Update System iobroker failed
Dear All,
this morning I would like to upgrade my IOBROKER.ADMIN as I was in version 4
So I've upgrade node.js to V14.20.0,
I've tried to upgrade js-controller with command
iobroker upgrade selfafter that... nothing was working... i tried lots of things from Forum and now I've already the same error message...
when put command : iobroker updatepi@raspberrypi:/ $ iobroker upadte
internal/modules/cjs/loader.js:905
throw err;
^Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
at Function.Module._load (internal/modules/cjs/loader.js:746:27)
at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
at internal/main/run_main_module.js:17:47 {
code: 'MODULE_NOT_FOUND',
requireStack: []
}I tried
npm install iobroker.js-controller
pi@raspberrypi:/ $ npm install iobroker.js-controller
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
npm WARN checkPermissions Missing write access to /
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
npm WARN enoent ENOENT: no such file or directory, open '/package.json'
npm WARN !invalid#1 No description
npm WARN !invalid#1 No repository field.
npm WARN !invalid#1 No README data
npm WARN !invalid#1 No license field.npm ERR! code EACCES
npm ERR! syscall access
npm ERR! path /
npm ERR! errno -13
npm ERR! Error: EACCES: permission denied, access '/'
npm ERR! [Error: EACCES: permission denied, access '/'] {
npm ERR! errno: -13,
npm ERR! code: 'EACCES',
npm ERR! syscall: 'access',
npm ERR! path: '/'
npm ERR! }
npm ERR!
npm ERR! The operation was rejected by your operating system.
npm ERR! It is likely you do not have the permissions to access this file as the current user
npm ERR!
npm ERR! If you believe this might be a permissions issue, please double-check the
npm ERR! permissions of the file and its containing directories, or try running
npm ERR! the command again as root/Administrator.npm ERR! A complete log of this run can be found in:
npm ERR! /home/pi/.npm/_logs/2022-08-15T11_51_26_878Z-debug.log
2022-08-15T11_51_26_878Z-debug.logversion are
NPM -v : 6.14.17
node -v : 14.20.0Thanks for your help for a beginner...
Regards
What is the current situation?
Check:sudo ln -s /usr/bin/node /usr/bin/nodejs uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejsYou are standig in the wrong directroy with the wrong command:
npm install iobroker.js-controller pi@raspberrypi:/ $ npm install iobroker.js-controller -
npm install iobroker.js-controller pi@raspberrypi:/ $ npm install iobroker.js-controller@thomas-braun
This is what I've when checking :pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs ln: failed to create symbolic link '/usr/bin/nodejs': File exists pi@raspberrypi:~ $ pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs armv7l /usr/bin/nodejs /usr/local/bin/node /usr/local/bin/npm v10.24.1 v14.20.0 6.14.17 pi /home/pii'd retied in the correct folder (hoping it is the good one ;)
with the lfollowing messages :pi@raspberrypi:~ $ npm install iobroker.js-controller npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142 npm WARN deprecated har-validator@5.1.5: this library is no longer supported npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details. > iobroker.js-controller@4.0.23 preinstall /home/pi/node_modules/iobroker.js-controller > node lib/preinstallCheck.js NPM version: 6.14.17 > unix-dgram@2.0.4 install /home/pi/node_modules/unix-dgram > node-gyp rebuild make: Entering directory '/home/pi/node_modules/unix-dgram/build' CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o In file included from ../../nan/nan.h:60, from ../src/unix_dgram.cc:5: /home/pi/.cache/node-gyp/14.20.0/include/node/node.h:793:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^ /home/pi/.cache/node-gyp/14.20.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~ ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(unix_dgram, Initialize) ^~~~~~~~~~~ SOLINK_MODULE(target) Release/obj.target/unix_dgram.node COPY Release/unix_dgram.node make: Leaving directory '/home/pi/node_modules/unix-dgram/build' > ursa-optional@0.9.10 install /home/pi/node_modules/ursa-optional > node rebuild.js ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks. > diskusage@1.1.3 install /home/pi/node_modules/diskusage > node-gyp rebuild make: Entering directory '/home/pi/node_modules/diskusage/build' CXX(target) Release/obj.target/diskusage/src/main.o In file included from ../../nan/nan.h:60, from ../src/main.cpp:3: /home/pi/.cache/node-gyp/14.20.0/include/node/node.h:793:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^ /home/pi/.cache/node-gyp/14.20.