  4. [ Geklärt ] Problem bei Influx Installation
    6.5k
influxdb
178 Beiträge 12 Kommentatoren 43.0k Aufrufe 11 Beobachtet
    @Altersrentner weil ich gerade systemd.... lese
    geb mal folgendes ein
    sudo systemctl unmask influxdb.service
    sudo systemctl start influxdb
    und prüfe danach ob der service läuft
    Altersrentner
    @crunchip
    pi@raspberrypi:~ $ sudo systemctl unmask influxdb.service
    pi@raspberrypi:~ $ sudo systemctl start influxdb
    pi@raspberrypi:~ $ sudo influxd
     8888888           .d888 888                   8888888b.  888888b.
       888            d88P"  888                   888  "Y88b 888  "88b
       888            888    888                   888    888 888  .88P
       888   88888b.  888888 888 888  888 888  888 888    888 8888888K.
       888   888 "88b 888    888 888  888  Y8bd8P' 888    888 888  "Y88b
       888   888  888 888    888 888  888   X88K   888    888 888    888
       888   888  888 888    888 Y88b 888 .d8""8b. 888  .d88P 888   d88P
     8888888 888  888 888    888  "Y88888 888  888 8888888P"  8888888P"
    2020-12-20T14:15:35.152027Z     info    InfluxDB starting       {"log_id": "0RC7wJwl000", "version": "1.8.3", "branch": "1.8", "commit": "563e6c3d1a7a2790763c6289501095dbec19244e"}
    2020-12-20T14:15:35.152128Z     info    Go runtime      {"log_id": "0RC7wJwl000", "version": "go1.13.8", "maxprocs": 4}
    2020-12-20T14:15:35.253479Z     info    Using data dir  {"log_id": "0RC7wJwl000", "service": "store", "path": "/var/lib/influxdb/data"}
    2020-12-20T14:15:35.253597Z     info    Compaction settings     {"log_id": "0RC7wJwl000", "service": "store", "max_concurrent_compactions": 2, "throughput_bytes_per_second": 50331648, "throughput_bytes_per_second_burst": 50331648}
    2020-12-20T14:15:35.253674Z     info    Open store (start)      {"log_id": "0RC7wJwl000", "service": "store", "trace_id": "0RC7wKLG000", "op_name": "tsdb_open", "op_event": "start"}
    2020-12-20T14:15:35.257327Z     info    Reading file    {"log_id": "0RC7wJwl000", "engine": "tsm1", "service": "cacheloader", "path": "/var/lib/influxdb/wal/_internal/monitor/1/_00001.wal", "size": 132881}
    2020-12-20T14:15:37.573216Z     info    Opened shard    {"log_id": "0RC7wJwl000", "service": "store", "trace_id": "0RC7wKLG000", "op_name": "tsdb_open", "index_version": "inmem", "path": "/var/lib/influxdb/data/_internal/monitor/1", "duration": "2317.079ms"}
    2020-12-20T14:15:37.573402Z     info    Open store (end)        {"log_id": "0RC7wJwl000", "service": "store", "trace_id": "0RC7wKLG000", "op_name": "tsdb_open", "op_event": "end", "op_elapsed": "2319.731ms"}
    2020-12-20T14:15:37.573525Z     info    Opened service  {"log_id": "0RC7wJwl000", "service": "subscriber"}
    2020-12-20T14:15:37.573570Z     info    Starting monitor service        {"log_id": "0RC7wJwl000", "service": "monitor"}
    2020-12-20T14:15:37.573611Z     info    Registered diagnostics client   {"log_id": "0RC7wJwl000", "service": "monitor", "name": "build"}
    2020-12-20T14:15:37.573649Z     info    Registered diagnostics client   {"log_id": "0RC7wJwl000", "service": "monitor", "name": "runtime"}
    2020-12-20T14:15:37.573688Z     info    Registered diagnostics client   {"log_id": "0RC7wJwl000", "service": "monitor", "name": "network"}
    2020-12-20T14:15:37.573737Z     info    Registered diagnostics client   {"log_id": "0RC7wJwl000", "service": "monitor", "name": "system"}
    2020-12-20T14:15:37.573810Z     info    Starting precreation service    {"log_id": "0RC7wJwl000", "service": "shard-precreation", "check_interval": "10m", "advance_period": "30m"}
