  2. English
  3. ioBroker general
  4. Update System iobroker failed
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 45.2k Aufrufe 5 Beobachtet
  • T Tiger
    Yes I've two backup in fact
    • 1 made thanks to win32 image disc, so I've my image of yestarday
      -1 made thanks to iobroker backup
    My idea was to copy the imagedisc of yestarday and retry to upgrade thanks to a guide, and with the correct order of different upgrade
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    @tiger
    First action:
    iobroker stop
    sudo apt update
    sudo apt full-upgrade
    sudo reboot
    Please post the output of
    sudo apt update
      @homoran and install vis before backup if vis is used
      @crunchip sagte in Update System iobroker failed:
      Restore
        @tiger sagte in Update System iobroker failed:
        win32 image disc,
        this contains all the broken stuff.
        not recommended!
        what adapters did you install?
        iobroker update -i
        T
        T
        Tiger
        to be honest yestarday I tried to upgrade and was in same situation as now, so I took the imagedisc and works as before.
        Adapters installed and needed was :
        • Siemens S7 adapter
        • Zigbee
        • Rfxcom
        • History
        iobroker update -i gives error too
        internal/modules/cjs/loader.js:905
        throw err;
        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
        at Function.Module._load (internal/modules/cjs/loader.js:746:27)
        at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
        at internal/main/run_main_module.js:17:47 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
        • Thomas BraunT
          Thomas BraunT
          @tiger
          Will you try to setup nodejs the proper way or trying around with your backups (which are most propably based on a wrong installation)
          • T Tiger
            • Zigbee
            • Rfxcom
            • History
            throw err;
            requireStack: []
            History
            in the regular iobroker backup the history won't be included.
            You have to save the directory /opt/iobroker/iobroker-data/history by yourself
              @tiger
              T
              T
              Tiger
              actually I'm trying your command, it's in progress.
              It should be better to re install everything... to have a proper installation up to date...
              But as you have notice, installation part is not my favorite things, I'm afroid to lost all my domotics and all i've already done with Alexa, Node red etc...
              Moreover, as I used the commande : iobroker backup, and I don't see the backup in /opt/iobroker... not sure I've the backup...
              regards
              • Thomas BraunT
                Thomas BraunT
                @tiger
                So what is the output to
                sudo apt update
                then?
                T 2 Antworten Letzte Antwort
                  @tiger
                  sudo apt update
                  then?
                  T
                  T
                  Tiger
                  command : sudo apt full-upgrade took time
                  progress is 13% since some minutes
                  Unpacking wolfram-engine (12.2.0+2021041101) over (12.0.1+2019062401) ...
                  Progress: [ 13%] [#######...................................................]
                  • T Tiger
                    Thomas BraunT
                    Thomas BraunT
                    @tiger
                    Then you never did update your system before.
                    And you are running the Desktop-Variant. Both is a no-go.
                      @tiger
                      T
                      T
                      Tiger
                      Once everything was working.. i Didn't made any update...
                      Now It's because I would like to add some functionnality as Smappee on my Vis...
                      I need it.
                      or I will continue like that with old version and will continue to work as before :)
                      Whatever, thanks to all for your help.
                      progress is 48%
                      • T Tiger
                        I need it.
                        progress is 48%
                        don't even think about this.
                        the day will come and you have to update an adapter you need.
                        due to the 'never change a running system' approach, now you are in trouble.
                        And then you'll be in big trouble for sure.
                        Please keep your system up to date always. for security and convenience
                          @tiger
                          sudo apt update
                          then?
                          T
                          T
                          Tiger
                          so, here the result
                          pi@raspberrypi:~ $ sudo apt update
                          Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                          Hit:2 https://deb.nodesource.com/node_10.x buster InRelease
                          Hit:3 http://archive.raspberrypi.org/debian buster InRelease
                          Reading package lists... Done
                          Building dependency tree
                          All packages are up to date.
                          • T Tiger
                            I need it.
                            progress is 48%
                            Thomas BraunT
                            Thomas BraunT
                            I'm not sure if it makes any sense to help you with that attitude...
                            Once again:
                            uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                              Once again:
                              T
                              T
                              Tiger
                              schrieb am zuletzt editiert von Tiger
                              I understand you, but I would like to be up to date and continue, it's just because i dont like to not understand everything and take time of other poeple ;)
                              That's why I thank you for all.
                              pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                              armv7l
                              /usr/bin/nodejs
                              /usr/local/bin/node
                              /usr/local/bin/npm
                              v10.24.1
                              v14.20.0
                              6.14.17
                              pi
                              /home/pi
                              Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                              Hit:3 https://deb.nodesource.com/node_10.x buster InRelease
                              nodejs:
                                Installed: 10.24.1-1nodesource1
                                Candidate: 10.24.1-1nodesource1
                                Version table:
                               *** 10.24.1-1nodesource1 500
                                      500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
                                   10.24.0~dfsg-1~deb10u1 500
                              • T Tiger
                                armv7l
                                /usr/bin/nodejs
                                /usr/local/bin/node
                                /usr/local/bin/npm
                                v10.24.1
                                v14.20.0
                                6.14.17
                                pi
                                /home/pi
                                nodejs:
                                  Version table:
                                that's a good point of view
                                so we will work on it, making you to understand it
                                that's our decision! hoping you learn something and possible give this to others
                                • T Tiger
                                  armv7l
                                  /usr/bin/nodejs
                                  /usr/local/bin/node
                                  /usr/local/bin/npm
                                  v10.24.1
                                  v14.20.0
                                  6.14.17
                                  pi
                                  /home/pi
                                  nodejs:
                                    Version table:
                                  Thomas BraunT
                                  Thomas BraunT
                                  sudo rm /usr/local/bin/node
                                  sudo rm /usr/local/bin/npm
                                  curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
                                  sudo apt install nodejs
                                    T
                                    T
                                    Tiger
                                    Thanks, like to see that.
