  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
  • T Tiger
    @thomas-braun said in Update System iobroker failed:
    You'll find here after all I've done
    pi@raspberrypi:~ $ sudo rm /usr/local/bin/node
    pi@raspberrypi:~ $ sudo rm /usr/local/bin/npm
    pi@raspberrypi:~ $ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
    ## Installing the NodeSource Node.js 16.x repo...
    ## Populating apt-get cache...
    + apt-get update
    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:2 https://deb.nodesource.com/node_10.x buster InRelease
    Hit:3 http://archive.raspberrypi.org/debian buster InRelease
    Reading package lists... Done
    ## Confirming "buster" is supported...
    + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_16.x/dists/buster/Release'
    ## Adding the NodeSource signing key to your keyring...
    + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
    gpg: WARNING: unsafe ownership on homedir '/home/pi/.gnupg'
    ## Creating apt sources list file for the NodeSource Node.js 16.x repo...
    + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' > /etc/apt/sources.list.d/nodesource.list
    + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' >> /etc/apt/sources.list.d/nodesource.list
    ## Running `apt-get update` for you...
    + apt-get update
    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
    Get:3 https://deb.nodesource.com/node_16.x buster InRelease [4,584 B]
    Get:4 https://deb.nodesource.com/node_16.x buster/main armhf Packages [782 B]
    Fetched 5,366 B in 1s (3,599 B/s)
    ## Run `sudo apt-get install -y nodejs` to install Node.js 16.x and npm
    ## You may also need development tools to build native addons:
         sudo apt-get install gcc g++ make
    ## To install the Yarn package manager, run:
         curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
         echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
         sudo apt-get update && sudo apt-get install yarn
    pi@raspberrypi:~ $ sudo apt install nodejs
    Building dependency tree
    The following packages were automatically installed and are no longer required:
      gconf-service gconf2-common libbluetooth3 libexiv2-14 libgconf-2-4 libgfortran3 libgmime-2.6-0
      libncurses5 lxplug-volume python-colorzero
    Use 'sudo apt autoremove' to remove them.
    The following packages will be upgraded:
      nodejs
    1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    Need to get 23.6 MB of archives.
    After this operation, 38.8 MB of additional disk space will be used.
    Get:1 https://deb.nodesource.com/node_16.x buster/main armhf nodejs armhf 16.16.0-deb-1nodesource1 [23.6 MB]
    Fetched 23.6 MB in 1min 14s (318 kB/s)
    Reading changelogs... Done
    (Reading database ... 167450 files and directories currently installed.)
    Preparing to unpack .../nodejs_16.16.0-deb-1nodesource1_armhf.deb ...
    Unpacking nodejs (16.16.0-deb-1nodesource1) over (10.24.1-1nodesource1) ...
    Setting up nodejs (16.16.0-deb-1nodesource1) ...
    Processing triggers for man-db (2.8.5-2) ...
    pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
    ln: failed to create symbolic link '/usr/bin/nodejs': File exists
    @tiger sagte in Update System iobroker failed:
    sudo apt autoremove
    iobroker restart
    iobroker status
    T 2 Antworten Letzte Antwort
      sudo apt autoremove
      iobroker restart
      iobroker status
      Tiger
      pi@raspberrypi:~ $ sudo apt autoremove
      The following packages will be REMOVED:
      0 upgraded, 0 newly installed, 10 to remove and 0 not upgraded.
      After this operation, 11.8 MB disk space will be freed.
      Do you want to continue? [Y/n] y
      (Reading database ... 165809 files and directories currently installed.)
      Removing gconf-service (3.2.6-5) ...
      Removing libgconf-2-4:armhf (3.2.6-5) ...
      Removing gconf2-common (3.2.6-5) ...
      Removing libbluetooth3:armhf (5.50-1.2~deb10u2+rpt1) ...
      Removing libexiv2-14:armhf (0.25-4+deb10u2) ...
      Removing libgfortran3:armhf (6.5.0-1+rpi1+b1) ...
      Removing libgmime-2.6-0:armhf (2.6.23+dfsg1-4) ...
      Removing libncurses5:armhf (6.1+20181013-2+deb10u2) ...
      Removing lxplug-volume (0.25) ...
      Removing python-colorzero (1.1) ...
      Processing triggers for sgml-base (1.29) ...
      Processing triggers for libc-bin (2.28-10+rpt2+rpi1+deb10u1) ...
      pi@raspberrypi:~ $ iobroker restart
      pi@raspberrypi:~ $ iobroker status
      node:internal/modules/cjs/loader:936
        throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
          at Function.Module._load (node:internal/modules/cjs/loader:778:27)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
          at node:internal/main/run_main_module:17:47 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      pi@raspberrypi:~ $
        sudo apt autoremove
        iobroker restart
        iobroker status
        Tiger
        juste one things more... I'd forgot to reboot ...
        I'd just reboot now...
        Sorry...
