  2. English
  3. ioBroker general
  4. Update System iobroker failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
update iobroker
164 Beiträge 7 Kommentatoren 36.3k Aufrufe 5 Beobachtet
  • T Tiger
    I understand you, but I would like to be up to date and continue, it's just because i dont like to not understand everything and take time of other poeple ;)
    That's why I thank you for all.
    pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    armv7l
    /usr/bin/nodejs
    /usr/local/bin/node
    /usr/local/bin/npm
    v10.24.1
    v14.20.0
    6.14.17
    pi
    /home/pi
    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
    Hit:3 https://deb.nodesource.com/node_10.x buster InRelease
    Reading package lists... Done
    Building dependency tree
    All packages are up to date.
    nodejs:
      Installed: 10.24.1-1nodesource1
      Candidate: 10.24.1-1nodesource1
      Version table:
     *** 10.24.1-1nodesource1 500
            500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u1 500
    @tiger sagte in Update System iobroker failed:
    sudo rm /usr/local/bin/node
    sudo rm /usr/local/bin/npm
    curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
    sudo apt install nodejs
      that's a good point of view
      so we will work on it, making you to understand it
      that's our decision! hoping you learn something and possible give this to others
      Tiger
      Thanks, like to see that.
        Tiger
        @thomas-braun said in Update System iobroker failed:
        You'll find here after all I've done
        pi@raspberrypi:~ $ sudo rm /usr/local/bin/node
        pi@raspberrypi:~ $ sudo rm /usr/local/bin/npm
        pi@raspberrypi:~ $ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
        ## Installing the NodeSource Node.js 16.x repo...
        ## Populating apt-get cache...
        + apt-get update
        Hit:2 https://deb.nodesource.com/node_10.x buster InRelease
        Hit:3 http://archive.raspberrypi.org/debian buster InRelease
        ## Confirming "buster" is supported...
        + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_16.x/dists/buster/Release'
        ## Adding the NodeSource signing key to your keyring...
        + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
        gpg: WARNING: unsafe ownership on homedir '/home/pi/.gnupg'
        ## Creating apt sources list file for the NodeSource Node.js 16.x repo...
        + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' > /etc/apt/sources.list.d/nodesource.list
        + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' >> /etc/apt/sources.list.d/nodesource.list
        ## Running `apt-get update` for you...
        + apt-get update
        Get:3 https://deb.nodesource.com/node_16.x buster InRelease [4,584 B]
        Get:4 https://deb.nodesource.com/node_16.x buster/main armhf Packages [782 B]
        Fetched 5,366 B in 1s (3,599 B/s)
        ## Run `sudo apt-get install -y nodejs` to install Node.js 16.x and npm
        ## You may also need development tools to build native addons:
             sudo apt-get install gcc g++ make
        ## To install the Yarn package manager, run:
             curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
             echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
             sudo apt-get update && sudo apt-get install yarn
        pi@raspberrypi:~ $ sudo apt install nodejs
        The following packages were automatically installed and are no longer required:
          gconf-service gconf2-common libbluetooth3 libexiv2-14 libgconf-2-4 libgfortran3 libgmime-2.6-0
          libncurses5 lxplug-volume python-colorzero
        Use 'sudo apt autoremove' to remove them.
        The following packages will be upgraded:
          nodejs
        1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        Need to get 23.6 MB of archives.
        After this operation, 38.8 MB of additional disk space will be used.
        Get:1 https://deb.nodesource.com/node_16.x buster/main armhf nodejs armhf 16.16.0-deb-1nodesource1 [23.6 MB]
        Fetched 23.6 MB in 1min 14s (318 kB/s)
        Reading changelogs... Done
        (Reading database ... 167450 files and directories currently installed.)
        Preparing to unpack .../nodejs_16.16.0-deb-1nodesource1_armhf.deb ...
        Unpacking nodejs (16.16.0-deb-1nodesource1) over (10.24.1-1nodesource1) ...
        Setting up nodejs (16.16.0-deb-1nodesource1) ...
        Processing triggers for man-db (2.8.5-2) ...
        pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
        ln: failed to create symbolic link '/usr/bin/nodejs': File exists
        • T Tiger
          + apt-get update
          + apt-get update
            nodejs
          sudo apt autoremove
          iobroker restart
          iobroker status
          T 2 Antworten Letzte Antwort
            sudo apt autoremove
            iobroker restart
            iobroker status
            Tiger
            pi@raspberrypi:~ $ sudo apt autoremove
            The following packages will be REMOVED:
            0 upgraded, 0 newly installed, 10 to remove and 0 not upgraded.
            After this operation, 11.8 MB disk space will be freed.
            Do you want to continue? [Y/n] y
            (Reading database ... 165809 files and directories currently installed.)
            Removing gconf-service (3.2.6-5) ...
            Removing libgconf-2-4:armhf (3.2.6-5) ...
            Removing gconf2-common (3.2.6-5) ...
            Removing libbluetooth3:armhf (5.50-1.2~deb10u2+rpt1) ...
            Removing libexiv2-14:armhf (0.25-4+deb10u2) ...
            Removing libgfortran3:armhf (6.5.0-1+rpi1+b1) ...
            Removing libgmime-2.6-0:armhf (2.6.23+dfsg1-4) ...
            Removing libncurses5:armhf (6.1+20181013-2+deb10u2) ...
            Removing lxplug-volume (0.25) ...
            Removing python-colorzero (1.1) ...
            Processing triggers for sgml-base (1.29) ...
