  4. [ Geklärt ] Problem bei Influx Installation
    6.4k
influxdb
178 Beiträge 12 Kommentatoren 43.0k Aufrufe 11 Beobachtet
  • A Altersrentner
    @crunchip Hallo,
    Ich muss mich doch noch mal um Hilfe bitten.
    Nicht das jemand denkt ich bin zu düsig! aber es geling mir nicht
    Influxdb zu konfigurieren.
    Mehrmaliges löschen und wieder installieren hat nichts gebracht.
    Ich komme immer bis zu diesem Punkt:
    pi@raspberrypi:~ $ wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add -
    OK
    pi@raspberrypi:~ $ source /etc/lsb-release
    -bash: /etc/lsb-release: No such file or directory
    pi@raspberrypi:~ $ sudo source /etc/lsb-release
    sudo: source: command not found
    pi@raspberrypi:~ $ source /etc/os-release
    pi@raspberrypi:~ $ echo "deb https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
    deb https://repos.influxdata.com/  stable
    pi@raspberrypi:~ $ sudo apt update
    E: Malformed entry 1 in list file /etc/apt/sources.list.d/influxdb.list (Component)
    E: The list of sources could not be read.
    pi@raspberrypi:~ $ echo "deb https://repos.influxdata.com/debian $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
    deb https://repos.influxdata.com/debian buster stable
    Get:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
    Hit:3 https://deb.nodesource.com/node_10.x buster InRelease
    Hit:4 https://repos.influxdata.com/debian buster InRelease
    Fetched 15.0 kB in 2s (9,888 B/s)
    Reading package lists... Done
    Building dependency tree
    All packages are up to date.
    pi@raspberrypi:~ $ sudo apt install influxdb
    The following NEW packages will be installed:
      influxdb
    0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
    Need to get 0 B/60.0 MB of archives.
    After this operation, 153 MB of additional disk space will be used.
    Selecting previously unselected package influxdb.
    (Reading database ... 63673 files and directories currently installed.)
    Preparing to unpack .../influxdb_1.8.3-1_armhf.deb ...
    Unpacking influxdb (1.8.3-1) ...
    Setting up influxdb (1.8.3-1) ...
    Processing triggers for man-db (2.8.5-2) ...
    pi@raspberrypi:~ $ sudo systemctl status influxdb.service
    ● influxdb.service - InfluxDB is an open-source, distributed, time series database
       Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
       Active: active (running) since Tue 2020-12-22 11:44:21 CET; 3h 12min ago
         Docs: https://docs.influxdata.com/influxdb/
     Main PID: 5478 (influxd)
        Tasks: 14 (limit: 4915)
       CGroup: /system.slice/influxdb.service
               └─5478 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
    Dec 22 14:55:30 raspberrypi influxd[5478]: ts=2020-12-22T13:55:30.303321Z lvl=info msg="failed to store statistic
    Dec 22 14:55:40 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:55:40 +0100] "GET /query?db=
    Dec 22 14:55:40 raspberrypi influxd[5478]: ts=2020-12-22T13:55:40.504680Z lvl=info msg="failed to store statistic
    Dec 22 14:55:50 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:55:50 +0100] "GET /query?db=
    Dec 22 14:56:00 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:56:00 +0100] "GET /query?db=
    Dec 22 14:56:10 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:56:10 +0100] "GET /query?db=
    Dec 22 14:56:21 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:56:20 +0100] "GET /query?db=
    Dec 22 14:56:31 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:56:31 +0100] "GET /query?db=
    Dec 22 14:56:41 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:56:41 +0100] "GET /query?db=
    Dec 22 14:56:51 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:56:51 +0100] "GET /query?db=
    pi@raspberrypi:~ $ sudo systemctl unmask influxdb.service
    pi@raspberrypi:~ $ sudo systemctl start influxdb
    pi@raspberrypi:~ $ sudo systemctl enable influxdb.service
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $ sudo influx
    Connected to http://localhost:8086 version 1.8.3
    InfluxDB shell version: 1.8.3
    > CREATE DATABASE "iobroker"
    ERR: unable to parse authentication credentials
    Warning: It is possible this error is due to not setting a database.
