm not sure if it makes any sense to help you with that attitude...
                Once again:
                uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  Once again:
                  Tiger
                  schrieb am zuletzt editiert von Tiger
                  I understand you, but I would like to be up to date and continue, it's just because i dont like to not understand everything and take time of other poeple ;)
                  That's why I thank you for all.
                  pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  armv7l
                  /usr/bin/nodejs
                  /usr/local/bin/node
                  /usr/local/bin/npm
                  v10.24.1
                  v14.20.0
                  6.14.17
                  pi
                  /home/pi
                  Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                  Hit:3 https://deb.nodesource.com/node_10.x buster InRelease
                  nodejs:
                    Installed: 10.24.1-1nodesource1
                    Candidate: 10.24.1-1nodesource1
                    Version table:
                   *** 10.24.1-1nodesource1 500
                          500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
                          100 /var/lib/dpkg/status
                       10.24.0~dfsg-1~deb10u1 500
                  • T Tiger
                    armv7l
                    /usr/bin/nodejs
                    /usr/local/bin/node
                    /usr/local/bin/npm
                    v10.24.1
                    v14.20.0
                    6.14.17
                    pi
                    /home/pi
                    nodejs:
                      Version table:
                    that's a good point of view
                    so we will work on it, making you to understand it
                    that's our decision! hoping you learn something and possible give this to others
                    • T Tiger
                      armv7l
                      /usr/bin/nodejs
                      /usr/local/bin/node
                      /usr/local/bin/npm
                      v10.24.1
                      v14.20.0
                      6.14.17
                      pi
                      /home/pi
                      nodejs:
                        Version table:
                      sudo rm /usr/local/bin/node
                      sudo rm /usr/local/bin/npm
                      curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
                      sudo apt install nodejs
                        Tiger
                        Thanks, like to see that.
                          Tiger
                          @thomas-braun said in Update System iobroker failed:
                          You'll find here after all I've done
                          pi@raspberrypi:~ $ sudo rm /usr/local/bin/node
                          pi@raspberrypi:~ $ sudo rm /usr/local/bin/npm
                          pi@raspberrypi:~ $ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
                          ## Installing the NodeSource Node.js 16.x repo...
                          ## Populating apt-get cache...
                          + apt-get update
                          ## Confirming "buster" is supported...
                          + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_16.x/dists/buster/Release'
                          ## Adding the NodeSource signing key to your keyring...
                          + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
                          gpg: WARNING: unsafe ownership on homedir '/home/pi/.gnupg'
                          ## Creating apt sources list file for the NodeSource Node.js 16.x repo...
                          + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' > /etc/apt/sources.list.d/nodesource.list
                          + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' >> /etc/apt/sources.list.d/nodesource.list
                          ## Running `apt-get update` for you...
                          + apt-get update
                          Get:3 https://deb.nodesource.com/node_16.x buster InRelease [4,584 B]
                          Get:4 https://deb.nodesource.com/node_16.x buster/main armhf Packages [782 B]
                          Fetched 5,366 B in 1s (3,599 B/s)
                          ## Run `sudo apt-get install -y nodejs` to install Node.js 16.x and npm
                          ## You may also need development tools to build native addons:
                               sudo apt-get install gcc g++ make
                          ## To install the Yarn package manager, run:
                               curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
                               echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                               sudo apt-get update && sudo apt-get install yarn
                          pi@raspberrypi:~ $ sudo apt install nodejs
                          The following packages were automatically installed and are no longer required:
                            gconf-service gconf2-common libbluetooth3 libexiv2-14 libgconf-2-4 libgfortran3 libgmime-2.6-0
                            libncurses5 lxplug-volume python-colorzero
                          Use 'sudo apt autoremove' to remove them.
                          The following packages will be upgraded:
                            nodejs
                          1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                          Need to get 23.6 MB of archives.
                          After this operation, 38.8 MB of additional disk space will be used.
                          Get:1 https://deb.nodesource.com/node_16.x buster/main armhf nodejs armhf 16.16.0-deb-1nodesource1 [23.6 MB]
                          Fetched 23.6 MB in 1min 14s (318 kB/s)
                          Reading changelogs... Done
                          (Reading database ... 167450 files and directories currently installed.)
                          Preparing to unpack .../nodejs_16.16.0-deb-1nodesource1_armhf.deb ...
                          Unpacking nodejs (16.16.0-deb-1nodesource1) over (10.24.1-1nodesource1) ...
                          Setting up nodejs (16.16.0-deb-1nodesource1) ...
