  4. [ Geklärt ] Problem bei Influx Installation
    6.4k
influxdb
178 Beiträge 12 Kommentatoren 43.0k Aufrufe 11 Beobachtet
    @Altersrentner die Ampel interessiert momentan nicht, da dein influx-service nicht läuft, Zeile 7
    hast du in der
    /etc/influxdb/influxdb.conf
    irgendwas geändert/angepasst?
    Altersrentner
    #41
    @crunchip NEIN!!
    • A Altersrentner
      @crunchip NEIN!!
      crunchipC Abwesend
      crunchipC Abwesend
      #42
      @Altersrentner dann nochmal, mit enable...
      sudo systemctl stop influxdb
      sudo systemctl unmask influxdb.service
      sudo systemctl enable influxdb
      sudo systemctl start influxdb
      sudo systemctl status influxdb
      netstat -tulpen
      A 1 Antwort Letzte Antwort
        netstat -tulpen
        Altersrentner
        #43
        @crunchip
        pi@raspberrypi:~ $ sudo systemctl stop influxdb
        pi@raspberrypi:~ $ sudo systemctl unmask influxdb.service
        pi@raspberrypi:~ $ sudo systemctl enable influxdb
        pi@raspberrypi:~ $ sudo systemctl start influxdb
        pi@raspberrypi:~ $ sudo systemctl status influxdb
        ● influxdb.service - InfluxDB is an open-source, distributed, time series database
           Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
           Active: failed (Result: exit-code) since Sun 2020-12-20 19:07:54 CET; 26s ago
             Docs: https://docs.influxdata.com/influxdb/
          Process: 7963 ExecStart=/usr/bin/influxd -config /etc/influxdb/influxdb.conf $INFLUXD_OPTS (code=exited, status=1/FAILURE)
         Main PID: 7963 (code=exited, status=1/FAILURE)
        Dec 20 19:07:54 raspberrypi systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
        Dec 20 19:07:54 raspberrypi systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
        Dec 20 19:07:54 raspberrypi systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
        Dec 20 19:07:54 raspberrypi systemd[1]: influxdb.service: Start request repeated too quickly.
        Dec 20 19:07:54 raspberrypi systemd[1]: influxdb.service: Failed with result 'exit-code'.
        Dec 20 19:07:54 raspberrypi systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
        pi@raspberrypi:~ $ netstat -tulpen
        (Not all processes could be identified, non-owned process info
         will not be shown, you would have to be root to see it all.)
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       882108     -
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       881190     -
        tcp        0      0 192.168.178.41:2000     0.0.0.0:*               LISTEN      1001       887022     -
        tcp        0      0 192.168.178.41:2001     0.0.0.0:*               LISTEN      1001       884408     -
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15904      -
        tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       1015445    -
        tcp        0      0 192.168.178.41:8701     0.0.0.0:*               LISTEN      1001       886967     -
        tcp6       0      0 :::61991                :::*                    LISTEN      1001       883885     -
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       883049     -
        tcp6       0      0 :::8083                 :::*                    LISTEN      1001       885009     -
        tcp6       0      0 :::8084                 :::*                    LISTEN      1001       882261     -
        tcp6       0      0 :::22                   :::*                    LISTEN      0          15906      -
        tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       1015444    -
        tcp6       0      0 :::8090                 :::*                    LISTEN      1001       884598     -
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14271      -
        udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       883886     -
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       884062     -
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15151      -
        udp        0      0 0.0.0.0:43619           0.0.0.0:*                           108        14273      -
        udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       881469     -
        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       882347     -
        udp6       0      0 :::5353                 :::*                                108        14272      -
        udp6       0      0 :::546                  :::*                                0          18566      -
        udp6       0      0 :::51291                :::*                                108        14274      -
        pi@raspberrypi:~ $
        • A Altersrentner
          @crunchip
          pi@raspberrypi:~ $
          crunchipC Abwesend
          crunchipC Abwesend
          #44
          @Altersrentner so kommen wir nicht weiter, da is der Wurm drin und kann dir ehrlich gesagt, nicht sagen, wo der Fehler liegt.
          Ne Möglichkeit dann doch nochmal influx zu entfernen und frisch installieren.
          sudo apt-get autoremove influxdb
          danach nochmal eine installation anstoßen, bezieht sich auf ubuntu
          wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add -
          source /etc/lsb-release
          echo "deb https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
          sudo apt-get update && sudo apt-get install influxdb
          für debian
          source /etc/os-release
          echo "deb https://repos.influxdata.com/debian $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
          wenn fertig, prüfen ob der Dienst läuft
          A DuffyD 4 Antworten Letzte Antwort
            für debian
            Altersrentner
            schrieb am zuletzt editiert von Altersrentner
            #45
            @crunchip
            OK,
            Nach welcher Vorlage?
            pi@raspberrypi:~ $ sudo apt-get autoremove influxdb
            Reading package lists... Done
            Building dependency tree
            The following packages will be REMOVED:
              influxdb rpi-eeprom-images
            0 upgraded, 0 newly installed, 2 to remove and 0 not upgraded.
