  4. [ Geklärt ] Problem bei Influx Installation
    6.4k
influxdb
178 Beiträge 12 Kommentatoren 43.0k Aufrufe 11 Beobachtet
  • wendy2702W wendy2702
    @altersrentner Das ist jetzt deine alte HDD ?
    sudo systemctl status grafana-server
    Altersrentner
    #129
    @wendy2702 sagte in [ Geklärt ] Problem bei Influx Installation:
    pi@raspberrypi:/opt/iobroker $ sudo systemctl status grafana-server
    ● grafana-server.service - Grafana instance
       Loaded: loaded (/usr/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
       Active: active (running) since Sun 2021-03-07 14:28:17 CET; 3h 59min ago
         Docs: http://docs.grafana.org
     Main PID: 606 (grafana-server)
        Tasks: 17 (limit: 4915)
       CGroup: /system.slice/grafana-server.service
               └─606 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/var/run/grafana/grafana-server.
    Mar 07 18:19:44 raspberrypi grafana-server[606]: t=2021-03-07T18:19:44+0100 lvl=info msg="Request Completed" logger=co
    Mar 07 18:21:23 raspberrypi grafana-server[606]: t=2021-03-07T18:21:23+0100 lvl=info msg="Request Completed" logger=co
    Mar 07 18:21:27 raspberrypi grafana-server[606]: t=2021-03-07T18:21:27+0100 lvl=info msg="Request Completed" logger=co
    Mar 07 18:21:33 raspberrypi grafana-server[606]: t=2021-03-07T18:21:33+0100 lvl=info msg="Request Completed" logger=co
    Mar 07 18:21:34 raspberrypi grafana-server[606]: t=2021-03-07T18:21:33+0100 lvl=info msg="Request Completed" logger=co
    Mar 07 18:21:37 raspberrypi grafana-server[606]: t=2021-03-07T18:21:37+0100 lvl=info msg="Request Completed" logger=co
    Mar 07 18:21:44 raspberrypi grafana-server[606]: t=2021-03-07T18:21:44+0100 lvl=info msg="Request Completed" logger=co
    Mar 07 18:21:47 raspberrypi grafana-server[606]: t=2021-03-07T18:21:47+0100 lvl=info msg="Request Completed" logger=co
    lines 1-19/19 (END)...skipping...
    • A Altersrentner
      wendy2702W Online
      wendy2702W Online
      #130
      @altersrentner Also Grafane läuft. Ich gehe davon aus das es noch deine alte HDD ist.
      Hat er jetzt ein Grafana Backup erstellt?
      Wenn es noch die alte HDD ist kopiere die Backup files per FTP runter.
      Boote wieder von SSD und mach ein Restore von Influx und Grafana mit Backitup
        Altersrentner
        #131
        @wendy2702 Ja es ist noch die alte HDD angeschlossen
        Nein erhat kein Grafana Backup gemacht.
        Habe eben gesehen, das unter
        Backitup Grafana der Hostname und der Grafana API Key fehlen
        Was sollich dort eintragen bzw wie bekomme ich den Key
        wendy2702W crunchipC 2 Antworten Letzte Antwort
          @Altersrentner
          gib mal folgendes ein
          systemctl daemon-reload
          systemctl enable influxdb
          systemctl start influxdb
          Altersrentner
          #132
          @crunchip
          pi@raspberrypi:~ $ systemctl daemon-reload
          ==== AUTHENTICATING FOR org.freedesktop.systemd1.reload-daemon ===
          Authentication is required to reload the systemd state.
          Authenticating as: ,,, (pi)
          Password:
          ==== AUTHENTICATION COMPLETE ===
          pi@raspberrypi:~ $ systemctl enable influxdb
          ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-unit-files ===
          Authentication is required to manage system service or unit files.
          Password:
          Password:
          pi@raspberrypi:~ $ systemctl start influxdb
          ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
          Authentication is required to start 'influxdb.service'.
          Password:
          pi@raspberrypi:~ $
          • A Altersrentner
            @crunchip sagte in [ Geklärt ] Problem bei Influx Installation:
            ok, dein cifs mount ist fehlerhaft, influx hat er gemacht, grafana fehlerhaft, hast du Grafana laufen? Wenn ja , bräuchtest das ja auch noch
            Was kann ich hinsichtlich cifs machen?