    2020-12-20T14:15:37.573888Z     info    Starting snapshot service       {"log_id": "0RC7wJwl000", "service": "snapshot"}
    2020-12-20T14:15:37.573929Z     info    Starting continuous query service       {"log_id": "0RC7wJwl000", "service": "continuous_querier"}
    2020-12-20T14:15:37.573983Z     info    Starting HTTP service   {"log_id": "0RC7wJwl000", "service": "httpd", "authentication": false}
    2020-12-20T14:15:37.574022Z     info    opened HTTP access log  {"log_id": "0RC7wJwl000", "service": "httpd", "path": "stderr"}
    2020-12-20T14:15:37.574321Z     info    Storing statistics      {"log_id": "0RC7wJwl000", "service": "monitor", "db_instance": "_internal", "db_rp": "monitor", "interval": "10s"}
    2020-12-20T14:15:37.574445Z     info    Listening on HTTP       {"log_id": "0RC7wJwl000", "service": "httpd", "addr": "[::]:8086", "https": false}
    2020-12-20T14:15:37.574529Z     info    Starting retention policy enforcement service   {"log_id": "0RC7wJwl000", "service": "retention", "check_interval": "30m"}
    2020-12-20T14:15:37.574895Z     info    Sending usage statistics to usage.influxdata.com        {"log_id": "0RC7wJwl000"}
    2020-12-20T14:15:37.575398Z     info    Listening for signals   {"log_id": "0RC7wJwl000"}
    2020-12-20T14:15:43.954822Z     info    Executing query {"log_id": "0RC7wJwl000", "service": "query", "query": "SHOW DATABASES"}
    [httpd] 192.168.178.41 - MEB [20/Dec/2020:15:15:43 +0100] "GET /query?db=iobroker&p=%5BREDACTED%5D&precision=ms&q=show+databases&u=MEB HTTP/1.1" 200 122 "-" "-" d8e47f87-42cd-11eb-8001-dca6321bbd83 5504
    • A Altersrentner
      @crunchip
      crunchipC Abwesend
      crunchipC Abwesend
      @Altersrentner sudo systemctl status influxdb
        Altersrentner
        @crunchip
        Jetzt hat der influxdb.0 Adapter auf grün gewechselt.😊
        Wenn ich aber auf "Verbindung testen" gehe,
        gibt es keine Reaktion.
        Ist das normal?
        • A Altersrentner
          @crunchip
          Ist das normal?
          crunchipC Abwesend
          crunchipC Abwesend
          @Altersrentner sagte in Problem bei Influx Installation:
          im Iobroker? ja
            im Iobroker? ja
            Altersrentner
            @crunchip
            ja im ioBroker.
            Aber im Terminal wird immer noch "keine Verbindung" angezeigt.
            Womit soll er sich dann auch verbinden?
            Kann ich influxdb deinstallieren und neu aufsetzen?
            Könnte das zu einer Lösung beitragen?
            • A Altersrentner
              @crunchip
              ja im ioBroker.
              crunchipC Abwesend
              crunchipC Abwesend
              @Altersrentner verstehe ich gerade nicht ganz was du meinst?
              welche Verbindung funktioniert nicht?
                Altersrentner
                schrieb am zuletzt editiert von Altersrentner
                @crunchip
                Failed to connect to http://localhost:8086: Get http://localhost:8086/ping: dial tcp [::1]:8086: connect: connection refused
                Please check your connection settings and ensure 'influxd' is running.
                pi@raspberrypi:~ $
                und die Ampel vom influxdb ist wieder auf gelb
                • A Altersrentner
                  @crunchip
                  pi@raspberrypi:~ $
                  crunchipC Abwesend
                  crunchipC Abwesend
                  @Altersrentner dann jetzt nochmal von vorne
                  • hast du irgend etwas anderes noch gemacht?