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~ ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(diskusage, Init) ^~~~~~~~~~~ CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o SOLINK_MODULE(target) Release/obj.target/diskusage.node COPY Release/diskusage.node make: Leaving directory '/home/pi/node_modules/diskusage/build' > iobroker.js-controller@4.0.23 install /home/pi/node_modules/iobroker.js-controller > node iobroker.js setup first Successfully migrated 2282 objects to Redis Sets object _design/system updated { "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----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\r\nLQrsTuqtxiZzoneLoSuOcEsYGIB8TMHG1XNU6aGAJ0cI78mvbm8L\r\n-----END RSA PRIVATE KEY-----\r\n", "defaultPublic": "-----BEGIN CERTIFICATE-----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\r\nSYj6sP0IU2F3Gr3yMbYJAAHWsSagmHaLCViVXwwFDvQjLsZynHgBsZf0\r\n-----END CERTIFICATE-----\r\n" } Update certificate defaultPrivate The object "system.certificates" was updated successfully. Update certificate defaultPublic The object "system.certificates" was updated successfully. > @root/acme@3.1.0 postinstall /home/pi/node_modules/@root/acme > node scripts/postinstall > esbuild@0.11.23 postinstall /home/pi/node_modules/esbuild > node install.js npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}) npm WARN pi@1.0.0 No description npm WARN pi@1.0.0 No repository field. + iobroker.js-controller@4.0.23 added 312 packages from 288 contributors, removed 1 package and audited 313 packages in 85.481s 18 packages are looking for funding run `npm fund` for details found 8 vulnerabilities (3 low, 2 moderate, 3 high) run `npm audit fix` to fix them, or `npm audit` for detailsthanks
@tiger sagte in Update System iobroker failed:
/usr/bin/nodejs
/usr/local/bin/node
/usr/local/bin/npm
v10.24.1
v14.20.0nodejs is not installed correctly.
Can you understand German?
Here is an extended guide on how to fix it:https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
BTW: Still a wrong directory:
pi@raspberrypi:~ $ npm install iobroker.js-controllerYou need to stand in /opt/iobroker for any operations with npm.
Using npm is not recommended anyway. For this exakt reason.But first fix your nodejs-Installation.
/usr/bin/nodejs
/usr/local/bin/node
/usr/local/bin/npm
v10.24.1
I do not understand german, but will try with google traductor... :)
I come back after :) -
/usr/bin/nodejs
/usr/local/bin/node
/usr/local/bin/npm
v10.24.1
I'm trying to fix with your guide, but to complicate for me.
AS I'm a newbee and so I don't understand what I'm doing, so it's difficult.I've a backup of my Sd Card.
If I use this backup and retry to upgrade my system,
do you have a guide with all steps to do?When try to update Iobroker.Admin, tells me that Node.JS 10 is not goof and I've to upgrade to V16, when made, I try to upgrade system, and another adapter has to be upgraded but the version of Node.JS V16 was not good for it and should be not more than V14...
So if you've a guide, it should be more easy for a stupid guy like me
in other languages f.i. french it will be worse for us
@tiger dou you have a backup of your iobroker installation?
done by backitup oriobroker backup?then i would recommend to install all brandnew, best on a new SD card, so you'll still have the old one, and restore your backup to the new installation.
All will be built anew -
All will be built anew@homoran
Yes I've two backup in fact- 1 made thanks to win32 image disc, so I've my image of yestarday
-1 made thanks to iobroker backup
My idea was to copy the imagedisc of yestarday and retry to upgrade thanks to a guide, and with the correct order of different upgrade
All will be built anew@homoran and install vis before backup if vis is used
First action:
iobroker stop sudo apt update sudo apt full-upgrade sudo rebootPlease post the output of
sudo apt update - 1 made thanks to win32 image disc, so I've my image of yestarday
win32 image disc,
this contains all the broken stuff.
not recommended!what adapters did you install?
iobroker update -i@homoran
to be honest yestarday I tried to upgrade and was in same situation as now, so I took the imagedisc and works as before.Adapters installed and needed was :
- Siemens S7 adapter
- Zigbee
- Rfxcom
- History
iobroker update -i gives error too
throw err;
requireStack: []
Will you try to setup nodejs the proper way or trying around with your backups (which are most propably based on a wrong installation)
- Zigbee
- Rfxcom
- History
throw err;
requireStack: []
actually I'm trying your command, it's in progress.
It should be better to re install everything... to have a proper installation up to date...But as you have notice, installation part is not my favorite things, I'm afroid to lost all my domotics and all i've already done with Alexa, Node red etc...
Moreover, as I used the commande : iobroker backup, and I don't see the backup in /opt/iobroker... not sure I've the backup...
regards
