  4. [ Geklärt ] Problem bei Influx Installation
    6.4k
influxdb
178 Beiträge 12 Kommentatoren 43.0k Aufrufe 11 Beobachtet
  • A Altersrentner
    @crunchip Hallo,
    Ich muss mich doch noch mal um Hilfe bitten.
    Nicht das jemand denkt ich bin zu düsig! aber es geling mir nicht
    Influxdb zu konfigurieren.
    Mehrmaliges löschen und wieder installieren hat nichts gebracht.
    Ich komme immer bis zu diesem Punkt:
    pi@raspberrypi:~ $ wget -qO- https://repos.influxdata.com/influxdb.key | sudo apt-key add -
    OK
    pi@raspberrypi:~ $ source /etc/lsb-release
    -bash: /etc/lsb-release: No such file or directory
    pi@raspberrypi:~ $ sudo source /etc/lsb-release
    sudo: source: command not found
    pi@raspberrypi:~ $ source /etc/os-release
    pi@raspberrypi:~ $ echo "deb https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
    deb https://repos.influxdata.com/  stable
    pi@raspberrypi:~ $ sudo apt update
    E: Malformed entry 1 in list file /etc/apt/sources.list.d/influxdb.list (Component)
    E: The list of sources could not be read.
    pi@raspberrypi:~ $ echo "deb https://repos.influxdata.com/debian $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
    deb https://repos.influxdata.com/debian buster stable
    Get:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
    Hit:3 https://deb.nodesource.com/node_10.x buster InRelease
    Hit:4 https://repos.influxdata.com/debian buster InRelease
    Fetched 15.0 kB in 2s (9,888 B/s)
    Reading package lists... Done
    Building dependency tree
    All packages are up to date.
    pi@raspberrypi:~ $ sudo apt install influxdb
    The following NEW packages will be installed:
      influxdb
    0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
    Need to get 0 B/60.0 MB of archives.
    After this operation, 153 MB of additional disk space will be used.
    Selecting previously unselected package influxdb.
    (Reading database ... 63673 files and directories currently installed.)
    Preparing to unpack .../influxdb_1.8.3-1_armhf.deb ...
    Unpacking influxdb (1.8.3-1) ...
    Setting up influxdb (1.8.3-1) ...
    Processing triggers for man-db (2.8.5-2) ...
    pi@raspberrypi:~ $ sudo systemctl status influxdb.service
    ● influxdb.service - InfluxDB is an open-source, distributed, time series database
       Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
       Active: active (running) since Tue 2020-12-22 11:44:21 CET; 3h 12min ago
         Docs: https://docs.influxdata.com/influxdb/
     Main PID: 5478 (influxd)
        Tasks: 14 (limit: 4915)
       CGroup: /system.slice/influxdb.service
               └─5478 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
    Dec 22 14:55:30 raspberrypi influxd[5478]: ts=2020-12-22T13:55:30.303321Z lvl=info msg="failed to store statistic
    Dec 22 14:55:40 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:55:40 +0100] "GET /query?db=
    Dec 22 14:55:40 raspberrypi influxd[5478]: ts=2020-12-22T13:55:40.504680Z lvl=info msg="failed to store statistic
    Dec 22 14:55:50 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:55:50 +0100] "GET /query?db=
    Dec 22 14:56:00 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:56:00 +0100] "GET /query?db=
    Dec 22 14:56:10 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:56:10 +0100] "GET /query?db=
    Dec 22 14:56:21 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:56:20 +0100] "GET /query?db=
    Dec 22 14:56:31 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:56:31 +0100] "GET /query?db=
    Dec 22 14:56:41 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:56:41 +0100] "GET /query?db=
    Dec 22 14:56:51 raspberrypi influxd[5478]: [httpd] 127.0.0.1 - admin [22/Dec/2020:14:56:51 +0100] "GET /query?db=
    pi@raspberrypi:~ $ sudo systemctl unmask influxdb.service
    pi@raspberrypi:~ $ sudo systemctl start influxdb
    pi@raspberrypi:~ $ sudo systemctl enable influxdb.service
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $
    pi@raspberrypi:~ $ sudo influx
    Connected to http://localhost:8086 version 1.8.3
    InfluxDB shell version: 1.8.3
    > CREATE DATABASE "iobroker"
    ERR: unable to parse authentication credentials
    Warning: It is possible this error is due to not setting a database.
    Please set a database with the command "use <database>".
    Alles was danach versucht wird einzugeben wird mit der
    letzten Fehlermeldung beantwortet
    Die influxdb.0 Ampel ist gelb.
    Dortige Eingaben sind wie gehabt
    Auch USE "iobroker" bringt das selbe Ergebnis.
    > auth
    username: admin
    password:
    > show database
    ERR: authorization failed
    > show databases
    Gestern habe ich eine andere Speicherkarte neu aufgesetzt.
