  4. Und wieder einmal Harmony... Firmware 4.15.250...
101 Beiträge 29 Kommentatoren 17.3k Aufrufe 30 Beobachtet
  • Dr. BakteriusD Offline
    Dr. Bakterius
    #81
    Auch von meiner Seite vielen Dank an @foxriver76! 👍
    1.2.1 funktioniert ohne XMPP wieder bestens (bis Logitech wieder herum pfuscht). Ich musste auch keine Ordner löschen, einfach über 1.0.0 installiert.
      miwe
      schrieb am zuletzt editiert von miwe
      #82
      Moin,
      ich kann das UPDATE leider nicht installieren.
      $ ./iobroker upgrade harmony
      Update harmony from @1.0.0 to @1.2.1
      NPM version: 6.4.1
      npm install iobroker.harmony@1.2.1 --production --save --prefix "/opt/iobroker" (System call)
      npm
       WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.harmony
      npm
      WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none is installed. You must install peer dependencies yourself.
      npm
      ERR! path /opt/iobroker/node_modules/iobroker.harmonynpm ERR! code EACCES
      npm ERR! errno -13npm
       ERR! syscall access
      npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.harmony'npm ERR!  { Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.harmony'
      npm ERR!   stack: 'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/iobroker.harmony\'',
      npm ERR!   errno: -13,
      npm ERR!   code: 'EACCES',
      npm ERR!   syscall: 'access',
      npm ERR!   path: '/opt/iobroker/node_modules/iobroker.harmony' }
      npm ERR!
      npm ERR! The operation was rejected by your operating system.
      npm ERR! It is likely you do not have the permissions to access this file as the current user
      npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check the
      npm ERR! permissions of the file and its containing directories, or try running
      npm ERR! the command again as root/Administrator (though this is not recommended).
      npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-02-23T11_31_13_888Z-debug.log
      ERROR: host.iobroker Cannot install iobroker.harmony@1.2.1: 243
      Wie bekomme ich das hingebogen? Offenbar ein Benutzerrechteproblem? Ich will lieber hier fragen bevor ich irgendwelchen Mist baue und gar nichts mhr läuft.
      UPDATE: In der Konsole mit "Su" gehts. Wie bekomme ich es hin dass es wieder über die WEBGUI geht?
      • M miwe
        Moin,
        NPM version: 6.4.1
        npm
        npm
        npm
         ERR! syscall access
        npm ERR!
        npm ERR!
        HomoranH Offline
        HomoranH Offline
        #83
        @miwe
        Wann und wie hast du IoBroker installiert.
        Ggf. Bist du ein Kandidat für den Fixer
          @miwe
          miwe
          #84
          @Homoran
          Moin!
          IOBROKER läuft hier auf Proxmox. Wie ich es installiert habe kann ich Dir nicht mehr sagen :) Ich habe irgendne Anleitung im Internet bemüht.
          Installiert vor 2 bis 3 Monaten?
          Wie gesagt - in der Konsole unter "su" gehts - aus der GUI nicht. Ich tippe auf ein Benutzerrechteproblem.
          D HomoranH 2 Antworten Letzte Antwort
          • M miwe
            @Homoran
            Moin!
            danw
            #85
            @miwe Ist es. Einfach mal löschen und neu installieren.
            It's not a Bug, it's a Feature
            • SRo769S SRo769
              @Master77
              ja, im Ordner /opt/iobroker/node_modules/ den Ordner harmony... einfach löschen und dann im iobroker die V1.2.1 installieren.
              Grüße SRo769
              Master77
              #86
              @SRo769 sagte in Und wieder einmal Harmony... Firmware 4.15.250...:
              @Master77
              Grüße SRo769
              Hat einwandfrei funktioniert. Vielen Dank für die Hilfe.
              Und vielen Dank für das schnelle Update. 👍
              Gruß Markus
              • M miwe
                @Homoran
                Moin!
                HomoranH Offline
                HomoranH Offline
                #87
                @miwe sagte in Und wieder einmal Harmony... Firmware 4.15.250...:
                Wenn du Anfang januar über den Installer (curl....) installiert hast, solltest du auf jeden Fall mal den Fixer testen.
                  miwe
                  #88
                  @Homoran said in Und wieder einmal Harmony... Firmware 4.15.250...:
                  Ich krieg hier ne Macke. Ich wollte gerade den Fixer testen. Problem: Der will dass ich IOBROKER stoppe. Gebe ich ein IOBROKER stop sagt der mir das dieser nicht läuft. Dieser läuft aber definitiv. Gebe ich Iobroker status ein steht da: running. Hä?
