  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
    @tiger sagte in Update System iobroker failed:
    sudo apt autoremove
    iobroker restart
    iobroker status
    Tiger
    juste one things more... I'd forgot to reboot ...
    I'd just reboot now...
    Sorry...
    • T Tiger
      pi@raspberrypi:~ $ sudo apt autoremove
      Reading package lists... Done
      Building dependency tree
      The following packages will be REMOVED:
        gconf-service gconf2-common libbluetooth3 libexiv2-14 libgconf-2-4 libgfortran3 libgmime-2.6-0
        libncurses5 lxplug-volume python-colorzero
      0 upgraded, 0 newly installed, 10 to remove and 0 not upgraded.
      After this operation, 11.8 MB disk space will be freed.
      Do you want to continue? [Y/n] y
      (Reading database ... 165809 files and directories currently installed.)
      Removing gconf-service (3.2.6-5) ...
      Removing libgconf-2-4:armhf (3.2.6-5) ...
      Removing gconf2-common (3.2.6-5) ...
      Removing libbluetooth3:armhf (5.50-1.2~deb10u2+rpt1) ...
      Removing libexiv2-14:armhf (0.25-4+deb10u2) ...
      Removing libgfortran3:armhf (6.5.0-1+rpi1+b1) ...
      Removing libgmime-2.6-0:armhf (2.6.23+dfsg1-4) ...
      Removing libncurses5:armhf (6.1+20181013-2+deb10u2) ...
      Removing lxplug-volume (0.25) ...
      Removing python-colorzero (1.1) ...
      Processing triggers for sgml-base (1.29) ...
      Processing triggers for libc-bin (2.28-10+rpt2+rpi1+deb10u1) ...
      pi@raspberrypi:~ $ iobroker restart
      pi@raspberrypi:~ $ iobroker status
      node:internal/modules/cjs/loader:936
        throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
          at Function.Module._load (node:internal/modules/cjs/loader:778:27)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
          at node:internal/main/run_main_module:17:47 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      pi@raspberrypi:~ $
      @tiger
      Now the correct directories and commands:
      cd /opt/iobroker
      sudo -H -u iobroker npm install iobroker.js-controller
      iobroker stop
      iobroker fix
      iobroker start
        @tiger
        cd /opt/iobroker
        iobroker stop
        iobroker fix
        iobroker start
        Tiger
        Problem with command
        pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
        npm WARN old lockfile
        npm WARN old lockfile The package-lock.json file was created with an old version of npm,
        npm WARN old lockfile so supplemental metadata must be fetched from the registry.
        npm WARN old lockfile This is a one-time fix-up, please be patient...
        npm ERR! code 24
        npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
        npm ERR! command failed
        npm ERR! command sh -c node iobroker.js setup first
        npm ERR! Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
        npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T14_39_15_503Z-debug-0.log
        I attached Log file2022-08-15T14_39_15_503Z-debug-0.log
        • T Tiger
          npm ERR! code 24
          ok!
          delete it and try again.
          if you are afraid of deleting, rename it
            ok!
            Tiger
            I rename directly in the folder /opt/iobroker the file
            and remade the operation
            npm WARN deprecated har-validator@5.1.5: this library is no longer supported
            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
            npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
            npm ERR! code 32
            npm ERR! Successfully migrated 2282 objects to Redis Sets
            npm ERR! object _design/system updated
            npm ERR! host.raspberrypi install adapter backitup
            npm ERR! These apt-get packages were already installed: cifs-utils, nfs-common
            npm ERR! upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
            npm ERR! upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
            npm ERR! upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
            npm ERR! upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
            npm ERR! upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
            npm ERR! upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
            npm ERR! upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
            npm ERR! upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
            npm ERR! upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
            npm ERR! upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
            npm ERR! upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
            npm ERR! host.raspberrypi Invalid version of "admin". Installed "4.0.10", required ">=5.2.0"
            npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T14_47_08_695Z-debug-0.log
            log file 2022-08-15T14_47_08_695Z-debug-0.log
            • T Tiger
              npm ERR! code 32
              @tiger looks fine!
