  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
    @tiger
    What is the current situation?
    Check:
    uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    You are standig in the wrong directroy with the wrong command:
    npm install iobroker.js-controller
    pi@raspberrypi:/ $ npm install iobroker.js-controller
    Tiger
    This is what I've when checking :
    pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
    ln: failed to create symbolic link '/usr/bin/nodejs': File exists
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    armv7l
    /usr/bin/nodejs
    /usr/local/bin/node
    /usr/local/bin/npm
    v10.24.1
    v14.20.0
    6.14.17
    pi
    /home/pi
    i'd retied in the correct folder (hoping it is the good one ;)
    with the lfollowing messages :
    pi@raspberrypi:~ $ npm install iobroker.js-controller
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    > iobroker.js-controller@4.0.23 preinstall /home/pi/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.17
    > unix-dgram@2.0.4 install /home/pi/node_modules/unix-dgram
    > node-gyp rebuild
    make: Entering directory '/home/pi/node_modules/unix-dgram/build'
      CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
    In file included from ../../nan/nan.h:60,
                     from ../src/unix_dgram.cc:5:
    /home/pi/.cache/node-gyp/14.20.0/include/node/node.h:793:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /home/pi/.cache/node-gyp/14.20.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(unix_dgram, Initialize)
      SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
      COPY Release/unix_dgram.node
    make: Leaving directory '/home/pi/node_modules/unix-dgram/build'
    > ursa-optional@0.9.10 install /home/pi/node_modules/ursa-optional
    > node rebuild.js
    ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
    > diskusage@1.1.3 install /home/pi/node_modules/diskusage
    > node-gyp rebuild
    make: Entering directory '/home/pi/node_modules/diskusage/build'
      CXX(target) Release/obj.target/diskusage/src/main.o
                     from ../src/main.cpp:3:
    ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(diskusage, Init)
      CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
      SOLINK_MODULE(target) Release/obj.target/diskusage.node
      COPY Release/diskusage.node
    make: Leaving directory '/home/pi/node_modules/diskusage/build'
    > iobroker.js-controller@4.0.23 install /home/pi/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    Successfully migrated 2282 objects to Redis Sets
    object _design/system updated
      "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----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\r\nLQrsTuqtxiZzoneLoSuOcEsYGIB8TMHG1XNU6aGAJ0cI78mvbm8L\r\n-----END RSA PRIVATE KEY-----\r\n",
      "defaultPublic": "-----BEGIN CERTIFICATE-----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\r\nSYj6sP0IU2F3Gr3yMbYJAAHWsSagmHaLCViVXwwFDvQjLsZynHgBsZf0\r\n-----END CERTIFICATE-----\r\n"
    Update certificate defaultPrivate
    The object "system.certificates" was updated successfully.
    Update certificate defaultPublic
    > @root/acme@3.1.0 postinstall /home/pi/node_modules/@root/acme
    > node scripts/postinstall
    > esbuild@0.11.23 postinstall /home/pi/node_modules/esbuild
    > node install.js
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN pi@1.0.0 No description
    npm WARN pi@1.0.0 No repository field.
    + iobroker.js-controller@4.0.23
    added 312 packages from 288 contributors, removed 1 package and audited 313 packages in 85.481s
    18 packages are looking for funding
      run `npm fund` for details
    found 8 vulnerabilities (3 low, 2 moderate, 3 high)
      run `npm audit fix` to fix them, or `npm audit` for details
    thanks
    HomoranH Thomas BraunT 3 Antworten Letzte Antwort
    • T Tiger
      pi@raspberrypi:~ $
      armv7l
      /usr/bin/nodejs
      /usr/local/bin/node
      /usr/local/bin/npm
      v10.24.1
      v14.20.0
      6.14.17
      pi
      /home/pi
      > node-gyp rebuild
      > node rebuild.js
      > node-gyp rebuild
      > node install.js
      thanks
      @tiger please use code-tags for the log
      • T Tiger
        pi@raspberrypi:~ $
        armv7l
        /usr/bin/nodejs
        /usr/local/bin/node
        /usr/local/bin/npm
        v10.24.1
        v14.20.0
        6.14.17
        pi
        /home/pi
        > node-gyp rebuild
        > node rebuild.js
        > node-gyp rebuild
        > node install.js
        thanks
        @tiger sagte in Update System iobroker failed:
        /usr/bin/nodejs
        /usr/local/bin/node
        /usr/local/bin/npm
        v10.24.1
        v14.20.0
        nodejs is not installed correctly.
        Can you understand German?
        Here is an extended guide on how to fix it:
        https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
        BTW: Still a wrong directory:
        You need to stand in /opt/iobroker for any operations with npm.
