  4. [ Geklärt ] Problem bei Influx Installation
    6.5k
influxdb
178 Beiträge 12 Kommentatoren 43.0k Aufrufe 11 Beobachtet
  • wendy2702W wendy2702
    @altersrentner Hatt ich zwar schon geschrieben kannst aber auch gerne nochmal hier schauen
    cat /etc/hosts
    Altersrentner
    #141
    @wendy2702
    Es erscheint wieder ein Error bei Grafana
    DEBUG] [grafana] - Start Grafana Backup ...
    [DEBUG] [grafana] - Created grafana_tmp directory
    [DEBUG] [grafana] - Created dashboard directory
    [DEBUG] [grafana] - Created dashboards_manually_restore directory
    [DEBUG] [grafana] - Created datasource directory
    [DEBUG] [grafana] - start Grafana request ...
    [DEBUG] [grafana] - Grafana is available ... Status: 200
    [DEBUG] [grafana] - Error on Grafana Dashoard Request: Error: Request failed with status code 401
    [DEBUG] [grafana] - start Grafana backup compress ...
    [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
    [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
    [DEBUG] [grafana] - cannot found Grafana Backup files
    [DEBUG] [grafana] - done
    [DEBUG] [cifs] - done
    [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_03_07-19_08_53_influx grafana_backupiobroker.tar.gz...
    • A Altersrentner
      @wendy2702
      crunchipC Offline
      crunchipC Offline
      #142
      @altersrentner sagte in [ Geklärt ] Problem bei Influx Installation:
      Falschen Benutzerdaten oder Api-Key falsch
      Grafana ist erreichbar (siehe Status 200)
      A 2 Antworten Letzte Antwort
        Altersrentner
        #143
        @crunchip
        Danke, habe jetzt beim Host die IP eingestellt
        und ein neuer Versuch
          Altersrentner
          #144
          @crunchip
          Started iobroker ...
          [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
          [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/homes/Backup/iobroker/minimalPi4 /opt/iobroker/backups
          Unable to find suitable address.
          [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/homes/Backup/iobroker/minimalPi4 /opt/iobroker/backups
          [DEBUG] [iobroker] - host.raspberrypi 14084 states saved
          [DEBUG] [iobroker] - host.raspberrypi 16331 objects saved
          [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_03_07-19_34_18_influx grafana2_backupiobroker.tar.gz
          [DEBUG] [iobroker] - done
          [DEBUG] [influxDB] - Start InfluxDB Backup ...
          [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
          [DEBUG] [influxDB] - Packed 15MB so far...
          [DEBUG] [influxDB] - Packed 47MB so far...
          [DEBUG] [influxDB] - Packed 79MB so far...
          [DEBUG] [influxDB] - Packed 149MB so far...
          [DEBUG] [influxDB] - Packed 235MB so far...
          [DEBUG] [influxDB] - Packed 313MB so far...
          [DEBUG] [influxDB] - Packed 405MB so far...
          [DEBUG] [influxDB] - Packed 481MB so far...
          [DEBUG] [influxDB] - Packed 562MB so far...
          [DEBUG] [influxDB] - Packed 646MB so far...
          [DEBUG] [influxDB] - Packed 727MB so far...
          [DEBUG] [influxDB] - Packed 817MB so far...
          [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2021_03_07-19_34_51_influx grafana2_backupiobroker.tar.gz
          [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
          [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
          [DEBUG] [influxDB] - done
          [DEBUG] [grafana] - Start Grafana Backup ...
          [DEBUG] [grafana] - found Dashboard: n1-aussen-wz
          [DEBUG] [grafana] - Backup created: /opt/iobroker/backups/grafana_2021_03_07-19_42_25_backupiobroker.tar.gz
          [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_03_07-19_34_18_influx grafana2_backupiobroker.tar.gz...
          [DEBUG] [googledrive] - Google Drive: Copy influxDB_2021_03_07-19_34_51_influx grafana2_backupiobroker.tar.gz...
