  4. Und wieder einmal Harmony... Firmware 4.15.250...
101 Beiträge 29 Kommentatoren 17.3k Aufrufe 30 Beobachtet
  • M miwe
    Moin,
    ich kann das UPDATE leider nicht installieren.
    $ ./iobroker upgrade harmony
    Update harmony from @1.0.0 to @1.2.1
    NPM version: 6.4.1
    npm install iobroker.harmony@1.2.1 --production --save --prefix "/opt/iobroker" (System call)
    npm
     WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.harmony
    npm
    WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none is installed. You must install peer dependencies yourself.
    npm
    ERR! path /opt/iobroker/node_modules/iobroker.harmonynpm ERR! code EACCES
    npm ERR! errno -13npm
     ERR! syscall access
    npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.harmony'npm ERR!  { Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.harmony'
    npm ERR!   stack: 'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/iobroker.harmony\'',
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'access',
    npm ERR!   path: '/opt/iobroker/node_modules/iobroker.harmony' }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator (though this is not recommended).
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-02-23T11_31_13_888Z-debug.log
    ERROR: host.iobroker Cannot install iobroker.harmony@1.2.1: 243
    Wie bekomme ich das hingebogen? Offenbar ein Benutzerrechteproblem? Ich will lieber hier fragen bevor ich irgendwelchen Mist baue und gar nichts mhr läuft.
    UPDATE: In der Konsole mit "Su" gehts. Wie bekomme ich es hin dass es wieder über die WEBGUI geht?
    #83
    @miwe
    Wann und wie hast du IoBroker installiert.
    Ggf. Bist du ein Kandidat für den Fixer
      @miwe
      miwe
      #84
      @Homoran
      Moin!
      IOBROKER läuft hier auf Proxmox. Wie ich es installiert habe kann ich Dir nicht mehr sagen :) Ich habe irgendne Anleitung im Internet bemüht.
      Installiert vor 2 bis 3 Monaten?
      Wie gesagt - in der Konsole unter "su" gehts - aus der GUI nicht. Ich tippe auf ein Benutzerrechteproblem.
      D HomoranH 2 Antworten Letzte Antwort
      • M miwe
        @Homoran
        Moin!
        danw
        #85
        @miwe Ist es. Einfach mal löschen und neu installieren.
        It's not a Bug, it's a Feature
        • SRo769S SRo769
          @Master77
          ja, im Ordner /opt/iobroker/node_modules/ den Ordner harmony... einfach löschen und dann im iobroker die V1.2.1 installieren.
          Grüße SRo769
          Master77
          #86
          @SRo769 sagte in Und wieder einmal Harmony... Firmware 4.15.250...:
          @Master77
          Grüße SRo769
          Hat einwandfrei funktioniert. Vielen Dank für die Hilfe.
          Und vielen Dank für das schnelle Update. 👍
          Gruß Markus
          • M miwe
            @Homoran
            Moin!
            #87
            @miwe sagte in Und wieder einmal Harmony... Firmware 4.15.250...:
            Wenn du Anfang januar über den Installer (curl....) installiert hast, solltest du auf jeden Fall mal den Fixer testen.
              miwe
              #88
              @Homoran said in Und wieder einmal Harmony... Firmware 4.15.250...:
              Ich krieg hier ne Macke. Ich wollte gerade den Fixer testen. Problem: Der will dass ich IOBROKER stoppe. Gebe ich ein IOBROKER stop sagt der mir das dieser nicht läuft. Dieser läuft aber definitiv. Gebe ich Iobroker status ein steht da: running. Hä?
              • M miwe
                #89
                @miwe
                Das fixt der Fixer ;-)
                sudo systemctl stop iobroker
                  @miwe
                  miwe
                  #90
                  @Homoran Danke :)
                    kaiserm
                    schrieb am zuletzt editiert von kaiserm
                    #91
                    Auf der Webadmin Oberfläche sehe ich zum Update nur die 1.1.5
                    Wie bekommt man die 1.2.1?
                    Irgendwas mit Github?!
                    Was muss man da machen damit ich von der derzeitigen 1.0.0 auf die 1.2.1 komme?
                    Danke im Voraus
                    SRo769S 1 Antwort Letzte Antwort
                    • K kaiserm
                      Danke im Voraus
                      SRo769S Offline
                      SRo769S Offline
                      SRo769
                      #92
                      @kaiserm
                      Hi, über den Werkzeugschlüssel oben "Verwahrort" auf latest stellen - dann sollte die V1.2.1 sofort zum Update angezeigt werden. Nach dem Update kannst du ja den Verwahrort wieder auf default stellen.
                      • ? Offline
                        #93
                        ...oder direkt vom Github installieren.!
                        [Bild Text]8e7abae8-4466-4a03-88e2-4cb292261614-grafik.png (Bild Link)
                        • foxriver76F Offline
                          foxriver76F Offline
                          foxriver76
                          #94
                          Die Depdendency ist gefixt und wenn man 1.0.0 neu installiert, sollte man XMPP nutzen können ohne weiteres zu tun und für die Websocket-User bitte 1.2.1 (meine Empfehlung, auch wenn es da noch ein kleines Problem zu beheben gibt, da derzeit der Hub nicht als geblockt markiert wird während eine Aktivität gestartet wird).
                          Videotutorials & mehr
                            Master77
                            schrieb am zuletzt editiert von Master77
                            #95
                            Hallo zusammen.
                            Ich habe da ein kleines Problem.
                            Ich hatte ja auch das Downgrade gemacht und XMPP aktiviert. Nun habe ich das Update gemacht und benötige das XMPP nicht mehr. Leider bekomme ich XMPP nicht mehr über die App deaktiviert. Ich bekomme immer folgende Meldung:
                            Der Hub funktioniert einwandfrei und im Log stehen auch keine fehler.
                            Bekommt man XMPP auch ohne die App deaktiviert. Habe schon alles mögliche probiert.
                            Danke im voraus für die Hilfe.
                            Gruß Markus
                            • ? Offline
                              #96
                              Ich hatte damit keine Probleme....das liegt aber eher an Logitech und nicht am Adapter...
                                Master77
                                #97
                                @Menne sagte in Und wieder einmal Harmony... Firmware 4.15.250...:
                                Das weiß ich auch das es nicht am Adapter liegt. Hatte nur gehofft das mir da einer weiter helfen kann auch wenn es eigentlich OT ist.
                                Gruß Markus
                                • Samson71S Offline
                                  Samson71S Offline
                                  Samson71
                                  #98
                                  Hatte auch Probleme mit der App. Sprang irgendwie immer wieder zurück und machte einfach nicht weiter. Sync, Hub neu starten und die App komplett neu installieren brachten dann irgendwie den Erfolg.
                                  Markus
                                  Bitte beachten:
                                  • Samson71S Samson71
                                    Master77
                                    #99
                                    @Samson71 sagte in Und wieder einmal Harmony... Firmware 4.15.250...:
                                    ....die App komplett neu installieren brachten dann irgendwie den Erfolg.
                                    Das war's.... Danke für den Tipp.
                                    Gruß Markus
                                    • ? Offline
                                      #100
                                      @Master77...und was war an meiner Aussage jetzt falsch?
                                      Das wäre mein nächster Schritt,wenn es bei mir nicht funktioniert hätte, gewesen.
                                      Ohne zu fragen....
                                        Ohne zu fragen....
                                        Master77
                                        #101
                                        Ohne zu fragen....
                                        Habe ja auch nicht gesagt das an deiner Antwort was falsch ist.
                                        Hatte nur geschrieben das mir klar ist das es nicht am Adapter liegt.
                                        Gruß Markus
