  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
    @tiger
    cd /opt/iobroker
    sudo -H -u iobroker npm install ioBroker.admin@5.3.8
    sudo -H -u iobroker npm install iobroker.js-controller
    Tiger
    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install ioBroker.admin@5.3.8
    npm ERR! code E404
    npm ERR! 404 Not Found - GET https://registry.npmjs.org/ioBroker.admin - Not found
    npm ERR! 404
    npm ERR! 404  'ioBroker.admin@5.3.8' is not in this registry.
    npm ERR! 404 This package name is not valid, because
    npm ERR! 404  1. name can no longer contain capital letters
    npm ERR! 404
    npm ERR! 404 Note that you can also install from a
    npm ERR! 404 tarball, folder, http url, or git url.
    npm ERR!     [2022-08-15T15_04_08_107Z-debug-0.log
    log file2022-08-15T15_04_08_107Z-debug-0.log
    • T Tiger
      npm ERR! code E404
      npm ERR! 404
      npm ERR! 404
      @tiger
      cd /opt/iobroker
      sudo -H -u iobroker npm install admin@5.3.8
      sudo -H -u iobroker npm install js-controller
        @tiger
        cd /opt/iobroker
        @thomas-braun sagte in Update System iobroker failed:
        @tiger
        cd /opt/iobroker
        sudo -H -u iobroker npm install .js-controller
        no
        why 404?
        iobroker.admin 5.3.8 is stable
          @tiger
          cd /opt/iobroker
          no
          why 404?
          Tiger
          schrieb am zuletzt editiert von Tiger
          pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install admin@5.3.8
          npm ERR! code ETARGET
          npm ERR! notarget No matching version found for admin@5.3.8.
          npm ERR! notarget In most cases you or one of your dependencies are requesting
          npm ERR! notarget a package version that doesn't exist.
          npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_11_04_483Z-debug-0.log
          log 2022-08-15T15_11_04_483Z-debug-0.log
          • T Tiger
            @tiger sagte in Update System iobroker failed:
            expected it
            there seems to be a typo.
            i just saw!
            iobroker.admin not ioBroker.admin
            messing around on my mobile. didn't see at once. sorry!
            • T Tiger
              @tiger
              cd /opt/iobroker
              sudo -H -u iobroker npm install iobroker.admin@5.3.8
                @tiger
                cd /opt/iobroker
                Tiger
                pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.admin@5.3.8
                npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                npm ERR! code ENOENT
                npm ERR! syscall chmod
                npm ERR! path /opt/iobroker/node_modules/request/node_modules/uuid/bin/uuid
                npm ERR! errno -2
                npm ERR! enoent ENOENT: no such file or directory, chmod '/opt/iobroker/node_modules/request/node_modules/uuid/bin/uuid'
                npm ERR! enoent This is related to npm not being able to find a file.
                npm ERR! enoent
                npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_15_37_253Z-debug-0.log
                log 2022-08-15T15_15_37_253Z-debug-0.log
                • T Tiger
                  npm ERR! errno -2
                  npm ERR! enoent
                  @tiger
                  cd /opt/iobroker
                    @tiger
                    cd /opt/iobroker
                    Tiger
                    @thomas-braun said in Update System iobroker failed:
                    Sorry I made step by step, and if I see some errors I prefer to wait
                    here the result
                    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                    npm ERR! code 32
                    npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                    npm ERR! command failed
                    npm ERR! command sh -c node iobroker.js setup first
                    npm ERR! Successfully migrated 2282 objects to Redis Sets
                    npm ERR! object _design/system updated
                    npm ERR! host.raspberrypi install adapter backitup
                    npm ERR! These apt-get packages were already installed: cifs-utils, nfs-common
                    npm ERR! upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                    npm ERR! upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                    npm ERR! upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                    npm ERR! upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                    npm ERR! upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                    npm ERR! upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                    npm ERR! upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                    npm ERR! upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                    npm ERR! upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                    npm ERR! upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                    npm ERR! upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                    npm ERR! host.raspberrypi Invalid version of "admin". Installed "4.0.10", required ">=5.2.0"
                    npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_27_12_327Z-debug-0.log
                    log2022-08-15T15_27_12_327Z-debug-0.log
                    • T Tiger
                      here the result
                      npm ERR! code 32
                      thats ok!
                      but I'm confused.
                      you twice installed 5.3.8 but it seems still not to be installed
                      • T Tiger
                        here the result
                        npm ERR! code 32
                        @tiger
                        curl -fsL https://iobroker.net/fix.sh | bash -
                        if that fails:
                        curl -sLf https://iobroker.net/install.sh | bash -
                        T HomoranH 3 Antworten Letzte Antwort
                          @tiger
                          if that fails:
                          Tiger
                          already in /opt/iobriker?
                            @tiger
                            if that fails:
                            @thomas-braun may there be another installation in an unappropriate directory?
                            • T Tiger
                              yes, but broker 😄
                                @tiger
                                if that fails:
                                Tiger
                                first failed... and strange, as you said... seems not to be installed
                                pi@raspberrypi:/opt/iobroker $ curl -fsL https://iobroker.net/fix.sh | bash -
                                library: loaded
                                Library version=2022-06-15
                                ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                                Second is on the road... but tell me that password will be asked few time... don't remember that I'had a password .. hum hum
                                • T Tiger
                                  library: loaded
                                  The password is for your linux user, more specific for the root (or root entiteled) user.
                                    Tiger
                                    @thomas-braun that what I said.. I don't remember I'd one...
                                    As the raspberry was only for iobroker
                                    • T Tiger
                                      @tiger
                                      The user 'pi' has a password.
                                      • T Tiger
                                        security issue if you didn't change it raspberry
                                          Tiger
                                          pi@raspberrypi:/opt/iobroker $ curl -sLf https://iobroker.net/install.sh | bash -
                                          library: loaded
                                              Welcome to the ioBroker installer!
                                              Installer version: 2022-06-03
                                              You might need to enter your password a couple of times.
                                              Installing prerequisites (1/4)
                                          Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                          Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                                          Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
                                          Reading package lists... Done
                                          Changing npm registry to https://registry.npmjs.org
                                          Installed gcc-c++
                                              Creating ioBroker user and directory (2/4)
                                          Directory /opt/iobroker created
                                              Installing ioBroker (3/4)
                                          npm ERR! code 32
                                          npm ERR! Successfully migrated 2308 objects to Redis Sets
                                          npm ERR!     /home/pi/.npm/_logs/2022-08-15T15_38_44_496Z-debug-0.log
                                              Finalizing installation (4/4)
                                          Enabling autostart...
                                          Autostart enabled!
                                              ioBroker was installed successfully
                                              Open http://192.168.0.100 192.168.1.16:8081 in a browser and start configuring!
                                          You need to re-login before doing anything else on the console!
                                          log 2022-08-15T15_38_44_496Z-debug-0.log
                                          how to re-login?
