  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
  • T Tiger
    @thomas-braun said in Update System iobroker failed:
    curl -fsL https://iobroker.net/fix.sh | bash -
    already in /opt/iobriker?
    @tiger sagte in Update System iobroker failed:
    yes, but broker 😄
      @tiger
      if that fails:
      curl -sLf https://iobroker.net/install.sh | bash -
      Tiger
      first failed... and strange, as you said... seems not to be installed
      pi@raspberrypi:/opt/iobroker $ curl -fsL https://iobroker.net/fix.sh | bash -
      library: loaded
      Library version=2022-06-15
      ioBroker is not installed in /opt/iobroker! Cannot fix anything...
      Second is on the road... but tell me that password will be asked few time... don't remember that I'had a password .. hum hum
      • T Tiger
        library: loaded
        The password is for your linux user, more specific for the root (or root entiteled) user.
        T 2 Antworten Letzte Antwort
          Tiger
          @thomas-braun that what I said.. I don't remember I'd one...
          As the raspberry was only for iobroker
          • T Tiger
            @tiger
            The user 'pi' has a password.
            • T Tiger
              security issue if you didn't change it raspberry
                Tiger
                pi@raspberrypi:/opt/iobroker $ curl -sLf https://iobroker.net/install.sh | bash -
                library: loaded
                    Welcome to the ioBroker installer!
                    Installer version: 2022-06-03
                    You might need to enter your password a couple of times.
                    Installing prerequisites (1/4)
                Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
                Reading package lists... Done
                Changing npm registry to https://registry.npmjs.org
                Installed gcc-c++
                    Creating ioBroker user and directory (2/4)
                Directory /opt/iobroker created
                    Installing ioBroker (3/4)
                npm ERR! code 32
                npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                npm ERR! command failed
                npm ERR! command sh -c node iobroker.js setup first
                npm ERR! Successfully migrated 2308 objects to Redis Sets
                npm ERR! object _design/system updated
                npm ERR! host.raspberrypi install adapter backitup
                npm ERR! These apt-get packages were already installed: cifs-utils, nfs-common
                npm ERR! upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                npm ERR! upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                npm ERR! upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                npm ERR! upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                npm ERR! upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                npm ERR! upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                npm ERR! upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                npm ERR! upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                npm ERR! upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                npm ERR! upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                npm ERR! upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                npm ERR! host.raspberrypi Invalid version of "admin". Installed "4.0.10", required ">=5.2.0"
                npm ERR!     /home/pi/.npm/_logs/2022-08-15T15_38_44_496Z-debug-0.log
                    Finalizing installation (4/4)
                Enabling autostart...
                Autostart enabled!
                    ioBroker was installed successfully
                    Open http://192.168.0.100 192.168.1.16:8081 in a browser and start configuring!
                You need to re-login before doing anything else on the console!
                log 2022-08-15T15_38_44_496Z-debug-0.log
                how to re-login?
                • T Tiger
                  library: loaded
                  Installed gcc-c++
                  npm ERR! code 32
                  Autostart enabled!
                  how to re-login?
                  two different Subnets for LAN and WLAN?
                    Tiger
                    schrieb am zuletzt editiert von Tiger
                    yes, both was connected, I tryed but
                    This site can’t be reached
                    localhost refused to connect.
                    • T Tiger
                      #66
                      try with IP
                      otherwise we have to proceed with the console
                        try with IP
                        Tiger
                        #67
                        already tryied
                        same issue
                        192.168.1.16 refused to connect.
                          #68
                          @Thomas-Braun
                          npm ERR! code 32
                          Did you see?
                          • T Tiger
                            already tryied
                            same issue
                            #69
                            did you call ip:8081?
                            if yes, does iobroker list instances work this time?
                              Tiger
                              #70
                              Of course I did...this is what I written : http://192.168.1.16:8081/
                              but iobroker list instances has same result as before... (I tryied in directory /opt/iobroker and in the directory show here after)
                              pi@raspberrypi:~ $ iobroker list instances
                              node:internal/modules/cjs/loader:936
                                throw err;
                              Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                  at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
                                  at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                                  at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
                                  at node:internal/main/run_main_module:17:47 {
                                code: 'MODULE_NOT_FOUND',
                                requireStack: []
                              • T Tiger
                                  throw err;
                                  requireStack: []
                                #71
                                @tiger Sorry, I don't have any clue. we have to wait for @Thomas-Braun
                                  Tiger
                                  #72
                                  for information, I found in directory the backup of this morning ;) if it can help to restart from there...
                                  • T Tiger
                                    #73
                                    if you want listen to my advice from earlier this day:
                                    take a new SD card, install the latest RaspberryOS lite and iobroker by curl -sLf https://iobroker.net/install.sh | bash - and restore it there.
                                    and don"t vorget to save your history folder
                                    • Thomas BraunT Online
                                      #74
                                      @homoran sagte in Update System iobroker failed:
                                      Me neither.
                                        Tiger
                                        #75
                                        to be honest as I installed everything some years ago... I don't remember everyting to reinstalled.
                                        But I can buy new one and try.
                                        am I right
                                        • Reinstall OS on the new one
                                        • install iobroker with yout command
                                        And after? restore from the backup made?
                                        history is just for temperature... not big issue even if I lost it.
                                        In waiting for that, I suppose that I can use my imagedisk to have my domotic runs?
                                        I'd already try to search to reinstall raspberry, to flash the new SdCard with the raspberry OS lite, Can I do it from my PC windows?
                                        Which version you recommended? (32bit or 64 bit as i've the raspberry pi4) I suppose for me the version lite with desktop?
                                        Why not with desktop and recommended software?
                                        Stupid question... how can I save my backup file from iobroker ? as the file is on the actual sdcard...
                                        thanks
                                        • T Tiger
                                          am I right
                                          thanks
                                          #76
                                          @tiger
                                          Use the Raspberry OS Imager, go for the 64bit (lite) Version.
                                          No Desktop for added security, speed and convenience.
