  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
    @tiger sagte in Update System iobroker failed:
    sudo rm /usr/local/bin/node
    sudo rm /usr/local/bin/npm
    curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
    sudo apt install nodejs
    Tiger
    @thomas-braun said in Update System iobroker failed:
    You'll find here after all I've done
    pi@raspberrypi:~ $ sudo rm /usr/local/bin/node
    pi@raspberrypi:~ $ sudo rm /usr/local/bin/npm
    pi@raspberrypi:~ $ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
    ## Installing the NodeSource Node.js 16.x repo...
    ## Populating apt-get cache...
    + apt-get update
    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:2 https://deb.nodesource.com/node_10.x buster InRelease
    Hit:3 http://archive.raspberrypi.org/debian buster InRelease
    Reading package lists... Done
    ## Confirming "buster" is supported...
    + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_16.x/dists/buster/Release'
    ## Adding the NodeSource signing key to your keyring...
    + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
    gpg: WARNING: unsafe ownership on homedir '/home/pi/.gnupg'
    ## Creating apt sources list file for the NodeSource Node.js 16.x repo...
    + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' > /etc/apt/sources.list.d/nodesource.list
    + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' >> /etc/apt/sources.list.d/nodesource.list
    ## Running `apt-get update` for you...
    + apt-get update
    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
    Get:3 https://deb.nodesource.com/node_16.x buster InRelease [4,584 B]
    Get:4 https://deb.nodesource.com/node_16.x buster/main armhf Packages [782 B]
    Fetched 5,366 B in 1s (3,599 B/s)
    ## Run `sudo apt-get install -y nodejs` to install Node.js 16.x and npm
    ## You may also need development tools to build native addons:
         sudo apt-get install gcc g++ make
    ## To install the Yarn package manager, run:
         curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
         echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
         sudo apt-get update && sudo apt-get install yarn
    pi@raspberrypi:~ $ sudo apt install nodejs
    Building dependency tree
    The following packages were automatically installed and are no longer required:
      gconf-service gconf2-common libbluetooth3 libexiv2-14 libgconf-2-4 libgfortran3 libgmime-2.6-0
      libncurses5 lxplug-volume python-colorzero
    Use 'sudo apt autoremove' to remove them.
    The following packages will be upgraded:
      nodejs
    1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    Need to get 23.6 MB of archives.
    After this operation, 38.8 MB of additional disk space will be used.
    Get:1 https://deb.nodesource.com/node_16.x buster/main armhf nodejs armhf 16.16.0-deb-1nodesource1 [23.6 MB]
    Fetched 23.6 MB in 1min 14s (318 kB/s)
    Reading changelogs... Done
    (Reading database ... 167450 files and directories currently installed.)
    Preparing to unpack .../nodejs_16.16.0-deb-1nodesource1_armhf.deb ...
    Unpacking nodejs (16.16.0-deb-1nodesource1) over (10.24.1-1nodesource1) ...
    Setting up nodejs (16.16.0-deb-1nodesource1) ...
    Processing triggers for man-db (2.8.5-2) ...
    pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
    ln: failed to create symbolic link '/usr/bin/nodejs': File exists
    • T Tiger
      + apt-get update
      + apt-get update
        nodejs
      sudo apt autoremove
      iobroker restart
      iobroker status
      T 2 Antworten Letzte Antwort
        sudo apt autoremove
        iobroker restart
        iobroker status
        Tiger
        pi@raspberrypi:~ $ sudo apt autoremove
        The following packages will be REMOVED:
        0 upgraded, 0 newly installed, 10 to remove and 0 not upgraded.
        After this operation, 11.8 MB disk space will be freed.
        Do you want to continue? [Y/n] y
        (Reading database ... 165809 files and directories currently installed.)
        Removing gconf-service (3.2.6-5) ...
        Removing libgconf-2-4:armhf (3.2.6-5) ...
        Removing gconf2-common (3.2.6-5) ...
        Removing libbluetooth3:armhf (5.50-1.2~deb10u2+rpt1) ...
        Removing libexiv2-14:armhf (0.25-4+deb10u2) ...
        Removing libgfortran3:armhf (6.5.0-1+rpi1+b1) ...
        Removing libgmime-2.6-0:armhf (2.6.23+dfsg1-4) ...
        Removing libncurses5:armhf (6.1+20181013-2+deb10u2) ...
        Removing lxplug-volume (0.25) ...
        Removing python-colorzero (1.1) ...
        Processing triggers for sgml-base (1.29) ...
        Processing triggers for libc-bin (2.28-10+rpt2+rpi1+deb10u1) ...
        pi@raspberrypi:~ $ iobroker restart
        pi@raspberrypi:~ $ iobroker status
        node:internal/modules/cjs/loader:936
          throw err;
        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
            at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
            at Function.Module._load (node:internal/modules/cjs/loader:778:27)
            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
            at node:internal/main/run_main_module:17:47 {
          code: 'MODULE_NOT_FOUND',
          requireStack: []
        pi@raspberrypi:~ $
          sudo apt autoremove
          iobroker restart
          iobroker status
          Tiger
          juste one things more... I'd forgot to reboot ...
          I'd just reboot now...
          Sorry...
