  2. English
  3. ioBroker general
  4. Update System iobroker failed
    apollon77A
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 44.2k Aufrufe 5 Beobachtet
  • T Tiger
    Yes I've two backup in fact
    • 1 made thanks to win32 image disc, so I've my image of yestarday
      -1 made thanks to iobroker backup
    My idea was to copy the imagedisc of yestarday and retry to upgrade thanks to a guide, and with the correct order of different upgrade
    @tiger sagte in Update System iobroker failed:
    win32 image disc,
    this contains all the broken stuff.
    not recommended!
    what adapters did you install?
    iobroker update -i
    • T Tiger
      Thomas BraunT
      Thomas BraunT
      Most Active Developer
      @tiger
      First action:
      iobroker stop
      sudo apt update
      sudo apt full-upgrade
      sudo reboot
      Please post the output of
      sudo apt update
        @homoran and install vis before backup if vis is used
        @crunchip sagte in Update System iobroker failed:
        Restore
          win32 image disc,
          not recommended!
          iobroker update -i
          T
          T
          Tiger
          to be honest yestarday I tried to upgrade and was in same situation as now, so I took the imagedisc and works as before.
          Adapters installed and needed was :
          • Siemens S7 adapter
          • Zigbee
          • Rfxcom
          • History
          iobroker update -i gives error too
          internal/modules/cjs/loader.js:905
          throw err;
          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
          at Function.Module._load (internal/modules/cjs/loader.js:746:27)
          at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
          at internal/main/run_main_module.js:17:47 {
          code: 'MODULE_NOT_FOUND',
          requireStack: []
          • Thomas BraunT
            Thomas BraunT
            @tiger
            Will you try to setup nodejs the proper way or trying around with your backups (which are most propably based on a wrong installation)
            • T Tiger
              • Zigbee
              • Rfxcom
              • History
              throw err;
              requireStack: []
              History
              in the regular iobroker backup the history won't be included.
              You have to save the directory /opt/iobroker/iobroker-data/history by yourself
                @tiger
                T
                T
                Tiger
                actually I'm trying your command, it's in progress.
                It should be better to re install everything... to have a proper installation up to date...
                But as you have notice, installation part is not my favorite things, I'm afroid to lost all my domotics and all i've already done with Alexa, Node red etc...
                Moreover, as I used the commande : iobroker backup, and I don't see the backup in /opt/iobroker... not sure I've the backup...
                regards
                • Thomas BraunT
                  Thomas BraunT
                  @tiger
                  So what is the output to
                  sudo apt update
                  then?
                  T 2 Antworten Letzte Antwort
                    @tiger
                    sudo apt update
                    then?
                    T
                    T
                    Tiger
                    command : sudo apt full-upgrade took time
                    progress is 13% since some minutes
                    Unpacking wolfram-engine (12.2.0+2021041101) over (12.0.1+2019062401) ...
                    Progress: [ 13%] [#######...................................................]
                    • T Tiger
                      Thomas BraunT
                      Thomas BraunT
                      @tiger
                      Then you never did update your system before.
                      And you are running the Desktop-Variant. Both is a no-go.
                        @tiger
                        T
                        T
                        Tiger
                        Once everything was working.. i Didn't made any update...
                        Now It's because I would like to add some functionnality as Smappee on my Vis...
                        I need it.
                        or I will continue like that with old version and will continue to work as before :)
                        Whatever, thanks to all for your help.
                        progress is 48%
                        • T Tiger
                          I need it.
                          progress is 48%
                          don't even think about this.
                          the day will come and you have to update an adapter you need.
                          due to the 'never change a running system' approach, now you are in trouble.
                          And then you'll be in big trouble for sure.
                          Please keep your system up to date always. for security and convenience
                            @tiger
                            sudo apt update
                            then?
                            T
                            T
                            Tiger
                            so, here the result
                            pi@raspberrypi:~ $ sudo apt update
                            Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                            Hit:2 https://deb.nodesource.com/node_10.x buster InRelease
                            Hit:3 http://archive.raspberrypi.org/debian buster InRelease
                            Reading package lists... Done
                            Building dependency tree
                            All packages are up to date.
                            • T Tiger
                              I need it.
                              progress is 48%
                              Thomas BraunT
                              Thomas BraunT
                              I'm not sure if it makes any sense to help you with that attitude...
                              Once again:
                              uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                Once again:
                                T
                                T
                                Tiger
                                schrieb am zuletzt editiert von Tiger
                                I understand you, but I would like to be up to date and continue, it's just because i dont like to not understand everything and take time of other poeple ;)
                                That's why I thank you for all.