    Rasphian buster und iobroker installiert und
    dort hat die Installation von influxdb und Grafana auf Anhieb geklappt.
    Ich vermute, das es in einer Konfigurationsdatei Einträge gibt,
    die diese Fehlermeldungen herforrufen.
    Freundliche Grüße
    Michael
    crunchipC Abwesend
    crunchipC Abwesend
    @Altersrentner du kannst influx löschen incl aller Abhängigkeiten und Konfigurationseinstellungen, mittels
    sudo apt-get autoremove --purge influxdb
    Anschliessend kannst du sauber neu installieren
    Und wenn du schon beim installieren bist, warum nicht gleich die neuste Version?
    https://portal.influxdata.com/downloads/
    Influxdb v 2.0.3
      Influxdb v 2.0.3
      @crunchip sagte in Problem bei Influx Installation:
      Weil's da keinen passenden build für 32bit Raspian OS gibt. Alles arm64.
      A crunchipC 2 Antworten Letzte Antwort
        Altersrentner
        @Thomas-Braun Hallo,
        So habe ich das auch gesehen!??
        Gruß Michael
          crunchipC Abwesend
          crunchipC Abwesend
          @Thomas-Braun stimmt, hatte ich nicht dran gedacht🤦 geht ja um nen raspberry
          • A Altersrentner
            @crunchip Hallo,
            OK
              influxdb
            pi@raspberrypi:~ $
            pi@raspberrypi:~ $
            > auth
            username: admin
            password:
            > show database
            > show databases
            Freundliche Grüße
            Michael
            crunchipC Abwesend
            crunchipC Abwesend
            @Altersrentner wenn ich mich nicht Irre, kannst du das create database.... Weglassen auf der Konsole.
            Die wird nämlich automatisch angelegt, wenn du in deiner Influx Instanz, die Werte/Einstellungen gemacht hast und anschliessend startest. Das denke ich, behebt auch deinen Fehler
              Altersrentner
              @crunchip Hallo,
              😊 😊 😊 Es hat geklappt.
              Folgende Situation war gegeben,
              trotz mehrmaligem löschen der influxdb war aber noch die
              alte config vorhanden und damit die vormals kommentierten Zeilen.
              Ich war immer davon ausgegangen, das die config auch entfernt wurde.
              Habe dann alle Zeilen bis auf bind.... auskommentiert und damit hatten
              sich login und database selbst unter influxdb eingetragen.
              Das brachte dann SHOW..... ans Licht. ist zwar etwas komisch,
              denn in den Anleitungen wird ja immer geschrieben CREATE......
              Na ja - alles gut!! für heute reicht`s
              Ich bedanke mich nochmals für Eure Unterstützung!
              Freundliche Grüße und besinnliche Feiertage
              wünscht Michael
              • A Altersrentner
                @crunchip Hallo,
                wünscht Michael
                crunchipC Abwesend
                crunchipC Abwesend
                @Altersrentner sagte in [ Geklärt ] Problem bei Influx Installation:
                Ja, man geht bei der offiziellen Anleitung auch nicht davon aus, das iobroker genutzt wird😉
                Nein, die config bleibt erhalten, daher hatte ich den Befehl oben genannt, damit alles "Restlos" gelöscht wird und du von Grundauf neu installeren kannst.
                • A Altersrentner
                  Guten Morgen,
                  Ich möchte meine Graphen zukünftig mittels Grafana darstellen.
                  Dafür benötige ich die InfluxDB.
                  Dazu habe ich mir sehr viele Videos angesehen und es sollte von der
                  Sache her kein Problem sein, Aber der teufel steckt im Detail
                  pi@raspberrypi:~ $ sudo service influxdb start
                  Failed to connect to http://localhost:8086: Get http://localhost:8086/ping: dial       tcp [::1]:8086: connect: connection refused
                  Please check your connection settings and ensure 'influxd' is running.
                  pi@raspberrypi:~ $
                  Heist:
                  sudo influx Fehler beim Herstellen einer Verbindung zu http: // localhost: 8086: Abrufen von http: // localhost: 8086 / ping: Wählen von TCP [:: 1]: 8086: Verbinden: Verbindung abgelehnt
                  Bitte überprüfen Sie Ihre Verbindungseinstellungen und stellen Sie sicher, dass 'influxd' ausgeführt wird.
                  Wer kann mir bitte helfen das Problem zu lösen.
                  Freundliche Grüße
                  Michael
                  Altersrentner
                  schrieb am zuletzt editiert von Altersrentner
                  @Altersrentner
                  crunchip 👍 👍 👍
                  • A Altersrentner
                    @Altersrentner
                    crunchip 👍 👍 👍
                    crunchipC Abwesend
                    crunchipC Abwesend
                    @Altersrentner ein Tipp vorne weg, beim loggen eines Datenpunktes.
