  2. English
  3. ioBroker general
  4. Update System iobroker failed
    apollon77A
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 42.9k Aufrufe 5 Beobachtet
  • T
    T
    Tiger
    Dear All,
    this morning I would like to upgrade my IOBROKER.ADMIN as I was in version 4
    So I've upgrade node.js to V14.20.0,
    I've tried to upgrade js-controller with command
    iobroker upgrade self
    after that... nothing was working... i tried lots of things from Forum and now I've already the same error message...
    when put command : iobroker update
    pi@raspberrypi:/ $ iobroker upadte
    internal/modules/cjs/loader.js:905
    throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
    at Function.Module._load (internal/modules/cjs/loader.js:746:27)
    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
    at internal/main/run_main_module.js:17:47 {
    code: 'MODULE_NOT_FOUND',
    requireStack: []
    I tried
    npm install iobroker.js-controller
    pi@raspberrypi:/ $ npm install iobroker.js-controller
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
    npm WARN checkPermissions Missing write access to /
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN enoent ENOENT: no such file or directory, open '/package.json'
    npm WARN !invalid#1 No description
    npm WARN !invalid#1 No repository field.
    npm WARN !invalid#1 No README data
    npm WARN !invalid#1 No license field.
    npm ERR! code EACCES
    npm ERR! syscall access
    npm ERR! path /
    npm ERR! errno -13
    npm ERR! Error: EACCES: permission denied, access '/'
    npm ERR! [Error: EACCES: permission denied, access '/'] {
    npm ERR! errno: -13,
    npm ERR! code: 'EACCES',
    npm ERR! syscall: 'access',
    npm ERR! path: '/'
    npm ERR! }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator.
    npm ERR! /home/pi/.npm/_logs/2022-08-15T11_51_26_878Z-debug.log
    version are
    NPM -v : 6.14.17
    node -v : 14.20.0
    Thanks for your help for a beginner...
    Regards
    • T Tiger
      Dear All,
      throw err;
      requireStack: []
      I tried
      npm ERR! path /
      npm ERR! errno -13
      npm ERR! path: '/'
      npm ERR! }
      npm ERR!
      npm ERR!
      version are
      NPM -v : 6.14.17
      node -v : 14.20.0
      Regards
      Thomas BraunT
      Thomas BraunT
      @tiger
      What is the current situation?
      Check:
      uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      You are standig in the wrong directroy with the wrong command:
        @tiger
        Check:
        T
        T
        Tiger
        This is what I've when checking :
        pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
        ln: failed to create symbolic link '/usr/bin/nodejs': File exists
        pi@raspberrypi:~ $
        pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        armv7l
        /usr/bin/nodejs
        /usr/local/bin/node
        /usr/local/bin/npm
        v10.24.1
        v14.20.0
        6.14.17
        pi
        /home/pi
        i'd retied in the correct folder (hoping it is the good one ;)
        with the lfollowing messages :
        pi@raspberrypi:~ $ npm install iobroker.js-controller
        > iobroker.js-controller@4.0.23 preinstall /home/pi/node_modules/iobroker.js-controller
        > node lib/preinstallCheck.js
        NPM version: 6.14.17
        > unix-dgram@2.0.4 install /home/pi/node_modules/unix-dgram
        > node-gyp rebuild
        make: Entering directory '/home/pi/node_modules/unix-dgram/build'
          CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
        In file included from ../../nan/nan.h:60,
                         from ../src/unix_dgram.cc:5:
        /home/pi/.cache/node-gyp/14.20.0/include/node/node.h:793:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
               (node::addon_register_func) (regfunc),                          \
        /home/pi/.cache/node-gyp/14.20.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
           NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
        ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
         NODE_MODULE(unix_dgram, Initialize)
          SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
          COPY Release/unix_dgram.node
        make: Leaving directory '/home/pi/node_modules/unix-dgram/build'
        > ursa-optional@0.9.10 install /home/pi/node_modules/ursa-optional
        > node rebuild.js
        ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
        > diskusage@1.1.3 install /home/pi/node_modules/diskusage
        > node-gyp rebuild
        make: Entering directory '/home/pi/node_modules/diskusage/build'
          CXX(target) Release/obj.target/diskusage/src/main.o
                         from ../src/main.cpp:3:
        ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
         NODE_MODULE(diskusage, Init)
          CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
          SOLINK_MODULE(target) Release/obj.target/diskusage.node
          COPY Release/diskusage.node
        make: Leaving directory '/home/pi/node_modules/diskusage/build'
        > iobroker.js-controller@4.0.23 install /home/pi/node_modules/iobroker.js-controller
        > node iobroker.js setup first
        Successfully migrated 2282 objects to Redis Sets
        object _design/system updated
          "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----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\r\nLQrsTuqtxiZzoneLoSuOcEsYGIB8TMHG1XNU6aGAJ0cI78mvbm8L\r\n-----END RSA PRIVATE KEY-----\r\n",
          "defaultPublic": "-----BEGIN CERTIFICATE-----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\r\nSYj6sP0IU2F3Gr3yMbYJAAHWsSagmHaLCViVXwwFDvQjLsZynHgBsZf0\r\n-----END CERTIFICATE-----\r\n"
        Update certificate defaultPrivate
        The object "system.certificates" was updated successfully.
        Update certificate defaultPublic
        > @root/acme@3.1.0 postinstall /home/pi/node_modules/@root/acme
        > node scripts/postinstall
        > esbuild@0.11.23 postinstall /home/pi/node_modules/esbuild
        > node install.js
        npm WARN pi@1.0.0 No description
        npm WARN pi@1.0.0 No repository field.
        + iobroker.js-controller@4.0.23
        added 312 packages from 288 contributors, removed 1 package and audited 313 packages in 85.481s
        18 packages are looking for funding
          run `npm fund` for details
        found 8 vulnerabilities (3 low, 2 moderate, 3 high)
          run `npm audit fix` to fix them, or `npm audit` for details
        thanks
        HomoranH Thomas BraunT 3 Antworten Letzte Antwort
        • T Tiger
          pi@raspberrypi:~ $
          armv7l
          /usr/bin/nodejs
          /usr/local/bin/node
          /usr/local/bin/npm
          v10.24.1
          v14.20.0
          6.14.17
          pi
          /home/pi
          > node-gyp rebuild
          > node rebuild.js
          > node-gyp rebuild
          > node install.js
          thanks
          @tiger please use code-tags for the log
          • T Tiger
            pi@raspberrypi:~ $
            armv7l
            /usr/bin/nodejs
            /usr/local/bin/node
            /usr/local/bin/npm
            v10.24.1
            v14.20.0
            6.14.17
            pi
            /home/pi
            > node-gyp rebuild
            > node rebuild.js
            > node-gyp rebuild
            > node install.js
            thanks
            Thomas BraunT
            Thomas BraunT
            @tiger sagte in Update System iobroker failed:
            /usr/bin/nodejs
            /usr/local/bin/node
            /usr/local/bin/npm
            v10.24.1
            v14.20.0
            nodejs is not installed correctly.
            Can you understand German?
            Here is an extended guide on how to fix it:
            BTW: Still a wrong directory:
            You need to stand in /opt/iobroker for any operations with npm.
            Using npm is not recommended anyway. For this exakt reason.
            But first fix your nodejs-Installation.
