  4. [ Geklärt ] Problem bei Influx Installation
    6.4k
influxdb
178 Beiträge 12 Kommentatoren 43.0k Aufrufe 11 Beobachtet
  • A Altersrentner
    @crunchip
    jetzt wird influx nicht mehr gefunden
    pi@raspberrypi:~ $ sudo iobroker stop
    pi@raspberrypi:~ $ sudo iobroker restart
    pi@raspberrypi:~ $ sudo systemctl daemon-reload
    pi@raspberrypi:~ $ sudo systemctl enable influxdb
    pi@raspberrypi:~ $ sudo systemctl start influxdb
    pi@raspberrypi:~ $ sudo systemctl status influx
    Unit influx.service could not be found.
    pi@raspberrypi:~ $
    crunchipC Abwesend
    crunchipC Abwesend
    @Altersrentner mein Fehler
    sudo systemctl status influxdb
    A 1 Antwort Letzte Antwort
      Altersrentner
      @crunchip
      pi@raspberrypi:~ $ sudo systemctl status influxdb
      ● influxdb.service - InfluxDB is an open-source, distributed, time series database
         Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
         Active: failed (Result: exit-code) since Sun 2020-12-20 14:47:04 CET; 12min ago
           Docs: https://docs.influxdata.com/influxdb/
        Process: 22523 ExecStart=/usr/bin/influxd -config /etc/influxdb/influxdb.conf $INFLUXD_OPTS (code=exited, status=1/FAILURE)
       Main PID: 22523 (code=exited, status=1/FAILURE)
      Dec 20 14:47:04 raspberrypi systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
      Dec 20 14:47:04 raspberrypi systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
      Dec 20 14:47:04 raspberrypi systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
      Dec 20 14:47:04 raspberrypi systemd[1]: influxdb.service: Start request repeated too quickly.
      Dec 20 14:47:04 raspberrypi systemd[1]: influxdb.service: Failed with result 'exit-code'.
      Dec 20 14:47:04 raspberrypi systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
      pi@raspberrypi:~ $
      konnte nicht gestartet werden
      • A Altersrentner
        @crunchip
        pi@raspberrypi:~ $
        crunchipC Abwesend
        crunchipC Abwesend
        @Altersrentner weil ich gerade systemd.... lese
        geb mal folgendes ein
        sudo systemctl unmask influxdb.service
        und prüfe danach ob der service läuft
          Altersrentner
          @crunchip
          pi@raspberrypi:~ $ sudo systemctl unmask influxdb.service
          pi@raspberrypi:~ $ sudo influxd
           8888888           .d888 888                   8888888b.  888888b.
             888            d88P"  888                   888  "Y88b 888  "88b
             888            888    888                   888    888 888  .88P
             888   88888b.  888888 888 888  888 888  888 888    888 8888888K.
             888   888 "88b 888    888 888  888  Y8bd8P' 888    888 888  "Y88b
             888   888  888 888    888 888  888   X88K   888    888 888    888
             888   888  888 888    888 Y88b 888 .d8""8b. 888  .d88P 888   d88P
           8888888 888  888 888    888  "Y88888 888  888 8888888P"  8888888P"
          2020-12-20T14:15:35.152027Z     info    InfluxDB starting       {"log_id": "0RC7wJwl000", "version": "1.8.3", "branch": "1.8", "commit": "563e6c3d1a7a2790763c6289501095dbec19244e"}
          2020-12-20T14:15:35.152128Z     info    Go runtime      {"log_id": "0RC7wJwl000", "version": "go1.13.8", "maxprocs": 4}
          2020-12-20T14:15:35.253479Z     info    Using data dir  {"log_id": "0RC7wJwl000", "service": "store", "path": "/var/lib/influxdb/data"}
          2020-12-20T14:15:35.253597Z     info    Compaction settings     {"log_id": "0RC7wJwl000", "service": "store", "max_concurrent_compactions": 2, "throughput_bytes_per_second": 50331648, "throughput_bytes_per_second_burst": 50331648}
          2020-12-20T14:15:35.253674Z     info    Open store (start)      {"log_id": "0RC7wJwl000", "service": "store", "trace_id": "0RC7wKLG000", "op_name": "tsdb_open", "op_event": "start"}
          2020-12-20T14:15:35.257327Z     info    Reading file    {"log_id": "0RC7wJwl000", "engine": "tsm1", "service": "cacheloader", "path": "/var/lib/influxdb/wal/_internal/monitor/1/_00001.wal", "size": 132881}
          2020-12-20T14:15:37.573216Z     info    Opened shard    {"log_id": "0RC7wJwl000", "service": "store", "trace_id": "0RC7wKLG000", "op_name": "tsdb_open", "index_version": "inmem", "path": "/var/lib/influxdb/data/_internal/monitor/1", "duration": "2317.079ms"}
          2020-12-20T14:15:37.573402Z     info    Open store (end)        {"log_id": "0RC7wJwl000", "service": "store", "trace_id": "0RC7wKLG000", "op_name": "tsdb_open", "op_event": "end", "op_elapsed": "2319.731ms"}
          2020-12-20T14:15:37.573525Z     info    Opened service  {"log_id": "0RC7wJwl000", "service": "subscriber"}