            After this operation, 153 MB disk space will be freed.
            Do you want to continue? [Y/n] y
            y
            (Reading database ... 61344 files and directories currently installed.)
            Removing influxdb (1.8.3-1) ...
            Removing rpi-eeprom-images (11.0-1) ...
            Processing triggers for man-db (2.8.5-2) ...
            pi@raspberrypi:~ $
            War es das schon?
            • A Altersrentner
              @crunchip
              OK,
              y
              pi@raspberrypi:~ $
              War es das schon?
              crunchipC Abwesend
              crunchipC Abwesend
              #46
              @Altersrentner scheint so,
              hab oben weiter ergänzt, zwecks Installation
                Altersrentner
                #47
                @crunchip
                Wo ist oben?
                Das sind die Angaben zu meinem System
                pi@raspberrypi:~ $ cat /proc/version
                Linux version 5.4.79-v7l+ (dom@buildbot) (gcc version 8.4.0 (Ubuntu/Linaro 8.4.0-3ubuntu1)) #1373 SMP Mon Nov 23 13:27:40                  GMT 2020
                pi@raspberrypi:~ $ uname -a
                Linux raspberrypi 5.4.79-v7l+ #1373 SMP Mon Nov 23 13:27:40 GMT 2020 armv7l GNU/Linux
                pi@raspberrypi:~ $ cat /etc/debian_version
                10.7
                pi@raspberrypi:~ $
                • A Altersrentner
                  @crunchip
                  Wo ist oben?
                  10.7
                  pi@raspberrypi:~ $
                  crunchipC Abwesend
                  crunchipC Abwesend
                  #48
                  @Altersrentner sagte in Problem bei Influx Installation:
                  Wo ist oben?
                  https://forum.iobroker.net/post/541116
                  ah moment stop, Ubuntu
                  @Altersrentner sorry, war grad abgelenkt, hatte kleinen zwischenfall,
                  also debian läuft?, dann war ich doch richtig, mit der Anleitung
                    für debian
                    Altersrentner
                    #49
                    @crunchip
                    Zeile 2 ?
                    pi@raspberrypi:~ $ wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add -
                    OK
                    pi@raspberrypi:~ $ source /etc/lsb-release
                    -bash: /etc/lsb-release: No such file or directory
                    pi@raspberrypi:~ $ sudo source /etc/lsb-release
                    sudo: source: command not found
                    pi@raspberrypi:~ $
                    • A Altersrentner
                      @crunchip
                      Zeile 2 ?
                      OK
                      pi@raspberrypi:~ $
                      crunchipC Abwesend
                      crunchipC Abwesend
                      #50
                      @Altersrentner das sind doch ganze Befehle, guck mal selbst, auf der ganz normalen offiziellen Seite
                        für debian
                        Altersrentner
                        #51
                        @crunchip
                           Active: active (running) since Sun 2020-12-20 20:05:48 CET; 20s ago
                         Main PID: 4285 (influxd)
                            Tasks: 14 (limit: 4915)
                           CGroup: /system.slice/influxdb.service
                                   └─4285 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
                        Dec 20 20:05:49 raspberrypi influxd[4285]: ts=2020-12-20T19:05:49.999473Z lvl=info msg="Starting continuous query service" log_id=0RCOY820000 service
                        Dec 20 20:05:49 raspberrypi influxd[4285]: ts=2020-12-20T19:05:49.999496Z lvl=info msg="Starting HTTP service" log_id=0RCOY820000 service=httpd authe
                        Dec 20 20:05:49 raspberrypi influxd[4285]: ts=2020-12-20T19:05:49.999517Z lvl=info msg="opened HTTP access log" log_id=0RCOY820000 service=httpd path
                        Dec 20 20:05:49 raspberrypi influxd[4285]: ts=2020-12-20T19:05:49.999520Z lvl=info msg="Storing statistics" log_id=0RCOY820000 service=monitor db_ins
                        Dec 20 20:05:50 raspberrypi influxd[4285]: ts=2020-12-20T19:05:49.999745Z lvl=info msg="Listening on HTTP" log_id=0RCOY820000 service=httpd addr=[::]
                        Dec 20 20:05:50 raspberrypi influxd[4285]: ts=2020-12-20T19:05:49.999809Z lvl=info msg="Starting retention policy enforcement service" log_id=0RCOY82
                        Dec 20 20:05:50 raspberrypi influxd[4285]: ts=2020-12-20T19:05:50.000038Z lvl=info msg="Listening for signals" log_id=0RCOY820000
                        Dec 20 20:05:50 raspberrypi influxd[4285]: ts=2020-12-20T19:05:50.004535Z lvl=info msg="Sending usage statistics to usage.influxdata.com" log_id=0RCO
                        Dec 20 20:05:59 raspberrypi influxd[4285]: ts=2020-12-20T19:05:59.234954Z lvl=info msg="Executing query" log_id=0RCOY820000 service=query query="SHOW
                        Dec 20 20:05:59 raspberrypi influxd[4285]: [httpd] 192.168.178.41 - MEB [20/Dec/2020:20:05:59 +0100] "GET /query?db=iobroker&p=%5BREDACTED%5D&precisi
                        lines 1-19/19 (END)
                        Sieht das gut aus?