            T 2 Antworten Letzte Antwort
              /usr/bin/nodejs
              /usr/local/bin/node
              /usr/local/bin/npm
              v10.24.1
              v14.20.0
              T
              T
              Tiger
              I do not understand german, but will try with google traductor... :)
              I come back after :)
              • T Tiger
                pi@raspberrypi:~ $
                armv7l
                /usr/bin/nodejs
                /usr/local/bin/node
                /usr/local/bin/npm
                v10.24.1
                v14.20.0
                6.14.17
                pi
                /home/pi
                > node-gyp rebuild
                > node rebuild.js
                > node-gyp rebuild
                > node install.js
                thanks
                this command is executed in the pi's home instead of /opt/iobroker
                • T Tiger
                  in other languages f.i. french it will be worse for us
                    /usr/bin/nodejs
                    /usr/local/bin/node
                    /usr/local/bin/npm
                    v10.24.1
                    v14.20.0
                    T
                    T
                    Tiger
                    I'm trying to fix with your guide, but to complicate for me.
                    AS I'm a newbee and so I don't understand what I'm doing, so it's difficult.
                    I've a backup of my Sd Card.
                    If I use this backup and retry to upgrade my system,
                    do you have a guide with all steps to do?
                    When try to update Iobroker.Admin, tells me that Node.JS 10 is not goof and I've to upgrade to V16, when made, I try to upgrade system, and another adapter has to be upgraded but the version of Node.JS V16 was not good for it and should be not more than V14...
                    So if you've a guide, it should be more easy for a stupid guy like me
                      T
                      T
                      Tiger
                      @homoran I completely agree, that's why I'm trying to explain in English :)
                      • T Tiger
                        @tiger dou you have a backup of your iobroker installation?
                        done by backitup or iobroker backup?
                        then i would recommend to install all brandnew, best on a new SD card, so you'll still have the old one, and restore your backup to the new installation.
                        All will be built anew
                        T crunchipC 2 Antworten Letzte Antwort
                          T
                          T
                          Tiger
                          Yes I've two backup in fact
                          • 1 made thanks to win32 image disc, so I've my image of yestarday
                            -1 made thanks to iobroker backup
                          My idea was to copy the imagedisc of yestarday and retry to upgrade thanks to a guide, and with the correct order of different upgrade
                            crunchipC
                            crunchipC
                            Developer Global Moderator Most Active Forum Testing
                            @homoran and install vis before backup if vis is used
                            • T Tiger
                              win32 image disc,
                              this contains all the broken stuff.
                              not recommended!
                              what adapters did you install?
                              iobroker update -i
                              • T Tiger
                                Thomas BraunT
                                Thomas BraunT
                                @tiger
                                First action:
                                iobroker stop
                                sudo apt update
                                sudo apt full-upgrade
                                sudo reboot
                                Please post the output of
                                sudo apt update
                                  @crunchip sagte in Update System iobroker failed:
                                  Restore
                                    win32 image disc,
                                    not recommended!
                                    iobroker update -i
                                    T
                                    T
                                    Tiger
                                    to be honest yestarday I tried to upgrade and was in same situation as now, so I took the imagedisc and works as before.
                                    Adapters installed and needed was :
                                    • Siemens S7 adapter
                                    • Zigbee
                                    • Rfxcom
                                    • History
                                    iobroker update -i gives error too
                                    throw err;
                                    requireStack: []
                                    • Thomas BraunT
                                      Thomas BraunT
                                      @tiger
                                      Will you try to setup nodejs the proper way or trying around with your backups (which are most propably based on a wrong installation)
                                      • T Tiger
                                        • Zigbee
                                        • Rfxcom
                                        • History
                                        throw err;
                                        requireStack: []
                                        History
                                        in the regular iobroker backup the history won't be included.
                                        You have to save the directory /opt/iobroker/iobroker-data/history by yourself
                                          @tiger
                                          T
                                          T
                                          Tiger
                                          actually I'm trying your command, it's in progress.
                                          It should be better to re install everything... to have a proper installation up to date...
                                          But as you have notice, installation part is not my favorite things, I'm afroid to lost all my domotics and all i've already done with Alexa, Node red etc...
                                          Moreover, as I used the commande : iobroker backup, and I don't see the backup in /opt/iobroker... not sure I've the backup...
                                          regards
                                          84.0k
                                          1.4m
