  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
  • T Tiger
    pi@raspberrypi:~ $ iobroker list adapters
    node:internal/modules/cjs/loader:936
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
        at Function.Module._load (node:internal/modules/cjs/loader:778:27)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
        at node:internal/main/run_main_module:17:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    @tiger
    cd /opt/iobroker
    sudo -H -u iobroker npm install ioBroker.admin@5.3.8
    sudo -H -u iobroker npm install iobroker.js-controller
      @tiger
      cd /opt/iobroker
      Tiger
      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install ioBroker.admin@5.3.8
      npm ERR! code E404
      npm ERR! 404 Not Found - GET https://registry.npmjs.org/ioBroker.admin - Not found
      npm ERR! 404
      npm ERR! 404  'ioBroker.admin@5.3.8' is not in this registry.
      npm ERR! 404 This package name is not valid, because
      npm ERR! 404  1. name can no longer contain capital letters
      npm ERR! 404
      npm ERR! 404 Note that you can also install from a
      npm ERR! 404 tarball, folder, http url, or git url.
      npm ERR!     [2022-08-15T15_04_08_107Z-debug-0.log
      log file2022-08-15T15_04_08_107Z-debug-0.log
      • T Tiger
        npm ERR! code E404
        npm ERR! 404
        npm ERR! 404
        @tiger
        cd /opt/iobroker
        sudo -H -u iobroker npm install admin@5.3.8
        sudo -H -u iobroker npm install js-controller
          @tiger
          cd /opt/iobroker
          @thomas-braun sagte in Update System iobroker failed:
          @tiger
          cd /opt/iobroker
          sudo -H -u iobroker npm install .js-controller
          no
          why 404?
          iobroker.admin 5.3.8 is stable
            @tiger
            cd /opt/iobroker
            no
            why 404?
            Tiger
            schrieb am zuletzt editiert von Tiger
            pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install admin@5.3.8
            npm ERR! code ETARGET
            npm ERR! notarget No matching version found for admin@5.3.8.
            npm ERR! notarget In most cases you or one of your dependencies are requesting
            npm ERR! notarget a package version that doesn't exist.
            npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_11_04_483Z-debug-0.log
            log 2022-08-15T15_11_04_483Z-debug-0.log
            • T Tiger
              @tiger sagte in Update System iobroker failed:
              expected it
              there seems to be a typo.
              i just saw!
              iobroker.admin not ioBroker.admin
              messing around on my mobile. didn't see at once. sorry!
              • T Tiger
                @tiger
                cd /opt/iobroker
                sudo -H -u iobroker npm install iobroker.admin@5.3.8
                  @tiger
                  cd /opt/iobroker
                  Tiger
                  pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.admin@5.3.8
                  npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                  npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                  npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                  npm ERR! code ENOENT
                  npm ERR! syscall chmod
                  npm ERR! path /opt/iobroker/node_modules/request/node_modules/uuid/bin/uuid
                  npm ERR! errno -2
                  npm ERR! enoent ENOENT: no such file or directory, chmod '/opt/iobroker/node_modules/request/node_modules/uuid/bin/uuid'
                  npm ERR! enoent This is related to npm not being able to find a file.
                  npm ERR! enoent
                  npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_15_37_253Z-debug-0.log
                  log 2022-08-15T15_15_37_253Z-debug-0.log
                  • T Tiger
                    npm ERR! errno -2
                    npm ERR! enoent
                    @tiger
                    cd /opt/iobroker
                      @tiger
                      cd /opt/iobroker
                      Tiger
                      @thomas-braun said in Update System iobroker failed:
                      Sorry I made step by step, and if I see some errors I prefer to wait
                      here the result
                      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                      npm ERR! code 32
                      npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                      npm ERR! command failed
                      npm ERR! command sh -c node iobroker.js setup first
                      npm ERR! Successfully migrated 2282 objects to Redis Sets
                      npm ERR! object _design/system updated
                      npm ERR! host.raspberrypi install adapter backitup
                      npm ERR! These apt-get packages were already installed: cifs-utils, nfs-common
                      npm ERR! upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                      npm ERR! upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                      npm ERR! upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                      npm ERR! upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                      npm ERR! upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                      npm ERR! upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                      npm ERR! upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                      npm ERR! upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                      npm ERR! upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                      npm ERR! upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                      npm ERR! upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                      npm ERR! host.raspberrypi Invalid version of "admin". Installed "4.0.10", required ">=5.2.0"
                      npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_27_12_327Z-debug-0.log
                      log2022-08-15T15_27_12_327Z-debug-0.log
                      • T Tiger
                        here the result
                        npm ERR! code 32
                        thats ok!
                        but I'm confused.
                        you twice installed 5.3.8 but it seems still not to be installed
                        • T Tiger
                          here the result
                          npm ERR! code 32
                          @tiger
                          curl -fsL https://iobroker.net/fix.sh | bash -
                          if that fails:
                          curl -sLf https://iobroker.net/install.sh | bash -
                          T HomoranH 3 Antworten Letzte Antwort
                            @tiger
                            if that fails:
                            Tiger
                            already in /opt/iobriker?
                              @tiger
                              if that fails:
                              @thomas-braun may there be another installation in an unappropriate directory?
                              • T Tiger
                                yes, but broker 😄
                                  @tiger
                                  if that fails:
                                  Tiger
                                  first failed... and strange, as you said... seems not to be installed
                                  pi@raspberrypi:/opt/iobroker $ curl -fsL https://iobroker.net/fix.sh | bash -
                                  library: loaded
                                  Library version=2022-06-15
                                  ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                                  Second is on the road... but tell me that password will be asked few time... don't remember that I'had a password .. hum hum
                                  • T Tiger
                                    library: loaded
                                    The password is for your linux user, more specific for the root (or root entiteled) user.
                                      Tiger
                                      @thomas-braun that what I said.. I don't remember I'd one...
                                      As the raspberry was only for iobroker
                                      • T Tiger
                                        @tiger
                                        The user 'pi' has a password.
                                        • T Tiger
                                          security issue if you didn't change it raspberry
