  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
  • T Tiger
    I rename directly in the folder /opt/iobroker the file
    and remade the operation
    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm ERR! code 32
    npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
    npm ERR! command failed
    npm ERR! command sh -c node iobroker.js setup first
    npm ERR! Successfully migrated 2282 objects to Redis Sets
    npm ERR! object _design/system updated
    npm ERR! host.raspberrypi install adapter backitup
    npm ERR! These apt-get packages were already installed: cifs-utils, nfs-common
    npm ERR! upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
    npm ERR! upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
    npm ERR! upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
    npm ERR! upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
    npm ERR! upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
    npm ERR! upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
    npm ERR! upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
    npm ERR! upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
    npm ERR! upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
    npm ERR! upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
    npm ERR! upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
    npm ERR! host.raspberrypi Invalid version of "admin". Installed "4.0.10", required ">=5.2.0"
    npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T14_47_08_695Z-debug-0.log
    log file 2022-08-15T14_47_08_695Z-debug-0.log
    #41
    @tiger
    iobroker list adapters
    iobroker list instances
      @tiger
      Tiger
      #42
      pi@raspberrypi:~ $ iobroker list adapters
      node:internal/modules/cjs/loader:936
        throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
          at Function.Module._load (node:internal/modules/cjs/loader:778:27)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
          at node:internal/main/run_main_module:17:47 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      • T Tiger
          throw err;
          requireStack: []
        #43
        @tiger
        cd /opt/iobroker
        sudo -H -u iobroker npm install ioBroker.admin@5.3.8
          @tiger
          cd /opt/iobroker
          Tiger
          #44
          pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install ioBroker.admin@5.3.8
          npm ERR! code E404
          npm ERR! 404 Not Found - GET https://registry.npmjs.org/ioBroker.admin - Not found
          npm ERR! 404
          npm ERR! 404  'ioBroker.admin@5.3.8' is not in this registry.
          npm ERR! 404 This package name is not valid, because
          npm ERR! 404  1. name can no longer contain capital letters
          npm ERR! 404
          npm ERR! 404 Note that you can also install from a
          npm ERR! 404 tarball, folder, http url, or git url.
          npm ERR!     [2022-08-15T15_04_08_107Z-debug-0.log
          log file2022-08-15T15_04_08_107Z-debug-0.log
          • T Tiger
            npm ERR! code E404
            npm ERR! 404
            npm ERR! 404
            #45
            @tiger
            cd /opt/iobroker
            sudo -H -u iobroker npm install admin@5.3.8
            sudo -H -u iobroker npm install js-controller
              @tiger
              cd /opt/iobroker
              #46
              @thomas-braun sagte in Update System iobroker failed:
              @tiger
              cd /opt/iobroker
              sudo -H -u iobroker npm install .js-controller
              no
              why 404?
              iobroker.admin 5.3.8 is stable
                @tiger
                cd /opt/iobroker
                no
                why 404?
                Tiger
                schrieb am zuletzt editiert von Tiger
                #47
                pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install admin@5.3.8
                npm ERR! code ETARGET
                npm ERR! notarget No matching version found for admin@5.3.8.
                npm ERR! notarget In most cases you or one of your dependencies are requesting
                npm ERR! notarget a package version that doesn't exist.
                npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_11_04_483Z-debug-0.log
                log 2022-08-15T15_11_04_483Z-debug-0.log
                • T Tiger
                  #48
                  @tiger sagte in Update System iobroker failed:
                  expected it
                  there seems to be a typo.
                  i just saw!
                  iobroker.admin not ioBroker.admin
                  messing around on my mobile. didn't see at once. sorry!
                  • T Tiger
                    #49
                    @tiger
                    cd /opt/iobroker
                    sudo -H -u iobroker npm install iobroker.admin@5.3.8
                      @tiger
                      cd /opt/iobroker
                      Tiger
                      #50
                      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.admin@5.3.8
                      npm ERR! code ENOENT
                      npm ERR! syscall chmod
                      npm ERR! path /opt/iobroker/node_modules/request/node_modules/uuid/bin/uuid
                      npm ERR! errno -2
                      npm ERR! enoent ENOENT: no such file or directory, chmod '/opt/iobroker/node_modules/request/node_modules/uuid/bin/uuid'
                      npm ERR! enoent This is related to npm not being able to find a file.
                      npm ERR! enoent
                      npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_15_37_253Z-debug-0.log
                      log 2022-08-15T15_15_37_253Z-debug-0.log
                      • T Tiger
                        npm ERR! errno -2
                        npm ERR! enoent
                        #51
                        @tiger
                        cd /opt/iobroker
                          @tiger
                          cd /opt/iobroker
                          Tiger
                          #52
                          @thomas-braun said in Update System iobroker failed:
                          Sorry I made step by step, and if I see some errors I prefer to wait
                          here the result
                          npm ERR! code 32
                          npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_27_12_327Z-debug-0.log
                          log2022-08-15T15_27_12_327Z-debug-0.log
                          • T Tiger
                            here the result
                            npm ERR! code 32
                            #53
                            thats ok!
                            but I'm confused.
                            you twice installed 5.3.8 but it seems still not to be installed
                            • T Tiger
                              here the result
                              npm ERR! code 32
                              #54
                              @tiger
                              curl -fsL https://iobroker.net/fix.sh | bash -
                              if that fails:
                              curl -sLf https://iobroker.net/install.sh | bash -
                              T HomoranH 3 Antworten Letzte Antwort
                                @tiger
                                if that fails:
                                Tiger
                                #55
                                already in /opt/iobriker?
                                  @tiger
                                  if that fails:
                                  #56
                                  @thomas-braun may there be another installation in an unappropriate directory?
                                  • T Tiger
                                    #57
                                    yes, but broker 😄
                                      @tiger
                                      if that fails:
                                      Tiger
                                      #58
                                      first failed... and strange, as you said... seems not to be installed
                                      pi@raspberrypi:/opt/iobroker $ curl -fsL https://iobroker.net/fix.sh | bash -
                                      library: loaded
                                      Library version=2022-06-15
                                      ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                                      Second is on the road... but tell me that password will be asked few time... don't remember that I'had a password .. hum hum
                                      • T Tiger
                                        library: loaded
                                        #59
                                        The password is for your linux user, more specific for the root (or root entiteled) user.
                                          Tiger
                                          #60
                                          @thomas-braun that what I said.. I don't remember I'd one...
                                          As the raspberry was only for iobroker