            Grafana läuft wohl nicht aber die Graphen sind in vis vorhanden und aktualisieren auch
            Links ist aber Grafana auf der HDD vorhande?
            crunchipC Abwesend
            crunchipC Abwesend
            #133
            @altersrentner sagte in [ Geklärt ] Problem bei Influx Installation:
            ich habe keine Ahnung was du alles eingerichtet hast, bzw was du wohin schickst um backup's zu machen. Nutzt du überhaupt cifs oder nur google drive?
            grafana läuft, aber du hast wahrscheinlich die Einstellungen für das Grafana Backup nicht richtig gesetzt.(benutzername/passwort/api-key)
            • A Altersrentner
              wendy2702W Online
              wendy2702W Online
              #134
              @altersrentner Hostname sollte der hier sein:
              raspberrypi
              Key... keine Ahnung.
              Vielleicht ist es einfacher wenn du über die Grafana GUI gehst und deine Dashboards einfach exportierst.
              • A Altersrentner
                crunchipC Abwesend
                crunchipC Abwesend
                #135
                Des Weiteren muss in der Grafana-Weboberfläche ein Api-Key erzeugt werden, um Zugriff auf die Dashboards zu bekommen.
                Der Api-Key kann unter "Configuration → API Keys" erstellt werden.
                Edit:
                Nochmal zusammengefasst, du hast möchtest umziehen von einer Hdd auf eine SSD. Iobroker hast du dort schon laufen, mittels Backup.
                Was du vergessen/nicht beachtet hast, das Grafana und InfluxDB zwei separate Installationen sind, die mit dem Backup des Iobrokers nichts zu tun haben, daher musst du beide entsprechend wieder auf deiner SSD installieren.
                wenn du beide Backups(via backitup) von Influx und Grafana hast, kannst du diese auch wieder per backitup zurückspielen, wenn nicht, musst du dir die Daten entsprechend aus deiner HDD holen und wieder in deiner SSD einfügen
                  Altersrentner
                  schrieb am zuletzt editiert von Altersrentner
                  #136
                  Nur Google Drive
                  Den Key habe ich erstellt.
                  Nun der Hostname
                  Wo finde ich den?
                  crunchipC wendy2702W 2 Antworten Letzte Antwort
                  • A Altersrentner
                    Nur Google Drive
                    Nun der Hostname
                    Wo finde ich den?
                    crunchipC Abwesend
                    crunchipC Abwesend
                    #137
                    Nun der Hostname
                    gib einfach deine Ip Adresse ein
                    Nur Google Drive
                    dann hast du NAS/Kopieren scheinbar angehakt, in den Haupteinstellungen, daher der Fehler
                    • A Altersrentner
                      Nur Google Drive
                      Nun der Hostname
                      Wo finde ich den?
                      wendy2702W Online
                      wendy2702W Online
                      #138
                      @altersrentner Hatt ich zwar schon geschrieben kannst aber auch gerne nochmal hier schauen
                      cat /etc/hosts
                      A 3 Antworten Letzte Antwort
                        Nun der Hostname
                        Nur Google Drive
                        Altersrentner
                        #139
                        @crunchip
                        Danke!
                        Jetz mache ich noch ein Backup
                        mal sehen was dann ist
                          cat /etc/hosts
                          Altersrentner
                          #140
                          @wendy2702 super Danke😊 👍
                            cat /etc/hosts
                            Altersrentner
                            #141
                            @wendy2702
                            Es erscheint wieder ein Error bei Grafana
                            DEBUG] [grafana] - Start Grafana Backup ...
                            [DEBUG] [grafana] - Created grafana_tmp directory
                            [DEBUG] [grafana] - Created dashboard directory
                            [DEBUG] [grafana] - Created dashboards_manually_restore directory
                            [DEBUG] [grafana] - Created datasource directory
                            [DEBUG] [grafana] - start Grafana request ...
                            [DEBUG] [grafana] - Grafana is available ... Status: 200
                            [DEBUG] [grafana] - Error on Grafana Dashoard Request: Error: Request failed with status code 401
                            [DEBUG] [grafana] - start Grafana backup compress ...
                            [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
                            [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
                            [DEBUG] [grafana] - cannot found Grafana Backup files
                            [DEBUG] [grafana] - done
                            [DEBUG] [cifs] - done
                            [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_03_07-19_08_53_influx grafana_backupiobroker.tar.gz...
                            • A Altersrentner
                              @wendy2702
                              crunchipC Abwesend
                              crunchipC Abwesend
                              #142
                              Falschen Benutzerdaten oder Api-Key falsch
                              Grafana ist erreichbar (siehe Status 200)
                              A 2 Antworten Letzte Antwort
                                Altersrentner
                                #143
                                @crunchip
                                Danke, habe jetzt beim Host die IP eingestellt
                                und ein neuer Versuch
                                  Altersrentner
                                  #144
                                  @crunchip
                                  Started iobroker ...