          Ich glaube jetzt hat es geklappt👍 oder👎
          • A Altersrentner
            @crunchip
            crunchipC Offline
            crunchipC Offline
            #145
            @altersrentner sieht so aus, grafana und influx, dein cifs hast aber noch aktiv(was du ja nicht nutzt), also Haken noch raus bei Nas.
            aber deine Backups sind gemacht
            musst nur dran denken, das du bei deiner SSD Influx und Grafana installiert haben musst um das backup ein zu spielen
            A 1 Antwort Letzte Antwort
              Altersrentner
              #146
              @crunchip OK
              wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add -
              source /etc/os-release
              echo "deb https://repos.influxdata.com/debian $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
              sudo apt update
              sudo apt install -y influxdb
              sudo systemctl unmask influxdb.service
              sudo systemctl start influxdb.service
              sudo systemctl enable influxdb.service
              Damit installiere ich Influx.
              Kannst Du mir bitte noch den Code für Grafana mitteilen?
              Mit freundlichen Grüßen
              Michael
              • A Altersrentner
                @crunchip OK
                sudo apt update
                Michael
                crunchipC Offline
                crunchipC Offline
                #147
                @altersrentner
                apt-Schlüssel zufügen
                wget -q -O - https://packages.grafana.com/gpg.key | sudo apt-key add -
                grafana repository hinzufügen
                echo "deb https://packages.grafana.com/oss/deb stable main" | sudo tee -a /etc/apt/sources.list.d/grafana.list
                installieren
                sudo apt-get update
                sudo apt-get install -y grafana
                aktivieren und starten
                sudo /bin/systemctl enable grafana-server
                sudo /bin/systemctl start grafana-server
                aufrufen dann über http://<ip address>:3000
                Name und Kennwort ist standard
                admin
                admin
                  @altersrentner
                  installieren
                  sudo apt-get update
                  admin
                  admin
                  Altersrentner
                  #148
                  @crunchip D A N K E !
                  Michael
                    @altersrentner
                    installieren
                    sudo apt-get update
                    admin
                    admin
                    Altersrentner
                    #149
                    @crunchip Hallo,
                    Die neue SSD ist angeschlossen.
                    ioBroker läuft,
                    InfluxDB ist wieder hergestellt,
                    Influx Adapter ist grün,
                    Grafana ist wieder hergestellt,
                    API Key ist eingegeben
                    In vis kommt bei den Graphen die Meldung:
                    IP hat Verbindung abgelehnt.
                    Wenn ich Grafana öffne erscheinen meine angelegten
                    Dashboards nicht.
                    Gibt es eine Möglichkeit sie zu finden?
                    Ist das Protokoll so ok?
                    Michael
                    • A Altersrentner
                      @crunchip Hallo,
                      ioBroker läuft,
                      Dashboards nicht.
                      Michael
                      crunchipC Offline
                      crunchipC Offline
                      #150
                      du meinst bei der Einbindung eines Dashboards in vis? dein Rechner hat ja nun ne neue Ip oder? Dann stimmt ja der Pfad nicht mehr(IP).
                      in deinem Screen, sofern ichs richtig entziffern kann, steht dein api key, bez. Nutzername/Passwort falsch
                      du musst auch wieder die Grafana.ini bearbeiten
                      sudo nano /etc/grafana/grafana.ini
                      dort musst du folgende Einträge anppassen(ebenfalls das ; vor jeder dieser Zeilen entfernen, damit dies aktiv werden
                      orgName musst du natürlich mit deinem ersetzen
                      [security]
                      allow_embedding = true
                      [auth.anonymous]
                      enabled = true
                      org_name = Main Org.
                      org_role = Viewer
                      [users]
                      allow_sign_up = false
                      anschliesssend grafana-server neustarten
                      sudo service grafana-server restart
                      A 3 Antworten Letzte Antwort
                        [security]
                        [auth.anonymous]
                        enabled = true
                        org_role = Viewer
                        [users]
                        Altersrentner
                        #151
                        @crunchip sagte in [ Geklärt ] Problem bei Influx Installation:
                        Neindie IP ist geblieben. Benutzer und Passwort solten auch richtig sein..