          • T Tiger
              throw err;
              requireStack: []
            pi@raspberrypi:~ $
            @tiger
            Now the correct directories and commands:
            cd /opt/iobroker
            sudo -H -u iobroker npm install iobroker.js-controller
            iobroker stop
            iobroker fix
            iobroker start
              @tiger
              cd /opt/iobroker
              iobroker stop
              iobroker fix
              iobroker start
              Tiger
              Problem with command
              pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
              npm WARN old lockfile
              npm WARN old lockfile The package-lock.json file was created with an old version of npm,
              npm WARN old lockfile so supplemental metadata must be fetched from the registry.
              npm WARN old lockfile This is a one-time fix-up, please be patient...
              npm ERR! code 24
              npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
              npm ERR! command failed
              npm ERR! command sh -c node iobroker.js setup first
              npm ERR! Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
              npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T14_39_15_503Z-debug-0.log
              I attached Log file2022-08-15T14_39_15_503Z-debug-0.log
              • T Tiger
                npm ERR! code 24
                ok!
                delete it and try again.
                if you are afraid of deleting, rename it
                  ok!
                  Tiger
                  I rename directly in the folder /opt/iobroker the file
                  and remade the operation
                  npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                  npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                  npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                  npm ERR! code 32
                  npm ERR! Successfully migrated 2282 objects to Redis Sets
                  npm ERR! object _design/system updated
                  npm ERR! host.raspberrypi install adapter backitup
                  npm ERR! These apt-get packages were already installed: cifs-utils, nfs-common
                  npm ERR! upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                  npm ERR! upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                  npm ERR! upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                  npm ERR! upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                  npm ERR! upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                  npm ERR! upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                  npm ERR! upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                  npm ERR! upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                  npm ERR! upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                  npm ERR! upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                  npm ERR! upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                  npm ERR! host.raspberrypi Invalid version of "admin". Installed "4.0.10", required ">=5.2.0"
                  npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T14_47_08_695Z-debug-0.log
                  log file 2022-08-15T14_47_08_695Z-debug-0.log
                  • T Tiger
                    npm ERR! code 32
                    @tiger looks fine!
                    npm works correctly now
                    • T Tiger
                      npm ERR! code 32
                      @tiger
                      iobroker list adapters
                      iobroker list instances
                        @tiger
                        Tiger
                        pi@raspberrypi:~ $ iobroker list adapters
                          throw err;
                          requireStack: []
                        • T Tiger
                            throw err;
                            requireStack: []
                          @tiger
                          cd /opt/iobroker
                          sudo -H -u iobroker npm install ioBroker.admin@5.3.8
                            @tiger
                            cd /opt/iobroker
                            Tiger
                            pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install ioBroker.admin@5.3.8
                            npm ERR! code E404
                            npm ERR! 404 Not Found - GET https://registry.npmjs.org/ioBroker.admin - Not found
                            npm ERR! 404
                            npm ERR! 404  'ioBroker.admin@5.3.8' is not in this registry.
                            npm ERR! 404 This package name is not valid, because
                            npm ERR! 404  1. name can no longer contain capital letters
                            npm ERR! 404
                            npm ERR! 404 Note that you can also install from a
                            npm ERR! 404 tarball, folder, http url, or git url.
                            npm ERR!     [2022-08-15T15_04_08_107Z-debug-0.log
                            log file2022-08-15T15_04_08_107Z-debug-0.log
                            • T Tiger
                              npm ERR! code E404
                              npm ERR! 404
                              npm ERR! 404
                              @tiger
                              cd /opt/iobroker
                              sudo -H -u iobroker npm install admin@5.3.8
                              sudo -H -u iobroker npm install js-controller
                                @tiger
                                cd /opt/iobroker
                                @thomas-braun sagte in Update System iobroker failed:
                                @tiger
                                cd /opt/iobroker
                                sudo -H -u iobroker npm install .js-controller
                                no
                                why 404?
                                iobroker.admin 5.3.8 is stable
                                  @tiger
                                  cd /opt/iobroker
                                  no
                                  why 404?
                                  Tiger
                                  schrieb am zuletzt editiert von Tiger
                                  pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install admin@5.3.8
                                  npm ERR! code ETARGET
                                  npm ERR! notarget No matching version found for admin@5.3.8.
                                  npm ERR! notarget In most cases you or one of your dependencies are requesting
                                  npm ERR! notarget a package version that doesn't exist.
                                  npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_11_04_483Z-debug-0.log
                                  log 2022-08-15T15_11_04_483Z-debug-0.log
                                  • T Tiger
                                    expected it
                                    there seems to be a typo.
                                    i just saw!
                                    iobroker.admin not ioBroker.admin
                                    messing around on my mobile. didn't see at once. sorry!
                                    • T Tiger
                                      @tiger
                                      cd /opt/iobroker
                                      sudo -H -u iobroker npm install iobroker.admin@5.3.8
                                        @tiger
                                        cd /opt/iobroker
                                        Tiger
                                        pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.admin@5.3.8
                                        npm ERR! code ENOENT
                                        npm ERR! syscall chmod
                                        npm ERR! path /opt/iobroker/node_modules/request/node_modules/uuid/bin/uuid
                                        npm ERR! errno -2
                                        npm ERR! enoent ENOENT: no such file or directory, chmod '/opt/iobroker/node_modules/request/node_modules/uuid/bin/uuid'
                                        npm ERR! enoent This is related to npm not being able to find a file.
                                        npm ERR! enoent
                                        npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_15_37_253Z-debug-0.log
                                        log 2022-08-15T15_15_37_253Z-debug-0.log
                                        • T Tiger
                                          npm ERR! errno -2
                                          npm ERR! enoent
                                          @tiger
                                          cd /opt/iobroker