                                  [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
                                  [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/homes/Backup/iobroker/minimalPi4 /opt/iobroker/backups
                                  Unable to find suitable address.
                                  [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/homes/Backup/iobroker/minimalPi4 /opt/iobroker/backups
                                  [DEBUG] [iobroker] - host.raspberrypi 14084 states saved
                                  [DEBUG] [iobroker] - host.raspberrypi 16331 objects saved
                                  [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_03_07-19_34_18_influx grafana2_backupiobroker.tar.gz
                                  [DEBUG] [iobroker] - done
                                  [DEBUG] [influxDB] - Start InfluxDB Backup ...
                                  [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
                                  [DEBUG] [influxDB] - Packed 15MB so far...
                                  [DEBUG] [influxDB] - Packed 47MB so far...
                                  [DEBUG] [influxDB] - Packed 79MB so far...
                                  [DEBUG] [influxDB] - Packed 149MB so far...
                                  [DEBUG] [influxDB] - Packed 235MB so far...
                                  [DEBUG] [influxDB] - Packed 313MB so far...
                                  [DEBUG] [influxDB] - Packed 405MB so far...
                                  [DEBUG] [influxDB] - Packed 481MB so far...
                                  [DEBUG] [influxDB] - Packed 562MB so far...
                                  [DEBUG] [influxDB] - Packed 646MB so far...
                                  [DEBUG] [influxDB] - Packed 727MB so far...
                                  [DEBUG] [influxDB] - Packed 817MB so far...
                                  [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2021_03_07-19_34_51_influx grafana2_backupiobroker.tar.gz
                                  [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
                                  [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
                                  [DEBUG] [influxDB] - done
                                  [DEBUG] [grafana] - Start Grafana Backup ...
                                  [DEBUG] [grafana] - found Dashboard: n1-aussen-wz
                                  [DEBUG] [grafana] - Backup created: /opt/iobroker/backups/grafana_2021_03_07-19_42_25_backupiobroker.tar.gz
                                  [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_03_07-19_34_18_influx grafana2_backupiobroker.tar.gz...
                                  [DEBUG] [googledrive] - Google Drive: Copy influxDB_2021_03_07-19_34_51_influx grafana2_backupiobroker.tar.gz...
                                  Ich glaube jetzt hat es geklappt👍 oder👎
                                  • A Altersrentner
                                    @crunchip
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    #145
                                    @altersrentner sieht so aus, grafana und influx, dein cifs hast aber noch aktiv(was du ja nicht nutzt), also Haken noch raus bei Nas.
                                    aber deine Backups sind gemacht
                                    musst nur dran denken, das du bei deiner SSD Influx und Grafana installiert haben musst um das backup ein zu spielen
                                      Altersrentner
                                      #146
                                      @crunchip OK
                                      wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add -
                                      source /etc/os-release
                                      echo "deb https://repos.influxdata.com/debian $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
                                      sudo apt update
                                      sudo apt install -y influxdb
                                      sudo systemctl unmask influxdb.service
                                      sudo systemctl start influxdb.service
                                      sudo systemctl enable influxdb.service
                                      Damit installiere ich Influx.
                                      Kannst Du mir bitte noch den Code für Grafana mitteilen?
                                      Mit freundlichen Grüßen
                                      Michael
                                      • A Altersrentner
                                        @crunchip OK
                                        sudo apt update
                                        Michael
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        #147
                                        @altersrentner
                                        apt-Schlüssel zufügen
                                        wget -q -O - https://packages.grafana.com/gpg.key | sudo apt-key add -
                                        grafana repository hinzufügen
                                        echo "deb https://packages.grafana.com/oss/deb stable main" | sudo tee -a /etc/apt/sources.list.d/grafana.list
                                        installieren
                                        sudo apt-get update
                                        sudo apt-get install -y grafana
                                        aktivieren und starten
                                        sudo /bin/systemctl enable grafana-server
                                        sudo /bin/systemctl start grafana-server
                                        aufrufen dann über http://<ip address>:3000
                                        Name und Kennwort ist standard
                                        admin
                                        admin
                                          @altersrentner
                                          installieren
                                          sudo apt-get update
                                          admin
                                          admin
                                          Altersrentner
                                          #148
                                          @crunchip D A N K E !
                                          Michael