                        Ich stecke nochmal die alte FP an. Mal sehen ob ich was finde
                        MfG Michael
                          [security]
                          [auth.anonymous]
                          enabled = true
                          org_role = Viewer
                          [users]
                          Altersrentner
                          #152
                          @crunchip
                          Bei mir steht ei Semikolon vor.
                          Bleibt das stehen?
                            [security]
                            [auth.anonymous]
                            enabled = true
                            org_role = Viewer
                            [users]
                            Altersrentner
                            #153
                            @crunchip
                            Die ini ist bearbeitet
                            DEBUG] [grafana] - Start Grafana Restore ...
                            [DEBUG] [grafana] - filename for restore: /opt/iobroker/backups/grafana_2021_03_08-02_18_32_backupiobroker.tar.gz
                            [DEBUG] [grafana] - Grafana tmp directory created: /opt/iobroker/backups/grafana_tmp
                            [DEBUG] [grafana] - start decompress
                            [DEBUG] [grafana] - Grafana request started
                            [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/datasource/InfluxDB-1.json
                            [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/datasource/InfluxDB.json
                            [DEBUG] [grafana] - datasoure restore "InfluxDB-1" finish: {"datasource":{"id":2,"uid":"s1r54cgRz","orgId":1,"name":"InfluxDB-1","type":"influxdb","typeLogoUrl":"","access":"proxy","url":"http://192.168.178.41:8086","password":"","user":"admin","database":"iobroker","basicAuth":false,"basicAuthUser":"","basicAuthPassword":"","withCredentials":false,"isDefault":false,"jsonData":{"httpMode":"GET"},"secureJsonFields":{},"version":1,"readOnly":false},"id":2,"message":"Datasource added","name":"InfluxDB-1"}
                            [DEBUG] [grafana] - cannot restore datasource "InfluxDB": "data source with the same name already exists"
                            [DEBUG] [grafana] - Try to Restore: /opt/iobroker/backups/grafana_tmp/dashboards/n1-aussen-wz.json
                            [DEBUG] [grafana] - cannot restore dashboard "n1-aussen-wz": {"message":"invalid API key"}
                            [DEBUG] [grafana] - Grafana request ended
                            [DEBUG] [grafana] - Grafana tmp directory was successfully deleted
                            [DEBUG] [grafana] - Grafana Restore completed successfully
                            [EXIT] Grafana restore done
                            Da stehen die Daten:
                            irgend etwas stimmt noch nicht
                            • A Altersrentner
                              @crunchip
                              crunchipC Offline
                              crunchipC Offline
                              #154
                              @altersrentner laut deinem log
                              • hast du ne InfluxDB.json und eine InfluxDB.json1, InfluxDB.json existiert aber scheinbar schon
                              • für n1-aussen-wz.json stimmt scheinbar dein api key nicht
                              ich bin da nicht so fit drin, da ich diese backup Funktion via backitup nicht verwende
                              du hast doch ein backup von Grafana erstellt grafana_2021_03_07-19_42_25_backupiobroker.tar.gz und dieses muss zurückgespielt werden.
                              was beinhaltet dieses backup?
                                Altersrentner
                                #155
                                @crunchip
                                Das Backup habe ich schon mehrmals zurückgespielt.
                                Es ist von der alten Platte .
