  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
  • T Tiger
    I rename directly in the folder /opt/iobroker the file
    and remade the operation
    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm ERR! code 32
    npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
    npm ERR! command failed
    npm ERR! command sh -c node iobroker.js setup first
    npm ERR! Successfully migrated 2282 objects to Redis Sets
    npm ERR! object _design/system updated
    npm ERR! host.raspberrypi install adapter backitup
    npm ERR! These apt-get packages were already installed: cifs-utils, nfs-common
    npm ERR! upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
    npm ERR! upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
    npm ERR! upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
    npm ERR! upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
    npm ERR! upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
    npm ERR! upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
    npm ERR! upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
    npm ERR! upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
    npm ERR! upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
    npm ERR! upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
    npm ERR! upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
    npm ERR! host.raspberrypi Invalid version of "admin". Installed "4.0.10", required ">=5.2.0"
    npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T14_47_08_695Z-debug-0.log
    log file 2022-08-15T14_47_08_695Z-debug-0.log
    @tiger looks fine!
    npm works correctly now
    • T Tiger
      npm ERR! code 32
      @tiger
      iobroker list adapters
      iobroker list instances
        @tiger
        Tiger
        pi@raspberrypi:~ $ iobroker list adapters
        node:internal/modules/cjs/loader:936
          throw err;
        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
            at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
            at Function.Module._load (node:internal/modules/cjs/loader:778:27)
            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
            at node:internal/main/run_main_module:17:47 {
          code: 'MODULE_NOT_FOUND',
          requireStack: []
        • T Tiger
            throw err;
            requireStack: []
          @tiger
          cd /opt/iobroker
          sudo -H -u iobroker npm install ioBroker.admin@5.3.8
            @tiger
            cd /opt/iobroker
            Tiger
            pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install ioBroker.admin@5.3.8
            npm ERR! code E404
            npm ERR! 404 Not Found - GET https://registry.npmjs.org/ioBroker.admin - Not found
            npm ERR! 404
            npm ERR! 404  'ioBroker.admin@5.3.8' is not in this registry.
            npm ERR! 404 This package name is not valid, because
            npm ERR! 404  1. name can no longer contain capital letters
            npm ERR! 404
            npm ERR! 404 Note that you can also install from a
            npm ERR! 404 tarball, folder, http url, or git url.
            npm ERR!     [2022-08-15T15_04_08_107Z-debug-0.log
            log file2022-08-15T15_04_08_107Z-debug-0.log
            • T Tiger
              npm ERR! code E404
              npm ERR! 404
              npm ERR! 404
              @tiger
              cd /opt/iobroker
              sudo -H -u iobroker npm install admin@5.3.8
              sudo -H -u iobroker npm install js-controller
                @tiger
                cd /opt/iobroker
                @thomas-braun sagte in Update System iobroker failed:
                @tiger
                cd /opt/iobroker
                sudo -H -u iobroker npm install .js-controller
                no
                why 404?
                iobroker.admin 5.3.8 is stable
                  @tiger
                  cd /opt/iobroker
                  no
                  why 404?
                  Tiger
                  schrieb am zuletzt editiert von Tiger
                  pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install admin@5.3.8
                  npm ERR! code ETARGET
                  npm ERR! notarget No matching version found for admin@5.3.8.
                  npm ERR! notarget In most cases you or one of your dependencies are requesting
                  npm ERR! notarget a package version that doesn't exist.
                  npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_11_04_483Z-debug-0.log
                  log 2022-08-15T15_11_04_483Z-debug-0.log
                  • T Tiger
                    @tiger sagte in Update System iobroker failed:
                    expected it
                    there seems to be a typo.
                    i just saw!
                    iobroker.admin not ioBroker.admin
                    messing around on my mobile. didn't see at once. sorry!
                    • T Tiger
                      @tiger
                      cd /opt/iobroker
                      sudo -H -u iobroker npm install iobroker.admin@5.3.8
                        @tiger
                        cd /opt/iobroker
                        Tiger
                        pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.admin@5.3.8
                        npm ERR! code ENOENT
                        npm ERR! syscall chmod
                        npm ERR! path /opt/iobroker/node_modules/request/node_modules/uuid/bin/uuid
                        npm ERR! errno -2
                        npm ERR! enoent ENOENT: no such file or directory, chmod '/opt/iobroker/node_modules/request/node_modules/uuid/bin/uuid'
                        npm ERR! enoent This is related to npm not being able to find a file.
                        npm ERR! enoent
                        npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_15_37_253Z-debug-0.log
                        log 2022-08-15T15_15_37_253Z-debug-0.log
                        • T Tiger
                          npm ERR! errno -2
                          npm ERR! enoent
                          @tiger
                          cd /opt/iobroker
                            @tiger
                            cd /opt/iobroker
                            Tiger
                            @thomas-braun said in Update System iobroker failed:
                            Sorry I made step by step, and if I see some errors I prefer to wait
                            here the result
                            npm ERR! code 32
                            npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_27_12_327Z-debug-0.log
                            log2022-08-15T15_27_12_327Z-debug-0.log
                            • T Tiger
                              here the result
                              npm ERR! code 32
                              thats ok!
                              but I'm confused.
                              you twice installed 5.3.8 but it seems still not to be installed
                              • T Tiger
                                here the result
                                npm ERR! code 32
                                @tiger
                                curl -fsL https://iobroker.net/fix.sh | bash -
                                if that fails:
                                curl -sLf https://iobroker.net/install.sh | bash -
                                T HomoranH 3 Antworten Letzte Antwort
                                  @tiger
                                  if that fails:
                                  Tiger
                                  already in /opt/iobriker?
                                    @tiger
                                    if that fails:
                                    @thomas-braun may there be another installation in an unappropriate directory?
                                    • T Tiger
                                      yes, but broker 😄
                                        @tiger
                                        if that fails:
                                        Tiger
                                        first failed... and strange, as you said... seems not to be installed
                                        pi@raspberrypi:/opt/iobroker $ curl -fsL https://iobroker.net/fix.sh | bash -
                                        library: loaded
                                        Library version=2022-06-15
                                        ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                                        Second is on the road... but tell me that password will be asked few time... don't remember that I'had a password .. hum hum
                                        • T Tiger
                                          library: loaded
                                          The password is for your linux user, more specific for the root (or root entiteled) user.