                          Processing triggers for man-db (2.8.5-2) ...
                          pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                          ln: failed to create symbolic link '/usr/bin/nodejs': File exists
                          • T Tiger
                            + apt-get update
                            + apt-get update
                              nodejs
                            sudo apt autoremove
                            iobroker restart
                            iobroker status
                              sudo apt autoremove
                              iobroker restart
                              iobroker status
                              Tiger
                              pi@raspberrypi:~ $ sudo apt autoremove
                              The following packages will be REMOVED:
                              0 upgraded, 0 newly installed, 10 to remove and 0 not upgraded.
                              After this operation, 11.8 MB disk space will be freed.
                              Do you want to continue? [Y/n] y
                              (Reading database ... 165809 files and directories currently installed.)
                              Removing gconf-service (3.2.6-5) ...
                              Removing libgconf-2-4:armhf (3.2.6-5) ...
                              Removing gconf2-common (3.2.6-5) ...
                              Removing libbluetooth3:armhf (5.50-1.2~deb10u2+rpt1) ...
                              Removing libexiv2-14:armhf (0.25-4+deb10u2) ...
                              Removing libgfortran3:armhf (6.5.0-1+rpi1+b1) ...
                              Removing libgmime-2.6-0:armhf (2.6.23+dfsg1-4) ...
                              Removing libncurses5:armhf (6.1+20181013-2+deb10u2) ...
                              Removing lxplug-volume (0.25) ...
                              Removing python-colorzero (1.1) ...
                              Processing triggers for sgml-base (1.29) ...
                              Processing triggers for libc-bin (2.28-10+rpt2+rpi1+deb10u1) ...
                              pi@raspberrypi:~ $ iobroker restart
                              pi@raspberrypi:~ $ iobroker status
                              node:internal/modules/cjs/loader:936
                                throw err;
                              Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                  at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
                                  at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                                  at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
                                  at node:internal/main/run_main_module:17:47 {
                                code: 'MODULE_NOT_FOUND',
                                requireStack: []
                              pi@raspberrypi:~ $
                                sudo apt autoremove
                                iobroker restart
                                iobroker status
                                Tiger
                                juste one things more... I'd forgot to reboot ...
                                I'd just reboot now...
                                Sorry...
                                • T Tiger
                                    throw err;
                                    requireStack: []
                                  pi@raspberrypi:~ $
                                  @tiger
                                  Now the correct directories and commands:
                                  cd /opt/iobroker
                                  sudo -H -u iobroker npm install iobroker.js-controller
                                  iobroker stop
                                  iobroker fix
                                  iobroker start
                                    @tiger
                                    cd /opt/iobroker
                                    iobroker stop
                                    iobroker fix
                                    iobroker start
                                    Tiger
                                    Problem with command
                                    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                                    npm WARN old lockfile
                                    npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                                    npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                                    npm WARN old lockfile This is a one-time fix-up, please be patient...
                                    npm ERR! code 24
                                    npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                                    npm ERR! command failed
                                    npm ERR! command sh -c node iobroker.js setup first
                                    npm ERR! Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
                                    npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T14_39_15_503Z-debug-0.log
                                    I attached Log file2022-08-15T14_39_15_503Z-debug-0.log
                                    • T Tiger
                                      npm ERR! code 24
                                      ok!
                                      delete it and try again.
                                      if you are afraid of deleting, rename it
                                        ok!
                                        Tiger
                                        I rename directly in the folder /opt/iobroker the file
                                        and remade the operation
                                        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                                        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                                        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                                        npm ERR! code 32
                                        npm ERR! Successfully migrated 2282 objects to Redis Sets
                                        npm ERR! object _design/system updated
                                        npm ERR! host.raspberrypi install adapter backitup
                                        npm ERR! These apt-get packages were already installed: cifs-utils, nfs-common
                                        npm ERR! upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                                        npm ERR! upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                                        npm ERR! upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                                        npm ERR! upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                                        npm ERR! upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                                        npm ERR! upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                                        npm ERR! upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                                        npm ERR! upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                                        npm ERR! upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                                        npm ERR! upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                                        npm ERR! upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                                        npm ERR! host.raspberrypi Invalid version of "admin". Installed "4.0.10", required ">=5.2.0"
                                        npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T14_47_08_695Z-debug-0.log
                                        log file 2022-08-15T14_47_08_695Z-debug-0.log
                                        • T Tiger
                                          npm ERR! code 32
                                          @tiger looks fine!
                                          npm works correctly now