                                Habe mir jetzt das Skript aus Grafana der alten Platte geladen
                                  "datasource": "InfluxDB-1",
                                  "aliasColors": {
                                    "Temperatur Wohnzimmer": "rgb(221, 176, 63)"
                                  "bars": false,
                                  "dashLength": 10,
                                  "dashes": false,
                                  "decimals": 1,
                                  "fill": 1,
                                  "fillGradient": 0,
                                  "gridPos": {
                                    "h": 9,
                                    "w": 12,
                                    "x": 12,
                                    "y": 0
                                  "hiddenSeries": false,
                                  "id": 4,
                                  "legend": {
                                    "avg": false,
                                    "current": true,
                                    "max": true,
                                    "min": true,
                                    "show": true,
                                    "total": false,
                                    "values": true
                                  "lines": true,
                                  "linewidth": 1,
                                  "nullPointMode": "null",
                                  "options": {
                                    "dataLinks": [
                                        "title": "",
                                        "url": ""
                                  "percentage": false,
                                  "pointradius": 2,
                                  "points": false,
                                  "renderer": "flot",
                                  "seriesOverrides": [
                                      "alias": "Außentemperatur",
                                      "fill": 3,
                                      "fillGradient": 0,
                                      "yaxis": 1
                                      "alias": "Temperatur Wohnzimmer",
                                      "yaxis": 1
                                      "alias": "Power",
                                      "yaxis": 2
                                  "spaceLength": 10,
                                  "stack": false,
                                  "steppedLine": false,
                                  "targets": [
                                      "groupBy": [
                                          "params": [
                                            "$__interval"
                                          "type": "time"
                                          "params": [
                                            "previous"
                                          "type": "fill"
                                      "measurement": "mihome.0.devices.weather_v1_158d00023213f6.temperature",
                                      "orderByTime": "ASC",
                                      "policy": "default",
                                      "refId": "A",
                                      "resultFormat": "time_series",
                                      "select": [
                                            "params": [
                                              "value"
                                            "type": "field"
                                            "params": [],
                                            "type": "max"
                                      "tags": []
                                      "alias": "Temperatur Heizkessel",
                                      "groupBy": [
                                          "params": [
                                            "$__interval"
                                          "type": "time"
                                          "params": [
                                            "previous"
                                          "type": "fill"
                                      "measurement": "fhem.0.Temp_Heizkessel.temperature",
                                      "refId": "B",
                                      "select": [
                                            "params": [
                                              "value"
                                            "type": "field"
                                            "params": [],
                                            "type": "max"
                                      "tags": []
                                      "alias": "Temperatur Puffer",
                                      "groupBy": [
                                          "params": [
                                            "$__interval"
                                          "type": "time"
                                          "params": [
                                            "previous"
                                          "type": "fill"
                                      "measurement": "hm-rpc.0.OEQ0673599.2.TEMPERATURE",
                                      "refId": "C",
                                      "select": [
                                            "params": [
                                              "value"
                                            "type": "field"
                                            "params": [],
                                            "type": "max"
                                      "tags": []
                                      "alias": "Power",
                                      "groupBy": [
                                          "params": [
                                            "$__interval"
                                          "type": "time"
                                          "params": [
                                            "previous"
                                          "type": "fill"
                                      "measurement": "shelly.0.SHSW-PM#8CAAB542C16C#1.Relay0.Power",
                                      "refId": "E",
                                      "select": [
                                            "params": [
                                              "value"
                                            "type": "field"
                                            "params": [],
                                            "type": "max"
                                      "tags": []
                                  "thresholds": [],
                                  "timeFrom": null,
                                  "timeRegions": [],
                                  "timeShift": null,
                                  "title": "Temperatur Außen  / Temperatur Kessel /Temperatur Puffer9 / KesselStatus",
                                  "tooltip": {
                                    "shared": true,
                                    "sort": 0,
                                    "value_type": "individual"
                                  "type": "graph",
                                  "xaxis": {
                                    "buckets": null,
                                    "mode": "time",
                                    "name": null,
                                    "show": true,
                                    "values": []
                                  "yaxes": [
                                      "decimals": 1,
                                      "format": "celsius",
                                      "label": null,
                                      "logBase": 1,
                                      "max": null,
                                      "min": null,
                                      "show": true
                                      "decimals": 1,
                                      "format": "watt",
                                      "label": null,
                                      "logBase": 1,
                                      "max": null,
                                      "min": null,
                                      "show": true
                                  "yaxis": {
                                    "align": false,
                                    "alignLevel": null
                                Kann man das einbinden?
