  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
    @tiger
    curl -fsL https://iobroker.net/fix.sh | bash -
    if that fails:
    curl -sLf https://iobroker.net/install.sh | bash -
    @thomas-braun may there be another installation in an unappropriate directory?
    • T Tiger
      @thomas-braun said in Update System iobroker failed:
      already in /opt/iobriker?
      @tiger sagte in Update System iobroker failed:
      yes, but broker 😄
        @tiger
        if that fails:
        Tiger
        first failed... and strange, as you said... seems not to be installed
        pi@raspberrypi:/opt/iobroker $ curl -fsL https://iobroker.net/fix.sh | bash -
        library: loaded
        Library version=2022-06-15
        ioBroker is not installed in /opt/iobroker! Cannot fix anything...
        Second is on the road... but tell me that password will be asked few time... don't remember that I'had a password .. hum hum
        • T Tiger
          library: loaded
          The password is for your linux user, more specific for the root (or root entiteled) user.
          T 2 Antworten Letzte Antwort
            Tiger
            @thomas-braun that what I said.. I don't remember I'd one...
            As the raspberry was only for iobroker
            • T Tiger
              @tiger
              The user 'pi' has a password.
              • T Tiger
                security issue if you didn't change it raspberry
                  Tiger
                  pi@raspberrypi:/opt/iobroker $ curl -sLf https://iobroker.net/install.sh | bash -
                  library: loaded
                      Welcome to the ioBroker installer!
                      Installer version: 2022-06-03
                      You might need to enter your password a couple of times.
                      Installing prerequisites (1/4)
                  Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                  Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                  Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
                  Reading package lists... Done
                  Changing npm registry to https://registry.npmjs.org
                  Installed gcc-c++
                      Creating ioBroker user and directory (2/4)
                  Directory /opt/iobroker created
                      Installing ioBroker (3/4)
                  npm ERR! code 32
                  npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                  npm ERR! command failed
                  npm ERR! command sh -c node iobroker.js setup first
                  npm ERR! Successfully migrated 2308 objects to Redis Sets
                  npm ERR! object _design/system updated
                  npm ERR! host.raspberrypi install adapter backitup
                  npm ERR! These apt-get packages were already installed: cifs-utils, nfs-common
                  npm ERR! upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                  npm ERR! upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                  npm ERR! upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                  npm ERR! upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                  npm ERR! upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                  npm ERR! upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                  npm ERR! upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                  npm ERR! upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                  npm ERR! upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                  npm ERR! upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                  npm ERR! upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                  npm ERR! host.raspberrypi Invalid version of "admin". Installed "4.0.10", required ">=5.2.0"
                  npm ERR!     /home/pi/.npm/_logs/2022-08-15T15_38_44_496Z-debug-0.log
                      Finalizing installation (4/4)
                  Enabling autostart...
                  Autostart enabled!
                      ioBroker was installed successfully
                      Open http://192.168.0.100 192.168.1.16:8081 in a browser and start configuring!
                  You need to re-login before doing anything else on the console!
                  log 2022-08-15T15_38_44_496Z-debug-0.log
                  how to re-login?
                  • T Tiger
                    library: loaded
                    Installed gcc-c++
                    npm ERR! code 32
                    Autostart enabled!
                    how to re-login?
                    two different Subnets for LAN and WLAN?
                      Tiger
                      schrieb am zuletzt editiert von Tiger
                      yes, both was connected, I tryed but
                      This site can’t be reached
                      localhost refused to connect.
                      • T Tiger
                        #66
                        try with IP
                        otherwise we have to proceed with the console
                          try with IP
                          Tiger
                          #67
                          already tryied
                          same issue
                          192.168.1.16 refused to connect.
                            #68
                            @Thomas-Braun
                            npm ERR! code 32
                            Did you see?
                            • T Tiger
                              already tryied
                              same issue
                              #69
                              did you call ip:8081?
                              if yes, does iobroker list instances work this time?
                                Tiger
                                #70
                                Of course I did...this is what I written : http://192.168.1.16:8081/
                                but iobroker list instances has same result as before... (I tryied in directory /opt/iobroker and in the directory show here after)
                                pi@raspberrypi:~ $ iobroker list instances
                                node:internal/modules/cjs/loader:936
                                  throw err;
                                Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                    at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
                                    at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                                    at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
                                    at node:internal/main/run_main_module:17:47 {
                                  code: 'MODULE_NOT_FOUND',
                                  requireStack: []
                                • T Tiger
                                    throw err;
                                    requireStack: []
                                  #71
                                  @tiger Sorry, I don't have any clue. we have to wait for @Thomas-Braun
                                    Tiger
                                    #72
                                    for information, I found in directory the backup of this morning ;) if it can help to restart from there...
                                    • T Tiger
                                      #73
                                      if you want listen to my advice from earlier this day:
                                      take a new SD card, install the latest RaspberryOS lite and iobroker by curl -sLf https://iobroker.net/install.sh | bash - and restore it there.
                                      and don"t vorget to save your history folder
                                      • Thomas BraunT Online
                                        #74
                                        @homoran sagte in Update System iobroker failed:
                                        Me neither.
                                          Tiger
                                          #75
                                          to be honest as I installed everything some years ago... I don't remember everyting to reinstalled.
                                          But I can buy new one and try.
                                          am I right
                                          • Reinstall OS on the new one
                                          • install iobroker with yout command
                                          And after? restore from the backup made?
                                          history is just for temperature... not big issue even if I lost it.
                                          In waiting for that, I suppose that I can use my imagedisk to have my domotic runs?
                                          I'd already try to search to reinstall raspberry, to flash the new SdCard with the raspberry OS lite, Can I do it from my PC windows?
                                          Which version you recommended? (32bit or 64 bit as i've the raspberry pi4) I suppose for me the version lite with desktop?
                                          Why not with desktop and recommended software?
                                          Stupid question... how can I save my backup file from iobroker ? as the file is on the actual sdcard...
                                          thanks