                                      T
                                      T
                                      Tiger
                                      @thomas-braun said in Update System iobroker failed:
                                      You'll find here after all I've done
                                      pi@raspberrypi:~ $ sudo rm /usr/local/bin/node
                                      pi@raspberrypi:~ $ sudo rm /usr/local/bin/npm
                                      pi@raspberrypi:~ $ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
                                      ## Installing the NodeSource Node.js 16.x repo...
                                      ## Populating apt-get cache...
                                      + apt-get update
                                      ## Confirming "buster" is supported...
                                      + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_16.x/dists/buster/Release'
                                      ## Adding the NodeSource signing key to your keyring...
                                      + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
                                      gpg: WARNING: unsafe ownership on homedir '/home/pi/.gnupg'
                                      ## Creating apt sources list file for the NodeSource Node.js 16.x repo...
                                      + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' > /etc/apt/sources.list.d/nodesource.list
                                      + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' >> /etc/apt/sources.list.d/nodesource.list
                                      ## Running `apt-get update` for you...
                                      + apt-get update
                                      Get:3 https://deb.nodesource.com/node_16.x buster InRelease [4,584 B]
                                      Get:4 https://deb.nodesource.com/node_16.x buster/main armhf Packages [782 B]
                                      Fetched 5,366 B in 1s (3,599 B/s)
                                      ## Run `sudo apt-get install -y nodejs` to install Node.js 16.x and npm
                                      ## You may also need development tools to build native addons:
                                           sudo apt-get install gcc g++ make
                                      ## To install the Yarn package manager, run:
                                           curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
                                           echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                                           sudo apt-get update && sudo apt-get install yarn
                                      pi@raspberrypi:~ $ sudo apt install nodejs
                                      The following packages were automatically installed and are no longer required:
                                        gconf-service gconf2-common libbluetooth3 libexiv2-14 libgconf-2-4 libgfortran3 libgmime-2.6-0
                                        libncurses5 lxplug-volume python-colorzero
                                      Use 'sudo apt autoremove' to remove them.
                                      The following packages will be upgraded:
                                        nodejs
                                      1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                      Need to get 23.6 MB of archives.
                                      After this operation, 38.8 MB of additional disk space will be used.
                                      Get:1 https://deb.nodesource.com/node_16.x buster/main armhf nodejs armhf 16.16.0-deb-1nodesource1 [23.6 MB]
                                      Fetched 23.6 MB in 1min 14s (318 kB/s)
                                      Reading changelogs... Done
                                      (Reading database ... 167450 files and directories currently installed.)
                                      Preparing to unpack .../nodejs_16.16.0-deb-1nodesource1_armhf.deb ...
                                      Unpacking nodejs (16.16.0-deb-1nodesource1) over (10.24.1-1nodesource1) ...
                                      Setting up nodejs (16.16.0-deb-1nodesource1) ...
                                      Processing triggers for man-db (2.8.5-2) ...
                                      pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                                      ln: failed to create symbolic link '/usr/bin/nodejs': File exists
                                      • T Tiger
                                        + apt-get update
                                        + apt-get update
                                          nodejs
                                        Thomas BraunT
                                        Thomas BraunT
                                        sudo apt autoremove
                                        iobroker restart
                                        iobroker status
                                          sudo apt autoremove
                                          iobroker restart
                                          iobroker status
                                          T
                                          T
                                          Tiger
                                          pi@raspberrypi:~ $ sudo apt autoremove
                                          The following packages will be REMOVED:
                                          0 upgraded, 0 newly installed, 10 to remove and 0 not upgraded.
                                          After this operation, 11.8 MB disk space will be freed.
                                          Do you want to continue? [Y/n] y
                                          (Reading database ... 165809 files and directories currently installed.)
                                          Removing gconf-service (3.2.6-5) ...
                                          Removing libgconf-2-4:armhf (3.2.6-5) ...
                                          Removing gconf2-common (3.2.6-5) ...
                                          Removing libbluetooth3:armhf (5.50-1.2~deb10u2+rpt1) ...
                                          Removing libexiv2-14:armhf (0.25-4+deb10u2) ...
                                          Removing libgfortran3:armhf (6.5.0-1+rpi1+b1) ...
                                          Removing libgmime-2.6-0:armhf (2.6.23+dfsg1-4) ...
                                          Removing libncurses5:armhf (6.1+20181013-2+deb10u2) ...
                                          Removing lxplug-volume (0.25) ...
                                          Removing python-colorzero (1.1) ...
                                          Processing triggers for sgml-base (1.29) ...
                                          Processing triggers for libc-bin (2.28-10+rpt2+rpi1+deb10u1) ...
                                          pi@raspberrypi:~ $ iobroker restart
                                          pi@raspberrypi:~ $ iobroker status
                                          node:internal/modules/cjs/loader:936
                                            throw err;
                                              at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
                                              at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                                              at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
                                              at node:internal/main/run_main_module:17:47 {
                                            requireStack: []
                                          pi@raspberrypi:~ $
                                          84.1k