                        • A Altersrentner
                          @crunchip
                          lines 1-19/19 (END)
                          Sieht das gut aus?
                          crunchipC Abwesend
                          crunchipC Abwesend
                          #52
                          @Altersrentner 👍
                          A 2 Antworten Letzte Antwort
                            @Altersrentner 👍
                            Altersrentner
                            #53
                            @crunchip
                            Ich bedanke 👍 👍 👍 mich für Deine unendlichen Bemühungen
                            mir zu helfen.
                            Für heute ist Schluss.
                            Morgen ist auch noch ein Tag
                            Einen schönen Abend
                            wünscht Michael
                              @Altersrentner 👍
                              Altersrentner
                              #54
                              @crunchip Hallo,
                              Der Ärger geht weiter.
                              Heute Morgen war noch alles im grünen Bereich.
                              Influydb lief, und der influxdb.0 Adapter war auch grün.
                              Dann hatte ich grafana installiert.
                              Konnte über Port 3000 zugreifen.
                              Bei der Dateneingabe verlief alles gut nur bei Host war
                              localhost vorgegeben. konnte auch nicht in IP geändert werden.
                              Nach Sicherung kam die Meldung keine Verbindung möglich.
                              Darauf habe ich in der influxdb.0 die iP in localhost geändert,
                              in derHoffnung eine Verbindung zu bekommen.
                              Leider klappte das nicht.
                              Nach zurücksetzen localhost in IP bleibt die Ampel jetzt auf gelb.
                              Habe dann grafana und den influxdb.0 Adapter deinstalliert.
                              Adapter neu installiert, daten eingegeben, gestartet und die Ampel bleibt gelb.
                              Im Terminal influxdb überprüft. alles ok, läuft.
                              Das ist die Fehlermeldung aus dem log.
                              influxdb.0	2020-12-21 11:05:35.664	error	(1453) Error: authorization failed
                              influxdb.0	2020-12-21 11:05:35.659	info	(1453) Connecting http://192.168.178.41:8086 ...
                              Juser und Paswort im Adapter sind die, In influxdb eingegebenen.
                              Hast Du noch eine Idee?
                              Gruß Michael
                              • A Altersrentner
                                @crunchip Hallo,
                                Gruß Michael
                                crunchipC Abwesend
                                crunchipC Abwesend
                                #55
                                @Altersrentner auf die schnelle nicht, da ich unterwegs bin. Möglich, das sich ein Leerzeichen oder so mit eingeschlichen hat?
                                  Altersrentner
                                  #56
                                  @crunchip Hallo,
                                  Ich muss mich doch noch mal um Hilfe bitten.
                                  Nicht das jemand denkt ich bin zu düsig! aber es geling mir nicht
                                  Influxdb zu konfigurieren.
                                  Mehrmaliges löschen und wieder installieren hat nichts gebracht.
                                  Ich komme immer bis zu diesem Punkt:
                                  OK
                                  pi@raspberrypi:~ $ source /etc/os-release
                                  pi@raspberrypi:~ $ echo "deb https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
                                  deb https://repos.influxdata.com/  stable
                                  pi@raspberrypi:~ $ sudo apt update
                                  E: Malformed entry 1 in list file /etc/apt/sources.list.d/influxdb.list (Component)
                                  E: The list of sources could not be read.
                                  pi@raspberrypi:~ $ echo "deb https://repos.influxdata.com/debian $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
                                  deb https://repos.influxdata.com/debian buster stable
                                  Get:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
                                  Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                                  Hit:3 https://deb.nodesource.com/node_10.x buster InRelease
                                  Hit:4 https://repos.influxdata.com/debian buster InRelease
                                  Fetched 15.0 kB in 2s (9,888 B/s)
                                  All packages are up to date.