                  • was zeigt der status an, läuft influx?
                    Altersrentner
                    @crunchip
                    Nein, ich habe nichts weiter gemacht,
                    Ampel ist jetzt wieder grün.
                    pi@raspberrypi:~ $
                    HALH crunchipC 2 Antworten Letzte Antwort
                    • A Altersrentner
                      @crunchip
                      pi@raspberrypi:~ $
                      HALH Offline
                      HALH Offline
                      HAL
                      @Altersrentner hiernach hat bei mir die Installation von influxb problemlos geklappt
                      lnfluxdb Raspberry
                      Alle Raspberry ( 5 ) gegen NUC (N100, 16GB Ram und 500GB M2 SSD, extern 2TB SSD ) mit Proxmox 8.3.3 gewechselt. Läuft absolut super !
                      (Iobroker, Grafana, Teslalogger, Nextcloud, go2rtc, PiHole, IOB-VIS2, Teslamate, homeassistant nur als test)
                      SegwayS A 2 Antworten Letzte Antwort
                      • HALH HAL
                        lnfluxdb Raspberry
                        SegwayS Offline
                        SegwayS Offline
                        Segway
                        Ich nehme immer die offizielle Herstellerseite --> H I E R
                        Da bin ich sicher immer alles aktuell zu haben und das das Setup auch klappt. Alles andere kann und meistens ist es auch so dann veraltet sein ! Das gibt nur Probleme
                        Gruß Dirk
                        • A Altersrentner
                          @crunchip
                          pi@raspberrypi:~ $
                          crunchipC Abwesend
                          crunchipC Abwesend
                          @Altersrentner ich wollte wissen, ob der status grün ist/bzw aktiv
                          • HALH HAL
                            lnfluxdb Raspberry
                            Altersrentner
                            @HAL
                            kann ich das so drüber installieren oder meine Installation löschen?
                            Aber wie!!
                              Altersrentner
                              @crunchip
                              Hatte ich leider übersehen, Entschuldigung
                              Nein
                              pi@raspberrypi:~ $ sudo systemctl status influxdb
                              ● influxdb.service - InfluxDB is an open-source, distributed, time series database
                                 Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
                                 Active: failed (Result: exit-code) since Sun 2020-12-20 18:04:01 CET; 13min ago
                                   Docs: https://docs.influxdata.com/influxdb/
                               Main PID: 30313 (code=exited, status=1/FAILURE)
                              Dec 20 18:04:01 raspberrypi systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling r
                              Dec 20 18:04:01 raspberrypi systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5
                              Dec 20 18:04:01 raspberrypi systemd[1]: Stopped InfluxDB is an open-source, distributed, time series dat
                              Dec 20 18:04:01 raspberrypi systemd[1]: influxdb.service: Start request repeated too quickly.
                              Dec 20 18:04:01 raspberrypi systemd[1]: influxdb.service: Failed with result 'exit-code'.
                              Dec 20 18:04:01 raspberrypi systemd[1]: Failed to start InfluxDB is an open-source, distributed, time se
                              lines 1-12/12 (END)
                              Dec 20 18:04:01 raspberrypi systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
                              Dec 20 18:04:01 raspberrypi systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
                              Dec 20 18:04:01 raspberrypi systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
                              Dec 20 18:04:01 raspberrypi systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
                              lines 1-12/12 (END)
                              lines 1-12/12 (END)
                              • A Altersrentner
                                @crunchip
                                Nein
                                lines 1-12/12 (END)
                                lines 1-12/12 (END)
                                lines 1-12/12 (END)
                                crunchipC Abwesend
                                crunchipC Abwesend
                                @Altersrentner na irgend etwas ist da bei dir faul
                                probier bitte nochmal in der Reihenfolge
                                sudo systemctl stop influxdb
                                  Altersrentner
                                  @crunchip
                                  pi@raspberrypi:~ $ sudo systemctl stop influxdb
                                     Active: failed (Result: exit-code) since Sun 2020-12-20 18:39:16 CET; 17s ago
                                    Process: 3797 ExecStart=/usr/bin/influxd -config /etc/influxdb/influxdb.conf $INFLUXD_OPTS (code=exited, status=1/FAILURE)
                                   Main PID: 3797 (code=exited, status=1/FAILURE)
                                  Dec 20 18:39:16 raspberrypi systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
                                  Dec 20 18:39:16 raspberrypi systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
                                  Dec 20 18:39:16 raspberrypi systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
                                  Dec 20 18:39:16 raspberrypi systemd[1]: influxdb.service: Start request repeated too quickly.