                  • M miwe
                    HomoranH Offline
                    HomoranH Offline
                    #89
                    @miwe
                    Das fixt der Fixer ;-)
                    sudo systemctl stop iobroker
                      @miwe
                      miwe
                      #90
                      @Homoran Danke :)
                      • K Offline
                        kaiserm
                        schrieb am zuletzt editiert von kaiserm
                        #91
                        Auf der Webadmin Oberfläche sehe ich zum Update nur die 1.1.5
                        Wie bekommt man die 1.2.1?
                        Irgendwas mit Github?!
                        Was muss man da machen damit ich von der derzeitigen 1.0.0 auf die 1.2.1 komme?
                        Danke im Voraus
                        SRo769S 1 Antwort Letzte Antwort
                        • K kaiserm
                          Danke im Voraus
                          SRo769S Offline
                          SRo769S Offline
                          SRo769
                          #92
                          @kaiserm
                          Hi, über den Werkzeugschlüssel oben "Verwahrort" auf latest stellen - dann sollte die V1.2.1 sofort zum Update angezeigt werden. Nach dem Update kannst du ja den Verwahrort wieder auf default stellen.
                          • ? Offline
                            #93
                            ...oder direkt vom Github installieren.!
                            [Bild Text]8e7abae8-4466-4a03-88e2-4cb292261614-grafik.png (Bild Link)
                            • foxriver76F Offline
                              foxriver76F Offline
                              foxriver76
                              #94
                              Die Depdendency ist gefixt und wenn man 1.0.0 neu installiert, sollte man XMPP nutzen können ohne weiteres zu tun und für die Websocket-User bitte 1.2.1 (meine Empfehlung, auch wenn es da noch ein kleines Problem zu beheben gibt, da derzeit der Hub nicht als geblockt markiert wird während eine Aktivität gestartet wird).
                              Videotutorials & mehr
                                Master77
                                schrieb am zuletzt editiert von Master77
                                #95
                                Hallo zusammen.
                                Ich habe da ein kleines Problem.
                                Ich hatte ja auch das Downgrade gemacht und XMPP aktiviert. Nun habe ich das Update gemacht und benötige das XMPP nicht mehr. Leider bekomme ich XMPP nicht mehr über die App deaktiviert. Ich bekomme immer folgende Meldung:
                                Der Hub funktioniert einwandfrei und im Log stehen auch keine fehler.
                                Bekommt man XMPP auch ohne die App deaktiviert. Habe schon alles mögliche probiert.
                                Danke im voraus für die Hilfe.
                                Gruß Markus
                                • ? Offline
                                  #96
                                  Ich hatte damit keine Probleme....das liegt aber eher an Logitech und nicht am Adapter...
                                    Master77
                                    #97
                                    @Menne sagte in Und wieder einmal Harmony... Firmware 4.15.250...:
                                    Das weiß ich auch das es nicht am Adapter liegt. Hatte nur gehofft das mir da einer weiter helfen kann auch wenn es eigentlich OT ist.
                                    Gruß Markus
                                    • Samson71S Offline
                                      Samson71S Offline
                                      Samson71
                                      #98
                                      Hatte auch Probleme mit der App. Sprang irgendwie immer wieder zurück und machte einfach nicht weiter. Sync, Hub neu starten und die App komplett neu installieren brachten dann irgendwie den Erfolg.
                                      Markus
                                      Bitte beachten:
                                      • Samson71S Samson71
                                        Master77
                                        #99
                                        @Samson71 sagte in Und wieder einmal Harmony... Firmware 4.15.250...:
                                        ....die App komplett neu installieren brachten dann irgendwie den Erfolg.
                                        Das war's.... Danke für den Tipp.
                                        Gruß Markus
                                        • ? Offline
                                          #100
                                          @Master77...und was war an meiner Aussage jetzt falsch?
                                          Das wäre mein nächster Schritt,wenn es bei mir nicht funktioniert hätte, gewesen.
                                          Ohne zu fragen....
