  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
  • T Tiger
    @thomas-braun that what I said.. I don't remember I'd one...
    As the raspberry was only for iobroker
    #61
    @tiger
    The user 'pi' has a password.
    • T Tiger
      #62
      @tiger sagte in Update System iobroker failed:
      security issue if you didn't change it raspberry
        don't remember that I'had a password
        The password is for your linux user, more specific for the root (or root entiteled) user.
        Tiger
        #63
        pi@raspberrypi:/opt/iobroker $ curl -sLf https://iobroker.net/install.sh | bash -
        library: loaded
        Library version=2022-06-15
            Welcome to the ioBroker installer!
            Installer version: 2022-06-03
            You might need to enter your password a couple of times.
            Installing prerequisites (1/4)
        Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:2 http://archive.raspberrypi.org/debian buster InRelease
        Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
        Reading package lists... Done
        Changing npm registry to https://registry.npmjs.org
        Installed gcc-c++
            Creating ioBroker user and directory (2/4)
        Created /etc/sudoers.d/iobroker
        Directory /opt/iobroker created
            Installing ioBroker (3/4)
        npm ERR! code 32
        npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
        npm ERR! command failed
        npm ERR! command sh -c node iobroker.js setup first
        npm ERR! Successfully migrated 2308 objects to Redis Sets
        npm ERR! object _design/system updated
        npm ERR! host.raspberrypi install adapter backitup
        npm ERR! These apt-get packages were already installed: cifs-utils, nfs-common
        npm ERR! upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
        npm ERR! upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
        npm ERR! upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
        npm ERR! upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
        npm ERR! upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
        npm ERR! upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
        npm ERR! upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
        npm ERR! upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
        npm ERR! upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
        npm ERR! upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
        npm ERR! upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
        npm ERR! host.raspberrypi Invalid version of "admin". Installed "4.0.10", required ">=5.2.0"
        npm ERR!     /home/pi/.npm/_logs/2022-08-15T15_38_44_496Z-debug-0.log
            Finalizing installation (4/4)
        Enabling autostart...
        Autostart enabled!
            ioBroker was installed successfully
            Open http://192.168.0.100 192.168.1.16:8081 in a browser and start configuring!
        You need to re-login before doing anything else on the console!
        log 2022-08-15T15_38_44_496Z-debug-0.log
        how to re-login?
        • T Tiger
          library: loaded
          Installed gcc-c++
          npm ERR! code 32
          Autostart enabled!
          how to re-login?
          #64
          two different Subnets for LAN and WLAN?
            Tiger
            schrieb am zuletzt editiert von Tiger
            #65
            yes, both was connected, I tryed but
            This site can’t be reached
            localhost refused to connect.
            • T Tiger
              #66
              try with IP
              otherwise we have to proceed with the console
                try with IP
                Tiger
                #67
                already tryied
                same issue
                192.168.1.16 refused to connect.
                  #68
                  @Thomas-Braun
                  npm ERR! code 32
                  Did you see?
                  • T Tiger
                    already tryied
                    same issue
                    #69
                    did you call ip:8081?
                    if yes, does iobroker list instances work this time?
                      Tiger
                      #70
                      Of course I did...this is what I written : http://192.168.1.16:8081/
                      but iobroker list instances has same result as before... (I tryied in directory /opt/iobroker and in the directory show here after)
                      pi@raspberrypi:~ $ iobroker list instances
                      node:internal/modules/cjs/loader:936
                        throw err;
                      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
                          at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
                          at node:internal/main/run_main_module:17:47 {
                        code: 'MODULE_NOT_FOUND',
                        requireStack: []
                      • T Tiger
                          throw err;
                          requireStack: []
                        #71
                        @tiger Sorry, I don't have any clue. we have to wait for @Thomas-Braun
                          Tiger
                          #72
                          for information, I found in directory the backup of this morning ;) if it can help to restart from there...
                          • T Tiger
                            #73
                            if you want listen to my advice from earlier this day:
                            take a new SD card, install the latest RaspberryOS lite and iobroker by curl -sLf https://iobroker.net/install.sh | bash - and restore it there.
                            and don"t vorget to save your history folder
                            • Thomas BraunT Online
                              #74
                              @homoran sagte in Update System iobroker failed:
                              Me neither.
                                Tiger
                                #75
                                to be honest as I installed everything some years ago... I don't remember everyting to reinstalled.
                                But I can buy new one and try.
                                am I right
                                • Reinstall OS on the new one
                                • install iobroker with yout command
                                And after? restore from the backup made?
                                history is just for temperature... not big issue even if I lost it.
                                In waiting for that, I suppose that I can use my imagedisk to have my domotic runs?
                                I'd already try to search to reinstall raspberry, to flash the new SdCard with the raspberry OS lite, Can I do it from my PC windows?
                                Which version you recommended? (32bit or 64 bit as i've the raspberry pi4) I suppose for me the version lite with desktop?
                                Why not with desktop and recommended software?
                                Stupid question... how can I save my backup file from iobroker ? as the file is on the actual sdcard...
                                thanks
                                • T Tiger
                                  am I right
                                  thanks
                                  #76
                                  @tiger
                                  Use the Raspberry OS Imager, go for the 64bit (lite) Version.
                                  No Desktop for added security, speed and convenience.
                                  • T Tiger
                                    am I right
                                    thanks
                                    #77
                                    am I right
                                    YES!!
                                    even though, save the folder /opt/iobroker/iobroker-data/history and simply copy it back on the new install.
                                    other questions answered by Thomas. You won't get other answers by me 😀
                                    There are no stupid questions at all - just stupid answers!
                                    use filezilla, but log in as the same user u will use later on. it should be pi
                                      @tiger
                                      Tiger
                                      #78
                                      ok I will try... perhaps too hard for my actual knowledge...
                                      I'll comeback when new sdcard will be operating, and when I will have made the command you asked to install.
                                      What I'm going to do...
                                      • Copy the iobroker backup on USB key
                                      • restore from image disk to have access to my domotics
                                      • on new SDcard, install the last Raspberry OSbit without desktop 😧
                                      • install iobroker
                                      and come back to have your support.
                                      Many thanks to both of you for your help and time
                                        am I right
                                        YES!!
                                        Tiger
                                        #79
                                        @homoran said in Update System iobroker failed:
                                        so what is the answer? :)
                                        Filezilla is to send the iobroker backup if I'm right
                                        sorry to much information for me today lol
                                        • T Tiger
                                          • install iobroker
                                          #80
                                          no, I'm sure!
                                          but if you insist, we will brush up your skills.
                                          please ask!
                                          that's another possibility - ok
                                          don't know about this stuff.
                                          but if you still "play back" an image/mirrored disk, you also play back all faulty stuff.
                                          This wouldn't be a good idea
                                          we will wait for you!