    Please set a database with the command "use <database>".
    Alles was danach versucht wird einzugeben wird mit der
    letzten Fehlermeldung beantwortet
    Die influxdb.0 Ampel ist gelb.
    Dortige Eingaben sind wie gehabt
    Auch USE "iobroker" bringt das selbe Ergebnis.
    > auth
    username: admin
    password:
    > show database
    ERR: authorization failed
    > show databases
    Gestern habe ich eine andere Speicherkarte neu aufgesetzt.
    Rasphian buster und iobroker installiert und
    dort hat die Installation von influxdb und Grafana auf Anhieb geklappt.
    Ich vermute, das es in einer Konfigurationsdatei Einträge gibt,
    die diese Fehlermeldungen herforrufen.
    Freundliche Grüße
    Michael
    crunchipC Abwesend
    crunchipC Abwesend
    #61
    @Altersrentner wenn ich mich nicht Irre, kannst du das create database.... Weglassen auf der Konsole.
    Die wird nämlich automatisch angelegt, wenn du in deiner Influx Instanz, die Werte/Einstellungen gemacht hast und anschliessend startest. Das denke ich, behebt auch deinen Fehler
    A 1 Antwort Letzte Antwort
      Altersrentner
      #62
      @crunchip Hallo,
      😊 😊 😊 Es hat geklappt.
      Folgende Situation war gegeben,
      trotz mehrmaligem löschen der influxdb war aber noch die
      alte config vorhanden und damit die vormals kommentierten Zeilen.
      Ich war immer davon ausgegangen, das die config auch entfernt wurde.
      Habe dann alle Zeilen bis auf bind.... auskommentiert und damit hatten
      sich login und database selbst unter influxdb eingetragen.
      Das brachte dann SHOW..... ans Licht. ist zwar etwas komisch,
      denn in den Anleitungen wird ja immer geschrieben CREATE......
      Na ja - alles gut!! für heute reicht`s
      Ich bedanke mich nochmals für Eure Unterstützung!
      Freundliche Grüße und besinnliche Feiertage
      wünscht Michael
      • A Altersrentner
        @crunchip Hallo,
        wünscht Michael
        crunchipC Abwesend
        crunchipC Abwesend
        #63
        @Altersrentner sagte in [ Geklärt ] Problem bei Influx Installation:
        Ja, man geht bei der offiziellen Anleitung auch nicht davon aus, das iobroker genutzt wird😉
        Nein, die config bleibt erhalten, daher hatte ich den Befehl oben genannt, damit alles "Restlos" gelöscht wird und du von Grundauf neu installeren kannst.
        • A Altersrentner
          Guten Morgen,
          Ich möchte meine Graphen zukünftig mittels Grafana darstellen.
          Dafür benötige ich die InfluxDB.
          Dazu habe ich mir sehr viele Videos angesehen und es sollte von der
          Sache her kein Problem sein, Aber der teufel steckt im Detail
          pi@raspberrypi:~ $ sudo service influxdb start
          Failed to connect to http://localhost:8086: Get http://localhost:8086/ping: dial       tcp [::1]:8086: connect: connection refused
          Please check your connection settings and ensure 'influxd' is running.
          pi@raspberrypi:~ $
          Heist:
          sudo influx Fehler beim Herstellen einer Verbindung zu http: // localhost: 8086: Abrufen von http: // localhost: 8086 / ping: Wählen von TCP [:: 1]: 8086: Verbinden: Verbindung abgelehnt
          Bitte überprüfen Sie Ihre Verbindungseinstellungen und stellen Sie sicher, dass 'influxd' ausgeführt wird.
          Wer kann mir bitte helfen das Problem zu lösen.
