  4. [ Geklärt ] Problem bei Influx Installation
    6.4k
influxdb
178 Beiträge 12 Kommentatoren 43.0k Aufrufe 11 Beobachtet
  • wendy2702W Online
    wendy2702W Online
    #128
    @altersrentner Das ist jetzt deine alte HDD ?
    sudo systemctl status grafana-server
    • wendy2702W wendy2702
      Altersrentner
      #129
      @wendy2702 sagte in [ Geklärt ] Problem bei Influx Installation:
      pi@raspberrypi:/opt/iobroker $ sudo systemctl status grafana-server
      ● grafana-server.service - Grafana instance
         Loaded: loaded (/usr/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
         Active: active (running) since Sun 2021-03-07 14:28:17 CET; 3h 59min ago
           Docs: http://docs.grafana.org
       Main PID: 606 (grafana-server)
          Tasks: 17 (limit: 4915)
         CGroup: /system.slice/grafana-server.service
                 └─606 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/var/run/grafana/grafana-server.
      Mar 07 18:19:44 raspberrypi grafana-server[606]: t=2021-03-07T18:19:44+0100 lvl=info msg="Request Completed" logger=co
      Mar 07 18:21:23 raspberrypi grafana-server[606]: t=2021-03-07T18:21:23+0100 lvl=info msg="Request Completed" logger=co
      Mar 07 18:21:27 raspberrypi grafana-server[606]: t=2021-03-07T18:21:27+0100 lvl=info msg="Request Completed" logger=co
      Mar 07 18:21:33 raspberrypi grafana-server[606]: t=2021-03-07T18:21:33+0100 lvl=info msg="Request Completed" logger=co
      Mar 07 18:21:34 raspberrypi grafana-server[606]: t=2021-03-07T18:21:33+0100 lvl=info msg="Request Completed" logger=co
      Mar 07 18:21:37 raspberrypi grafana-server[606]: t=2021-03-07T18:21:37+0100 lvl=info msg="Request Completed" logger=co
      Mar 07 18:21:44 raspberrypi grafana-server[606]: t=2021-03-07T18:21:44+0100 lvl=info msg="Request Completed" logger=co
      Mar 07 18:21:47 raspberrypi grafana-server[606]: t=2021-03-07T18:21:47+0100 lvl=info msg="Request Completed" logger=co
      lines 1-19/19 (END)...skipping...
      • A Altersrentner
        wendy2702W Online
        wendy2702W Online
        #130
        @altersrentner Also Grafane läuft. Ich gehe davon aus das es noch deine alte HDD ist.
        Hat er jetzt ein Grafana Backup erstellt?
        Wenn es noch die alte HDD ist kopiere die Backup files per FTP runter.
        Boote wieder von SSD und mach ein Restore von Influx und Grafana mit Backitup
          Altersrentner
          #131
          @wendy2702 Ja es ist noch die alte HDD angeschlossen
          Nein erhat kein Grafana Backup gemacht.
          Habe eben gesehen, das unter
          Backitup Grafana der Hostname und der Grafana API Key fehlen
          Was sollich dort eintragen bzw wie bekomme ich den Key
          wendy2702W crunchipC 2 Antworten Letzte Antwort
            @Altersrentner
            gib mal folgendes ein
            systemctl daemon-reload
            systemctl enable influxdb
            systemctl start influxdb
            Altersrentner
            #132
            @crunchip
            pi@raspberrypi:~ $ systemctl daemon-reload
            ==== AUTHENTICATING FOR org.freedesktop.systemd1.reload-daemon ===
            Authentication is required to reload the systemd state.
            Authenticating as: ,,, (pi)
            Password:
            ==== AUTHENTICATION COMPLETE ===
            pi@raspberrypi:~ $ systemctl enable influxdb
            ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-unit-files ===
            Authentication is required to manage system service or unit files.
            Password:
            Password:
            pi@raspberrypi:~ $ systemctl start influxdb
            ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
            Authentication is required to start 'influxdb.service'.
            Password:
            pi@raspberrypi:~ $
            • A Altersrentner
              @crunchip sagte in [ Geklärt ] Problem bei Influx Installation:
              ok, dein cifs mount ist fehlerhaft, influx hat er gemacht, grafana fehlerhaft, hast du Grafana laufen? Wenn ja , bräuchtest das ja auch noch
              Was kann ich hinsichtlich cifs machen?
