  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
    @tiger sagte in Update System iobroker failed:
    sudo apt autoremove
    iobroker restart
    iobroker status
    Tiger
    pi@raspberrypi:~ $ sudo apt autoremove
    Reading package lists... Done
    Building dependency tree
    The following packages will be REMOVED:
      gconf-service gconf2-common libbluetooth3 libexiv2-14 libgconf-2-4 libgfortran3 libgmime-2.6-0
      libncurses5 lxplug-volume python-colorzero
    0 upgraded, 0 newly installed, 10 to remove and 0 not upgraded.
    After this operation, 11.8 MB disk space will be freed.
    Do you want to continue? [Y/n] y
    (Reading database ... 165809 files and directories currently installed.)
    Removing gconf-service (3.2.6-5) ...
    Removing libgconf-2-4:armhf (3.2.6-5) ...
    Removing gconf2-common (3.2.6-5) ...
    Removing libbluetooth3:armhf (5.50-1.2~deb10u2+rpt1) ...
    Removing libexiv2-14:armhf (0.25-4+deb10u2) ...
    Removing libgfortran3:armhf (6.5.0-1+rpi1+b1) ...
    Removing libgmime-2.6-0:armhf (2.6.23+dfsg1-4) ...
    Removing libncurses5:armhf (6.1+20181013-2+deb10u2) ...
    Removing lxplug-volume (0.25) ...
    Removing python-colorzero (1.1) ...
    Processing triggers for sgml-base (1.29) ...
    Processing triggers for libc-bin (2.28-10+rpt2+rpi1+deb10u1) ...
    pi@raspberrypi:~ $ iobroker restart
    pi@raspberrypi:~ $ iobroker status
    node:internal/modules/cjs/loader:936
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
        at Function.Module._load (node:internal/modules/cjs/loader:778:27)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
        at node:internal/main/run_main_module:17:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    pi@raspberrypi:~ $
      sudo apt autoremove
      iobroker restart
      iobroker status
      Tiger
      juste one things more... I'd forgot to reboot ...
      I'd just reboot now...
      Sorry...
      • T Tiger
          throw err;
          requireStack: []
        pi@raspberrypi:~ $
        @tiger
        Now the correct directories and commands:
        cd /opt/iobroker
        sudo -H -u iobroker npm install iobroker.js-controller
        iobroker stop
        iobroker fix
        iobroker start
          @tiger
          cd /opt/iobroker
          iobroker stop
          iobroker fix
          iobroker start
          Tiger
          Problem with command
          pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
          npm WARN old lockfile
          npm WARN old lockfile The package-lock.json file was created with an old version of npm,
          npm WARN old lockfile so supplemental metadata must be fetched from the registry.
          npm WARN old lockfile This is a one-time fix-up, please be patient...
          npm ERR! code 24
          npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
          npm ERR! command failed
          npm ERR! command sh -c node iobroker.js setup first
          npm ERR! Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
          npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T14_39_15_503Z-debug-0.log
          I attached Log file2022-08-15T14_39_15_503Z-debug-0.log
          • T Tiger
            npm ERR! code 24
            ok!
            delete it and try again.
            if you are afraid of deleting, rename it
              ok!
              Tiger
              I rename directly in the folder /opt/iobroker the file
              and remade the operation
              npm WARN deprecated har-validator@5.1.5: this library is no longer supported
              npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
              npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
              npm ERR! code 32
              npm ERR! Successfully migrated 2282 objects to Redis Sets
              npm ERR! object _design/system updated
              npm ERR! host.raspberrypi install adapter backitup
              npm ERR! These apt-get packages were already installed: cifs-utils, nfs-common
              npm ERR! upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
              npm ERR! upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
              npm ERR! upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
              npm ERR! upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
              npm ERR! upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
              npm ERR! upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
              npm ERR! upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
              npm ERR! upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
              npm ERR! upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
              npm ERR! upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
              npm ERR! upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
              npm ERR! host.raspberrypi Invalid version of "admin". Installed "4.0.10", required ">=5.2.0"
              npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T14_47_08_695Z-debug-0.log
              log file 2022-08-15T14_47_08_695Z-debug-0.log
              • T Tiger
                npm ERR! code 32
                @tiger looks fine!