          2020-12-20T14:15:37.573570Z     info    Starting monitor service        {"log_id": "0RC7wJwl000", "service": "monitor"}
          2020-12-20T14:15:37.573611Z     info    Registered diagnostics client   {"log_id": "0RC7wJwl000", "service": "monitor", "name": "build"}
          2020-12-20T14:15:37.573649Z     info    Registered diagnostics client   {"log_id": "0RC7wJwl000", "service": "monitor", "name": "runtime"}
          2020-12-20T14:15:37.573688Z     info    Registered diagnostics client   {"log_id": "0RC7wJwl000", "service": "monitor", "name": "network"}
          2020-12-20T14:15:37.573737Z     info    Registered diagnostics client   {"log_id": "0RC7wJwl000", "service": "monitor", "name": "system"}
          2020-12-20T14:15:37.573810Z     info    Starting precreation service    {"log_id": "0RC7wJwl000", "service": "shard-precreation", "check_interval": "10m", "advance_period": "30m"}
          2020-12-20T14:15:37.573888Z     info    Starting snapshot service       {"log_id": "0RC7wJwl000", "service": "snapshot"}
          2020-12-20T14:15:37.573929Z     info    Starting continuous query service       {"log_id": "0RC7wJwl000", "service": "continuous_querier"}
          2020-12-20T14:15:37.573983Z     info    Starting HTTP service   {"log_id": "0RC7wJwl000", "service": "httpd", "authentication": false}
          2020-12-20T14:15:37.574022Z     info    opened HTTP access log  {"log_id": "0RC7wJwl000", "service": "httpd", "path": "stderr"}
          2020-12-20T14:15:37.574321Z     info    Storing statistics      {"log_id": "0RC7wJwl000", "service": "monitor", "db_instance": "_internal", "db_rp": "monitor", "interval": "10s"}
          2020-12-20T14:15:37.574445Z     info    Listening on HTTP       {"log_id": "0RC7wJwl000", "service": "httpd", "addr": "[::]:8086", "https": false}
          2020-12-20T14:15:37.574529Z     info    Starting retention policy enforcement service   {"log_id": "0RC7wJwl000", "service": "retention", "check_interval": "30m"}
          2020-12-20T14:15:37.574895Z     info    Sending usage statistics to usage.influxdata.com        {"log_id": "0RC7wJwl000"}
          2020-12-20T14:15:37.575398Z     info    Listening for signals   {"log_id": "0RC7wJwl000"}
          2020-12-20T14:15:43.954822Z     info    Executing query {"log_id": "0RC7wJwl000", "service": "query", "query": "SHOW DATABASES"}
          [httpd] 192.168.178.41 - MEB [20/Dec/2020:15:15:43 +0100] "GET /query?db=iobroker&p=%5BREDACTED%5D&precision=ms&q=show+databases&u=MEB HTTP/1.1" 200 122 "-" "-" d8e47f87-42cd-11eb-8001-dca6321bbd83 5504
          • A Altersrentner
            @crunchip
            crunchipC Abwesend
            crunchipC Abwesend
            @Altersrentner sudo systemctl status influxdb
              Altersrentner
              @crunchip
              Jetzt hat der influxdb.0 Adapter auf grün gewechselt.😊
              Wenn ich aber auf "Verbindung testen" gehe,
              gibt es keine Reaktion.
              Ist das normal?
              • A Altersrentner
                @crunchip
                Ist das normal?
                crunchipC Abwesend
                crunchipC Abwesend
                @Altersrentner sagte in Problem bei Influx Installation:
                im Iobroker? ja
                  im Iobroker? ja
                  Altersrentner
                  @crunchip
                  ja im ioBroker.
                  Aber im Terminal wird immer noch "keine Verbindung" angezeigt.
                  Womit soll er sich dann auch verbinden?
                  Kann ich influxdb deinstallieren und neu aufsetzen?
                  Könnte das zu einer Lösung beitragen?
                  • A Altersrentner
                    @crunchip
                    ja im ioBroker.
                    crunchipC Abwesend
                    crunchipC Abwesend
                    @Altersrentner verstehe ich gerade nicht ganz was du meinst?
                    welche Verbindung funktioniert nicht?
                      Altersrentner
                      schrieb am zuletzt editiert von Altersrentner
                      @crunchip
                      Failed to connect to http://localhost:8086: Get http://localhost:8086/ping: dial tcp [::1]:8086: connect: connection refused
                      Please check your connection settings and ensure 'influxd' is running.
                      pi@raspberrypi:~ $
                      und die Ampel vom influxdb ist wieder auf gelb
                      • A Altersrentner
                        @crunchip
                        pi@raspberrypi:~ $
                        crunchipC Abwesend
                        crunchipC Abwesend
                        @Altersrentner dann jetzt nochmal von vorne
                        • hast du irgend etwas anderes noch gemacht?