          Freundliche Grüße
          Michael
          Altersrentner
          schrieb am zuletzt editiert von Altersrentner
          #64
          @Altersrentner
          crunchip 👍 👍 👍
          • A Altersrentner
            @Altersrentner
            crunchip 👍 👍 👍
            crunchipC Abwesend
            crunchipC Abwesend
            #65
            @Altersrentner ein Tipp vorne weg, beim loggen eines Datenpunktes.
            Beim Auswahlmenü "Speichern unter" nicht Automatic auswählen, da es je nach Datenpunkt zu Problemen führen kann, wenn der zu loggende Datentyp z.b. vom Typ "boolean" oder "String" ist. Ein nachträgliches Ändern führt dazu, das keine Werte mehr in Grafana angezeigt werden und dieser dann erst aus der Datenbank gelöscht werden muss. Dementsprechend also gleich beim aktivieren den "richtigen Typ auswählen.
              Altersrentner
              #66
              @crunchip Hallo,
              Danke für Deinen Hinweis!!!!
              Ich kämpfe immer noch😧
              Möchte mit mi Temperaturen und Türmagneten anfangen.
              Natürlich steht alles auf Autom.
              Temperaturen sind ja Zahlen und Schalter Logikwerte.
              Ich habe aber nur die von Dir gezeigten Parameter zur Auswahl.
              Was benutze ich wo?
              • A Altersrentner
                @crunchip Hallo,
                Was benutze ich wo?
                crunchipC Abwesend
                crunchipC Abwesend
                #67
                @Altersrentner ist richtig, siehst du im RAW des jeweiligen Datenpunktes, Stichwort Typ
                Beispiel dein xiaomi Klima Sensor. Öffnest den Objektbaum.
                Bei Temperatur und Humitidy jeweils, rechts auf den Schraubenschlüssel und config influx aufrufen, da erscheint dann das Fenster, wie in meinem Screen.
                Da der Typ in dem Fall "Number" ist ,wählst du dies entsprechend aus. Wenn du unten links "alias" frei lässt, erscheint dein geloggter Datenpunkt auch so wie er in iobroker benannt ist.
                Wenn du dann unten mit ok bestätigst, füllt sich die Datenbank, sobald eine Änderung des Wertes stattgefunden hat.
                Bei deinem Tür/Fensterkontakt gehst du genauso vor, jedoch ist da der Typ "boolean" auszuwählen.
                  Altersrentner
                  #68
                  @crunchip
                  Danke, habe jetzt erst mal wieder Futter.
                  Wünsche einen schönen Abend
                  Freundliche Grüße Michael
                  • A Altersrentner
                    @crunchip
                    crunchipC Abwesend
                    crunchipC Abwesend
                    #69
                    @Altersrentner ich sitz noch auf Arbeit😁
                    A 2 Antworten Letzte Antwort
                      Altersrentner
                      #70
                      @crunchip In der jetzigen Situation bin ich recht froh,
                      meinen Pflichtteil seit sieben Jahren beendet zu haben.
                        Altersrentner
                        #71
                        @crunchip Ich noch mal,
                        Habe ein weiteres Problem lokalisiert.
                        Wenn ich in der influxdb
                        auth-enabled = true
                        aktiviere, schaltet die Ampel des Adapters nicht mehr auf Grün.
                        Habe alle 8 Positionen nacheinander getestet.
                        Gibt es dafür eine Erklärung?
                        Danke und
                        Gute Nacht
                        • A Altersrentner
                          auth-enabled = true
                          Danke und
                          Gute Nacht
                          crunchipC Abwesend
                          crunchipC Abwesend
                          #72
                          @Altersrentner
                          @Altersrentner sagte in [Noch nicht Geklärt ] Problem bei Influx Installation:
                          denke, das hängt damit zusammen
                          in der influxdb.conf musst du eigentlich gar nichts ändern, zumindest nicht in deinem Fall
                          meinst du den Teil [http]? der sollte so aussehen
                            @Altersrentner
                            Altersrentner
                            #73
                            @crunchip
                            Ja ich meine den http Bereich.
