  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
    @tiger sagte in Update System iobroker failed:
    don't remember that I'had a password
    The password is for your linux user, more specific for the root (or root entiteled) user.
    Tiger
    @thomas-braun that what I said.. I don't remember I'd one...
    As the raspberry was only for iobroker
    • T Tiger
      @tiger
      The user 'pi' has a password.
      • T Tiger
        security issue if you didn't change it raspberry
          Tiger
          pi@raspberrypi:/opt/iobroker $ curl -sLf https://iobroker.net/install.sh | bash -
          library: loaded
          Library version=2022-06-15
              Welcome to the ioBroker installer!
              Installer version: 2022-06-03
              You might need to enter your password a couple of times.
              Installing prerequisites (1/4)
          Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
          Hit:2 http://archive.raspberrypi.org/debian buster InRelease
          Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
          Reading package lists... Done
          Changing npm registry to https://registry.npmjs.org
          Installed gcc-c++
              Creating ioBroker user and directory (2/4)
          Directory /opt/iobroker created
              Installing ioBroker (3/4)
          npm ERR! code 32
          npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
          npm ERR! command failed
          npm ERR! command sh -c node iobroker.js setup first
          npm ERR! Successfully migrated 2308 objects to Redis Sets
          npm ERR! object _design/system updated
          npm ERR! host.raspberrypi install adapter backitup
          npm ERR! These apt-get packages were already installed: cifs-utils, nfs-common
          npm ERR! upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
          npm ERR! upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
          npm ERR! upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
          npm ERR! upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
          npm ERR! upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
          npm ERR! upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
          npm ERR! upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
          npm ERR! upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
          npm ERR! upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
          npm ERR! upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
          npm ERR! upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
          npm ERR! host.raspberrypi Invalid version of "admin". Installed "4.0.10", required ">=5.2.0"
          npm ERR!     /home/pi/.npm/_logs/2022-08-15T15_38_44_496Z-debug-0.log
              Finalizing installation (4/4)
          Enabling autostart...
          Autostart enabled!
              ioBroker was installed successfully
              Open http://192.168.0.100 192.168.1.16:8081 in a browser and start configuring!
          You need to re-login before doing anything else on the console!
          log 2022-08-15T15_38_44_496Z-debug-0.log
          how to re-login?
          • T Tiger
            library: loaded
            Installed gcc-c++
            npm ERR! code 32
            Autostart enabled!
            how to re-login?
            two different Subnets for LAN and WLAN?
              Tiger
              schrieb am zuletzt editiert von Tiger
              yes, both was connected, I tryed but
              This site can’t be reached
              localhost refused to connect.
              • T Tiger
                #66
                try with IP
                otherwise we have to proceed with the console
                  try with IP
                  Tiger
                  #67
                  already tryied
                  same issue
                  192.168.1.16 refused to connect.
                    #68
                    @Thomas-Braun
                    npm ERR! code 32
                    Did you see?
                    • T Tiger
                      already tryied
                      same issue
                      #69
                      did you call ip:8081?
                      if yes, does iobroker list instances work this time?
                        Tiger
                        #70
                        Of course I did...this is what I written : http://192.168.1.16:8081/
                        but iobroker list instances has same result as before... (I tryied in directory /opt/iobroker and in the directory show here after)
                        pi@raspberrypi:~ $ iobroker list instances
                        node:internal/modules/cjs/loader:936
                          throw err;
                        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                            at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
                            at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
                            at node:internal/main/run_main_module:17:47 {
                          code: 'MODULE_NOT_FOUND',
                          requireStack: []
                        • T Tiger
                            throw err;
                            requireStack: []
                          #71
                          @tiger Sorry, I don't have any clue. we have to wait for @Thomas-Braun
                            Tiger
                            #72
                            for information, I found in directory the backup of this morning ;) if it can help to restart from there...
                            • T Tiger
                              #73
                              if you want listen to my advice from earlier this day:
                              take a new SD card, install the latest RaspberryOS lite and iobroker by curl -sLf https://iobroker.net/install.sh | bash - and restore it there.
                              and don"t vorget to save your history folder
                              • Thomas BraunT Online
                                #74
                                @homoran sagte in Update System iobroker failed:
                                Me neither.
                                  Tiger
                                  #75
                                  to be honest as I installed everything some years ago... I don't remember everyting to reinstalled.
                                  But I can buy new one and try.
                                  am I right
                                  • Reinstall OS on the new one
                                  • install iobroker with yout command
                                  And after? restore from the backup made?
                                  history is just for temperature... not big issue even if I lost it.
                                  In waiting for that, I suppose that I can use my imagedisk to have my domotic runs?
                                  I'd already try to search to reinstall raspberry, to flash the new SdCard with the raspberry OS lite, Can I do it from my PC windows?
                                  Which version you recommended? (32bit or 64 bit as i've the raspberry pi4) I suppose for me the version lite with desktop?
                                  Why not with desktop and recommended software?
                                  Stupid question... how can I save my backup file from iobroker ? as the file is on the actual sdcard...
                                  thanks
                                  • T Tiger
                                    am I right
                                    thanks
                                    #76
                                    @tiger
                                    Use the Raspberry OS Imager, go for the 64bit (lite) Version.
                                    No Desktop for added security, speed and convenience.
                                    • T Tiger
                                      am I right
                                      thanks
                                      #77
                                      am I right
                                      YES!!
                                      even though, save the folder /opt/iobroker/iobroker-data/history and simply copy it back on the new install.
                                      other questions answered by Thomas. You won't get other answers by me 😀
                                      There are no stupid questions at all - just stupid answers!
                                      use filezilla, but log in as the same user u will use later on. it should be pi
                                        @tiger
                                        Tiger
                                        #78
                                        ok I will try... perhaps too hard for my actual knowledge...
                                        I'll comeback when new sdcard will be operating, and when I will have made the command you asked to install.
                                        What I'm going to do...
                                        • Copy the iobroker backup on USB key
                                        • restore from image disk to have access to my domotics
                                        • on new SDcard, install the last Raspberry OSbit without desktop 😧
                                        • install iobroker
                                        and come back to have your support.
                                        Many thanks to both of you for your help and time
                                          am I right
                                          YES!!
                                          Tiger
                                          #79
                                          @homoran said in Update System iobroker failed:
                                          so what is the answer? :)
                                          Filezilla is to send the iobroker backup if I'm right
                                          sorry to much information for me today lol