        • T Tiger
            throw err;
            requireStack: []
          pi@raspberrypi:~ $
          @tiger
          Now the correct directories and commands:
          cd /opt/iobroker
          sudo -H -u iobroker npm install iobroker.js-controller
          iobroker stop
          iobroker fix
          iobroker start
            @tiger
            cd /opt/iobroker
            iobroker stop
            iobroker fix
            iobroker start
            Tiger
            Problem with command
            pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
            npm WARN old lockfile
            npm WARN old lockfile The package-lock.json file was created with an old version of npm,
            npm WARN old lockfile so supplemental metadata must be fetched from the registry.
            npm WARN old lockfile This is a one-time fix-up, please be patient...
            npm ERR! code 24
            npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
            npm ERR! command failed
            npm ERR! command sh -c node iobroker.js setup first
            npm ERR! Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
            npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T14_39_15_503Z-debug-0.log
            I attached Log file2022-08-15T14_39_15_503Z-debug-0.log
            • T Tiger
              npm ERR! code 24
              ok!
              delete it and try again.
              if you are afraid of deleting, rename it
                ok!
                Tiger
                I rename directly in the folder /opt/iobroker the file
                and remade the operation
                npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                npm ERR! code 32
                npm ERR! Successfully migrated 2282 objects to Redis Sets
                npm ERR! object _design/system updated
                npm ERR! host.raspberrypi install adapter backitup
                npm ERR! These apt-get packages were already installed: cifs-utils, nfs-common
                npm ERR! upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                npm ERR! upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                npm ERR! upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                npm ERR! upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                npm ERR! upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                npm ERR! upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                npm ERR! upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                npm ERR! upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                npm ERR! upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                npm ERR! upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                npm ERR! upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                npm ERR! host.raspberrypi Invalid version of "admin". Installed "4.0.10", required ">=5.2.0"
                npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T14_47_08_695Z-debug-0.log
                log file 2022-08-15T14_47_08_695Z-debug-0.log
                • T Tiger
                  npm ERR! code 32
                  @tiger looks fine!
                  npm works correctly now
                  • T Tiger
                    npm ERR! code 32
                    @tiger
                    iobroker list adapters
                    iobroker list instances
                      @tiger
                      Tiger
                      pi@raspberrypi:~ $ iobroker list adapters
                        throw err;
                        requireStack: []
                      • T Tiger
                          throw err;
                          requireStack: []
                        @tiger
                        cd /opt/iobroker
                        sudo -H -u iobroker npm install ioBroker.admin@5.3.8
                          @tiger
                          cd /opt/iobroker
                          Tiger
                          pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install ioBroker.admin@5.3.8
                          npm ERR! code E404
                          npm ERR! 404 Not Found - GET https://registry.npmjs.org/ioBroker.admin - Not found
                          npm ERR! 404
                          npm ERR! 404  'ioBroker.admin@5.3.8' is not in this registry.
                          npm ERR! 404 This package name is not valid, because
                          npm ERR! 404  1. name can no longer contain capital letters
                          npm ERR! 404
                          npm ERR! 404 Note that you can also install from a
                          npm ERR! 404 tarball, folder, http url, or git url.
                          npm ERR!     [2022-08-15T15_04_08_107Z-debug-0.log
                          log file2022-08-15T15_04_08_107Z-debug-0.log
                          • T Tiger
                            npm ERR! code E404
                            npm ERR! 404
                            npm ERR! 404
                            @tiger
                            cd /opt/iobroker
                            sudo -H -u iobroker npm install admin@5.3.8
                            sudo -H -u iobroker npm install js-controller
                              @tiger
                              cd /opt/iobroker
                              @thomas-braun sagte in Update System iobroker failed:
                              @tiger
                              cd /opt/iobroker
                              sudo -H -u iobroker npm install .js-controller
                              no
                              why 404?
                              iobroker.admin 5.3.8 is stable
                                @tiger
                                cd /opt/iobroker
                                no
                                why 404?
                                Tiger
                                schrieb am zuletzt editiert von Tiger
                                pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install admin@5.3.8
                                npm ERR! code ETARGET
                                npm ERR! notarget No matching version found for admin@5.3.8.
                                npm ERR! notarget In most cases you or one of your dependencies are requesting
                                npm ERR! notarget a package version that doesn't exist.
                                npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_11_04_483Z-debug-0.log
                                log 2022-08-15T15_11_04_483Z-debug-0.log
                                • T Tiger
                                  expected it
                                  there seems to be a typo.
                                  i just saw!
                                  iobroker.admin not ioBroker.admin
                                  messing around on my mobile. didn't see at once. sorry!
                                  • T Tiger
                                    @tiger
                                    cd /opt/iobroker
                                    sudo -H -u iobroker npm install iobroker.admin@5.3.8
                                      @tiger
                                      cd /opt/iobroker
                                      Tiger
                                      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.admin@5.3.8
                                      npm ERR! code ENOENT
                                      npm ERR! syscall chmod
                                      npm ERR! path /opt/iobroker/node_modules/request/node_modules/uuid/bin/uuid
                                      npm ERR! errno -2
                                      npm ERR! enoent ENOENT: no such file or directory, chmod '/opt/iobroker/node_modules/request/node_modules/uuid/bin/uuid'
                                      npm ERR! enoent This is related to npm not being able to find a file.
                                      npm ERR! enoent
                                      npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_15_37_253Z-debug-0.log
                                      log 2022-08-15T15_15_37_253Z-debug-0.log
                                      • T Tiger
                                        npm ERR! errno -2
                                        npm ERR! enoent
                                        @tiger
                                        cd /opt/iobroker
                                          @tiger
                                          cd /opt/iobroker
                                          Tiger
                                          Sorry I made step by step, and if I see some errors I prefer to wait
                                          here the result
                                          npm ERR! code 32
                                          npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_27_12_327Z-debug-0.log
                                          log2022-08-15T15_27_12_327Z-debug-0.log