                                MfG Michael
                                crunchipC 2 Antworten Letzte Antwort
                                • A Altersrentner
                                  @crunchip
                                    "aliasColors": {
                                    "bars": false,
                                    "dashLength": 10,
                                    "dashes": false,
                                    "decimals": 1,
                                    "fill": 1,
                                    "fillGradient": 0,
                                    "gridPos": {
                                      "h": 9,
                                      "w": 12,
                                      "x": 12,
                                      "y": 0
                                    "id": 4,
                                    "legend": {
                                      "avg": false,
                                      "current": true,
                                      "max": true,
                                      "min": true,
                                      "show": true,
                                      "total": false,
                                      "values": true
                                    "lines": true,
                                    "linewidth": 1,
                                    "options": {
                                      "dataLinks": [
                                          "title": "",
                                          "url": ""
                                    "pointradius": 2,
                                    "points": false,
                                    "renderer": "flot",
                                        "fill": 3,
                                        "fillGradient": 0,
                                        "yaxis": 1
                                        "yaxis": 1
                                        "alias": "Power",
                                        "yaxis": 2
                                    "spaceLength": 10,
                                    "stack": false,
                                    "targets": [
                                        "groupBy": [
                                            "params": [
                                              "$__interval"
                                            "type": "time"
                                            "params": [
                                              "previous"
                                            "type": "fill"
                                        "refId": "A",
                                        "select": [
                                              "params": [
                                                "value"
                                              "type": "field"
                                              "params": [],
                                              "type": "max"
                                        "tags": []
                                        "groupBy": [
                                            "params": [
                                              "$__interval"
                                            "type": "time"
                                            "params": [
                                              "previous"
                                            "type": "fill"
                                        "refId": "B",
                                        "select": [
                                              "params": [
                                                "value"
                                              "type": "field"
                                              "params": [],
                                              "type": "max"
                                        "tags": []
                                        "groupBy": [
                                            "params": [
                                              "$__interval"
                                            "type": "time"
                                            "params": [
                                              "previous"
                                            "type": "fill"
                                        "refId": "C",
                                        "select": [
                                              "params": [
                                                "value"
                                              "type": "field"
                                              "params": [],
                                              "type": "max"
                                        "tags": []
                                        "alias": "Power",
                                        "groupBy": [
                                            "params": [
                                              "$__interval"
                                            "type": "time"
                                            "params": [
                                              "previous"
                                            "type": "fill"
                                        "refId": "E",
                                        "select": [
                                              "params": [
                                                "value"
                                              "type": "field"
                                              "params": [],
                                              "type": "max"
                                        "tags": []
                                    "thresholds": [],
                                    "timeFrom": null,
                                    "timeRegions": [],
                                    "timeShift": null,
                                    "tooltip": {
                                      "shared": true,
                                      "sort": 0,
                                    "type": "graph",
                                    "xaxis": {
                                      "buckets": null,
                                      "mode": "time",
                                      "name": null,
                                      "show": true,
                                      "values": []
                                    "yaxes": [
                                        "decimals": 1,
                                        "label": null,
                                        "logBase": 1,
                                        "max": null,
                                        "min": null,
                                        "show": true
                                        "decimals": 1,
                                        "format": "watt",
                                        "label": null,
                                        "logBase": 1,
                                        "max": null,
                                        "min": null,
                                        "show": true
                                    "yaxis": {
                                      "align": false,
                                      "alignLevel": null
                                  MfG Michael
                                  crunchipC Offline
                                  crunchipC Offline
                                  #156
                                  @altersrentner ist das dein einziges Dashboard? Ja das kann man einfügen.
                                  Auf deiner Grafana Seite, links auf das +,dann Import
                                  unterhalb von Import via panel json, kannst du es einfügen.
