  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
  • mickymM mickym
    @tiger I do not work with authentication. May be you should disable it in the adapter config.
    Tiger
    #161
    @mickym
    ok works without password...strange
    Thanks a lot :)
    • T Tiger
      @Thomas-Braun
      @mickym
      @crunchip
      THanks a lot for your help !
      My system is completely as before but with all update !!! (just the problem of login in node red)
      Last question, to stay up to date, I've only to check if there is update on Iobroker?
      As I don't go very often in the page of iobroker, is it possible to send all the update available via notification on vis?
      Thanks a lot for all!
      #162
      @tiger sagte in Update System iobroker failed:
      as you've learned the last days, you should keep your system up to date.
      so you surely will open puTTY at least all 2 weeks and upgrade the system with
      sudo apt update followed by a sudo apt upgrade
      after finishing upgrading the OS you can upgrade iobroker the same way with iobroker update followed by a iobroker upgrade
      I know, this isn't any new information for you :-)
      How to display existing upgrades in the vis, you should ask in another thread, as I don't know
        Tiger
        #163
        you're right... with PuTTY is more easy...
        Very big THANK YOU.
        • T Tiger
          @Thomas-Braun
          @mickym
          @crunchip
          mickymM Offline
          mickymM Offline
          mickym
          #164
          @tiger For the nodes within Node-Red you need to look to the palette manager. If you use the linux device adapter, you get automatically states where you can see if update packages are available.
          Check Hosts.mp4