                                  Dec 20 18:39:16 raspberrypi systemd[1]: influxdb.service: Failed with result 'exit-code'.
                                  Dec 20 18:39:16 raspberrypi systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
                                  pi@raspberrypi:~ $
                                  Ampel ist grün
                                  • A Altersrentner
                                    @crunchip
                                    pi@raspberrypi:~ $
                                    Ampel ist grün
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    @Altersrentner die Ampel interessiert momentan nicht, da dein influx-service nicht läuft, Zeile 7
                                    hast du in der
                                    irgendwas geändert/angepasst?
                                      hast du in der
                                      Altersrentner
                                      @crunchip NEIN!!
                                      • A Altersrentner
                                        @crunchip NEIN!!
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        @Altersrentner dann nochmal, mit enable...
                                        sudo systemctl enable influxdb
                                        netstat -tulpen
                                          netstat -tulpen
                                          Altersrentner
                                          @crunchip
                                          pi@raspberrypi:~ $ sudo systemctl enable influxdb
                                             Active: failed (Result: exit-code) since Sun 2020-12-20 19:07:54 CET; 26s ago
                                            Process: 7963 ExecStart=/usr/bin/influxd -config /etc/influxdb/influxdb.conf $INFLUXD_OPTS (code=exited, status=1/FAILURE)
                                           Main PID: 7963 (code=exited, status=1/FAILURE)
                                          Dec 20 19:07:54 raspberrypi systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
                                          Dec 20 19:07:54 raspberrypi systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
                                          Dec 20 19:07:54 raspberrypi systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
                                          Dec 20 19:07:54 raspberrypi systemd[1]: influxdb.service: Start request repeated too quickly.
                                          Dec 20 19:07:54 raspberrypi systemd[1]: influxdb.service: Failed with result 'exit-code'.
                                          Dec 20 19:07:54 raspberrypi systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
                                          pi@raspberrypi:~ $ netstat -tulpen
                                          (Not all processes could be identified, non-owned process info
                                           will not be shown, you would have to be root to see it all.)
                                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       882108     -
                                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       881190     -
                                          tcp        0      0 192.168.178.41:2000     0.0.0.0:*               LISTEN      1001       887022     -
                                          tcp        0      0 192.168.178.41:2001     0.0.0.0:*               LISTEN      1001       884408     -
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15904      -
                                          tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       1015445    -
                                          tcp        0      0 192.168.178.41:8701     0.0.0.0:*               LISTEN      1001       886967     -
                                          tcp6       0      0 :::61991                :::*                    LISTEN      1001       883885     -
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       883049     -
                                          tcp6       0      0 :::8083                 :::*                    LISTEN      1001       885009     -
                                          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       882261     -
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          15906      -
                                          tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       1015444    -
                                          tcp6       0      0 :::8090                 :::*                    LISTEN      1001       884598     -
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14271      -
                                          udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       883886     -
                                          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       884062     -
                                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15151      -
                                          udp        0      0 0.0.0.0:43619           0.0.0.0:*                           108        14273      -
                                          udp        0      0 0.0.0.0:9898            0.0.0.0:*                           1001       881469     -
                                          udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       882347     -
                                          udp6       0      0 :::5353                 :::*                                108        14272      -
                                          udp6       0      0 :::546                  :::*                                0          18566      -
                                          udp6       0      0 :::51291                :::*                                108        14274      -
                                          pi@raspberrypi:~ $