                                  dann ist es ja scheinbar schon vorhanden. Schau doch mal unter folgendem Pfad was du so findest
                                  var/lib/grafana
                                  • A Altersrentner
                                    @crunchip
                                      "aliasColors": {
                                      "bars": false,
                                      "dashLength": 10,
                                      "dashes": false,
                                      "decimals": 1,
                                      "fill": 1,
                                      "fillGradient": 0,
                                      "gridPos": {
                                        "h": 9,
                                        "w": 12,
                                        "x": 12,
                                        "y": 0
                                      "id": 4,
                                      "legend": {
                                        "avg": false,
                                        "current": true,
                                        "max": true,
                                        "min": true,
                                        "show": true,
                                        "total": false,
                                        "values": true
                                      "lines": true,
                                      "linewidth": 1,
                                      "options": {
                                        "dataLinks": [
                                            "title": "",
                                            "url": ""
                                      "pointradius": 2,
                                      "points": false,
                                      "renderer": "flot",
                                          "fill": 3,
                                          "fillGradient": 0,
                                          "yaxis": 1
                                          "yaxis": 1
                                          "alias": "Power",
                                          "yaxis": 2
                                      "spaceLength": 10,
                                      "stack": false,
                                      "targets": [
                                          "groupBy": [
                                              "params": [
                                                "$__interval"
                                              "type": "time"
                                              "params": [
                                                "previous"
                                              "type": "fill"
                                          "refId": "A",
                                          "select": [
                                                "params": [
                                                  "value"
                                                "type": "field"
                                                "params": [],
                                                "type": "max"
                                          "tags": []
                                          "groupBy": [
                                              "params": [
                                                "$__interval"
                                              "type": "time"
                                              "params": [
                                                "previous"
                                              "type": "fill"
                                          "refId": "B",
                                          "select": [
                                                "params": [
                                                  "value"
                                                "type": "field"
                                                "params": [],
                                                "type": "max"
                                          "tags": []
                                          "groupBy": [
                                              "params": [
                                                "$__interval"
                                              "type": "time"
                                              "params": [
                                                "previous"
                                              "type": "fill"
                                          "refId": "C",
                                          "select": [
                                                "params": [
                                                  "value"
                                                "type": "field"
                                                "params": [],
                                                "type": "max"
                                          "tags": []
                                          "alias": "Power",
                                          "groupBy": [
                                              "params": [
                                                "$__interval"
                                              "type": "time"
                                              "params": [
                                                "previous"
                                              "type": "fill"
                                          "refId": "E",
                                          "select": [
                                                "params": [
                                                  "value"
                                                "type": "field"
                                                "params": [],
                                                "type": "max"
                                          "tags": []
                                      "thresholds": [],
                                      "timeFrom": null,
                                      "timeRegions": [],
                                      "timeShift": null,
                                      "tooltip": {
                                        "shared": true,
                                        "sort": 0,
                                      "type": "graph",
                                      "xaxis": {
                                        "buckets": null,
                                        "mode": "time",
                                        "name": null,
                                        "show": true,
                                        "values": []
                                      "yaxes": [
                                          "decimals": 1,
                                          "label": null,
                                          "logBase": 1,
                                          "max": null,
                                          "min": null,
                                          "show": true
                                          "decimals": 1,
                                          "format": "watt",
                                          "label": null,
                                          "logBase": 1,
                                          "max": null,
                                          "min": null,
                                          "show": true
                                      "yaxis": {
                                        "align": false,
                                        "alignLevel": null
                                    MfG Michael
                                    crunchipC Offline
                                    crunchipC Offline
                                    #157
                                    @altersrentner ansonsten, wenn es speziell um's Backup geht, könntest du dort mal nachfragen
                                      Altersrentner
                                      #158
                                      @crunchip Guten Morgen,
                                      Hier ist auch die heutige eingefügte grafanaDB zu sehen.
                                      Nur es gibt keine graphische Darstellung.
                                      Michael
                                      • A Altersrentner
                                        Michael
                                        crunchipC Offline
                                        crunchipC Offline
                                        #159
                                        Lässt sich das Dashboard nicht öffnen, oder ist leer?
                                          Altersrentner
                                          #160
                                          @crunchip Hallo,
                                          Ich bedanke mich für die Unterstützung.
                                          Die dortige Nachfrage hat mich auf den richtigen Weg gebracht.
                                          Ich hatte vermutlich den API key nicht als Admin angelegt sondern als viewer.
                                          Michael