                        • was zeigt der status an, läuft influx?
                          Altersrentner
                          @crunchip
                          Nein, ich habe nichts weiter gemacht,
                          Ampel ist jetzt wieder grün.
                          pi@raspberrypi:~ $
                          HALH crunchipC 2 Antworten Letzte Antwort
                          • A Altersrentner
                            @crunchip
                            pi@raspberrypi:~ $
                            HALH Offline
                            HALH Offline
                            HAL
                            @Altersrentner hiernach hat bei mir die Installation von influxb problemlos geklappt
                            lnfluxdb Raspberry
                            Alle Raspberry ( 5 ) gegen NUC (N100, 16GB Ram und 500GB M2 SSD, extern 2TB SSD ) mit Proxmox 8.3.3 gewechselt. Läuft absolut super !
                            (Iobroker, Grafana, Teslalogger, Nextcloud, go2rtc, PiHole, IOB-VIS2, Teslamate, homeassistant nur als test)
                            SegwayS A 2 Antworten Letzte Antwort
                            • HALH HAL
                              lnfluxdb Raspberry
                              SegwayS Offline
                              SegwayS Offline
                              Segway
                              Ich nehme immer die offizielle Herstellerseite --> H I E R
                              Da bin ich sicher immer alles aktuell zu haben und das das Setup auch klappt. Alles andere kann und meistens ist es auch so dann veraltet sein ! Das gibt nur Probleme
                              Gruß Dirk
                              • A Altersrentner
                                @crunchip
                                pi@raspberrypi:~ $
                                crunchipC Abwesend
                                crunchipC Abwesend
                                @Altersrentner ich wollte wissen, ob der status grün ist/bzw aktiv
                                • HALH HAL
                                  lnfluxdb Raspberry
                                  Altersrentner
                                  @HAL
                                  kann ich das so drüber installieren oder meine Installation löschen?
                                  Aber wie!!
                                    Altersrentner
                                    @crunchip
                                    Hatte ich leider übersehen, Entschuldigung
                                    Nein
                                       Active: failed (Result: exit-code) since Sun 2020-12-20 18:04:01 CET; 13min ago
                                     Main PID: 30313 (code=exited, status=1/FAILURE)
                                    Dec 20 18:04:01 raspberrypi systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling r
                                    Dec 20 18:04:01 raspberrypi systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5
                                    Dec 20 18:04:01 raspberrypi systemd[1]: Stopped InfluxDB is an open-source, distributed, time series dat
                                    Dec 20 18:04:01 raspberrypi systemd[1]: influxdb.service: Start request repeated too quickly.
                                    Dec 20 18:04:01 raspberrypi systemd[1]: influxdb.service: Failed with result 'exit-code'.
                                    Dec 20 18:04:01 raspberrypi systemd[1]: Failed to start InfluxDB is an open-source, distributed, time se
                                    lines 1-12/12 (END)
                                    Dec 20 18:04:01 raspberrypi systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
                                    Dec 20 18:04:01 raspberrypi systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
                                    Dec 20 18:04:01 raspberrypi systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
                                    Dec 20 18:04:01 raspberrypi systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
                                    lines 1-12/12 (END)
                                    lines 1-12/12 (END)
                                    • A Altersrentner
                                      @crunchip
                                      Nein
                                      lines 1-12/12 (END)
                                      lines 1-12/12 (END)
                                      lines 1-12/12 (END)
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      @Altersrentner na irgend etwas ist da bei dir faul
                                      probier bitte nochmal in der Reihenfolge
                                      sudo systemctl stop influxdb
                                        Altersrentner
                                        @crunchip
                                        pi@raspberrypi:~ $ sudo systemctl stop influxdb
                                           Active: failed (Result: exit-code) since Sun 2020-12-20 18:39:16 CET; 17s ago
                                          Process: 3797 ExecStart=/usr/bin/influxd -config /etc/influxdb/influxdb.conf $INFLUXD_OPTS (code=exited, status=1/FAILURE)
                                         Main PID: 3797 (code=exited, status=1/FAILURE)
                                        Dec 20 18:39:16 raspberrypi systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
                                        Dec 20 18:39:16 raspberrypi systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
                                        Dec 20 18:39:16 raspberrypi systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
                                        Dec 20 18:39:16 raspberrypi systemd[1]: influxdb.service: Start request repeated too quickly.
                                        Dec 20 18:39:16 raspberrypi systemd[1]: influxdb.service: Failed with result 'exit-code'.
                                        Dec 20 18:39:16 raspberrypi systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
                                        pi@raspberrypi:~ $
                                        Ampel ist grün
                                        • A Altersrentner
                                          @crunchip
                                          pi@raspberrypi:~ $
                                          Ampel ist grün
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          @Altersrentner die Ampel interessiert momentan nicht, da dein influx-service nicht läuft, Zeile 7
                                          hast du in der
                                          irgendwas geändert/angepasst?