                            Laut Beschreibungen sollten folgende Einträge
                            kommentiert werden.
                            [http]
                             enabled = true
                             bind-address = ":8086"
                             auth-enabled = true
                             log-enabled = true
                             write-tracing = false
                             pprof-enabled = false
                             https-enabled = false
                             https-certificate = "/etc/ssl/influxdb.pem"
                            Ich habe alle außer
                             auth-enabled = true
                            kommentiert, weil dieser die Ampel blockiert.
                            • A Altersrentner
                              @crunchip
                              kommentiert werden.
                              [http]
                               enabled = true
                               auth-enabled = true
                               log-enabled = true
                              Ich habe alle außer
                               auth-enabled = true
                              crunchipC Abwesend
                              crunchipC Abwesend
                              #74
                              @Altersrentner bei mir ist das so für [http]
                              die 3 sind aktiv
                              enabled = true
                              pprof-enabled = true
                              alles andere ist auskommentiert
                                die 3 sind aktiv
                                enabled = true
                                Altersrentner
                                #75
                                @crunchip Danke,
                                Werde ich probieren😊
                                  die 3 sind aktiv
                                  enabled = true
                                  Altersrentner
                                  #76
                                  @crunchip Guten Morgen und einen schönen Feiertag;
                                  Bin jetzt damit beschäftigt Grafana einzurichten.
                                  Aber auch hier ist alles anders wie normal.
                                  Es beginnt schon mit der Eingabe der Settings
                                  Grafana verbindet sich nur wenn unter Access "BROWSER" ausgewählt ist.
                                  Habe viel gesucht und überall nur Verbindung über Server gefunden.
                                  Deshalb die Frage ist Browser OK oder eher nicht.
                                  Nach diesem Video habe ich dann meine Datenpunkte konfiguriert und überprüft.
                                  https://www.youtube.com/watch?v=VXfpds4Rtqc&t=4072s
                                  Alles prima..
                                  In den Dashboard Einstellungen sollten dann die in influxdb geloggten Daten
                                  unter dem Reiter "select measurement" erscheinen. Das Feld bleibt aber leer.
                                  Wie kann ich prüfen, ob besagte date überhaupt in der influxdb auftauchen.
                                  Z. B. mit einem Befehl im Terminal.
                                  Ich bin doch noch etwas weiter gekommen.😊
                                  > show databases
                                  name
                                  _internal
                                  iobroker
                                  > use iobroker
                                  Using database iobroker
                                  > show measurements
                                  name
                                  influxdb.0.info.connection
                                  mihome.0.devices.magnet_158d00020910b2.state
                                  mihome.0.devices.magnet_158d00020b5d12.state
                                  mihome.0.devices.magnet_158d00020b5d69.state
                                  mihome.0.devices.magnet_158d0003e72274.state
                                  mihome.0.devices.magnet_158d0003e741ac.state
                                  mihome.0.devices.magnet_158d0003e74624.state
                                  mihome.0.devices.magnet_158d0003e746aa.state
                                  mihome.0.devices.magnet_158d0003e747f7.state
                                  mihome.0.devices.weather_v1_158d00023213f6.humidity
                                  mihome.0.devices.weather_v1_158d00023213f6.temperature
                                  mihome.0.devices.weather_v1_158d000232801d.humidity
                                  mihome.0.devices.weather_v1_158d000232801d.temperature
                                  mihome.0.devices.weather_v1_158d0002329079.humidity
                                  mihome.0.devices.weather_v1_158d0002329079.temperature
                                  mihome.0.devices.weather_v1_158d00023290a8.humidity
                                  mihome.0.devices.weather_v1_158d00023290a8.temperature
                                  mihome.0.devices.weather_v1_158d00023290e8.humidity
                                  mihome.0.devices.weather_v1_158d00023290e8.temperature
                                  mihome.0.devices.weather_v1_158d00024906fa.humidity
                                  mihome.0.devices.weather_v1_158d00024906fa.temperature
                                  mihome.0.devices.weather_v1_158d00036b52b9.humidity
                                  mihome.0.devices.weather_v1_158d00036b52b9.temperature
                                  mihome.0.devices.weather_v1_158d00036b53b3.humidity
                                  mihome.0.devices.weather_v1_158d00036b53b3.temperature
                                  mihome.0.devices.weather_v1_158d00036b53ce.humidity
                                  mihome.0.devices.weather_v1_158d00036b53ce.temperature
                                  mihome.0.devices.weather_v1_158d00036bd6ea.humidity
                                  mihome.0.devices.weather_v1_158d00036bd6ea.temperature
                                  mihome.0.devices.weather_v1_158d00036bd78e.humidity
                                  mihome.0.devices.weather_v1_158d00036bd78e.temperature
                                  > show series
                                  key
                                  > > Das Initallisieren des Grafana Server:
                                  ERR: error parsing query: found >, expected SELECT, DELETE, SHOW, CREATE, DROP, EXPLAIN, GRANT, REVOKE, ALTER, SET, KILL at line 1, char 1
                                  > show tag keys
                                  > show field keys
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    string
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    boolean
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    boolean
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    boolean
