  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
  • T Tiger
    everything came back as before.
    But, Things I forgot to do...
    Node-red doens't work as all node has to be reinstall ...
    So, what is your recommandation? trying to have all working as before and after made the update?
    Or I search before how to have the backup of Node-red and other things... before continue?
    same for VIS, not possible to connect to vis from browser
    mickymM Offline
    mickymM Offline
    mickym
    #121
    @tiger You can try - the following.
    Restore from your former image the package.json file into /opt/iobroker/iobroker-data/node-red directory. replace the existing one or rename it. Run npm install.
    Change to that directory:
    cd /opt/iobroker/iobroker-data/node-red
    npm install
    T 2 Antworten Letzte Antwort
    • mickymM mickym
      npm install
      Tiger
      #122
      @mickym
      thanks for your answer,
      To be sure what I've to do... (to avoid problem... I'm newbee :) )
      I've juste to replace the package.json file in the actual directory /opt/iobroker/iobroker-data/node-red by the old one my old sdcard?
      and after that run npm install, correct?
      stupid question, to have access to the file on my old SDcard, is it possible to place the SDcard on my windows desktop pc and save it? or I've to place the old SDcard in the raspberry Pi to pick up file with filezilla?
      HomoranH mickymM 2 Antworten Letzte Antwort
      • T Tiger
        @mickym
        #123
        @tiger sagte in Update System iobroker failed:
        I'm pretty sure windows won't see it :-(
        • T Tiger
          crunchipC Abwesend
          crunchipC Abwesend
          #124
          show the settings for vis and web. You use the socketio?
          • T Tiger
            @mickym
            mickymM Offline
            mickymM Offline
            mickym
            #125
            @mickym
            correct. I doubt that you can directly access the files on your SD card , because you have no drivers in windows. for the ext4 file system. In your case - I would boot with the old SD card and copy the whole directory /opt/iobroker/iobroker-data/node-red to your USB stick. When you boot with the new card - you should have access to all files wherever you mounted your USB stick. You should even be able to replace the complete new directory in the /opt/iobroker-dat with the old one. Rename the exiting one and replace it with the new one. If you want to know what the files in your /opt/iobroker/iobroker-data/node-red data mean you can have a look to my extensive description here: https://github.com/ioBroker/ioBroker.node-red/issues/320
            • mickymM mickym
              npm install
              Tiger
              schrieb am zuletzt editiert von Tiger
              #126
              @mickym
              Sorry, didn't see your post before doing it...
              So I took the package.json and replace in the node-red and made npm install in the directory
              Error with alexa node, seems that the node used before doesn't exist now
              pi@raspberrypi:/opt/iobroker/iobroker-data/node-red $ npm install
              npm ERR! code ENOVERSIONS
              npm ERR! No versions available for node-red-node-alexa
              npm ERR!     /home/iobroker/.npm/_logs/2022-08-16T14_59_56_194Z-debug-0.log
              log file 2022-08-16T14_59_56_194Z-debug-0.log
              Do you want that I tryed with copy af all the directory? there is a lot of files... more than 60.000
              • T Tiger
                @mickym
                mickymM Offline
                mickymM Offline
                mickym
                #127
                node-red-node-alexa
                So this node is no longer supported. As said you can rename the existing directory and copy the whole directory to the original place - but I do not recommend this. So better is to look for an replacement.
                If you want to try if the old one is running copying the old directory in total - you should first rename the exiting one before you copy the old one. But better is to remove the alexa node. If this is the only error then you should have all except the alexa node.
                to test if the old one will run. you can do
                mv node-red node-red.new
                and then copy the old directory into the iobroker-data directory. But I am not sure if this old alexa node will work at all.
                • mickymM mickym
                  node-red-node-alexa
                  Tiger
                  #128
                  @mickym
                  I'm Trying to understand :)
                  1 I've to test with your command
                  once made, (depending of the result)
                  • change the name of the directory to have backup I supposed
                  • Copy all the directory from the old SD Card (lots of files... more than 60.000....) to the new SD Card at same place
                  and after?
                    Tiger
                    #129
                    @crunchip
                    don't remember if socketio is used but it was installed.
                    Web.0 is not configured, And I didn't reached to change the Ip adress.
                    Configuration of VIS, nothing, lincence key is show and when checking licence it's OK
                    Configuration of Web.0
                    No ip Adress, supposed is the reason
                    • T Tiger
                      @mickym
                      and after?
                      mickymM Offline
                      mickymM Offline
                      mickym
                      #130
                      @mickym
                      and after?
                      after you copied the old directory under /opt/iobroker/iobroker-data make sure that the rights are adapted.
                      go to the /opt/iobroker/iobroker-data directory and execute:
                      sudo chown -R iobroker:iobroker node-red
                      this will ensure that user iobroker has access to all files and you can try to start the adapter. If this will not work - you have to use again the backup (node-red.new) and delete the reference of the old alexa node in the package.json file. However I guess all other nodes should have been installed.
                      I have to go off now and can only support you on my mobile. But this is very limited. But these are standard procedures all others should be familiar with. ;)
                      • mickymM mickym
                        @mickym
                        and after?
                        Tiger
                        #131
                        @mickym said in Update System iobroker failed:
                        What do you mean by that?
                        • T Tiger
                          mickymM Offline
                          mickymM Offline
                          mickym
                          #132
                          @tiger If you copy with user pi - all files are owned by this user. As iobroker runs under user iobroker you need to change the owner of the files and directories.
                          • mickymM mickym
                            Tiger
                            #133
                            @mickym
                            ok I've same user name as before
                            • T Tiger
                              @mickym
                              mickymM Offline
                              mickymM Offline
                              mickym
                              #134
                              @tiger So but I am not sure if the old node will work at all with the new node version. You should better think about a replacement.
                              • mickymM mickym
                                Tiger
                                #135
                                @mickym
                                So... if I'm understanding well...
                                I've to let like that without copy the directory...
                                install the new node of Alexa...
                                and made a new programmation?
                                as i wanted to have an installation up to date... if it's your recommandation... i'll do like that...
                                  Tiger
                                  #136
                                  No problem Now that I'd understood Filezilla :)
                                  I'm going to have all working, and after we'll see to the update.
                                  After Node-red.. that if I understand well I've to reprogram... for alexa
                                  I've to check VIS
                                  RFXCOM it seems that I've to pair everything as I've the devices but seems not connected
                                  Zigbee, probably same, I've to pair everything
                                  • T Tiger
                                    @crunchip
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    #137
                                    Not currently, you can switch and test it or use pure web sockets
                                    • T Tiger
                                      @mickym
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      #138
                                      @mickym
                                      Yes my recommendation is to do not copy the old stuff. Edit your package.json and delete the line in the dependencies section which refers to the old- alexa node. Run npm install hopefully without errors. Activate in the node red adapter configuration that you use the pallet manager and install a different node. Then you need to rework all alexa flows
                                      • T Tiger
                                        I've to check VIS
                                        #139
                                        i don't use zigbee and therefore I'm very sorry if there is a pitfall too.
                                        But @Thomas-Braun may know wether there will be a solution.
                                        • mickymM mickym
                                          @mickym
                                          Tiger
                                          #140
                                          package.json
                                          ok I'll do it...
                                          but, how do you edit the package.json?