              npm works correctly now
              • T Tiger
                npm ERR! code 32
                @tiger
                iobroker list adapters
                iobroker list instances
                  @tiger
                  Tiger
                  pi@raspberrypi:~ $ iobroker list adapters
                    throw err;
                    requireStack: []
                  • T Tiger
                      throw err;
                      requireStack: []
                    @tiger
                    cd /opt/iobroker
                    sudo -H -u iobroker npm install ioBroker.admin@5.3.8
                      @tiger
                      cd /opt/iobroker
                      Tiger
                      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install ioBroker.admin@5.3.8
                      npm ERR! code E404
                      npm ERR! 404 Not Found - GET https://registry.npmjs.org/ioBroker.admin - Not found
                      npm ERR! 404
                      npm ERR! 404  'ioBroker.admin@5.3.8' is not in this registry.
                      npm ERR! 404 This package name is not valid, because
                      npm ERR! 404  1. name can no longer contain capital letters
                      npm ERR! 404
                      npm ERR! 404 Note that you can also install from a
                      npm ERR! 404 tarball, folder, http url, or git url.
                      npm ERR!     [2022-08-15T15_04_08_107Z-debug-0.log
                      log file2022-08-15T15_04_08_107Z-debug-0.log
                      • T Tiger
                        npm ERR! code E404
                        npm ERR! 404
                        npm ERR! 404
                        @tiger
                        cd /opt/iobroker
                        sudo -H -u iobroker npm install admin@5.3.8
                        sudo -H -u iobroker npm install js-controller
                          @tiger
                          cd /opt/iobroker
                          @thomas-braun sagte in Update System iobroker failed:
                          @tiger
                          cd /opt/iobroker
                          sudo -H -u iobroker npm install .js-controller
                          no
                          why 404?
                          iobroker.admin 5.3.8 is stable
                            @tiger
                            cd /opt/iobroker
                            no
                            why 404?
                            Tiger
                            schrieb am zuletzt editiert von Tiger
                            pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install admin@5.3.8
                            npm ERR! code ETARGET
                            npm ERR! notarget No matching version found for admin@5.3.8.
                            npm ERR! notarget In most cases you or one of your dependencies are requesting
                            npm ERR! notarget a package version that doesn't exist.
                            npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_11_04_483Z-debug-0.log
                            log 2022-08-15T15_11_04_483Z-debug-0.log
                            • T Tiger
                              expected it
                              there seems to be a typo.
                              i just saw!
                              iobroker.admin not ioBroker.admin
                              messing around on my mobile. didn't see at once. sorry!
                              • T Tiger
                                @tiger
                                cd /opt/iobroker
                                sudo -H -u iobroker npm install iobroker.admin@5.3.8
                                  @tiger
                                  cd /opt/iobroker
                                  Tiger
                                  pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.admin@5.3.8
                                  npm ERR! code ENOENT
                                  npm ERR! syscall chmod
                                  npm ERR! path /opt/iobroker/node_modules/request/node_modules/uuid/bin/uuid
                                  npm ERR! errno -2
                                  npm ERR! enoent ENOENT: no such file or directory, chmod '/opt/iobroker/node_modules/request/node_modules/uuid/bin/uuid'
                                  npm ERR! enoent This is related to npm not being able to find a file.
                                  npm ERR! enoent
                                  npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_15_37_253Z-debug-0.log
                                  log 2022-08-15T15_15_37_253Z-debug-0.log
                                  • T Tiger
                                    npm ERR! errno -2
                                    npm ERR! enoent
                                    @tiger
                                    cd /opt/iobroker
                                      @tiger
                                      cd /opt/iobroker
                                      Tiger
                                      @thomas-braun said in Update System iobroker failed:
                                      Sorry I made step by step, and if I see some errors I prefer to wait
                                      here the result
                                      npm ERR! code 32
                                      npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_27_12_327Z-debug-0.log
                                      log2022-08-15T15_27_12_327Z-debug-0.log
                                      • T Tiger
                                        here the result
                                        npm ERR! code 32
                                        thats ok!
                                        but I'm confused.
                                        you twice installed 5.3.8 but it seems still not to be installed
                                        • T Tiger
                                          here the result
                                          npm ERR! code 32
                                          @tiger
                                          curl -fsL https://iobroker.net/fix.sh | bash -
                                          if that fails:
                                          curl -sLf https://iobroker.net/install.sh | bash -
                                          T HomoranH 3 Antworten Letzte Antwort