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    boolean
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    boolean
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    boolean
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    boolean
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    boolean
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    float
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    float
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    float
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    float
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    float
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    float
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    float
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    float
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    float
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    float
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    float
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    float
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    float
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    float
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    float
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    float
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    float
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    float
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    float
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    float
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    float
                                  fieldKey fieldType
                                  ack      boolean
                                  from     string
                                  q        float
                                  value    float
                                  Ist soweit alles richtig?
                                  Soweit erst mal zum aktuellen Stand.
                                  Freundliche Grüße
                                  Michael
                                  crunchipC B 2 Antworten Letzte Antwort
                                  • A Altersrentner
                                    Alles prima..
                                    > show databases
                                    name
                                    _internal
                                    iobroker
                                    > use iobroker
                                    > show measurements
                                    name
                                    > show series
                                    key
                                    > show tag keys
                                    > show field keys
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    string
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    boolean
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    boolean
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    boolean
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    boolean
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    boolean
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    boolean
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    boolean
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    boolean
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    float
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    float
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    float
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    float
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    float
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    float
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    float
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    float
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    float
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    float
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    float
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    float
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    float
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    float
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    float
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    float
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    float
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    float
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    float
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    float
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    float
                                    fieldKey fieldType
                                    ack      boolean
                                    from     string
                                    q        float
                                    value    float
                                    Freundliche Grüße
                                    Michael
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    #77
                                    dort musst du deine URL eingeben, die ist nur als Beispiel "schwach sichtbar" hinterlegt
                                    Access muss auf Server stehen
                                    ganz unten bei Http Method auf Get stellen
                                    auf der Konsole
                                    influx
                                    use iobroker
                                    show series
                                    wenn du auf select measurement klickst, sollte sich eine Liste öffnen, mit allen Datenpunkten, die du geloggt hast
                                      auf der Konsole
                                      influx
                                      use iobroker
                                      show series
                                      Altersrentner
                                      #78
                                      @crunchip Danke für Deine Nachricht.
                                      Habe das jetzt umgestellt.
                                      Aber er bringt mir einen Error
                                      • A Altersrentner
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        #79
                                        @Altersrentner du hast die URL falsch eingegeben, hast das
                                        http://
                                        vor deiner Ip vergessen
                                          http://
                                          Altersrentner
                                          #80
                                          @crunchip Danke,
                                          dachte das macht er selbst😧
                                          Jetzt gibt es auch Werte aber nur Fhem Schalter.
                                          Keine Temperaturen z.B. von mi.
                                          Diese werden aber über influx aufgezeichnet