              Grafana läuft wohl nicht aber die Graphen sind in vis vorhanden und aktualisieren auch
              Links ist aber Grafana auf der HDD vorhande?
              crunchipC Abwesend
              crunchipC Abwesend
              #133
              @altersrentner sagte in [ Geklärt ] Problem bei Influx Installation:
              ich habe keine Ahnung was du alles eingerichtet hast, bzw was du wohin schickst um backup's zu machen. Nutzt du überhaupt cifs oder nur google drive?
              grafana läuft, aber du hast wahrscheinlich die Einstellungen für das Grafana Backup nicht richtig gesetzt.(benutzername/passwort/api-key)
              • A Altersrentner
                wendy2702W Online
                wendy2702W Online
                #134
                @altersrentner Hostname sollte der hier sein:
                raspberrypi
                Key... keine Ahnung.
                Vielleicht ist es einfacher wenn du über die Grafana GUI gehst und deine Dashboards einfach exportierst.
                • A Altersrentner
                  crunchipC Abwesend
                  crunchipC Abwesend
                  #135
                  Des Weiteren muss in der Grafana-Weboberfläche ein Api-Key erzeugt werden, um Zugriff auf die Dashboards zu bekommen.
                  Der Api-Key kann unter "Configuration → API Keys" erstellt werden.
                  Edit:
                  Nochmal zusammengefasst, du hast möchtest umziehen von einer Hdd auf eine SSD. Iobroker hast du dort schon laufen, mittels Backup.
                  Was du vergessen/nicht beachtet hast, das Grafana und InfluxDB zwei separate Installationen sind, die mit dem Backup des Iobrokers nichts zu tun haben, daher musst du beide entsprechend wieder auf deiner SSD installieren.
                  wenn du beide Backups(via backitup) von Influx und Grafana hast, kannst du diese auch wieder per backitup zurückspielen, wenn nicht, musst du dir die Daten entsprechend aus deiner HDD holen und wieder in deiner SSD einfügen
                    Altersrentner
                    schrieb am zuletzt editiert von Altersrentner
                    #136
                    Nur Google Drive
                    Den Key habe ich erstellt.
                    Nun der Hostname
                    Wo finde ich den?
                    crunchipC wendy2702W 2 Antworten Letzte Antwort
                    • A Altersrentner
                      Nur Google Drive
                      Nun der Hostname
                      Wo finde ich den?
                      crunchipC Abwesend
                      crunchipC Abwesend
                      #137
                      Nun der Hostname
                      gib einfach deine Ip Adresse ein
                      Nur Google Drive
                      dann hast du NAS/Kopieren scheinbar angehakt, in den Haupteinstellungen, daher der Fehler
                      • A Altersrentner
                        Nur Google Drive
                        Nun der Hostname
                        Wo finde ich den?
                        wendy2702W Online
                        wendy2702W Online
                        #138
                        @altersrentner Hatt ich zwar schon geschrieben kannst aber auch gerne nochmal hier schauen
                        cat /etc/hosts
                        A 3 Antworten Letzte Antwort
                          Nun der Hostname
                          Nur Google Drive
                          Altersrentner
                          #139
                          @crunchip
                          Danke!
                          Jetz mache ich noch ein Backup
                          mal sehen was dann ist
                            cat /etc/hosts
                            Altersrentner
                            #140
                            @wendy2702 super Danke😊 👍
                              cat /etc/hosts
                              Altersrentner
                              #141
                              @wendy2702
                              Es erscheint wieder ein Error bei Grafana
                              DEBUG] [grafana] - Start Grafana Backup ...
                              [DEBUG] [grafana] - Created grafana_tmp directory
                              [DEBUG] [grafana] - Created dashboard directory
                              [DEBUG] [grafana] - Created dashboards_manually_restore directory
                              [DEBUG] [grafana] - Created datasource directory
                              [DEBUG] [grafana] - start Grafana request ...
                              [DEBUG] [grafana] - Grafana is available ... Status: 200
                              [DEBUG] [grafana] - Error on Grafana Dashoard Request: Error: Request failed with status code 401
                              [DEBUG] [grafana] - start Grafana backup compress ...
                              [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
                              [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
                              [DEBUG] [grafana] - cannot found Grafana Backup files
                              [DEBUG] [grafana] - done
                              [DEBUG] [cifs] - done
                              [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_03_07-19_08_53_influx grafana_backupiobroker.tar.gz...
                              • A Altersrentner
                                @wendy2702
                                crunchipC Abwesend
                                crunchipC Abwesend
                                #142
                                Falschen Benutzerdaten oder Api-Key falsch
                                Grafana ist erreichbar (siehe Status 200)
                                A 2 Antworten Letzte Antwort
                                  Altersrentner
                                  #143
                                  @crunchip
                                  Danke, habe jetzt beim Host die IP eingestellt
                                  und ein neuer Versuch
                                    Altersrentner
                                    #144
                                    @crunchip
                                    Started iobroker ...