                    Beim Auswahlmenü "Speichern unter" nicht Automatic auswählen, da es je nach Datenpunkt zu Problemen führen kann, wenn der zu loggende Datentyp z.b. vom Typ "boolean" oder "String" ist. Ein nachträgliches Ändern führt dazu, das keine Werte mehr in Grafana angezeigt werden und dieser dann erst aus der Datenbank gelöscht werden muss. Dementsprechend also gleich beim aktivieren den "richtigen Typ auswählen.
                      Altersrentner
                      #66
                      @crunchip Hallo,
                      Danke für Deinen Hinweis!!!!
                      Ich kämpfe immer noch😧
                      Möchte mit mi Temperaturen und Türmagneten anfangen.
                      Natürlich steht alles auf Autom.
                      Temperaturen sind ja Zahlen und Schalter Logikwerte.
                      Ich habe aber nur die von Dir gezeigten Parameter zur Auswahl.
                      Was benutze ich wo?
                      • A Altersrentner
                        @crunchip Hallo,
                        Was benutze ich wo?
                        crunchipC Abwesend
                        crunchipC Abwesend
                        #67
                        @Altersrentner ist richtig, siehst du im RAW des jeweiligen Datenpunktes, Stichwort Typ
                        Beispiel dein xiaomi Klima Sensor. Öffnest den Objektbaum.
                        Bei Temperatur und Humitidy jeweils, rechts auf den Schraubenschlüssel und config influx aufrufen, da erscheint dann das Fenster, wie in meinem Screen.
                        Da der Typ in dem Fall "Number" ist ,wählst du dies entsprechend aus. Wenn du unten links "alias" frei lässt, erscheint dein geloggter Datenpunkt auch so wie er in iobroker benannt ist.
                        Wenn du dann unten mit ok bestätigst, füllt sich die Datenbank, sobald eine Änderung des Wertes stattgefunden hat.
                        Bei deinem Tür/Fensterkontakt gehst du genauso vor, jedoch ist da der Typ "boolean" auszuwählen.
                          Altersrentner
                          #68
                          @crunchip
                          Danke, habe jetzt erst mal wieder Futter.
                          Wünsche einen schönen Abend
                          Freundliche Grüße Michael
                          • A Altersrentner
                            @crunchip
                            crunchipC Abwesend
                            crunchipC Abwesend
                            #69
                            @Altersrentner ich sitz noch auf Arbeit😁
                            A 2 Antworten Letzte Antwort
                              Altersrentner
                              #70
                              @crunchip In der jetzigen Situation bin ich recht froh,
                              meinen Pflichtteil seit sieben Jahren beendet zu haben.
                                Altersrentner
                                #71
                                @crunchip Ich noch mal,
                                Habe ein weiteres Problem lokalisiert.
                                Wenn ich in der influxdb
                                auth-enabled = true
                                aktiviere, schaltet die Ampel des Adapters nicht mehr auf Grün.
                                Habe alle 8 Positionen nacheinander getestet.
                                Gibt es dafür eine Erklärung?
                                Danke und
                                Gute Nacht
                                • A Altersrentner
                                  auth-enabled = true
                                  Danke und
                                  Gute Nacht
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  #72
                                  @Altersrentner
                                  @Altersrentner sagte in [Noch nicht Geklärt ] Problem bei Influx Installation:
                                  denke, das hängt damit zusammen
                                  in der influxdb.conf musst du eigentlich gar nichts ändern, zumindest nicht in deinem Fall
                                  meinst du den Teil [http]? der sollte so aussehen
                                    @Altersrentner
                                    Altersrentner
                                    #73
                                    @crunchip
                                    Ja ich meine den http Bereich.
                                    Laut Beschreibungen sollten folgende Einträge
                                    kommentiert werden.
                                    [http]
                                     enabled = true
                                     bind-address = ":8086"
                                     auth-enabled = true
                                     log-enabled = true
                                     write-tracing = false
                                     pprof-enabled = false
                                     https-enabled = false
                                     https-certificate = "/etc/ssl/influxdb.pem"
                                    Ich habe alle außer
                                     auth-enabled = true
                                    kommentiert, weil dieser die Ampel blockiert.
                                    • A Altersrentner
                                      @crunchip
                                      kommentiert werden.
                                      [http]
                                       enabled = true
                                       auth-enabled = true
                                       log-enabled = true
                                      Ich habe alle außer
                                       auth-enabled = true
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      #74
                                      @Altersrentner bei mir ist das so für [http]
                                      die 3 sind aktiv
                                      enabled = true
                                      pprof-enabled = true
                                      alles andere ist auskommentiert
                                        die 3 sind aktiv
                                        enabled = true
                                        Altersrentner
                                        #75
                                        @crunchip Danke,
                                        Werde ich probieren😊
                                          die 3 sind aktiv
                                          enabled = true
                                          Altersrentner
                                          #76
                                          @crunchip Guten Morgen und einen schönen Feiertag;
                                          Bin jetzt damit beschäftigt Grafana einzurichten.