                                  pi@raspberrypi:~ $ sudo apt install influxdb
                                  The following NEW packages will be installed:
                                    influxdb
                                  0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                                  Need to get 0 B/60.0 MB of archives.
                                  After this operation, 153 MB of additional disk space will be used.
                                  Selecting previously unselected package influxdb.
                                  (Reading database ... 63673 files and directories currently installed.)
                                  Preparing to unpack .../influxdb_1.8.3-1_armhf.deb ...
                                  Unpacking influxdb (1.8.3-1) ...
                                  Setting up influxdb (1.8.3-1) ...
                                  pi@raspberrypi:~ $ sudo systemctl status influxdb.service
                                     Active: active (running) since Tue 2020-12-22 11:44:21 CET; 3h 12min ago
                                   Main PID: 5478 (influxd)
                                             └─5478 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
                                  Dec 22 14:55:30 raspberrypi influxd[5478]: ts=2020-12-22T13:55:30.303321Z lvl=info msg="failed to store statistic
                                  Dec 22 14:55:40 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:55:40 +0100] "GET /query?db=
                                  Dec 22 14:55:40 raspberrypi influxd[5478]: ts=2020-12-22T13:55:40.504680Z lvl=info msg="failed to store statistic
                                  Dec 22 14:55:50 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:55:50 +0100] "GET /query?db=
                                  Dec 22 14:56:00 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:56:00 +0100] "GET /query?db=
                                  Dec 22 14:56:10 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:56:10 +0100] "GET /query?db=
                                  Dec 22 14:56:21 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:56:20 +0100] "GET /query?db=
                                  Dec 22 14:56:31 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:56:31 +0100] "GET /query?db=
                                  Dec 22 14:56:41 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:56:41 +0100] "GET /query?db=
                                  Dec 22 14:56:51 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:56:51 +0100] "GET /query?db=
                                  pi@raspberrypi:~ $ sudo systemctl enable influxdb.service
                                  pi@raspberrypi:~ $
                                  pi@raspberrypi:~ $
                                  pi@raspberrypi:~ $ sudo influx
                                  Connected to http://localhost:8086 version 1.8.3
                                  InfluxDB shell version: 1.8.3
                                  > CREATE DATABASE "iobroker"
                                  ERR: unable to parse authentication credentials
                                  Warning: It is possible this error is due to not setting a database.
                                  Please set a database with the command "use <database>".
                                  Alles was danach versucht wird einzugeben wird mit der
                                  letzten Fehlermeldung beantwortet
                                  Die influxdb.0 Ampel ist gelb.
                                  Dortige Eingaben sind wie gehabt
                                  Auch USE "iobroker" bringt das selbe Ergebnis.
                                  > auth
                                  username: admin
                                  password:
                                  > show database
                                  ERR: authorization failed
                                  > show databases
                                  Gestern habe ich eine andere Speicherkarte neu aufgesetzt.
                                  Rasphian buster und iobroker installiert und
                                  dort hat die Installation von influxdb und Grafana auf Anhieb geklappt.
                                  Ich vermute, das es in einer Konfigurationsdatei Einträge gibt,
                                  die diese Fehlermeldungen herforrufen.
                                  Freundliche Grüße
                                  Michael
                                  crunchipC 2 Antworten Letzte Antwort
                                  • A Altersrentner
                                    @crunchip Hallo,
                                    OK
                                      influxdb
                                    pi@raspberrypi:~ $
                                    pi@raspberrypi:~ $
                                    > auth
                                    username: admin
                                    password:
                                    > show database
                                    > show databases
                                    Freundliche Grüße
                                    Michael
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    #57
                                    @Altersrentner du kannst influx löschen incl aller Abhängigkeiten und Konfigurationseinstellungen, mittels
                                    sudo apt-get autoremove --purge influxdb
                                    Anschliessend kannst du sauber neu installieren
                                    Und wenn du schon beim installieren bist, warum nicht gleich die neuste Version?
                                    https://portal.influxdata.com/downloads/
                                    Influxdb v 2.0.3
                                      Influxdb v 2.0.3
                                      #58
                                      @crunchip sagte in Problem bei Influx Installation:
                                      Weil's da keinen passenden build für 32bit Raspian OS gibt. Alles arm64.
                                      A crunchipC 2 Antworten Letzte Antwort
                                        Altersrentner
                                        #59
                                        @Thomas-Braun Hallo,
                                        So habe ich das auch gesehen!??
                                        Gruß Michael
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          #60
                                          @Thomas-Braun stimmt, hatte ich nicht dran gedacht🤦 geht ja um nen raspberry