                                    [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
                                    [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/homes/Backup/iobroker/minimalPi4 /opt/iobroker/backups
                                    Unable to find suitable address.
                                    [ERROR] [mount] - [IGNORED] Error: Command failed: sudo mount -t cifs -o username=Backup,password=****,rw,file_mode=0777,dir_mode=0777 //192.168.178.35/homes/Backup/iobroker/minimalPi4 /opt/iobroker/backups
                                    [DEBUG] [iobroker] - host.raspberrypi 14084 states saved
                                    [DEBUG] [iobroker] - host.raspberrypi 16331 objects saved
                                    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_03_07-19_34_18_influx grafana2_backupiobroker.tar.gz
                                    [DEBUG] [iobroker] - done
                                    [DEBUG] [influxDB] - Start InfluxDB Backup ...
                                    [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
                                    [DEBUG] [influxDB] - Packed 15MB so far...
                                    [DEBUG] [influxDB] - Packed 47MB so far...
                                    [DEBUG] [influxDB] - Packed 79MB so far...
                                    [DEBUG] [influxDB] - Packed 149MB so far...
                                    [DEBUG] [influxDB] - Packed 235MB so far...
                                    [DEBUG] [influxDB] - Packed 313MB so far...
                                    [DEBUG] [influxDB] - Packed 405MB so far...
                                    [DEBUG] [influxDB] - Packed 481MB so far...
                                    [DEBUG] [influxDB] - Packed 562MB so far...
                                    [DEBUG] [influxDB] - Packed 646MB so far...
                                    [DEBUG] [influxDB] - Packed 727MB so far...
                                    [DEBUG] [influxDB] - Packed 817MB so far...
                                    [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2021_03_07-19_34_51_influx grafana2_backupiobroker.tar.gz
                                    [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
                                    [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
                                    [DEBUG] [influxDB] - done
                                    [DEBUG] [grafana] - Start Grafana Backup ...
                                    [DEBUG] [grafana] - found Dashboard: n1-aussen-wz
                                    [DEBUG] [grafana] - Backup created: /opt/iobroker/backups/grafana_2021_03_07-19_42_25_backupiobroker.tar.gz
                                    [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_03_07-19_34_18_influx grafana2_backupiobroker.tar.gz...
                                    [DEBUG] [googledrive] - Google Drive: Copy influxDB_2021_03_07-19_34_51_influx grafana2_backupiobroker.tar.gz...
                                    Ich glaube jetzt hat es geklappt👍 oder👎
                                    • A Altersrentner
                                      @crunchip
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      #145
                                      @altersrentner sieht so aus, grafana und influx, dein cifs hast aber noch aktiv(was du ja nicht nutzt), also Haken noch raus bei Nas.
                                      aber deine Backups sind gemacht
                                      musst nur dran denken, das du bei deiner SSD Influx und Grafana installiert haben musst um das backup ein zu spielen
                                        Altersrentner
                                        #146
                                        @crunchip OK
                                        wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add -
                                        source /etc/os-release
                                        echo "deb https://repos.influxdata.com/debian $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
                                        sudo apt update
                                        sudo apt install -y influxdb
                                        sudo systemctl unmask influxdb.service
                                        sudo systemctl start influxdb.service
                                        sudo systemctl enable influxdb.service
                                        Damit installiere ich Influx.
                                        Kannst Du mir bitte noch den Code für Grafana mitteilen?
                                        Mit freundlichen Grüßen
                                        Michael
                                        • A Altersrentner
                                          @crunchip OK
                                          sudo apt update
                                          Michael
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          #147
                                          @altersrentner
                                          apt-Schlüssel zufügen
                                          wget -q -O - https://packages.grafana.com/gpg.key | sudo apt-key add -
                                          grafana repository hinzufügen
                                          echo "deb https://packages.grafana.com/oss/deb stable main" | sudo tee -a /etc/apt/sources.list.d/grafana.list
                                          installieren
                                          sudo apt-get update
                                          sudo apt-get install -y grafana
                                          aktivieren und starten
                                          sudo /bin/systemctl enable grafana-server
                                          sudo /bin/systemctl start grafana-server
                                          aufrufen dann über http://<ip address>:3000
                                          Name und Kennwort ist standard
                                          admin
                                          admin