            Processing triggers for libc-bin (2.28-10+rpt2+rpi1+deb10u1) ...
            pi@raspberrypi:~ $ iobroker restart
            pi@raspberrypi:~ $ iobroker status
            node:internal/modules/cjs/loader:936
              throw err;
            Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
                at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
                at node:internal/main/run_main_module:17:47 {
              code: 'MODULE_NOT_FOUND',
              requireStack: []
            pi@raspberrypi:~ $
              sudo apt autoremove
              iobroker restart
              iobroker status
              Tiger
              juste one things more... I'd forgot to reboot ...
              I'd just reboot now...
              Sorry...
              • T Tiger
                  throw err;
                  requireStack: []
                pi@raspberrypi:~ $
                @tiger
                Now the correct directories and commands:
                cd /opt/iobroker
                sudo -H -u iobroker npm install iobroker.js-controller
                iobroker stop
                iobroker fix
                iobroker start
                  @tiger
                  cd /opt/iobroker
                  iobroker stop
                  iobroker fix
                  iobroker start
                  Tiger
                  Problem with command
                  pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                  npm WARN old lockfile
                  npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                  npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                  npm WARN old lockfile This is a one-time fix-up, please be patient...
                  npm ERR! code 24
                  npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                  npm ERR! command failed
                  npm ERR! command sh -c node iobroker.js setup first
                  npm ERR! Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
                  npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T14_39_15_503Z-debug-0.log
                  I attached Log file2022-08-15T14_39_15_503Z-debug-0.log
                  • T Tiger
                    npm ERR! code 24
                    ok!
                    delete it and try again.
                    if you are afraid of deleting, rename it
                      ok!
                      Tiger
                      I rename directly in the folder /opt/iobroker the file
                      and remade the operation
                      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                      npm ERR! code 32
                      npm ERR! Successfully migrated 2282 objects to Redis Sets
                      npm ERR! object _design/system updated
                      npm ERR! host.raspberrypi install adapter backitup
                      npm ERR! These apt-get packages were already installed: cifs-utils, nfs-common
                      npm ERR! upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                      npm ERR! upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                      npm ERR! upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                      npm ERR! upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                      npm ERR! upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                      npm ERR! upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                      npm ERR! upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                      npm ERR! upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                      npm ERR! upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                      npm ERR! upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                      npm ERR! upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                      npm ERR! host.raspberrypi Invalid version of "admin". Installed "4.0.10", required ">=5.2.0"
                      npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T14_47_08_695Z-debug-0.log
                      log file 2022-08-15T14_47_08_695Z-debug-0.log
                      • T Tiger
                        npm ERR! code 32
                        @tiger looks fine!
                        npm works correctly now
                        • T Tiger
                          npm ERR! code 32
                          @tiger
                          iobroker list adapters
                          iobroker list instances
                            @tiger
                            Tiger
                            pi@raspberrypi:~ $ iobroker list adapters
                              throw err;
                              requireStack: []
                            • T Tiger
                                throw err;
                                requireStack: []
                              @tiger
                              cd /opt/iobroker
                              sudo -H -u iobroker npm install ioBroker.admin@5.3.8
                                @tiger
                                cd /opt/iobroker
                                Tiger
                                pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install ioBroker.admin@5.3.8
                                npm ERR! code E404
                                npm ERR! 404 Not Found - GET https://registry.npmjs.org/ioBroker.admin - Not found
                                npm ERR! 404
                                npm ERR! 404  'ioBroker.admin@5.3.8' is not in this registry.
                                npm ERR! 404 This package name is not valid, because
                                npm ERR! 404  1. name can no longer contain capital letters
                                npm ERR! 404
                                npm ERR! 404 Note that you can also install from a
                                npm ERR! 404 tarball, folder, http url, or git url.
                                npm ERR!     [2022-08-15T15_04_08_107Z-debug-0.log
                                log file2022-08-15T15_04_08_107Z-debug-0.log
                                • T Tiger
                                  npm ERR! code E404
                                  npm ERR! 404
                                  npm ERR! 404
                                  @tiger
                                  cd /opt/iobroker
                                  sudo -H -u iobroker npm install admin@5.3.8
                                  sudo -H -u iobroker npm install js-controller
                                    @tiger
                                    cd /opt/iobroker
                                    @thomas-braun sagte in Update System iobroker failed:
                                    @tiger
                                    cd /opt/iobroker
                                    sudo -H -u iobroker npm install .js-controller
                                    no
                                    why 404?
                                    iobroker.admin 5.3.8 is stable
                                      @tiger
                                      cd /opt/iobroker
                                      no
                                      why 404?
                                      Tiger
                                      schrieb am zuletzt editiert von Tiger
                                      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install admin@5.3.8
                                      npm ERR! code ETARGET
                                      npm ERR! notarget No matching version found for admin@5.3.8.
                                      npm ERR! notarget In most cases you or one of your dependencies are requesting
                                      npm ERR! notarget a package version that doesn't exist.
                                      npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_11_04_483Z-debug-0.log
                                      log 2022-08-15T15_11_04_483Z-debug-0.log
                                      • T Tiger
                                        expected it
                                        there seems to be a typo.
                                        i just saw!
                                        iobroker.admin not ioBroker.admin
                                        messing around on my mobile. didn't see at once. sorry!
                                        • T Tiger
                                          @tiger
                                          cd /opt/iobroker
                                          sudo -H -u iobroker npm install iobroker.admin@5.3.8
