  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
    @tiger sagte in Update System iobroker failed:
    /usr/bin/nodejs
    /usr/local/bin/node
    /usr/local/bin/npm
    v10.24.1
    v14.20.0
    nodejs is not installed correctly.
    Can you understand German?
    Here is an extended guide on how to fix it:
    https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
    BTW: Still a wrong directory:
    pi@raspberrypi:~ $ npm install iobroker.js-controller
    You need to stand in /opt/iobroker for any operations with npm.
    Using npm is not recommended anyway. For this exakt reason.
    But first fix your nodejs-Installation.
    Tiger
    I'm trying to fix with your guide, but to complicate for me.
    AS I'm a newbee and so I don't understand what I'm doing, so it's difficult.
    I've a backup of my Sd Card.
    If I use this backup and retry to upgrade my system,
    do you have a guide with all steps to do?
    When try to update Iobroker.Admin, tells me that Node.JS 10 is not goof and I've to upgrade to V16, when made, I try to upgrade system, and another adapter has to be upgraded but the version of Node.JS V16 was not good for it and should be not more than V14...
    So if you've a guide, it should be more easy for a stupid guy like me
      I do not understand german
      in other languages f.i. french it will be worse for us
      Tiger
      @homoran I completely agree, that's why I'm trying to explain in English :)
      • T Tiger
        @tiger dou you have a backup of your iobroker installation?
        done by backitup or iobroker backup?
        then i would recommend to install all brandnew, best on a new SD card, so you'll still have the old one, and restore your backup to the new installation.
        All will be built anew
        T crunchipC 2 Antworten Letzte Antwort
          Tiger
          Yes I've two backup in fact
          • 1 made thanks to win32 image disc, so I've my image of yestarday
            -1 made thanks to iobroker backup
          My idea was to copy the imagedisc of yestarday and retry to upgrade thanks to a guide, and with the correct order of different upgrade
            crunchipC Abwesend
            crunchipC Abwesend
            @homoran and install vis before backup if vis is used
            • T Tiger
              win32 image disc,
              this contains all the broken stuff.
              not recommended!
              what adapters did you install?
              iobroker update -i
              • T Tiger
                @tiger
                First action:
                iobroker stop
                sudo apt update
                sudo apt full-upgrade
                sudo reboot
                Please post the output of
                sudo apt update
                  @crunchip sagte in Update System iobroker failed:
                  Restore
                    win32 image disc,
                    not recommended!
                    iobroker update -i
                    Tiger
                    to be honest yestarday I tried to upgrade and was in same situation as now, so I took the imagedisc and works as before.
                    Adapters installed and needed was :
                    • Siemens S7 adapter
                    • Zigbee
                    • Rfxcom
                    • History
                    iobroker update -i gives error too
                    internal/modules/cjs/loader.js:905
                    throw err;
                    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
                    at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
                    at internal/main/run_main_module.js:17:47 {
                    code: 'MODULE_NOT_FOUND',
                    requireStack: []
                    • Thomas BraunT Online
                      @tiger
                      Will you try to setup nodejs the proper way or trying around with your backups (which are most propably based on a wrong installation)
                      • T Tiger
                        • Zigbee
                        • Rfxcom
                        • History
                        throw err;
                        requireStack: []
                        History
                        in the regular iobroker backup the history won't be included.
                        You have to save the directory /opt/iobroker/iobroker-data/history by yourself
                          @tiger
                          Tiger
                          actually I'm trying your command, it's in progress.
                          It should be better to re install everything... to have a proper installation up to date...
                          But as you have notice, installation part is not my favorite things, I'm afroid to lost all my domotics and all i've already done with Alexa, Node red etc...
                          Moreover, as I used the commande : iobroker backup, and I don't see the backup in /opt/iobroker... not sure I've the backup...
                          regards
                            @tiger
                            So what is the output to
                            sudo apt update
                            then?
                              @tiger
                              sudo apt update
                              then?
                              Tiger
                              command : sudo apt full-upgrade took time
                              progress is 13% since some minutes
                              Unpacking wolfram-engine (12.2.0+2021041101) over (12.0.1+2019062401) ...
                              Progress: [ 13%] [#######...................................................]
                              • T Tiger
                                @tiger
                                Then you never did update your system before.
                                And you are running the Desktop-Variant. Both is a no-go.
                                  @tiger
                                  Tiger
                                  Once everything was working.. i Didn't made any update...
                                  Now It's because I would like to add some functionnality as Smappee on my Vis...
                                  I need it.
                                  or I will continue like that with old version and will continue to work as before :)
                                  Whatever, thanks to all for your help.
                                  progress is 48%
                                  • T Tiger
                                    I need it.
                                    progress is 48%
                                    don't even think about this.
                                    the day will come and you have to update an adapter you need.
                                    due to the 'never change a running system' approach, now you are in trouble.
                                    And then you'll be in big trouble for sure.
                                    Please keep your system up to date always. for security and convenience
                                      @tiger
                                      sudo apt update
                                      then?
                                      Tiger
                                      so, here the result
                                      pi@raspberrypi:~ $ sudo apt update
                                      Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                      Hit:2 https://deb.nodesource.com/node_10.x buster InRelease
                                      Hit:3 http://archive.raspberrypi.org/debian buster InRelease
                                      Reading package lists... Done
                                      Building dependency tree
                                      All packages are up to date.
                                      • T Tiger
                                        I need it.
                                        progress is 48%
                                        I'm not sure if it makes any sense to help you with that attitude...
                                        Once again:
                                        uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                          Once again:
                                          Tiger
                                          schrieb am zuletzt editiert von Tiger
                                          I understand you, but I would like to be up to date and continue, it's just because i dont like to not understand everything and take time of other poeple ;)
                                          That's why I thank you for all.
                                          pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                          armv7l
                                          /usr/bin/nodejs
                                          /usr/local/bin/node
                                          /usr/local/bin/npm
                                          v10.24.1
                                          v14.20.0
                                          6.14.17
                                          pi
                                          /home/pi
                                          Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                                          Hit:3 https://deb.nodesource.com/node_10.x buster InRelease
                                          nodejs:
                                            Installed: 10.24.1-1nodesource1
                                            Candidate: 10.24.1-1nodesource1
                                            Version table:
                                           *** 10.24.1-1nodesource1 500
                                                  500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
                                               10.24.0~dfsg-1~deb10u1 500