        Using npm is not recommended anyway. For this exakt reason.
        But first fix your nodejs-Installation.
        T 2 Antworten Letzte Antwort
          /usr/bin/nodejs
          /usr/local/bin/node
          /usr/local/bin/npm
          v10.24.1
          v14.20.0
          Tiger
          I do not understand german, but will try with google traductor... :)
          I come back after :)
          • T Tiger
            pi@raspberrypi:~ $
            armv7l
            /usr/bin/nodejs
            /usr/local/bin/node
            /usr/local/bin/npm
            v10.24.1
            v14.20.0
            6.14.17
            pi
            /home/pi
            > node-gyp rebuild
            > node rebuild.js
            > node-gyp rebuild
            > node install.js
            thanks
            this command is executed in the pi's home instead of /opt/iobroker
            • T Tiger
              in other languages f.i. french it will be worse for us
                /usr/bin/nodejs
                /usr/local/bin/node
                /usr/local/bin/npm
                v10.24.1
                v14.20.0
                Tiger
                I'm trying to fix with your guide, but to complicate for me.
                AS I'm a newbee and so I don't understand what I'm doing, so it's difficult.
                I've a backup of my Sd Card.
                If I use this backup and retry to upgrade my system,
                do you have a guide with all steps to do?
                When try to update Iobroker.Admin, tells me that Node.JS 10 is not goof and I've to upgrade to V16, when made, I try to upgrade system, and another adapter has to be upgraded but the version of Node.JS V16 was not good for it and should be not more than V14...
                So if you've a guide, it should be more easy for a stupid guy like me
                  Tiger
                  @homoran I completely agree, that's why I'm trying to explain in English :)
                  • T Tiger
                    @tiger dou you have a backup of your iobroker installation?
                    done by backitup or iobroker backup?
                    then i would recommend to install all brandnew, best on a new SD card, so you'll still have the old one, and restore your backup to the new installation.
                    All will be built anew
                    T crunchipC 2 Antworten Letzte Antwort
                      Tiger
                      Yes I've two backup in fact
                      • 1 made thanks to win32 image disc, so I've my image of yestarday
                        -1 made thanks to iobroker backup
                      My idea was to copy the imagedisc of yestarday and retry to upgrade thanks to a guide, and with the correct order of different upgrade
                        crunchipC Abwesend
                        crunchipC Abwesend
                        @homoran and install vis before backup if vis is used
                        • T Tiger
                          win32 image disc,
                          this contains all the broken stuff.
                          not recommended!
                          what adapters did you install?
                          iobroker update -i
                          • T Tiger
                            @tiger
                            First action:
                            iobroker stop
                            sudo apt update
                            sudo apt full-upgrade
                            sudo reboot
                            Please post the output of
                            sudo apt update
                              @crunchip sagte in Update System iobroker failed:
                              Restore
                                win32 image disc,
                                not recommended!
                                iobroker update -i
                                Tiger
                                to be honest yestarday I tried to upgrade and was in same situation as now, so I took the imagedisc and works as before.
                                Adapters installed and needed was :
                                • Siemens S7 adapter
                                • Zigbee
                                • Rfxcom
                                • History
                                iobroker update -i gives error too
                                internal/modules/cjs/loader.js:905
                                throw err;
                                Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
                                at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                                at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
                                at internal/main/run_main_module.js:17:47 {
                                code: 'MODULE_NOT_FOUND',
                                requireStack: []
                                • Thomas BraunT Online
                                  @tiger
                                  Will you try to setup nodejs the proper way or trying around with your backups (which are most propably based on a wrong installation)
                                  • T Tiger
                                    • Zigbee
                                    • Rfxcom
                                    • History
                                    throw err;
                                    requireStack: []
                                    History
                                    in the regular iobroker backup the history won't be included.
                                    You have to save the directory /opt/iobroker/iobroker-data/history by yourself
                                      @tiger
                                      Tiger
                                      actually I'm trying your command, it's in progress.
                                      It should be better to re install everything... to have a proper installation up to date...
                                      But as you have notice, installation part is not my favorite things, I'm afroid to lost all my domotics and all i've already done with Alexa, Node red etc...
                                      Moreover, as I used the commande : iobroker backup, and I don't see the backup in /opt/iobroker... not sure I've the backup...
                                      regards
                                        @tiger
                                        So what is the output to
                                        sudo apt update
                                        then?
                                          @tiger
                                          sudo apt update
                                          then?
                                          Tiger
                                          command : sudo apt full-upgrade took time
                                          progress is 13% since some minutes
                                          Unpacking wolfram-engine (12.2.0+2021041101) over (12.0.1+2019062401) ...
                                          Progress: [ 13%] [#######...................................................]