                                          Aber auch hier ist alles anders wie normal.
                                          Es beginnt schon mit der Eingabe der Settings
                                          Grafana verbindet sich nur wenn unter Access "BROWSER" ausgewählt ist.
                                          Habe viel gesucht und überall nur Verbindung über Server gefunden.
                                          Deshalb die Frage ist Browser OK oder eher nicht.
                                          Nach diesem Video habe ich dann meine Datenpunkte konfiguriert und überprüft.
                                          https://www.youtube.com/watch?v=VXfpds4Rtqc&t=4072s
                                          Alles prima..
                                          In den Dashboard Einstellungen sollten dann die in influxdb geloggten Daten
                                          unter dem Reiter "select measurement" erscheinen. Das Feld bleibt aber leer.
                                          Wie kann ich prüfen, ob besagte date überhaupt in der influxdb auftauchen.
                                          Z. B. mit einem Befehl im Terminal.
                                          Ich bin doch noch etwas weiter gekommen.😊
                                          > show databases
                                          name
                                          _internal
                                          iobroker
                                          > use iobroker
                                          Using database iobroker
                                          > show measurements
                                          name
                                          influxdb.0.info.connection
                                          mihome.0.devices.magnet_158d00020910b2.state
                                          mihome.0.devices.magnet_158d00020b5d12.state
                                          mihome.0.devices.magnet_158d00020b5d69.state
                                          mihome.0.devices.magnet_158d0003e72274.state
                                          mihome.0.devices.magnet_158d0003e741ac.state
                                          mihome.0.devices.magnet_158d0003e74624.state
                                          mihome.0.devices.magnet_158d0003e746aa.state
                                          mihome.0.devices.magnet_158d0003e747f7.state
                                          mihome.0.devices.weather_v1_158d00023213f6.humidity
                                          mihome.0.devices.weather_v1_158d00023213f6.temperature
                                          mihome.0.devices.weather_v1_158d000232801d.humidity
                                          mihome.0.devices.weather_v1_158d000232801d.temperature
                                          mihome.0.devices.weather_v1_158d0002329079.humidity
                                          mihome.0.devices.weather_v1_158d0002329079.temperature
                                          mihome.0.devices.weather_v1_158d00023290a8.humidity
                                          mihome.0.devices.weather_v1_158d00023290a8.temperature
                                          mihome.0.devices.weather_v1_158d00023290e8.humidity
                                          mihome.0.devices.weather_v1_158d00023290e8.temperature
                                          mihome.0.devices.weather_v1_158d00024906fa.humidity
                                          mihome.0.devices.weather_v1_158d00024906fa.temperature
                                          mihome.0.devices.weather_v1_158d00036b52b9.humidity
                                          mihome.0.devices.weather_v1_158d00036b52b9.temperature
                                          mihome.0.devices.weather_v1_158d00036b53b3.humidity
                                          mihome.0.devices.weather_v1_158d00036b53b3.temperature
                                          mihome.0.devices.weather_v1_158d00036b53ce.humidity
                                          mihome.0.devices.weather_v1_158d00036b53ce.temperature
                                          mihome.0.devices.weather_v1_158d00036bd6ea.humidity
                                          mihome.0.devices.weather_v1_158d00036bd6ea.temperature
                                          mihome.0.devices.weather_v1_158d00036bd78e.humidity
                                          mihome.0.devices.weather_v1_158d00036bd78e.temperature
                                          > show series
                                          key
                                          > > Das Initallisieren des Grafana Server:
                                          ERR: error parsing query: found >, expected SELECT, DELETE, SHOW, CREATE, DROP, EXPLAIN, GRANT, REVOKE, ALTER, SET, KILL at line 1, char 1
                                          > show tag keys
                                          > show field keys
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    string
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    boolean
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    boolean
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    boolean
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    boolean
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    boolean
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    boolean
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    boolean
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    boolean
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    float
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    float
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    float
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    float
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    float
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    float
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    float
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    float
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    float
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    float
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    float
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    float
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    float
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    float
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    float
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    float
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    float
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    float
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    float
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    float
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    float
                                          fieldKey fieldType
                                          ack      boolean
                                          from     string
                                          q        float
                                          value    float
                                          Ist soweit alles richtig?
                                          Soweit erst mal zum aktuellen Stand.
                                          Freundliche Grüße
                                          Michael
                                          crunchipC B 2 Antworten Letzte Antwort