                                pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                armv7l
                                /usr/bin/nodejs
                                /usr/local/bin/node
                                /usr/local/bin/npm
                                v10.24.1
                                v14.20.0
                                6.14.17
                                pi
                                /home/pi
                                Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                                Hit:3 https://deb.nodesource.com/node_10.x buster InRelease
                                nodejs:
                                  Installed: 10.24.1-1nodesource1
                                  Candidate: 10.24.1-1nodesource1
                                  Version table:
                                 *** 10.24.1-1nodesource1 500
                                        500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
                                     10.24.0~dfsg-1~deb10u1 500
                                • T Tiger
                                  armv7l
                                  /usr/bin/nodejs
                                  /usr/local/bin/node
                                  /usr/local/bin/npm
                                  v10.24.1
                                  v14.20.0
                                  6.14.17
                                  pi
                                  /home/pi
                                  nodejs:
                                    Version table:
                                  that's a good point of view
                                  so we will work on it, making you to understand it
                                  that's our decision! hoping you learn something and possible give this to others
                                  • T Tiger
                                    armv7l
                                    /usr/bin/nodejs
                                    /usr/local/bin/node
                                    /usr/local/bin/npm
                                    v10.24.1
                                    v14.20.0
                                    6.14.17
                                    pi
                                    /home/pi
                                    nodejs:
                                      Version table:
                                    Thomas BraunT
                                    Thomas BraunT
                                    sudo rm /usr/local/bin/node
                                    sudo rm /usr/local/bin/npm
                                    curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
                                    sudo apt install nodejs
                                      T
                                      T
                                      Tiger
                                      Thanks, like to see that.
                                        T
                                        T
                                        Tiger
                                        @thomas-braun said in Update System iobroker failed:
                                        You'll find here after all I've done
                                        pi@raspberrypi:~ $ sudo rm /usr/local/bin/node
                                        pi@raspberrypi:~ $ sudo rm /usr/local/bin/npm
                                        pi@raspberrypi:~ $ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
                                        ## Installing the NodeSource Node.js 16.x repo...
                                        ## Populating apt-get cache...
                                        + apt-get update
                                        ## Confirming "buster" is supported...
                                        + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_16.x/dists/buster/Release'
                                        ## Adding the NodeSource signing key to your keyring...
                                        + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
                                        gpg: WARNING: unsafe ownership on homedir '/home/pi/.gnupg'
                                        ## Creating apt sources list file for the NodeSource Node.js 16.x repo...
                                        + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' > /etc/apt/sources.list.d/nodesource.list
                                        + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' >> /etc/apt/sources.list.d/nodesource.list
                                        ## Running `apt-get update` for you...
                                        + apt-get update
                                        Get:3 https://deb.nodesource.com/node_16.x buster InRelease [4,584 B]
                                        Get:4 https://deb.nodesource.com/node_16.x buster/main armhf Packages [782 B]
                                        Fetched 5,366 B in 1s (3,599 B/s)
                                        ## Run `sudo apt-get install -y nodejs` to install Node.js 16.x and npm
                                        ## You may also need development tools to build native addons:
                                             sudo apt-get install gcc g++ make
                                        ## To install the Yarn package manager, run:
                                             curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
                                             echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                                             sudo apt-get update && sudo apt-get install yarn
                                        pi@raspberrypi:~ $ sudo apt install nodejs
                                        The following packages were automatically installed and are no longer required:
                                          gconf-service gconf2-common libbluetooth3 libexiv2-14 libgconf-2-4 libgfortran3 libgmime-2.6-0
                                          libncurses5 lxplug-volume python-colorzero
                                        Use 'sudo apt autoremove' to remove them.
                                        The following packages will be upgraded:
                                          nodejs
                                        1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                        Need to get 23.6 MB of archives.
                                        After this operation, 38.8 MB of additional disk space will be used.
                                        Get:1 https://deb.nodesource.com/node_16.x buster/main armhf nodejs armhf 16.16.0-deb-1nodesource1 [23.6 MB]
                                        Fetched 23.6 MB in 1min 14s (318 kB/s)
                                        Reading changelogs... Done
                                        (Reading database ... 167450 files and directories currently installed.)
                                        Preparing to unpack .../nodejs_16.16.0-deb-1nodesource1_armhf.deb ...
                                        Unpacking nodejs (16.16.0-deb-1nodesource1) over (10.24.1-1nodesource1) ...
                                        Setting up nodejs (16.16.0-deb-1nodesource1) ...
                                        Processing triggers for man-db (2.8.5-2) ...
                                        pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                                        ln: failed to create symbolic link '/usr/bin/nodejs': File exists
                                        • T Tiger
                                          + apt-get update
                                          + apt-get update
                                            nodejs
                                          Thomas BraunT
                                          Thomas BraunT
                                          sudo apt autoremove
                                          iobroker restart
                                          iobroker status
                                          84.0k