                npm works correctly now
                • T Tiger
                  npm ERR! code 32
                  @tiger
                  iobroker list adapters
                  iobroker list instances
                    @tiger
                    Tiger
                    pi@raspberrypi:~ $ iobroker list adapters
                      throw err;
                      requireStack: []
                    • T Tiger
                        throw err;
                        requireStack: []
                      @tiger
                      cd /opt/iobroker
                      sudo -H -u iobroker npm install ioBroker.admin@5.3.8
                        @tiger
                        cd /opt/iobroker
                        Tiger
                        pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install ioBroker.admin@5.3.8
                        npm ERR! code E404
                        npm ERR! 404 Not Found - GET https://registry.npmjs.org/ioBroker.admin - Not found
                        npm ERR! 404
                        npm ERR! 404  'ioBroker.admin@5.3.8' is not in this registry.
                        npm ERR! 404 This package name is not valid, because
                        npm ERR! 404  1. name can no longer contain capital letters
                        npm ERR! 404
                        npm ERR! 404 Note that you can also install from a
                        npm ERR! 404 tarball, folder, http url, or git url.
                        npm ERR!     [2022-08-15T15_04_08_107Z-debug-0.log
                        log file2022-08-15T15_04_08_107Z-debug-0.log
                        • T Tiger
                          npm ERR! code E404
                          npm ERR! 404
                          npm ERR! 404
                          @tiger
                          cd /opt/iobroker
                          sudo -H -u iobroker npm install admin@5.3.8
                          sudo -H -u iobroker npm install js-controller
                            @tiger
                            cd /opt/iobroker
                            @thomas-braun sagte in Update System iobroker failed:
                            @tiger
                            cd /opt/iobroker
                            sudo -H -u iobroker npm install .js-controller
                            no
                            why 404?
                            iobroker.admin 5.3.8 is stable
                              @tiger
                              cd /opt/iobroker
                              no
                              why 404?
                              Tiger
                              schrieb am zuletzt editiert von Tiger
                              pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install admin@5.3.8
                              npm ERR! code ETARGET
                              npm ERR! notarget No matching version found for admin@5.3.8.
                              npm ERR! notarget In most cases you or one of your dependencies are requesting
                              npm ERR! notarget a package version that doesn't exist.
                              npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_11_04_483Z-debug-0.log
                              log 2022-08-15T15_11_04_483Z-debug-0.log
                              • T Tiger
                                expected it
                                there seems to be a typo.
                                i just saw!
                                iobroker.admin not ioBroker.admin
                                messing around on my mobile. didn't see at once. sorry!
                                • T Tiger
                                  @tiger
                                  cd /opt/iobroker
                                  sudo -H -u iobroker npm install iobroker.admin@5.3.8
                                    @tiger
                                    cd /opt/iobroker
                                    Tiger
                                    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.admin@5.3.8
                                    npm ERR! code ENOENT
                                    npm ERR! syscall chmod
                                    npm ERR! path /opt/iobroker/node_modules/request/node_modules/uuid/bin/uuid
                                    npm ERR! errno -2
                                    npm ERR! enoent ENOENT: no such file or directory, chmod '/opt/iobroker/node_modules/request/node_modules/uuid/bin/uuid'
                                    npm ERR! enoent This is related to npm not being able to find a file.
                                    npm ERR! enoent
                                    npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_15_37_253Z-debug-0.log
                                    log 2022-08-15T15_15_37_253Z-debug-0.log
                                    • T Tiger
                                      npm ERR! errno -2
                                      npm ERR! enoent
                                      @tiger
                                      cd /opt/iobroker
                                        @tiger
                                        cd /opt/iobroker
                                        Tiger
                                        @thomas-braun said in Update System iobroker failed:
                                        Sorry I made step by step, and if I see some errors I prefer to wait
                                        here the result
                                        npm ERR! code 32
                                        npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_27_12_327Z-debug-0.log
                                        log2022-08-15T15_27_12_327Z-debug-0.log
                                        • T Tiger
                                          here the result
                                          npm ERR! code 32
                                          thats ok!
                                          but I'm confused.
                                          you twice installed 5.3.8 but it seems still not to be installed
